So, recently I have been experiencing a lot of system freezes I have no idea why, I then try to gently reboot using the REISUB but the system doesn’t respond at all, tried as well the shutdown button I have that set already, no luck, only option is to hard reboot which I am not a fan of as I don’t want to ruin my HDD, I need guidance on locating the problem and fixing it, thanks.
inxi -zv8:
Kernel: 6.6.34-1-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 14.1.1
root=UUID=b395b351-d6f7-40f1-88ff-43ee89d7e608 rw quiet acpi_osi=Linux
apparmor=1 security=apparmor udev.log_priority=3 acpi_backlight=native
nowatchdog
Desktop: KDE Plasma v: 6.0.5 tk: Qt v: N/A info: frameworks v: 6.3.0
Type: Laptop System: LENOVO product: 82B5 v: Lenovo Legion 5 15ARH05
serial: <superuser required> Chassis: type: 10 v: Lenovo Legion 5 15ARH05
Mobo: LENOVO model: LNVNB161216 v: SDK0J40709 WIN
serial: <superuser required> part-nu: LENOVO_MT_82B5_BU_idea_FM_Legion 5
15ARH05 uuid: <superuser required> UEFI: LENOVO v: EUCN37WW
date: 04/14/2022
ID-1: BAT0 charge: 5.2 Wh (11.0%) condition: 47.2/60.0 Wh (78.6%)
power: 19.9 W volts: 14.4 min: 15.4 model: SMP L19M4PC0 type: Li-poly
serial: <filter> status: discharging cycles: 1089
System RAM: total: 16 GiB available: 15 GiB used: 7.65 GiB (51.0%)
(unregistered) size: 8 GiB speed: 3200 MT/s volts: note: check curr: 1
min: 1 max: 1 width (bits): data: 64 total: 64 manufacturer: Kingston
part-no: LV32D4S2S8HD-8 serial: <filter>
min: 1 max: 1 width (bits): data: 64 total: 64 manufacturer: Samsung
part-no: M471A1G44AB0-CWE serial: <filter>
Info: model: AMD Ryzen 5 4600H with Radeon Graphics bits: 64 type: MT MCP
arch: Zen 2 gen: 3 level: v3 note: check built: 2020-22
process: TSMC n7 (7nm) family: 0x17 (23) model-id: 0x60 (96) stepping: 1
microcode: 0x8600106
L1: 384 KiB desc: d-6x32 KiB; i-6x32 KiB L2: 3 MiB desc: 6x512 KiB L3: 8 MiB
desc: 2x4 MiB
Speed (MHz): avg: 1404 high: 1697 min/max: 1400/3000 boost: enabled
scaling: driver: acpi-cpufreq governor: ondemand cores: 1: 1442 2: 1457
3: 1694 4: 1697 5: 1212 6: 1212 7: 1297 8: 1240 9: 1397 10: 1413 11: 1397
12: 1397 bogomips: 71897
f16c flushbyasid fma fpu fsgsbase fxsr fxsr_opt ht hw_pstate ibpb ibrs
ibs irperf lahf_lm lbrv lm mba mca mce misalignsse mmx mmxext monitor
movbe msr mtrr mwaitx nonstop_tsc nopl npt nrip_save nx osvw
overflow_recov pae pat pausefilter pclmulqdq pdpe1gb perfctr_core
perfctr_llc perfctr_nb pfthreshold pge pni popcnt pse pse36 rapl rdpid
rdpru rdrand rdseed rdt_a rdtscp rep_good sep sha_ni skinit smap smca
smep ssbd sse sse2 sse4_1 sse4_2 sse4a ssse3 stibp succor svm svm_lock
syscall tce topoext tsc tsc_scale umip v_spec_ctrl v_vmsave_vmload vgif
vmcb_clean vme vmmcall wbnoinvd wdt xgetbv1 xsave xsavec xsaveerptr
xsaveopt
Type: retbleed mitigation: untrained return thunk; SMT enabled with STIBP
protection
always-on; RSB filling; PBRSB-eIBRS: Not affected; BHI: Not affected
