I can’t sign into my laptop. I was trying to update the packages for my system prior to this but it froze and after I reset my laptop I got those two messages.
See if this helps
You might need to (re)install the kernel or another kernel, but let’s start simple.
This is what I get when I run the commands in those instructions
sudo su - 1 ✘
[manjaro ~]# chroot -a
chroot: invalid option -- 'a'
Try 'chroot --help' for more information.
[manjaro ~]# manjaro-chroot -a
grub-probe: error: cannot find a GRUB drive for /dev/sdb1. Check your device.map.
==> Mounting (ManjaroLinux) [/dev/nvme0n1p2]
--> mount: [/mnt]
--> mount: [/mnt/boot/efi]
[manjaro /]# [ -f /var/lib/pacman/db.lck ] && rm -f /var/lib/pacman/db.lck
[manjaro /]# pacman-mirrors -f
::WARNING https://repo.manjaro.org 'Connection: HTTPSConnectionPool(host='repo.manjaro.org', port=443): Max retries exceeded with url: / (Caused by NewConnectionError('<urllib3.connection.HTTPSConnection object at 0x7fe46838a2d0>: Failed to establish a new connection: [Errno -3] Temporary failure in name resolution'))'
::WARNING https://wikipedia.org 'Connection: HTTPSConnectionPool(host='wikipedia.org', port=443): Max retries exceeded with url: / (Caused by NewConnectionError('<urllib3.connection.HTTPSConnection object at 0x7fe46838ad10>: Failed to establish a new connection: [Errno -3] Temporary failure in name resolution'))'
::WARNING https://bitbucket.org 'Connection: HTTPSConnectionPool(host='bitbucket.org', port=443): Max retries exceeded with url: / (Caused by NewConnectionError('<urllib3.connection.HTTPSConnection object at 0x7fe46838b410>: Failed to establish a new connection: [Errno -3] Temporary failure in name resolution'))'
::INFO Internet connection appears to be down
::INFO Mirror ranking is not available
::INFO Mirror list is generated using random method
::INFO Writing mirror list
::United_States : https://southfront.mm.fcix.net/manjaro/stable
::Georgia : https://repos.silknet.com/manjaro/stable
::China : https://mirrors.pku.edu.cn/manjaro/stable
::Germany : http://ftp.tu-chemnitz.de/pub/linux/manjaro/stable
::Brazil : https://manjaro.c3sl.ufpr.br/stable
::Colombia : https://edgeuno-bog2.mm.fcix.net/manjaro/stable
::Spain : https://mirrors.ft.uam.es/manjaro/stable
::China : https://mirrors.sjtug.sjtu.edu.cn/manjaro/stable
::Netherlands : https://ftp.nluug.nl/pub/os/Linux/distr/manjaro/stable
::Bangladesh : http://mirror.xeonbd.com/manjaro/stable
::Bangladesh : https://bd.mirror.vanehost.com/Manjaro/stable
::Ukraine : https://manjaro.astra.in.ua/stable
::United_Kingdom : https://mirrors.gethosted.online/manjaro/repos/stable
::Germany : https://mirror.23m.com/manjaro/stable
::United_States : https://forksystems.mm.fcix.net/manjaro/stable
::Sweden : https://mirror.zetup.net/manjaro/stable
::Czechia : https://mirrors.nic.cz/manjaro/stable
::Germany : https://ftp.gwdg.de/pub/linux/manjaro/stable
::Italy : https://ct.mirror.garr.it/mirrors/manjaro/stable
::Belarus : http://mirror.datacenter.by/pub/mirrors/manjaro/stable
::Netherlands : https://mirror.koddos.net/manjaro/stable
::Costa_Rica : https://mirrors.ucr.ac.cr/manjaro/stable
::United_States : https://mirrors.gigenet.com/manjaro/stable
::Finland : https://manjaro.kyberorg.fi/stable
::Austria : https://mirror.easyname.at/manjaro/stable
::Germany : https://mirror.netcologne.de/manjaro/stable
::France : http://ftp.free.org/mirrors/repo.manjaro.org/repos/stable
::Russia : https://mirror.truenetwork.ru/manjaro/stable
::Denmark : https://mirrors.dotsrc.org/manjaro/stable
::China : https://mirrors.tuna.tsinghua.edu.cn/manjaro/stable
::United_States : https://ziply.mm.fcix.net/manjaro/stable
::Chile : https://mirror.ufro.cl/manjaro/stable
::Brazil : https://linorg.usp.br/manjaro/stable
::Poland : https://ftp.psnc.pl/linux/manjaro/stable
::United_States : https://mirror.math.princeton.edu/pub/manjaro/stable
::Russia : https://mirror.kamtv.ru/manjaro/stable
::Chile : https://mirror1.cl.netactuate.com/manjaro/stable
::Poland : https://ftp.icm.edu.pl/pub/Linux/dist/manjaro/stable
::United_States : https://nnenix.mm.fcix.net/manjaro/stable
::New_Zealand : http://manjaro.mirrors.theom.nz/manjaro/stable
::Singapore : https://mirror.freedif.org/Manjaro/stable
::Sweden : https://ftpmirror1.infania.net/mirror/manjaro/stable
::Portugal : https://mirrors.up.pt/pub/manjaro/stable
::Hungary : https://quantum-mirror.hu/mirrors/pub/manjaro/stable
::United_States : https://codingflyboy.mm.fcix.net/manjaro/stable
::South_Korea : https://mirror.funami.tech/manjaro/stable
::New_Zealand : https://mirror.2degrees.nz/manjaro/stable
::Czechia : https://mirror.it4i.cz/manjaro/stable
::Sweden : https://ftp.lysator.liu.se/pub/manjaro/stable
::France : https://manjaro.ynh.ovh/stable
::Italy : https://ba.mirror.garr.it/mirrors/manjaro/stable
::United_States : https://opencolo.mm.fcix.net/manjaro/stable
::Austria : https://mirror.alwyzon.net/manjaro/stable
::Germany : https://ftp.halifax.rwth-aachen.de/manjaro/stable
::United_States : https://repo.ialab.dsu.edu/manjaro/stable
::United_States : https://ohioix.mm.fcix.net/manjaro/stable
::Czechia : https://mirror.dkm.cz/manjaro/stable
::Canada : https://mirror.xenyth.net/manjaro/stable
::Netherlands : https://manjaro.mirror.wearetriple.com/stable
::Netherlands : https://manjaro.mirrors.lavatech.top/stable
::Switzerland : https://mirror.init7.net/manjaro/stable
::United_States : https://ask4.mm.fcix.net/manjaro/stable
::South_Africa : http://mirror.is.co.za/mirrors/manjaro.org/stable
::Belgium : http://ftp.belnet.be/mirrors/manjaro/repos/stable
::Spain : https://ftp.caliu.cat/pub/distribucions/manjaro/stable
::United_Kingdom : https://www.mirrorservice.org/sites/repo.manjaro.org/repos/stable
::Belgium : https://mirror.futureweb.be/manjaro/stable
::Georgia : http://manjaro.grena.ge/stable
::Brazil : https://mirror.ufam.edu.br/manjaro/stable
::United_States : https://coresite.mm.fcix.net/manjaro/stable
::Russia : https://mirror.yandex.ru/mirrors/manjaro/stable
::United_States : https://nocix.mm.fcix.net/manjaro/stable
::Ukraine : https://fastmirror.pp.ua/manjaro/stable
::Japan : http://ftp.riken.jp/Linux/manjaro/stable
::Turkey : https://ftp.linux.org.tr/manjaro/stable
::China : https://mirror.nyist.edu.cn/manjaro/stable
::United_States : https://mnvoip.mm.fcix.net/manjaro/stable
::Uruguay : https://manjaro.repo.cure.edu.uy/stable
::Armenia : http://manjaro.ucom.am/stable
::Bulgaria : https://manjaro.ipacct.com/manjaro/stable
::Taiwan : http://free.nchc.org.tw/manjaro/stable
::Australia : https://gsl-syd.mm.fcix.net/manjaro/stable
::Japan : http://ftp.tsukuba.wide.ad.jp/Linux/manjaro/stable
::United_States : https://irltoolkit.mm.fcix.net/manjaro/stable
::United_States : http://mirror.fcix.net/manjaro/stable
::Canada : https://mirror.csclub.uwaterloo.ca/manjaro/stable
::Canada : https://muug.ca/mirror/manjaro/stable
::United_Kingdom : http://manjaro.mirrors.uk2.net/stable
::Mauritius : https://manjarolinux-mirror.cloud.mu/stable
::Italy : https://manjaro.mirror.garr.it/manjaro/stable
::Taiwan : https://mirror.archlinux.tw/Manjaro/stable
::United_States : https://mirrors.ocf.berkeley.edu/manjaro/stable
::United_States : https://volico.mm.fcix.net/manjaro/stable
::Uzbekistan : https://mirror.dc.uz/manjaro/stable
::Bulgaria : https://mirror.telepoint.bg/manjaro/stable
::Netherlands : http://ftp.snt.utwente.nl/pub/linux/manjaro/stable
::Germany : https://mirror.alpix.eu/manjaro/stable
::United_States : https://uvermont.mm.fcix.net/manjaro/stable
::Global : https://mirrors.manjaro.org/repo/stable
::France : https://mirror.ibakerserver.pt/manjaro/stable
::Bulgaria : https://mirrors.netix.net/manjaro/stable
::United_States : https://ridgewireless.mm.fcix.net/manjaro/stable
