inxi -Fxz
System: Kernel: 5.10.7-3-MANJARO x86_64 bits: 64 compiler: gcc v: 10.2.1 Desktop: KDE Plasma 5.20.5 Distro: Manjaro Linux
Machine: Type: Desktop Mobo: Micro-Star model: Z390-A PRO (MS-7B98) v: 1.0 serial: <filter> UEFI: American Megatrends
v: 1.80 date: 12/25/2019
CPU: Info: 6-Core model: Intel Core i5-9600K bits: 64 type: MCP arch: Kaby Lake note: check rev: C L2 cache: 9 MiB
flags: avx avx2 lm nx pae sse sse2 sse3 sse4_1 sse4_2 ssse3 vmx bogomips: 44412
Speed: 800 MHz min/max: 800/4700 MHz Core speeds (MHz): 1: 800 2: 800 3: 800 4: 800 5: 800 6: 800
Graphics: Device-1: NVIDIA TU106 [GeForce RTX 2070] driver: nvidia v: 460.32.03 bus ID: 01:00.0
Display: x11 server: X.Org 1.20.10 driver: loaded: nvidia resolution: 1920x1080
OpenGL: renderer: GeForce RTX 2070/PCIe/SSE2 v: 4.6.0 NVIDIA 460.32.03 direct render: Yes
Audio: Device-1: Intel Cannon Lake PCH cAVS vendor: Micro-Star MSI driver: snd_hda_intel v: kernel bus ID: 00:1f.3
Device-2: NVIDIA TU106 High Definition Audio driver: snd_hda_intel v: kernel bus ID: 01:00.1
Device-3: Logitech Logitech Webcam C925e type: USB driver: snd-usb-audio,uvcvideo bus ID: 1-1.1:4
Sound Server: ALSA v: k5.10.7-3-MANJARO
Network: Device-1: Intel Ethernet I219-V vendor: Micro-Star MSI driver: e1000e v: kernel port: efa0 bus ID: 00:1f.6
IF-ID-1: br-232fd21ea23b state: down mac: <filter>
IF-ID-2: br-5d01cbb2628b state: down mac: <filter>
IF-ID-3: docker0 state: down mac: <filter>
Drives: Local Storage: total: 912.89 GiB used: 143.57 GiB (15.7%)
ID-1: /dev/sda vendor: Samsung model: SSD 840 EVO 500GB size: 465.76 GiB
ID-2: /dev/sdb vendor: Kingston model: SA400S37480G size: 447.13 GiB
Partition: ID-1: / size: 183.4 GiB used: 143.54 GiB (78.3%) fs: ext4 dev: /dev/sdb1
ID-2: /boot/efi size: 96 MiB used: 35 MiB (36.5%) fs: vfat dev: /dev/sda2
Swap: ID-1: swap-1 type: file size: 4 GiB used: 0 KiB (0.0%) file: /swapfile
Sensors: System Temperatures: cpu: 41.0 C mobo: N/A gpu: nvidia temp: 38 C
Fan Speeds (RPM): N/A gpu: nvidia fan: 45%
Info: Processes: 234 Uptime: 6m Memory: 15.57 GiB used: 3.46 GiB (22.2%) Init: systemd Compilers: gcc: 10.2.0
Packages: 1629 Shell: Bash v: 5.1.0 inxi: 3.2.02
I was using the machine system froze and restarted, tried to find some relevant logs with no luck. I see some KDE and baloo core dumps but nothing to explain a hard reset like I experienced. Sound and screen froze, display went black and the system rebooted.