Device-1: NVIDIA TU117M [GeForce GTX 1650 Ti Mobile] vendor: Lenovo
driver: nvidia v: 550.90.07 alternate: nouveau,nvidia_drm non-free: 550.xx+
status: current (as of 2024-06; EOL~2026-12-xx) arch: Turing code: TUxxx
process: TSMC 12nm FF built: 2018-2022 pcie: gen: 1 speed: 2.5 GT/s
lanes: 8 link-max: gen: 3 speed: 8 GT/s lanes: 16 bus-ID: 01:00.0
chip-ID: 10de:1f95 class-ID: 0300
Device-2: AMD Renoir [Radeon Vega Series / Radeon Mobile Series]
vendor: Lenovo driver: amdgpu v: kernel arch: GCN-5 code: Vega
process: GF 14nm built: 2017-20 pcie: gen: 4 speed: 16 GT/s lanes: 16
ports: active: eDP-1 empty: none bus-ID: 05:00.0 chip-ID: 1002:1636
class-ID: 0300 temp: 49.0 C
Device-3: Bison Integrated Camera driver: uvcvideo type: USB rev: 2.0
speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 1-3:2 chip-ID: 5986:212b
class-ID: 0e02
Display: x11 server: X.Org v: 21.1.13 with: Xwayland v: 24.1.0
compositor: kwin_x11 driver: X: loaded: amdgpu,nvidia
unloaded: modesetting,nouveau alternate: fbdev,nv,vesa dri: radeonsi
gpu: amdgpu display-ID: :0 screens: 1
s-diag: 582mm (22.93")
Monitor-1: eDP-1 mapped: eDP model: AU Optronics 0xd1ed built: 2019
res: 1920x1080 hz: 120 dpi: 142 gamma: 1.2 chroma: red: x: 0.561 y: 0.341
green: x: 0.349 y: 0.573 blue: x: 0.161 y: 0.118 white: x: 0.314 y: 0.329
size: 344x193mm (13.54x7.6") diag: 394mm (15.5") ratio: 16:9
modes: 1920x1080, 1680x1050, 1280x1024, 1440x900, 1280x800, 1280x720,
1024x768, 800x600, 640x480
API: EGL v: 1.5 hw: drv: nvidia drv: amd radeonsi platforms: device: 0
drv: nvidia device: 1 drv: radeonsi device: 3 drv: swrast gbm:
drv: kms_swrast surfaceless: drv: nvidia x11: drv: radeonsi
inactive: wayland,device-2
API: OpenGL v: 4.6.0 compat-v: 4.5 vendor: amd mesa v: 24.1.1-manjaro1.1
renoir LLVM 17.0.6 DRM 3.54 6.6.34-1-MANJARO) device-ID: 1002:1636
memory: 500 MiB unified: no
API: Vulkan v: 1.3.279 layers: 5 device: 0 type: discrete-gpu name: NVIDIA
GeForce GTX 1650 Ti driver: nvidia v: 550.90.07 device-ID: 10de:1f95
surfaces: xcb,xlib device: 1 type: integrated-gpu name: AMD Radeon
Graphics (RADV RENOIR) driver: mesa radv v: 24.1.1-manjaro1.1
device-ID: 1002:1636 surfaces: xcb,xlib
Device-1: NVIDIA driver: snd_hda_intel v: kernel pcie: gen: 3 speed: 8 GT/s
lanes: 8 link-max: lanes: 16 bus-ID: 01:00.1 chip-ID: 10de:10fa
class-ID: 0403
Device-2: AMD ACP/ACP3X/ACP6x Audio Coprocessor vendor: Lenovo driver: N/A
alternate: snd_pci_acp3x, snd_rn_pci_acp3x, snd_pci_acp5x, snd_pci_acp6x,
snd_acp_pci, snd_rpl_pci_acp6x, snd_pci_ps, snd_sof_amd_renoir,
snd_sof_amd_rembrandt, snd_sof_amd_vangogh pcie: gen: 4 speed: 16 GT/s
lanes: 16 bus-ID: 05:00.5 chip-ID: 1022:15e2 class-ID: 0480
Device-3: AMD Family 17h/19h HD Audio vendor: Lenovo driver: snd_hda_intel
v: kernel pcie: gen: 4 speed: 16 GT/s lanes: 16 bus-ID: 05:00.6
chip-ID: 1022:15e3 class-ID: 0403
API: ALSA v: k6.6.34-1-MANJARO status: kernel-api with: aoss
Server-2: PipeWire v: 1.0.7 status: off with: pipewire-media-session