::Thailand : https://mirror.kku.ac.th/manjaro/stable
::United_States : https://mirrors.sonic.net/manjaro/stable
::Greece : https://fosszone.csd.auth.gr/manjaro/stable
::Indonesia : http://kartolo.sby.datautama.net.id/manjaro/stable
::China : https://mirrors.jlu.edu.cn/manjaro/stable
::INFO Mirror list generated and saved to: /etc/pacman.d/mirrorlist
pacman -Syyu
core.db failed to download
error: failed retrieving file 'core.db' from southfront.mm.fcix.net : Could not resolve host: southfront.mm.fcix.net
warning: too many errors from southfront.mm.fcix.net, skipping for the remainder of this transaction
error: failed retrieving file 'core.db' from repos.silknet.com : Could not resolve host: repos.silknet.com
warning: too many errors from repos.silknet.com, skipping for the remainder of this transaction
error: failed retrieving file 'core.db' from mirrors.pku.edu.cn : Could not resolve host: mirrors.pku.edu.cn
warning: too many errors from mirrors.pku.edu.cn, skipping for the remainder of this transaction
error: failed retrieving file 'core.db' from ftp.tu-chemnitz.de : Could not resolve host: ftp.tu-chemnitz.de
warning: too many errors from ftp.tu-chemnitz.de, skipping for the remainder of this transaction
error: failed retrieving file 'core.db' from manjaro.c3sl.ufpr.br : Could not resolve host: manjaro.c3sl.ufpr.br
warning: too many errors from manjaro.c3sl.ufpr.br, skipping for the remainder of this transaction
error: failed retrieving file 'core.db' from edgeuno-bog2.mm.fcix.net : Could not resolve host: edgeuno-bog2.mm.fcix.net
warning: too many errors from edgeuno-bog2.mm.fcix.net, skipping for the remainder of this transaction
error: failed retrieving file 'core.db' from mirrors.ft.uam.es : Could not resolve host: mirrors.ft.uam.es
warning: too many errors from mirrors.ft.uam.es, skipping for the remainder of this transaction
error: failed retrieving file 'core.db' from mirrors.sjtug.sjtu.edu.cn : Could not resolve host: mirrors.sjtug.sjtu.edu.cn
warning: too many errors from mirrors.sjtug.sjtu.edu.cn, skipping for the remainder of this transaction
error: failed retrieving file 'core.db' from ftp.nluug.nl : Could not resolve host: ftp.nluug.nl
warning: too many errors from ftp.nluug.nl, skipping for the remainder of this transaction
error: failed retrieving file 'core.db' from mirror.xeonbd.com : Could not resolve host: mirror.xeonbd.com
warning: too many errors from mirror.xeonbd.com, skipping for the remainder of this transaction
error: failed retrieving file 'core.db' from bd.mirror.vanehost.com : Could not resolve host: bd.mirror.vanehost.com
warning: too many errors from bd.mirror.vanehost.com, skipping for the remainder of this transaction
error: failed retrieving file 'core.db' from manjaro.astra.in.ua : Could not resolve host: manjaro.astra.in.ua
warning: too many errors from manjaro.astra.in.ua, skipping for the remainder of this transaction
error: failed retrieving file 'core.db' from mirrors.gethosted.online : Could not resolve host: mirrors.gethosted.online
warning: too many errors from mirrors.gethosted.online, skipping for the remainder of this transaction
error: failed retrieving file 'core.db' from mirror.23m.com : Could not resolve host: mirror.23m.com
warning: too many errors from mirror.23m.com, skipping for the remainder of this transaction
error: failed retrieving file 'core.db' from forksystems.mm.fcix.net : Could not resolve host: forksystems.mm.fcix.net
warning: too many errors from forksystems.mm.fcix.net, skipping for the remainder of this transaction
error: failed retrieving file 'core.db' from mirror.zetup.net : Could not resolve host: mirror.zetup.net
warning: too many errors from mirror.zetup.net, skipping for the remainder of this transaction
error: failed retrieving file 'core.db' from mirrors.nic.cz : Could not resolve host: mirrors.nic.cz
warning: too many errors from mirrors.nic.cz, skipping for the remainder of this transaction
error: failed retrieving file 'core.db' from ftp.gwdg.de : Could not resolve host: ftp.gwdg.de
warning: too many errors from ftp.gwdg.de, skipping for the remainder of this transaction
error: failed retrieving file 'core.db' from ct.mirror.garr.it : Could not resolve host: ct.mirror.garr.it
warning: too many errors from ct.mirror.garr.it, skipping for the remainder of this transaction
error: failed retrieving file 'core.db' from mirror.datacenter.by : Could not resolve host: mirror.datacenter.by
warning: too many errors from mirror.datacenter.by, skipping for the remainder of this transaction
error: failed retrieving file 'core.db' from mirror.koddos.net : Could not resolve host: mirror.koddos.net
warning: too many errors from mirror.koddos.net, skipping for the remainder of this transaction
error: failed retrieving file 'core.db' from mirrors.ucr.ac.cr : Could not resolve host: mirrors.ucr.ac.cr
warning: too many errors from mirrors.ucr.ac.cr, skipping for the remainder of this transaction
error: failed retrieving file 'core.db' from mirrors.gigenet.com : Could not resolve host: mirrors.gigenet.com
warning: too many errors from mirrors.gigenet.com, skipping for the remainder of this transaction
error: failed retrieving file 'core.db' from manjaro.kyberorg.fi : Could not resolve host: manjaro.kyberorg.fi
warning: too many errors from manjaro.kyberorg.fi, skipping for the remainder of this transaction
error: failed retrieving file 'core.db' from mirror.easyname.at : Could not resolve host: mirror.easyname.at
warning: too many errors from mirror.easyname.at, skipping for the remainder of this transaction
error: failed retrieving file 'core.db' from mirror.netcologne.de : Could not resolve host: mirror.netcologne.de
warning: too many errors from mirror.netcologne.de, skipping for the remainder of this transaction
error: failed retrieving file 'core.db' from ftp.free.org : Could not resolve host: ftp.free.org
warning: too many errors from ftp.free.org, skipping for the remainder of this transaction
error: failed retrieving file 'core.db' from mirror.truenetwork.ru : Could not resolve host: mirror.truenetwork.ru
warning: too many errors from mirror.truenetwork.ru, skipping for the remainder of this transaction
error: failed retrieving file 'core.db' from mirrors.dotsrc.org : Could not resolve host: mirrors.dotsrc.org
warning: too many errors from mirrors.dotsrc.org, skipping for the remainder of this transaction
error: failed retrieving file 'core.db' from mirrors.tuna.tsinghua.edu.cn : Could not resolve host: mirrors.tuna.tsinghua.edu.cn
warning: too many errors from mirrors.tuna.tsinghua.edu.cn, skipping for the remainder of this transaction
error: failed retrieving file 'core.db' from ziply.mm.fcix.net : Could not resolve host: ziply.mm.fcix.net
warning: too many errors from ziply.mm.fcix.net, skipping for the remainder of this transaction
error: failed retrieving file 'core.db' from mirror.ufro.cl : Could not resolve host: mirror.ufro.cl
warning: too many errors from mirror.ufro.cl, skipping for the remainder of this transaction
error: failed retrieving file 'core.db' from linorg.usp.br : Could not resolve host: linorg.usp.br
warning: too many errors from linorg.usp.br, skipping for the remainder of this transaction
error: failed retrieving file 'core.db' from ftp.psnc.pl : Could not resolve host: ftp.psnc.pl
warning: too many errors from ftp.psnc.pl, skipping for the remainder of this transaction
error: failed retrieving file 'core.db' from mirror.math.princeton.edu : Could not resolve host: mirror.math.princeton.edu
warning: too many errors from mirror.math.princeton.edu, skipping for the remainder of this transaction
