Please I need help and my system keeps frustrating me and hanging intermittently
$ inxi --admin --verbosity=7 --filter --no-host --width
Kernel: 5.15.49-1-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 12.1.0
parameters: BOOT_IMAGE=/@/boot/vmlinuz-5.15-x86_64
root=UUID=ea367113-5862-4a13-bcdf-cf4cf93de586 rw rootflags=subvol=@ quiet
cryptdevice=UUID=ba966926-1fe2-4ff7-b267-fa7b78b89723:luks-ba966926-1fe2-4ff7-b267-fa7b78b89723
root=/dev/mapper/luks-ba966926-1fe2-4ff7-b267-fa7b78b89723 splash
Desktop: GNOME v: 42.2 tk: GTK v: 3.24.34 wm: gnome-shell dm: GDM v: 42.0
Type: Laptop System: Dell product: Latitude E5450 v: 01
serial: <superuser required> Chassis: type: 9 serial: <superuser required>
Mobo: Dell model: 0DCPV1 v: A00 serial: <superuser required>
UEFI-[Legacy]: Dell v: A06 date: 04/10/2015
ID-1: BAT0 charge: 40.4 Wh (100.0%) condition: 40.4/52.4 Wh (77.1%)
volts: 8.6 min: 7.4 model: LGC-LGC3.4 DELL K9GVN63 type: Li-poly
serial: <filter> status: full
RAM: total: 15.52 GiB used: 5.28 GiB (34.0%)
RAM Report:
Info: model: Intel Core i5-5300U bits: 64 type: MT MCP arch: Broadwell
gen: core 5 built: 2015-18 process: Intel 14nm family: 6 model-id: 0x3D (61)
stepping: 4 microcode: 0x2F
L3: 3 MiB desc: 1x3 MiB
Speed (MHz): avg: 2357 high: 2458 min/max: 500/2900 scaling:
driver: intel_cpufreq governor: schedutil cores: 1: 2428 2: 2304 3: 2238
4: 2458 bogomips: 18366
Flags: 3dnowprefetch abm acpi adx aes aperfmperf apic arat arch_perfmon
avx avx2 bmi1 bmi2 bts clflush cmov constant_tsc cpuid cpuid_fault cx16 cx8
de ds_cpl dtes64 dtherm dts epb ept ept_ad erms est f16c flexpriority
flush_l1d fma fpu fsgsbase fxsr hle ht ibpb ibrs ida intel_pt invpcid
invpcid_single lahf_lm lm mca mce md_clear mmx monitor movbe msr mtrr
nonstop_tsc nopl nx pae pat pbe pcid pclmulqdq pdcm pdpe1gb pebs pge pln
pni popcnt pse pse36 pti pts rdrand rdseed rdtscp rep_good rtm sdbg sep
smap smep smx ss ssbd sse sse2 sse4_1 sse4_2 ssse3 stibp syscall tm tm2
xsave xsaveopt xtopology xtpr
Type: l1tf
Type: tsx_async_abort mitigation: Clear CPU buffers; SMT vulnerable
Device-1: Intel HD Graphics 5500 vendor: Dell driver: i915 v: kernel
arch: Gen8 process: Intel 14nm built: 2014-15 ports: active: eDP-1
empty: DP-1,HDMI-A-1,HDMI-A-2 bus-ID: 00:02.0 chip-ID: 8086:1616
class-ID: 0300
Device-2: Sunplus Innovation Integrated_Webcam_HD type: USB
driver: uvcvideo bus-ID: 1-1.6:4 chip-ID: 1bcf:2b8d class-ID: 0e02
Display: x11 server: X.org v: 1.21.1.3 with: Xwayland v: 22.1.2
compositor: gnome-shell driver: X: loaded: modesetting alternate: fbdev,vesa
gpu: i915 display-ID: :0 screens: 1
Screen-1: 0 s-res: 1366x768 s-size: <missing: xdpyinfo>
Monitor-1: eDP-1 model: AU Optronics 0x2a3c built: 2013 res: 1366x768
hz: 60 dpi: 112 gamma: 1.2 size: 309x173mm (12.17x6.81") diag: 354mm (13.9")
ratio: 16:9 modes: 1366x768
Message: Unable to show GL data. Required tool glxinfo missing.