status: active tools: pw-cli
Server-3: PulseAudio v: 17.0 status: active with: 1: pulseaudio-alsa
type: plugin 2: pulseaudio-jack type: module tools: pacat,pactl,pulsemixer
vendor: Lenovo driver: r8169 v: kernel pcie: speed: Unknown lanes: 63
link-max: gen: 6 speed: 64 GT/s port: 2000 bus-ID: 03:00.0
Device-2: Intel Wi-Fi 6 AX200 driver: iwlwifi v: kernel pcie: gen: 2
speed: 5 GT/s lanes: 1 bus-ID: 04:00.0 chip-ID: 8086:2723 class-ID: 0280
IF: wlp4s0 state: up mac: <filter>
Info: services: NetworkManager, systemd-networkd, systemd-timesyncd,
wpa_supplicant
speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 3-3:3 chip-ID: 8087:0029
class-ID: e001
Report: rfkill ID: hci0 rfk-id: 3 state: up address: see --recommends
Local Storage: total: 1.14 TiB used: 920.46 GiB (78.7%)
model: MZVLB256HBHQ-000L2 size: 238.47 GiB block-size: physical: 512 B
fw-rev: 3L1QEXH7 temp: 45.9 C scheme: GPT
ID-2: /dev/sda maj-min: 8:0 vendor: Western Digital model: WD10SPSX-08A6W
tech: HDD rpm: 7200 serial: <filter> fw-rev: 1A01 scheme: GPT
ID-1: / raw-size: 51.29 GiB size: 50.31 GiB (98.08%) used: 42.63 GiB (84.7%)
fs: ext4 dev: /dev/nvme0n1p5 maj-min: 259:5 label: N/A
uuid: b395b351-d6f7-40f1-88ff-43ee89d7e608
used: 48.4 MiB (50.4%) fs: vfat dev: /dev/nvme0n1p1 maj-min: 259:1
label: N/A uuid: 0C75-E2CB
ID-3: /home raw-size: 68.07 GiB size: 66.45 GiB (97.62%)
used: 60.86 GiB (91.6%) fs: ext4 dev: /dev/nvme0n1p7 maj-min: 259:7
label: N/A uuid: 8688e415-56b2-481d-827b-210e7dfd1197
ID-4: /run/media/yamo/9640794240792A5F raw-size: 98.02 GiB
size: 98.02 GiB (100.00%) used: 87.09 GiB (88.8%) fs: ntfs
dev: /dev/nvme0n1p3 maj-min: 259:3 label: N/A uuid: 9640794240792A5F
ID-5: /run/media/yamo/EDU raw-size: 292.97 GiB size: 292.97 GiB (100.00%)
used: 148.15 GiB (50.6%) fs: ntfs dev: /dev/sda3 maj-min: 8:3 label: EDU
uuid: 366C4A282D6F052F
ID-6: /run/media/yamo/Main raw-size: 638.53 GiB size: 638.53 GiB (100.00%)
used: 581.67 GiB (91.1%) fs: ntfs dev: /dev/sda2 maj-min: 8:2 label: Main
uuid: 3AEC09DCEC099375
ID-1: swap-1 type: partition size: 20.48 GiB used: 512 KiB (0.0%)
priority: -2 dev: /dev/nvme0n1p6 maj-min: 259:6 label: N/A
uuid: ae9bb7f8-1320-4d92-9e21-1ebd6e555f8a
ID-1: /dev/nvme0n1p2 maj-min: 259:2 size: 16 MiB fs: <superuser required>
label: N/A uuid: N/A
ID-2: /dev/nvme0n1p4 maj-min: 259:4 size: 508 MiB fs: ntfs label: N/A
uuid: 0E82B29B82B286AD
ID-3: /dev/sda1 maj-min: 8:1 size: 16 MiB fs: <superuser required>
Device-1: 1-3:2 info: Bison Integrated Camera type: video driver: uvcvideo
interfaces: 2 rev: 2.0 speed: 480 Mb/s (57.2 MiB/s) lanes: 1 mode: 2.0
power: 500mA chip-ID: 5986:212b class-ID: 0e02
Hub-4: 3-1:2 info: Genesys Logic Hub ports: 2 rev: 2.1
Device-1: 3-3:3 info: Intel AX200 Bluetooth type: bluetooth driver: btusb
power: 100mA chip-ID: 8087:0029 class-ID: e001
Device-2: 3-4:4 info: Integrated Express ITE Device(8910) type: keyboard