error: failed retrieving file 'core.db' from mirror.kamtv.ru : Could not resolve host: mirror.kamtv.ru
warning: too many errors from mirror.kamtv.ru, skipping for the remainder of this transaction
error: failed retrieving file 'core.db' from mirror1.cl.netactuate.com : Could not resolve host: mirror1.cl.netactuate.com
warning: too many errors from mirror1.cl.netactuate.com, skipping for the remainder of this transaction
error: failed retrieving file 'core.db' from ftp.icm.edu.pl : Could not resolve host: ftp.icm.edu.pl
warning: too many errors from ftp.icm.edu.pl, skipping for the remainder of this transaction
error: failed retrieving file 'core.db' from nnenix.mm.fcix.net : Could not resolve host: nnenix.mm.fcix.net
warning: too many errors from nnenix.mm.fcix.net, skipping for the remainder of this transaction
error: failed retrieving file 'core.db' from manjaro.mirrors.theom.nz : Could not resolve host: manjaro.mirrors.theom.nz
warning: too many errors from manjaro.mirrors.theom.nz, skipping for the remainder of this transaction
error: failed retrieving file 'core.db' from mirror.freedif.org : Could not resolve host: mirror.freedif.org
warning: too many errors from mirror.freedif.org, skipping for the remainder of this transaction
error: failed retrieving file 'core.db' from ftpmirror1.infania.net : Could not resolve host: ftpmirror1.infania.net
warning: too many errors from ftpmirror1.infania.net, skipping for the remainder of this transaction
error: failed retrieving file 'core.db' from mirrors.up.pt : Could not resolve host: mirrors.up.pt
warning: too many errors from mirrors.up.pt, skipping for the remainder of this transaction
error: failed retrieving file 'core.db' from quantum-mirror.hu : Could not resolve host: quantum-mirror.hu
warning: too many errors from quantum-mirror.hu, skipping for the remainder of this transaction
error: failed retrieving file 'core.db' from codingflyboy.mm.fcix.net : Could not resolve host: codingflyboy.mm.fcix.net
warning: too many errors from codingflyboy.mm.fcix.net, skipping for the remainder of this transaction
error: failed retrieving file 'core.db' from mirror.funami.tech : Could not resolve host: mirror.funami.tech
warning: too many errors from mirror.funami.tech, skipping for the remainder of this transaction
error: failed retrieving file 'core.db' from mirror.2degrees.nz : Could not resolve host: mirror.2degrees.nz
warning: too many errors from mirror.2degrees.nz, skipping for the remainder of this transaction
error: failed retrieving file 'core.db' from mirror.it4i.cz : Could not resolve host: mirror.it4i.cz
warning: too many errors from mirror.it4i.cz, skipping for the remainder of this transaction
error: failed retrieving file 'core.db' from ftp.lysator.liu.se : Could not resolve host: ftp.lysator.liu.se
warning: too many errors from ftp.lysator.liu.se, skipping for the remainder of this transaction
error: failed retrieving file 'core.db' from manjaro.ynh.ovh : Could not resolve host: manjaro.ynh.ovh
warning: too many errors from manjaro.ynh.ovh, skipping for the remainder of this transaction
error: failed retrieving file 'core.db' from ba.mirror.garr.it : Could not resolve host: ba.mirror.garr.it
warning: too many errors from ba.mirror.garr.it, skipping for the remainder of this transaction
error: failed retrieving file 'core.db' from opencolo.mm.fcix.net : Could not resolve host: opencolo.mm.fcix.net
warning: too many errors from opencolo.mm.fcix.net, skipping for the remainder of this transaction
error: failed retrieving file 'core.db' from mirror.alwyzon.net : Could not resolve host: mirror.alwyzon.net
warning: too many errors from mirror.alwyzon.net, skipping for the remainder of this transaction
error: failed retrieving file 'core.db' from ftp.halifax.rwth-aachen.de : Could not resolve host: ftp.halifax.rwth-aachen.de
warning: too many errors from ftp.halifax.rwth-aachen.de, skipping for the remainder of this transaction
error: failed retrieving file 'core.db' from repo.ialab.dsu.edu : Could not resolve host: repo.ialab.dsu.edu
warning: too many errors from repo.ialab.dsu.edu, skipping for the remainder of this transaction
error: failed retrieving file 'core.db' from ohioix.mm.fcix.net : Could not resolve host: ohioix.mm.fcix.net
warning: too many errors from ohioix.mm.fcix.net, skipping for the remainder of this transaction
error: failed retrieving file 'core.db' from mirror.dkm.cz : Could not resolve host: mirror.dkm.cz
warning: too many errors from mirror.dkm.cz, skipping for the remainder of this transaction
error: failed retrieving file 'core.db' from mirror.xenyth.net : Could not resolve host: mirror.xenyth.net
warning: too many errors from mirror.xenyth.net, skipping for the remainder of this transaction
error: failed retrieving file 'core.db' from manjaro.mirror.wearetriple.com : Could not resolve host: manjaro.mirror.wearetriple.com
warning: too many errors from manjaro.mirror.wearetriple.com, skipping for the remainder of this transaction
error: failed retrieving file 'core.db' from manjaro.mirrors.lavatech.top : Could not resolve host: manjaro.mirrors.lavatech.top
warning: too many errors from manjaro.mirrors.lavatech.top, skipping for the remainder of this transaction
error: failed retrieving file 'core.db' from mirror.init7.net : Could not resolve host: mirror.init7.net
warning: too many errors from mirror.init7.net, skipping for the remainder of this transaction
error: failed retrieving file 'core.db' from ask4.mm.fcix.net : Could not resolve host: ask4.mm.fcix.net
warning: too many errors from ask4.mm.fcix.net, skipping for the remainder of this transaction
error: failed retrieving file 'core.db' from mirror.is.co.za : Could not resolve host: mirror.is.co.za
warning: too many errors from mirror.is.co.za, skipping for the remainder of this transaction
error: failed retrieving file 'core.db' from ftp.belnet.be : Could not resolve host: ftp.belnet.be
warning: too many errors from ftp.belnet.be, skipping for the remainder of this transaction
error: failed retrieving file 'core.db' from ftp.caliu.cat : Could not resolve host: ftp.caliu.cat
warning: too many errors from ftp.caliu.cat, skipping for the remainder of this transaction
error: failed retrieving file 'core.db' from www.mirrorservice.org : Could not resolve host: www.mirrorservice.org
warning: too many errors from www.mirrorservice.org, skipping for the remainder of this transaction
error: failed retrieving file 'core.db' from mirror.futureweb.be : Could not resolve host: mirror.futureweb.be
warning: too many errors from mirror.futureweb.be, skipping for the remainder of this transaction
error: failed retrieving file 'core.db' from manjaro.grena.ge : Could not resolve host: manjaro.grena.ge
warning: too many errors from manjaro.grena.ge, skipping for the remainder of this transaction
error: failed retrieving file 'core.db' from mirror.ufam.edu.br : Could not resolve host: mirror.ufam.edu.br
warning: too many errors from mirror.ufam.edu.br, skipping for the remainder of this transaction
error: failed retrieving file 'core.db' from coresite.mm.fcix.net : Could not resolve host: coresite.mm.fcix.net
warning: too many errors from coresite.mm.fcix.net, skipping for the remainder of this transaction
error: failed retrieving file 'core.db' from mirror.yandex.ru : Could not resolve host: mirror.yandex.ru
warning: too many errors from mirror.yandex.ru, skipping for the remainder of this transaction
error: failed retrieving file 'core.db' from nocix.mm.fcix.net : Could not resolve host: nocix.mm.fcix.net
warning: too many errors from nocix.mm.fcix.net, skipping for the remainder of this transaction