Device-1: Intel Broadwell-U Audio vendor: Dell driver: snd_hda_intel
v: kernel bus-ID: 00:03.0 chip-ID: 8086:160c class-ID: 0403
Device-2: Intel Wildcat Point-LP High Definition Audio vendor: Dell
driver: snd_hda_intel v: kernel bus-ID: 00:1b.0 chip-ID: 8086:9ca0
class-ID: 0403
Sound Server-1: ALSA v: k5.15.49-1-MANJARO running: yes
Sound Server-4: PipeWire v: 0.3.52 running: yes
Device-1: Intel Ethernet I218-LM vendor: Dell driver: e1000e v: kernel
port: f080 bus-ID: 00:19.0 chip-ID: 8086:15a2 class-ID: 0200
Device-2: Intel Wireless 7265 driver: iwlwifi v: kernel pcie: gen: 1
speed: 2.5 GT/s lanes: 1 bus-ID: 02:00.0 chip-ID: 8086:095a class-ID: 0280
bus-ID: 1-1.3:3 chip-ID: 8087:0a2a class-ID: e001
Report: rfkill ID: hci0 rfk-id: 3 state: up address: see --recommends
Device-1: luks-ba966926-1fe2-4ff7-b267-fa7b78b89723 maj-min: 254:0
type: LUKS dm: dm-0 size: 223.57 GiB
Components:
p-1: sda1 maj-min: 8:1 size: 223.57 GiB
Local Storage: total: 223.57 GiB used: 150.59 GiB (67.4%)
ID-1: /dev/sda maj-min: 8:0 vendor: Kingston model: SV300S37A240G
size: 223.57 GiB block-size: physical: 512 B logical: 512 B speed: 6.0 Gb/s
type: SSD serial: <filter> rev: BBF0 scheme: MBR
ID-1: / raw-size: 223.57 GiB size: 223.57 GiB (100.00%)
used: 150.59 GiB (67.4%) fs: btrfs dev: /dev/dm-0 maj-min: 254:0
mapped: luks-ba966926-1fe2-4ff7-b267-fa7b78b89723 label: N/A
uuid: ea367113-5862-4a13-bcdf-cf4cf93de586
ID-2: /home raw-size: 223.57 GiB size: 223.57 GiB (100.00%)
ID-3: /swap raw-size: 223.57 GiB size: 223.57 GiB (100.00%)
ID-4: /var/cache raw-size: 223.57 GiB size: 223.57 GiB (100.00%)
ID-5: /var/log raw-size: 223.57 GiB size: 223.57 GiB (100.00%)
ID-1: swap-1 type: file size: 512 MiB used: 512 MiB (100.0%) priority: -2
file: /swap/swapfile
Hub-1: 1-0:1 info: Full speed or root hub ports: 3 rev: 2.0 speed: 480 Mb/s
Hub-2: 1-1:2 info: Intel Integrated Hub ports: 8 rev: 2.0 speed: 480 Mb/s
chip-ID: 8087:8001 class-ID: 0900
Device-1: 1-1.3:3 info: Intel Bluetooth wireless interface type: Bluetooth
Device-2: 1-1.6:4 info: Sunplus Innovation Integrated_Webcam_HD
type: Video driver: uvcvideo interfaces: 2 rev: 2.0 speed: 480 Mb/s
power: 500mA chip-ID: 1bcf:2b8d class-ID: 0e02
Hub-3: 2-0:1 info: Hi-speed hub with single TT ports: 11 rev: 2.0
Device-1: 2-1:2
info: SHARKOON GmbH 2.4GHz Wireless rechargeable vertical mouse [More&Better]
type: Mouse driver: hid-generic,usbhid interfaces: 1 rev: 1.1
speed: 12 Mb/s power: 100mA chip-ID: 1ea7:0064 class-ID: 0301
Device-2: 2-7:3 info: Broadcom BCM5880 Secure Applications Processor
type: Smart Card driver: N/A interfaces: 2 rev: 1.1 speed: 12 Mb/s
power: 100mA chip-ID: 0a5c:5800 class-ID: 0b00 serial: <filter>
Hub-4: 3-0:1 info: Super-speed hub ports: 4 rev: 3.0 speed: 5 Gb/s
System Temperatures: cpu: 49.0 C mobo: 45.0 C sodimm: SODIMM C
Fan Speeds (RPM): cpu: 2495
Processes: 306 Uptime: 3h 30m wakeups: 2 Init: systemd v: 251
default: graphical tool: systemctl Compilers: gcc: 12.1.0 clang: 13.0.1
Packages: pacman: 1316 lib: 335 flatpak: 0 Shell: Zsh v: 5.9
running-in: gnome-terminal inxi: 3.3.19