lanes: 1 mode: 1.1 power: 100mA chip-ID: 048d:c100 class-ID: 0301
Hub-5: 4-0:1 info: super-speed hub ports: 2 rev: 3.1
Hub-6: 4-1:2 info: Genesys Logic GL3523 Hub ports: 2 rev: 3.2
speed: 5 Gb/s (596.0 MiB/s) lanes: 1 mode: 3.2 gen-1x1 chip-ID: 05e3:0620
System Temperatures: cpu: 50.0 C mobo: N/A gpu: amdgpu temp: 48.0 C
Fan Speeds (rpm): N/A
Packages: 2072 pm: dpkg pkgs: 0 pm: pacman pkgs: 2049 libs: 499
tools: pamac,yay pm: flatpak pkgs: 10 pm: snap pkgs: 13
1: https://ask4.mm.fcix.net/manjaro/stable/$repo/$arch
2: https://mirror.ibakerserver.pt/manjaro/stable/$repo/$arch
3: https://ftp.nluug.nl/pub/os/Linux/distr/manjaro/stable/$repo/$arch
4: https://mirror.it4i.cz/manjaro/stable/$repo/$arch
5: https://mnvoip.mm.fcix.net/manjaro/stable/$repo/$arch
6: https://ohioix.mm.fcix.net/manjaro/stable/$repo/$arch
7: https://mirror.csclub.uwaterloo.ca/manjaro/stable/$repo/$arch
8: http://ftp.tsukuba.wide.ad.jp/Linux/manjaro/stable/$repo/$arch
Processes:
CPU top: 5 of 405
1: cpu: 42.7% command: plasma-systemmonitor pid: 11729
mem: 226.8 MiB (1.4%)
2: cpu: 18.5% command: vivaldi-bin pid: 6087 mem: 252.8 MiB (1.6%)
3: cpu: 15.4% command: vivaldi-bin pid: 5554 mem: 618.8 MiB (4.0%)
4: cpu: 14.8% command: vivaldi-bin pid: 6351 mem: 370.9 MiB (2.4%)
5: cpu: 13.9% command: kwin_x11 pid: 5710 mem: 242.1 MiB (1.5%)
Memory top: 5 of 405
1: mem: 618.8 MiB (4.0%) command: vivaldi-bin pid: 5554 cpu: 15.4%
2: mem: 456.9 MiB (2.9%) command: code pid: 7762 cpu: 2.7%
3: mem: 380.6 MiB (2.4%) command: Microsoft.CodeAnalysis.LanguageServer
pid: 9405 cpu: 2.6%
4: mem: 370.9 MiB (2.4%) command: vivaldi-bin pid: 6351 cpu: 14.8%
5: mem: 367.4 MiB (2.3%) command: plasmashell pid: 5887 cpu: 1.3%
Processes: 405 Power: uptime: 16m states: freeze,mem,disk suspend: deep
suspend, test_resume image: 5.99 GiB services: org_kde_powerdevil,upowerd
Init: systemd v: 256 default: graphical tool: systemctl
Compilers: clang: 17.0.6 gcc: 14.1.1 Shell: Zsh v: 5.9 running-in: kitty
inxi: 3.3.35
sudo dmesg:
[ 0.000000] Linux version 6.6.34-1-MANJARO (builduser@fv-az519-130) (gcc (GCC) 14.1.1 20240522, GNU ld (GNU Binutils) 2.42.0) #1 SMP PREEMPT_DYNAMIC Wed Jun 19 19:00:06 UTC 2024
[ 0.000000] Command line: BOOT_IMAGE=/boot/vmlinuz-6.6-x86_64 root=UUID=b395b351-d6f7-40f1-88ff-43ee89d7e608 rw quiet acpi_osi=Linux apparmor=1 security=apparmor udev.log_priority=3 acpi_backlight=native nowatchdog
[ 0.000000] BIOS-provided physical RAM map:
[ 0.000000] BIOS-e820: [mem 0x0000000000000000-0x000000000009efff] usable
[ 0.000000] BIOS-e820: [mem 0x000000000009f000-0x00000000000bffff] reserved
[ 0.000000] BIOS-e820: [mem 0x0000000000100000-0x0000000009afffff] usable
[ 0.000000] BIOS-e820: [mem 0x0000000009b00000-0x0000000009dfffff] reserved
[ 0.000000] BIOS-e820: [mem 0x0000000009e00000-0x0000000009efffff] usable
[ 0.000000] BIOS-e820: [mem 0x0000000009f00000-0x0000000009f0cfff] ACPI NVS
[ 0.000000] BIOS-e820: [mem 0x0000000009f0d000-0x00000000bab68fff] usable