error: failed retrieving file 'core.db' from fastmirror.pp.ua : Could not resolve host: fastmirror.pp.ua
warning: too many errors from fastmirror.pp.ua, skipping for the remainder of this transaction
error: failed retrieving file 'core.db' from ftp.riken.jp : Could not resolve host: ftp.riken.jp
warning: too many errors from ftp.riken.jp, skipping for the remainder of this transaction
error: failed retrieving file 'core.db' from ftp.linux.org.tr : Could not resolve host: ftp.linux.org.tr
warning: too many errors from ftp.linux.org.tr, skipping for the remainder of this transaction
error: failed retrieving file 'core.db' from mirror.nyist.edu.cn : Could not resolve host: mirror.nyist.edu.cn
warning: too many errors from mirror.nyist.edu.cn, skipping for the remainder of this transaction
error: failed retrieving file 'core.db' from mnvoip.mm.fcix.net : Could not resolve host: mnvoip.mm.fcix.net
warning: too many errors from mnvoip.mm.fcix.net, skipping for the remainder of this transaction
error: failed retrieving file 'core.db' from manjaro.repo.cure.edu.uy : Could not resolve host: manjaro.repo.cure.edu.uy
warning: too many errors from manjaro.repo.cure.edu.uy, skipping for the remainder of this transaction
error: failed retrieving file 'core.db' from manjaro.ucom.am : Could not resolve host: manjaro.ucom.am
warning: too many errors from manjaro.ucom.am, skipping for the remainder of this transaction
error: failed retrieving file 'core.db' from manjaro.ipacct.com : Could not resolve host: manjaro.ipacct.com
warning: too many errors from manjaro.ipacct.com, skipping for the remainder of this transaction
error: failed retrieving file 'core.db' from free.nchc.org.tw : Could not resolve host: free.nchc.org.tw
warning: too many errors from free.nchc.org.tw, skipping for the remainder of this transaction
error: failed retrieving file 'core.db' from gsl-syd.mm.fcix.net : Could not resolve host: gsl-syd.mm.fcix.net
warning: too many errors from gsl-syd.mm.fcix.net, skipping for the remainder of this transaction
error: failed retrieving file 'core.db' from ftp.tsukuba.wide.ad.jp : Could not resolve host: ftp.tsukuba.wide.ad.jp
warning: too many errors from ftp.tsukuba.wide.ad.jp, skipping for the remainder of this transaction
error: failed retrieving file 'core.db' from irltoolkit.mm.fcix.net : Could not resolve host: irltoolkit.mm.fcix.net
warning: too many errors from irltoolkit.mm.fcix.net, skipping for the remainder of this transaction
error: failed retrieving file 'core.db' from mirror.fcix.net : Could not resolve host: mirror.fcix.net
warning: too many errors from mirror.fcix.net, skipping for the remainder of this transaction
error: failed retrieving file 'core.db' from mirror.csclub.uwaterloo.ca : Could not resolve host: mirror.csclub.uwaterloo.ca
warning: too many errors from mirror.csclub.uwaterloo.ca, skipping for the remainder of this transaction
error: failed retrieving file 'core.db' from muug.ca : Could not resolve host: muug.ca
warning: too many errors from muug.ca, skipping for the remainder of this transaction
error: failed retrieving file 'core.db' from manjaro.mirrors.uk2.net : Could not resolve host: manjaro.mirrors.uk2.net
warning: too many errors from manjaro.mirrors.uk2.net, skipping for the remainder of this transaction
error: failed retrieving file 'core.db' from manjarolinux-mirror.cloud.mu : Could not resolve host: manjarolinux-mirror.cloud.mu
warning: too many errors from manjarolinux-mirror.cloud.mu, skipping for the remainder of this transaction
error: failed retrieving file 'core.db' from manjaro.mirror.garr.it : Could not resolve host: manjaro.mirror.garr.it
warning: too many errors from manjaro.mirror.garr.it, skipping for the remainder of this transaction
error: failed retrieving file 'core.db' from mirror.archlinux.tw : Could not resolve host: mirror.archlinux.tw
warning: too many errors from mirror.archlinux.tw, skipping for the remainder of this transaction
error: failed retrieving file 'core.db' from mirrors.ocf.berkeley.edu : Could not resolve host: mirrors.ocf.berkeley.edu
warning: too many errors from mirrors.ocf.berkeley.edu, skipping for the remainder of this transaction
error: failed retrieving file 'core.db' from volico.mm.fcix.net : Could not resolve host: volico.mm.fcix.net
warning: too many errors from volico.mm.fcix.net, skipping for the remainder of this transaction
error: failed retrieving file 'core.db' from mirror.dc.uz : Could not resolve host: mirror.dc.uz
warning: too many errors from mirror.dc.uz, skipping for the remainder of this transaction
error: failed retrieving file 'core.db' from mirror.telepoint.bg : Could not resolve host: mirror.telepoint.bg
warning: too many errors from mirror.telepoint.bg, skipping for the remainder of this transaction
error: failed retrieving file 'core.db' from ftp.snt.utwente.nl : Could not resolve host: ftp.snt.utwente.nl
warning: too many errors from ftp.snt.utwente.nl, skipping for the remainder of this transaction
error: failed retrieving file 'core.db' from mirror.alpix.eu : Could not resolve host: mirror.alpix.eu
warning: too many errors from mirror.alpix.eu, skipping for the remainder of this transaction
error: failed retrieving file 'core.db' from uvermont.mm.fcix.net : Could not resolve host: uvermont.mm.fcix.net
warning: too many errors from uvermont.mm.fcix.net, skipping for the remainder of this transaction
error: failed retrieving file 'core.db' from mirrors.manjaro.org : Could not resolve host: mirrors.manjaro.org
warning: too many errors from mirrors.manjaro.org, skipping for the remainder of this transaction
error: failed retrieving file 'core.db' from mirror.ibakerserver.pt : Could not resolve host: mirror.ibakerserver.pt
warning: too many errors from mirror.ibakerserver.pt, skipping for the remainder of this transaction
error: failed retrieving file 'core.db' from mirrors.netix.net : Could not resolve host: mirrors.netix.net
warning: too many errors from mirrors.netix.net, skipping for the remainder of this transaction
error: failed retrieving file 'core.db' from ridgewireless.mm.fcix.net : Could not resolve host: ridgewireless.mm.fcix.net
warning: too many errors from ridgewireless.mm.fcix.net, skipping for the remainder of this transaction
error: failed retrieving file 'core.db' from mirror.kku.ac.th : Could not resolve host: mirror.kku.ac.th
warning: too many errors from mirror.kku.ac.th, skipping for the remainder of this transaction
error: failed retrieving file 'core.db' from mirrors.sonic.net : Could not resolve host: mirrors.sonic.net
warning: too many errors from mirrors.sonic.net, skipping for the remainder of this transaction
error: failed retrieving file 'core.db' from fosszone.csd.auth.gr : Could not resolve host: fosszone.csd.auth.gr
warning: too many errors from fosszone.csd.auth.gr, skipping for the remainder of this transaction
error: failed retrieving file 'core.db' from kartolo.sby.datautama.net.id : Could not resolve host: kartolo.sby.datautama.net.id
warning: too many errors from kartolo.sby.datautama.net.id, skipping for the remainder of this transaction
error: failed retrieving file 'core.db' from mirrors.jlu.edu.cn : Could not resolve host: mirrors.jlu.edu.cn
warning: too many errors from mirrors.jlu.edu.cn, skipping for the remainder of this transaction
error: failed to synchronize all databases (invalid url for server)
[manjaro /]# update-grub
/usr/bin/grub-probe: /usr/lib/libc.so.6: version `GLIBC_2.38' not found (required by /usr/lib/libdevmapper.so.1.02)
/usr/bin/grub-probe: /usr/lib/libc.so.6: version `GLIBC_2.38' not found (required by /usr/lib/libudev.so.1)
Are you connected to the internet ?
It looks like I wasn’t connected at the time. This is what I get now.
~ sudo su - INT ✘ 28m 23s
--> mount: [/mnt]
[manjaro /]# [ -f /var/lib/pacman/db.lck ] && -f /var/lib/pacman/db.lck
::INFO => Mirror status: https://repo.manjaro.org/status.json
::INFO Using default mirror file
::INFO Querying mirrors - This may take some time
0.594 United_States : https://ask4.mm.fcix.net/manjaro/
2.905 Kenya : https://manjaro.mirror.liquidtelecom.com/
0.654 France : https://mirror.ibakerserver.pt/manjaro/
0.350 United_States : https://mirrors.gigenet.com/manjaro/
0.377 United_States : https://repo.ialab.dsu.edu/manjaro/
0.215 United_States : https://nnenix.mm.fcix.net/manjaro/
1.048 United_Kingdom : https://mirrors.gethosted.online/manjaro/repos/
0.702 Netherlands : http://ftp.snt.utwente.nl/pub/linux/manjaro/
1.530 Germany : https://ftp.halifax.rwth-aachen.de/manjaro/
0.630 United_States : https://irltoolkit.mm.fcix.net/manjaro/
..... South_Africa : http://mirror.is.co.za/mirrors/manjaro.org/
2.482 Australia : https://mirror.aarnet.edu.au/pub/manjaro/
..... South_Africa : http://manjaro.mirror.ac.za/
0.553 United_States : https://opencolo.mm.fcix.net/manjaro/
0.953 Austria : https://mirror.easyname.at/manjaro/
1.630 Bulgaria : https://mirror.telepoint.bg/manjaro/
0.722 Netherlands : https://manjaro.mirrors.lavatech.top/
0.155 United_States : https://uvermont.mm.fcix.net/manjaro/
1.444 Ukraine : https://manjaro.astra.in.ua/
1.520 Germany : https://ftp.gwdg.de/pub/linux/manjaro/
0.704 United_States : https://mirrors.sonic.net/manjaro/
1.524 United_States : https://ridgewireless.mm.fcix.net/manjaro/
1.313 Japan : http://ftp.riken.jp/Linux/manjaro/
..... Bangladesh : https://bd.mirror.vanehost.com/Manjaro/
2.139 Taiwan : https://mirror.archlinux.tw/Manjaro/
1.728 Japan : http://ftp.tsukuba.wide.ad.jp/Linux/manjaro/
1.629 Georgia : https://repos.silknet.com/manjaro/
0.405 United_States : https://southfront.mm.fcix.net/manjaro/
2.533 Uruguay : https://manjaro.repo.cure.edu.uy/
1.300 Sweden : https://mirror.zetup.net/manjaro/
0.595 United_Kingdom : https://mirror.vinehost.net/manjaro/
2.551 Italy : https://ba.mirror.garr.it/mirrors/manjaro/
1.011 United_States : https://mirrors.ocf.berkeley.edu/manjaro/
0.669 Netherlands : https://manjaro.mirror.wearetriple.com/
..... China : https://mirrors.ustc.edu.cn/manjaro/
1.183 Norway : http://mirror.terrahost.no/linux/manjaro/
1.936 Taiwan : http://free.nchc.org.tw/manjaro/
1.529 New_Zealand : http://manjaro.mirrors.theom.nz/manjaro/
..... Bangladesh : http://mirror.xeonbd.com/manjaro/
::ERROR Connection: HTTPConnectionPool(host='mirror.xeonbd.com', port=80): Max retries exceeded with url: /manjaro/stable/core/x86_64/core.db.tar.gz (Caused by NewConnectionError('<urllib3.connection.HTTPConnection object at 0x7fa4982cfad0>: Failed to establish a new connection: [Errno 101] Network is unreachable'))
1.815 South_Korea : https://mirror.funami.tech/manjaro/
0.550 United_States : https://ziply.mm.fcix.net/manjaro/
3.016 China : https://mirror.nyist.edu.cn/manjaro/
2.345 Uzbekistan : https://mirror.dc.uz/manjaro/
1.664 Australia : https://gsl-syd.mm.fcix.net/manjaro/
1.593 Poland : https://ftp.psnc.pl/linux/manjaro/
0.296 United_States : https://mnvoip.mm.fcix.net/manjaro/
1.013 Sweden : https://ftpmirror1.infania.net/mirror/manjaro/
1.147 Czechia : https://mirror.dkm.cz/manjaro/
1.393 Georgia : http://manjaro.grena.ge/
3.063 Thailand : https://mirror.kku.ac.th/manjaro/
1.833 Costa_Rica : https://mirrors.ucr.ac.cr/manjaro/
1.219 Poland : https://ftp.icm.edu.pl/pub/Linux/dist/manjaro/
0.144 United_States : https://mirror.math.princeton.edu/pub/manjaro/
2.490 China : https://mirrors.huaweicloud.com/manjaro/
1.426 Bulgaria : https://mirrors.netix.net/manjaro/
1.521 Austria : https://mirror.alwyzon.net/manjaro/
0.163 United_States : https://coresite.mm.fcix.net/manjaro/
..... Indonesia : http://kartolo.sby.datautama.net.id/manjaro/
1.222 Spain : https://mirrors.ft.uam.es/manjaro/
1.991 Italy : https://ct.mirror.garr.it/mirrors/manjaro/
1.265 Portugal : https://mirrors.up.pt/pub/manjaro/
0.748 United_Kingdom : https://www.mirrorservice.org/sites/repo.manjaro.org/repos/
2.406 New_Zealand : https://mirror.2degrees.nz/manjaro/
3.502 China : https://mirrors.sjtug.sjtu.edu.cn/manjaro/
2.622 Brazil : https://mirror.ufam.edu.br/manjaro/
1.426 Turkey : https://ftp.linux.org.tr/manjaro/
1.419 Germany : https://mirror.alpix.eu/manjaro/
2.449 Czechia : https://mirrors.nic.cz/manjaro/
3.108 China : https://mirrors.jlu.edu.cn/manjaro/
0.450 United_States : http://mirror.fcix.net/manjaro/
..... China : https://mirrors.pku.edu.cn/manjaro/
2.862 Russia : https://mirror.kamtv.ru/manjaro/
1.933 Mauritius : https://manjarolinux-mirror.cloud.mu/
2.240 Russia : https://mirror.truenetwork.ru/manjaro/
1.491 Greece : https://ftp.cc.uoc.gr/mirrors/linux/manjaro/
0.336 United_States : https://nocix.mm.fcix.net/manjaro/
1.205 Belarus : http://mirror.datacenter.by/pub/mirrors/manjaro/
1.325 Ukraine : https://fastmirror.pp.ua/manjaro/
1.623 Hungary : https://quantum-mirror.hu/mirrors/pub/manjaro/
0.181 United_States : https://forksystems.mm.fcix.net/manjaro/
0.804 France : https://manjaro.ynh.ovh/
3.629 China : https://mirrors.zju.edu.cn/manjaro/
1.684 Brazil : https://linorg.usp.br/manjaro/
0.681 Netherlands : https://mirror.koddos.net/manjaro/
0.403 Canada : https://mirror.xenyth.net/manjaro/
0.526 United_States : https://codingflyboy.mm.fcix.net/manjaro/
1.276 Italy : https://manjaro.mirror.garr.it/manjaro/
1.347 Sweden : https://ftp.lysator.liu.se/pub/manjaro/
0.378 Canada : https://mirror.csclub.uwaterloo.ca/manjaro/
1.239 Finland : https://manjaro.kyberorg.fi/
3.982 Chile : https://mirror.ufro.cl/manjaro/
..... Japan : http://mirror.phoepsilonix.love/manjaro/
0.767 Belgium : https://mirror.futureweb.be/manjaro/
0.229 United_States : https://ohioix.mm.fcix.net/manjaro/
0.577 Colombia : https://edgeuno-bog2.mm.fcix.net/manjaro/
1.551 Netherlands : https://ftp.nluug.nl/pub/os/Linux/distr/manjaro/
2.551 Bulgaria : https://manjaro.ipacct.com/manjaro/
1.626 Chile : https://mirror1.cl.netactuate.com/manjaro/
0.638 Canada : https://muug.ca/mirror/manjaro/
1.081 Denmark : https://mirrors.dotsrc.org/manjaro/
1.326 Russia : https://mirror.yandex.ru/mirrors/manjaro/
1.624 Portugal : http://ftp.dei.uc.pt/pub/linux/manjaro/
0.325 United_States : https://volico.mm.fcix.net/manjaro/
1.591 Greece : https://fosszone.csd.auth.gr/manjaro/
2.725 China : https://mirrors.tuna.tsinghua.edu.cn/manjaro/
0.713 France : http://ftp.free.org/mirrors/repo.manjaro.org/repos/
1.143 China : https://mirrors.aliyun.com/manjaro/
1.018 Switzerland : https://mirror.init7.net/manjaro/
2.030 Brazil : https://manjaro.c3sl.ufpr.br/
1.730 Spain : https://ftp.caliu.cat/pub/distribucions/manjaro/
2.143 Singapore : https://mirror.freedif.org/Manjaro/
1.834 India : https://mirror.albony.xyz/manjaro/
2.343 Poland : https://repo.skni.umcs.pl/manjaro/
0.606 Global : https://mirrors.manjaro.org/repo/
1.115 Germany : https://mirror.23m.com/manjaro/
1.229 Germany : https://mirror.netcologne.de/manjaro/
0.644 Belgium : http://ftp.belnet.be/mirrors/manjaro/repos/
1.578 Czechia : https://mirror.it4i.cz/manjaro/
0.761 United_Kingdom : http://manjaro.mirrors.uk2.net/
1.265 Armenia : http://manjaro.ucom.am/
1.240 Germany : http://ftp.tu-chemnitz.de/pub/linux/manjaro/
::United_Kingdom : https://mirror.vinehost.net/manjaro/stable
::China : https://mirrors.aliyun.com/manjaro/stable
::Norway : http://mirror.terrahost.no/linux/manjaro/stable
::Greece : https://ftp.cc.uoc.gr/mirrors/linux/manjaro/stable
::Portugal : http://ftp.dei.uc.pt/pub/linux/manjaro/stable
::India : https://mirror.albony.xyz/manjaro/stable
::South_Africa : http://manjaro.mirror.ac.za/stable
::Poland : https://repo.skni.umcs.pl/manjaro/stable
::Australia : https://mirror.aarnet.edu.au/pub/manjaro/stable
::China : https://mirrors.huaweicloud.com/manjaro/stable
::Japan : http://mirror.phoepsilonix.love/manjaro/stable
::Kenya : https://manjaro.mirror.liquidtelecom.com/stable
::China : https://mirrors.zju.edu.cn/manjaro/stable
::China : https://mirrors.ustc.edu.cn/manjaro/stable
[manjaro /]# pacman -Syyu
core 145.7 KiB 740 KiB/s 00:00 [########################################################################################################] 100%
extra 8.6 MiB 11.7 MiB/s 00:01 [########################################################################################################] 100%
community 29.0 B 1705 B/s 00:00 [########################################################################################################] 100%
multilib 146.8 KiB 1769 KiB/s 00:00 [########################################################################################################] 100%
resolving dependencies...
warning: dependency cycle detected:
warning: libcamera-ipa will be installed before its libcamera dependency
warning: ruby-stdlib will be installed before its ruby dependency
warning: ruby-test-unit will be installed before its ruby dependency
warning: ruby-bundledgems will be installed before its ruby dependency
Packages (190) electron25-25.3.2-1 fuse-common-3.16.1-1 fuse3-3.16.1-1 gcc-13.2.1-3 gcc-fortran-13.2.1-3 gcc-libs-13.2.1-3 git-2.41.0-2 glibc-2.38-2.0 glslang-12.3.1-2 gmp-6.3.0-1 go-2:1.21.0-1 gtk-update-icon-cache-1:4.10.5-1 gtk4-1:4.10.5-1 gupnp-1:1.6.5-1
gvfs-1.50.6-1 gvfs-afc-1.50.6-1 gvfs-gphoto2-1.50.6-1 gvfs-mtp-1.50.6-1 gvfs-nfs-1.50.6-1 gvfs-smb-1.50.6-1 harfbuzz-8.1.1-1 harfbuzz-icu-8.1.1-1 imagemagick-7.1.1.15-2 intel-ucode-20230808-1 kactivitymanagerd-5.27.7-1 kscreenlocker-5.27.7-1
ksshaskpass-5.27.7-1 kwin-5.27.7-1 kwrited-5.27.7-1 layer-shell-qt-5.27.7-1 lib32-curl-8.2.1-1 lib32-faudio-23.07-1 lib32-gcc-libs-13.2.1-3 lib32-glibc-2.38-2.0 lib32-harfbuzz-8.1.1-1 lib32-libjpeg-turbo-3.0.0-1 lib32-libldap-2.6.6-1
lib32-libva-2.19.0-1 lib32-libva-mesa-driver-23.1.5-2 lib32-llvm-libs-15.0.7-3 lib32-mesa-23.1.5-2 lib32-mesa-vdpau-23.1.5-2 lib32-nss-3.92-1 lib32-openssl-1:3.1.2-1 lib32-sdl2-2.28.2-1 lib32-vulkan-intel-23.1.5-2 lib32-vulkan-radeon-23.1.5-2
lib32-xz-5.4.4-1 libadwaita-1:1.3.4-1 libarchive-3.7.1-1 libcamera-0.1.0-1 libcamera-ipa-0.1.0-1 libcurl-compat-8.2.1-1 libelf-0.189-3 libgit2-1:1.7.0-3 libimagequant-4.2.0-1 libjpeg-turbo-3.0.0-1 libkscreen-5.27.7-1 libksysguard-5.27.7-1
libldap-2.6.6-1 libmfx-23.2.2-2 libpamac-11.6.0-0.3 libpamac-flatpak-plugin-11.6.0-0.3 libpamac-snap-plugin-11.6.0-0.3 libpipewire-1:0.3.77-1 libplacebo-5.264.1-2 libproxy-0.5.3-2 libsysprof-capture-3.48.0-4 libtool-2.4.7+4+g1ec8fa28-6
libva-mesa-driver-23.1.5-2 licenses-20230729-1 linux-api-headers-6.4-1 linux-firmware-20230810.7be2766d-1 linux-firmware-whence-20230810.7be2766d-1 linux515-5.15.125-1 lsb-release-2.0.r53.a86f885-1 lvm2-2.03.22-1 mesa-23.1.5-2 mesa-vdpau-23.1.5-2
meson-1.2.1-1 mhwd-nvidia-535.98-1 mhwd-nvidia-470xx-470.199.02-3 milou-5.27.7-1 mkinitcpio-36-4 mold-2.0.0-1 mpfr-4.2.0.p12-3 net-snmp-5.9.1-7 nextcloud-client-cloudproviders-2:3.9.1-1 nodejs-20.5.0-1 noto-fonts-1:23.8.1-1 nss-3.92-1
openexr-3.1.10-1 openssl-3.1.2-1 oxygen-5.27.7-1 oxygen-sounds-5.27.7-1 pamac-cli-11.6.0-0.1 pamac-gtk-11.6.0-0.1 perl-5.38.0-1 perl-alien-build-2.80-2 perl-alien-libxml2-0.19-2 perl-capture-tiny-0.48-7 perl-clone-0.46-2 perl-dbi-1.643-6
perl-encode-locale-1.05-11 perl-error-0.17029-5 perl-ffi-checklib-0.31-3 perl-file-basedir-0.09-3 perl-file-chdir-0.1011-5 perl-file-desktopentry-0.22-11 perl-file-listing-6.16-2 perl-file-mimeinfo-0.33-2 perl-file-which-1.27-3 perl-html-parser-3.81-2
perl-html-tagset-3.20-14 perl-http-cookies-6.10-4 perl-http-daemon-6.16-2 perl-http-date-6.06-1 perl-http-message-6.44-2 perl-http-negotiate-6.01-12 perl-io-html-1.004-4 perl-ipc-system-simple-1.30-5 perl-libwww-6.67-2 perl-lwp-mediatypes-6.04-4
perl-mailtools-2.21-7 perl-net-http-6.23-2 perl-parse-yapp-1.21-6 perl-path-tiny-0.144-2 perl-timedate-2.33-5 perl-try-tiny-0.31-3 perl-uri-5.19-2 perl-www-robotrules-6.02-12 perl-xml-libxml-2.0209-1 perl-xml-parser-2.46-5 perl-xml-simple-2.25-8
perl-xml-writer-0.900-2 pipewire-1:0.3.77-1 plasma-browser-integration-5.27.7-1 plasma-desktop-5.27.7.1-1 plasma-integration-5.27.7-1 plasma-nm-5.27.7-1 plasma-pa-5.27.7-1 plasma-workspace-5.27.7-2 plasma-workspace-wallpapers-5.27.7-1 polkit-123-1
polkit-kde-agent-5.27.7-1 powerdevil-5.27.7-1 pyside6-6.5.2-1 python-cairo-1.24.0-1 python-chardet-5.2.0-1 python-click-8.1.6-1 python-dill-0.3.7-1 python-filelock-3.12.2-1 python-grpcio-1.56.2-2 python-hypothesis-6.82.3-1
python-importlib_resources-6.0.1-1 python-inflect-7.0.0-1 python-joblib-1.3.1-1 python-jsonschema-4.18.4-1 python-jsonschema-specifications-2023.7.1-1 python-keyring-24.2.0-1 python-markdown-3.4.4-1 python-more-itertools-10.0.1-1 python-orjson-3.9.4-1
python-pathspec-0.11.2-1 python-pip-23.2.1-1 python-pluggy-1.1.0-1 python-pycodestyle-2.11.0-1 python-pylint-2.17.5-1 python-rapidfuzz-3.1.2-1 python-referencing-0.30.0-1 python-rich-13.5.2-1 python-rpds-py-0.9.2-1 python-sphinx-7.1.2-1
python-trove-classifiers-2023.8.7-1 python-yaml-6.0.1-2 python-zipp-3.16.1-1 qt5-base-5.15.10+kde+r147-1 ruby-3.0.6-1 ruby-bundledgems-3.0.6-1 ruby-stdlib-3.0.6-1 ruby-test-unit-3.6.0-1 rust-1:1.71.1-1 sddm-0.20.0-2 sddm-kcm-5.27.7-1 sdl2-2.28.2-1
shaderc-2023.4-1 shiboken6-6.5.2-1 smartmontools-7.4-1 snapd-2.60.2-1 spectre-meltdown-checker-0.46+10+gc1c1ac4-1
Total Installed Size: 3399.87 MiB
Net Upgrade Size: 20.01 MiB
:: Proceed with installation? [Y/n] Y
(190/190) checking keys in keyring [########################################################################################################] 100%
(190/190) checking package integrity [########################################################################################################] 100%
(190/190) loading package files [########################################################################################################] 100%
(190/190) checking for file conflicts [########################################################################################################] 100%
(190/190) checking available disk space [########################################################################################################] 100%
(1/2) Creating Timeshift snapshot before upgrade...
findmnt: /usr/lib/libc.so.6: version `GLIBC_2.38' not found (required by /usr/lib/libudev.so.1)
/usr/bin/timeshift-autosnap: line 5: [: ==: unary operator expected
/usr/bin/timeshift-autosnap: line 36: [: ==: unary operator expected
==> skipping timeshift-autosnap due skipRsyncAutosnap in /etc/timeshift-autosnap.conf set to TRUE.
(2/2) Removing linux initcpios...
( 1/190) upgrading linux-api-headers [########################################################################################################] 100%
( 2/190) upgrading glibc [########################################################################################################] 100%
Generating locales...
ja_JP.UTF-8... done
en_US.UTF-8... done
Generation complete.
( 3/190) upgrading gcc-libs [########################################################################################################] 100%
( 4/190) upgrading openssl [########################################################################################################] 100%
( 5/190) upgrading libldap [########################################################################################################] 100%
( 6/190) upgrading gmp [########################################################################################################] 100%
( 7/190) upgrading nss [########################################################################################################] 100%
( 8/190) upgrading libjpeg-turbo [########################################################################################################] 100%
( 9/190) upgrading libsysprof-capture [########################################################################################################] 100%
( 10/190) upgrading harfbuzz [########################################################################################################] 100%
( 11/190) upgrading libelf [########################################################################################################] 100%
( 12/190) upgrading mesa [########################################################################################################] 100%
( 13/190) upgrading sdl2 [########################################################################################################] 100%
( 14/190) upgrading libmfx [########################################################################################################] 100%
( 15/190) upgrading openexr [########################################################################################################] 100%
( 16/190) upgrading gtk-update-icon-cache [########################################################################################################] 100%
( 17/190) upgrading libproxy [########################################################################################################] 100%
( 18/190) upgrading electron25 [########################################################################################################] 100%
( 19/190) upgrading fuse-common [########################################################################################################] 100%
( 20/190) upgrading fuse3 [########################################################################################################] 100%
( 21/190) upgrading mpfr [########################################################################################################] 100%
( 22/190) upgrading gcc [########################################################################################################] 100%
( 23/190) upgrading gcc-fortran [########################################################################################################] 100%
( 24/190) upgrading perl [########################################################################################################] 100%
( 25/190) upgrading perl-error [########################################################################################################] 100%
( 26/190) upgrading perl-timedate [########################################################################################################] 100%
( 27/190) upgrading perl-mailtools [########################################################################################################] 100%
( 28/190) upgrading git [########################################################################################################] 100%
( 29/190) upgrading glslang [########################################################################################################] 100%
( 30/190) upgrading go [########################################################################################################] 100%
( 31/190) upgrading gupnp [########################################################################################################] 100%
( 32/190) upgrading gtk4 [########################################################################################################] 100%
( 33/190) upgrading libarchive [########################################################################################################] 100%
( 34/190) upgrading polkit [########################################################################################################] 100%
( 35/190) upgrading lib32-glibc [########################################################################################################] 100%
( 36/190) upgrading lib32-gcc-libs [########################################################################################################] 100%
( 37/190) upgrading lib32-openssl [########################################################################################################] 100%
( 38/190) upgrading lib32-libldap [########################################################################################################] 100%
( 39/190) upgrading gvfs [########################################################################################################] 100%
( 40/190) upgrading gvfs-afc [########################################################################################################] 100%
( 41/190) upgrading libtool [########################################################################################################] 100%
( 42/190) upgrading gvfs-gphoto2 [########################################################################################################] 100%
( 43/190) upgrading gvfs-mtp [########################################################################################################] 100%
( 44/190) upgrading gvfs-nfs [########################################################################################################] 100%
( 45/190) upgrading gvfs-smb [########################################################################################################] 100%
( 46/190) upgrading harfbuzz-icu [########################################################################################################] 100%
( 47/190) upgrading imagemagick [########################################################################################################] 100%
( 48/190) upgrading intel-ucode [########################################################################################################] 100%
( 49/190) upgrading qt5-base [########################################################################################################] 100%
( 50/190) upgrading kactivitymanagerd [########################################################################################################] 100%
( 51/190) upgrading layer-shell-qt [########################################################################################################] 100%
( 52/190) upgrading libkscreen [########################################################################################################] 100%
( 53/190) upgrading kscreenlocker [########################################################################################################] 100%
( 54/190) upgrading ksshaskpass [########################################################################################################] 100%
( 55/190) upgrading libpipewire [########################################################################################################] 100%
( 56/190) upgrading libcamera-ipa [########################################################################################################] 100%
( 57/190) upgrading libcamera [########################################################################################################] 100%
( 58/190) upgrading pipewire [########################################################################################################] 100%
( 59/190) upgrading kwin [########################################################################################################] 100%
( 60/190) upgrading oxygen-sounds [########################################################################################################] 100%
( 61/190) upgrading kwrited [########################################################################################################] 100%
( 62/190) upgrading lib32-curl [########################################################################################################] 100%
( 63/190) upgrading lib32-xz [########################################################################################################] 100%
( 64/190) upgrading lib32-llvm-libs [########################################################################################################] 100%
( 65/190) upgrading lib32-mesa [########################################################################################################] 100%
( 66/190) upgrading lib32-sdl2 [########################################################################################################] 100%
( 67/190) upgrading lib32-faudio [########################################################################################################] 100%
( 68/190) upgrading lib32-harfbuzz [########################################################################################################] 100%
( 69/190) upgrading lib32-libjpeg-turbo [########################################################################################################] 100%
( 70/190) upgrading lib32-libva [########################################################################################################] 100%
( 71/190) upgrading lib32-libva-mesa-driver [########################################################################################################] 100%
( 72/190) upgrading lib32-mesa-vdpau [########################################################################################################] 100%
( 73/190) upgrading lib32-nss [########################################################################################################] 100%
( 74/190) upgrading lib32-vulkan-intel [########################################################################################################] 100%
( 75/190) upgrading lib32-vulkan-radeon [########################################################################################################] 100%
( 76/190) upgrading libadwaita [########################################################################################################] 100%
( 77/190) upgrading libcurl-compat [########################################################################################################] 100%
( 78/190) upgrading libgit2 [########################################################################################################] 100%
( 79/190) upgrading libimagequant [########################################################################################################] 100%
( 80/190) upgrading noto-fonts [########################################################################################################] 100%
( 81/190) upgrading libksysguard [########################################################################################################] 100%
( 82/190) upgrading python-chardet [########################################################################################################] 100%
( 83/190) upgrading libpamac [########################################################################################################] 100%
( 84/190) upgrading libpamac-flatpak-plugin [########################################################################################################] 100%
( 85/190) upgrading snapd [########################################################################################################] 100%
( 86/190) upgrading libpamac-snap-plugin [########################################################################################################] 100%
( 87/190) upgrading shaderc [########################################################################################################] 100%
( 88/190) upgrading libplacebo [########################################################################################################] 100%
( 89/190) upgrading libva-mesa-driver [########################################################################################################] 100%
( 90/190) upgrading licenses [########################################################################################################] 100%
( 91/190) upgrading linux-firmware-whence [########################################################################################################] 100%
( 92/190) upgrading linux-firmware [########################################################################################################] 100%
( 93/190) upgrading mkinitcpio [########################################################################################################] 100%
( 94/190) upgrading linux515 [########################################################################################################] 100%
( 95/190) upgrading lsb-release [########################################################################################################] 100%
( 96/190) upgrading lvm2 [########################################################################################################] 100%
( 97/190) upgrading mesa-vdpau [########################################################################################################] 100%
( 98/190) upgrading meson [########################################################################################################] 100%
( 99/190) upgrading perl-encode-locale [########################################################################################################] 100%
(100/190) upgrading perl-uri [########################################################################################################] 100%
(101/190) upgrading perl-http-date [########################################################################################################] 100%
(102/190) upgrading perl-file-listing [########################################################################################################] 100%
(103/190) upgrading perl-html-tagset [########################################################################################################] 100%
(104/190) upgrading perl-clone [########################################################################################################] 100%
(105/190) upgrading perl-io-html [########################################################################################################] 100%
(106/190) upgrading perl-lwp-mediatypes [########################################################################################################] 100%
(107/190) upgrading perl-http-message [########################################################################################################] 100%
(108/190) upgrading perl-html-parser [########################################################################################################] 100%
(109/190) upgrading perl-http-cookies [########################################################################################################] 100%
(110/190) upgrading perl-http-daemon [########################################################################################################] 100%
(111/190) upgrading perl-http-negotiate [########################################################################################################] 100%
(112/190) upgrading perl-net-http [########################################################################################################] 100%
(113/190) upgrading perl-try-tiny [########################################################################################################] 100%
(114/190) upgrading perl-www-robotrules [########################################################################################################] 100%
(115/190) upgrading perl-libwww [########################################################################################################] 100%
(116/190) upgrading perl-xml-parser [########################################################################################################] 100%
(117/190) upgrading perl-xml-writer [########################################################################################################] 100%
(118/190) upgrading mhwd-nvidia-470xx [########################################################################################################] 100%
(119/190) upgrading mhwd-nvidia [########################################################################################################] 100%
(120/190) upgrading milou [########################################################################################################] 100%
(121/190) upgrading mold [########################################################################################################] 100%
(122/190) upgrading net-snmp [########################################################################################################] 100%
(123/190) upgrading nextcloud-client-cloudproviders [########################################################################################################] 100%
(124/190) upgrading nodejs [########################################################################################################] 100%
(125/190) upgrading oxygen [########################################################################################################] 100%
(126/190) upgrading pamac-cli [########################################################################################################] 100%
New optional dependencies for pamac-cli
libpamac-aur-plugin: for AUR support [installed]
(127/190) upgrading pamac-gtk [########################################################################################################] 100%
New optional dependencies for pamac-gtk
libpamac-appstream-plugin: for Appstream support [installed]
(128/190) upgrading perl-capture-tiny [########################################################################################################] 100%
(129/190) upgrading perl-ffi-checklib [########################################################################################################] 100%
(130/190) upgrading perl-file-chdir [########################################################################################################] 100%
(131/190) upgrading perl-file-which [########################################################################################################] 100%
(132/190) upgrading perl-path-tiny [########################################################################################################] 100%
(133/190) upgrading perl-alien-build [########################################################################################################] 100%
(134/190) upgrading perl-alien-libxml2 [########################################################################################################] 100%
(135/190) upgrading perl-dbi [########################################################################################################] 100%
(136/190) upgrading perl-ipc-system-simple [########################################################################################################] 100%
(137/190) upgrading perl-file-basedir [########################################################################################################] 100%
(138/190) upgrading perl-file-desktopentry [########################################################################################################] 100%
(139/190) upgrading perl-file-mimeinfo [########################################################################################################] 100%
(140/190) upgrading perl-parse-yapp [########################################################################################################] 100%
(141/190) upgrading perl-xml-libxml [########################################################################################################] 100%
(142/190) upgrading perl-xml-simple [########################################################################################################] 100%
(143/190) upgrading plasma-integration [########################################################################################################] 100%
(144/190) upgrading plasma-workspace [########################################################################################################] 100%
(145/190) upgrading plasma-browser-integration [########################################################################################################] 100%
(146/190) upgrading polkit-kde-agent [########################################################################################################] 100%
(147/190) upgrading powerdevil [########################################################################################################] 100%
(148/190) upgrading plasma-desktop [########################################################################################################] 100%
(149/190) upgrading plasma-nm [########################################################################################################] 100%
(150/190) upgrading plasma-pa [########################################################################################################] 100%
(151/190) upgrading plasma-workspace-wallpapers [########################################################################################################] 100%
(152/190) upgrading shiboken6 [########################################################################################################] 100%
(153/190) upgrading pyside6 [########################################################################################################] 100%
(154/190) upgrading python-cairo [########################################################################################################] 100%
(155/190) upgrading python-click [########################################################################################################] 100%
(156/190) upgrading python-dill [########################################################################################################] 100%
(157/190) upgrading python-filelock [########################################################################################################] 100%
(158/190) upgrading python-grpcio [########################################################################################################] 100%
(159/190) upgrading python-hypothesis [########################################################################################################] 100%
New optional dependencies for python-hypothesis
python-black: for CLI and ghostwriter
python-click: for CLI [installed]
python-dateutil: for date support [installed]
python-dpcontracts: for contracts support
python-pandas: for pandas support
python-redis: for redis support
python-rich: for CLI [installed]
(160/190) upgrading python-importlib_resources [########################################################################################################] 100%
(161/190) upgrading python-inflect [########################################################################################################] 100%
(162/190) upgrading python-joblib [########################################################################################################] 100%
(163/190) upgrading python-rpds-py [########################################################################################################] 100%
(164/190) upgrading python-referencing [########################################################################################################] 100%
(165/190) upgrading python-jsonschema-specifications [########################################################################################################] 100%
(166/190) upgrading python-jsonschema [########################################################################################################] 100%
(167/190) upgrading python-zipp [########################################################################################################] 100%
(168/190) upgrading python-more-itertools [########################################################################################################] 100%
(169/190) upgrading python-keyring [########################################################################################################] 100%
(170/190) upgrading python-markdown [########################################################################################################] 100%
(171/190) upgrading python-orjson [########################################################################################################] 100%
(172/190) upgrading python-pathspec [########################################################################################################] 100%
(173/190) upgrading python-pip [########################################################################################################] 100%
(174/190) upgrading python-pluggy [########################################################################################################] 100%
(175/190) upgrading python-pycodestyle [########################################################################################################] 100%
(176/190) upgrading python-pylint [########################################################################################################] 100%
(177/190) upgrading python-rapidfuzz [########################################################################################################] 100%
(178/190) upgrading python-rich [########################################################################################################] 100%
(179/190) upgrading python-sphinx [########################################################################################################] 100%
(180/190) upgrading python-trove-classifiers [########################################################################################################] 100%
(181/190) upgrading python-yaml [########################################################################################################] 100%
(182/190) upgrading ruby-stdlib [########################################################################################################] 100%
(183/190) upgrading ruby-test-unit [########################################################################################################] 100%
(184/190) upgrading ruby-bundledgems [########################################################################################################] 100%
(185/190) upgrading ruby [########################################################################################################] 100%
(186/190) upgrading rust [########################################################################################################] 100%
(187/190) upgrading sddm [########################################################################################################] 100%
(188/190) upgrading sddm-kcm [########################################################################################################] 100%
(189/190) upgrading smartmontools [########################################################################################################] 100%
(190/190) upgrading spectre-meltdown-checker [########################################################################################################] 100%
( 1/25) Creating system user accounts...
( 2/25) Reloading system manager configuration...
Skipped: Running in chroot.
( 3/25) Creating temporary files...
( 4/25) Reloading device manager configuration...
( 5/25) Arming ConditionNeedsUpdate...
( 6/25) Updating the MIME type database...
( 7/25) Updating module dependencies...
( 8/25) Restoring locales
( 9/25) Restarting cronie for libc upgrade...
Running in chroot, ignoring command 'try-restart'
(10/25) Updating linux initcpios...
==> Building image from preset: /etc/mkinitcpio.d/linux515.preset: 'default'
==> Using configuration file: '/etc/mkinitcpio.conf'
-> -k /boot/vmlinuz-5.15-x86_64 -c /etc/mkinitcpio.conf -g /boot/initramfs-5.15-x86_64.img
==> Starting build: '5.15.125-1-MANJARO'
-> Running build hook: [base]
-> Running build hook: [udev]
-> Running build hook: [consolefont]
==> WARNING: consolefont: no font found in configuration
-> Running build hook: [fsck]
==> Creating gzip-compressed initcpio image: '/boot/initramfs-5.15-x86_64.img'
==> Building image from preset: /etc/mkinitcpio.d/linux515.preset: 'fallback'
-> -k /boot/vmlinuz-5.15-x86_64 -c /etc/mkinitcpio.conf -g /boot/initramfs-5.15-x86_64-fallback.img -S autodetect
==> WARNING: Possibly missing firmware for module: 'qed'
==> WARNING: Possibly missing firmware for module: 'qla1280'
==> WARNING: Possibly missing firmware for module: 'qla2xxx'
==> WARNING: Possibly missing firmware for module: 'bfa'
==> Creating gzip-compressed initcpio image: '/boot/initramfs-5.15-x86_64-fallback.img'
(11/25) Refreshing PackageKit...
Error connecting: Could not connect: No such file or directory
error: command failed to execute correctly
(12/25) Updating Grub-Bootmenu
Found linux image: /boot/vmlinuz-5.15-x86_64
Found initrd image: /boot/intel-ucode.img /boot/initramfs-5.15-x86_64.img
Found initrd fallback image: /boot/initramfs-5.15-x86_64-fallback.img
grub-probe: error: cannot find a GRUB drive for /dev/sdb1. Check your device.map.
Root filesystem isn't btrfs
If you think an error has occurred, please file a bug report at "https://github.com/Antynea/grub-btrfs"
/usr/bin/grub-probe: warning: unknown device type nvme0n1.
done
(13/25) Reloading system bus configuration...
(14/25) Warn about old perl modules
(15/25) Updating fontconfig cache...
(16/25) Updating 32-bit fontconfig cache...
(17/25) Updating GIO module cache...
(18/25) Compiling GSettings XML schema files...
(19/25) Updating icon theme caches...
(20/25) Updating GTK4 module cache...
(21/25) Reloading GVFS config...
killall: /proc lacks process entries (not mounted ?)
(22/25) Modifying 'locale-gen'
(23/25) Updating the info directory file...
(24/25) Updating the desktop file MIME type cache...
(25/25) Updating X fontdir indices...
done
[manjaro /]# exit
exit
--> umount: [/mnt/boot/efi]
--> umount: [/mnt]
[manjaro ~]# exit
logout
Moderator edit: In the future, please use proper formatting: [HowTo] Post command output and file content as formatted text
It looks as if you were definitely not up to date.
Your initram was rebuilt and grub updated …
So how does the system function now?
PS. I notice you have kernel 515 … is that what you have always used?
PPS. You are using grub-btrfs when you dont appear to be using btrfs … is there a reason?
If not … you maybe want to replace it with regular grub.
I don’t know which kernel I was using. There isn’t a reason for me using grub-btrfs, how would I replace it with regular grub?
Ok. If you didnt change it yourself then it should not have changed.
You would just install grub and accept the removal of grub-btrfs
sudo pacman -Syu grub
And then update grub again:
sudo update-grub
Well … actually … grub needs to be installed to the ESP … which would be another step. I think its probably /boot/efi but I dont know without some output from something like lsblk
Still you performed some actions …
It looks like it’s back to normal now. Thank you for your help!