[ 0.000000] BIOS-e820: [mem 0x00000000bab69000-0x00000000bbd68fff] reserved
[ 0.000000] BIOS-e820: [mem 0x00000000bbd69000-0x00000000c9f7efff] usable
[ 0.000000] BIOS-e820: [mem 0x00000000c9f7f000-0x00000000caf7efff] type 20
[ 0.000000] BIOS-e820: [mem 0x00000000caf7f000-0x00000000ccf7efff] reserved
[ 0.000000] BIOS-e820: [mem 0x00000000ccf7f000-0x00000000cdf7efff] ACPI NVS
[ 0.000000] BIOS-e820: [mem 0x00000000cdf7f000-0x00000000cdffefff] ACPI data
[ 0.000000] BIOS-e820: [mem 0x00000000cdfff000-0x00000000cdffffff] usable
[ 0.000000] BIOS-e820: [mem 0x00000000ce000000-0x00000000ceffffff] reserved
[ 0.000000] BIOS-e820: [mem 0x00000000f8000000-0x00000000fbffffff] reserved
[ 0.000000] BIOS-e820: [mem 0x00000000fde00000-0x00000000fdefffff] reserved
[ 0.000000] BIOS-e820: [mem 0x00000000fec00000-0x00000000fec00fff] reserved
[ 0.000000] BIOS-e820: [mem 0x00000000fec10000-0x00000000fec10fff] reserved
[ 0.000000] BIOS-e820: [mem 0x00000000fed80000-0x00000000fed80fff] reserved
[ 0.000000] BIOS-e820: [mem 0x00000000fee00000-0x00000000fee00fff] reserved
[ 0.000000] BIOS-e820: [mem 0x00000000ff000000-0x00000000fff1ffff] reserved
[ 0.000000] BIOS-e820: [mem 0x0000000100000000-0x000000040f33ffff] usable
[ 0.000000] BIOS-e820: [mem 0x000000040f340000-0x000000042fffffff] reserved
[ 0.000000] NX (Execute Disable) protection: active
[ 0.000000] APIC: Static calls initialized
[ 0.000000] efi: EFI v2.7 by INSYDE Corp.
[ 0.000000] efi: ACPI=0xcdffe000 ACPI 2.0=0xcdffe014 TPMFinalLog=0xcdefc000 SMBIOS=0xcb70d000 SMBIOS 3.0=0xcb70b000 ESRT=0xb6640a18 MEMATTR=0xb52b7018
[ 0.000000] efi: Remove mem47: MMIO range=[0xf8000000-0xfbffffff] (64MB) from e820 map
[ 0.000000] e820: remove [mem 0xf8000000-0xfbffffff] reserved
[ 0.000000] efi: Remove mem48: MMIO range=[0xfde00000-0xfdefffff] (1MB) from e820 map
[ 0.000000] e820: remove [mem 0xfde00000-0xfdefffff] reserved
[ 0.000000] efi: Not removing mem49: MMIO range=[0xfec00000-0xfec00fff] (4KB) from e820 map
[ 0.000000] efi: Not removing mem50: MMIO range=[0xfec10000-0xfec10fff] (4KB) from e820 map
[ 0.000000] efi: Not removing mem51: MMIO range=[0xfed80000-0xfed80fff] (4KB) from e820 map
[ 0.000000] efi: Not removing mem52: MMIO range=[0xfee00000-0xfee00fff] (4KB) from e820 map
[ 0.000000] efi: Remove mem53: MMIO range=[0xff000000-0xfff1ffff] (15MB) from e820 map
[ 0.000000] e820: remove [mem 0xff000000-0xfff1ffff] reserved
[ 0.000000] SMBIOS 3.2.0 present.
[ 0.000000] DMI: LENOVO 82B5/LNVNB161216, BIOS EUCN37WW 04/14/2022
[ 0.000000] tsc: Fast TSC calibration using PIT
[ 0.000000] tsc: Detected 2994.453 MHz processor
[ 0.000349] e820: update [mem 0x00000000-0x00000fff] usable ==> reserved
[ 0.000352] e820: remove [mem 0x000a0000-0x000fffff] usable
[ 0.000358] last_pfn = 0x40f340 max_arch_pfn = 0x400000000
[ 0.000364] MTRR map: 7 entries (4 fixed + 3 variable; max 21), built from 9 variable MTRRs
[ 0.000366] x86/PAT: Configuration [0-7]: WB WC UC- UC WB WP UC- WT
[ 0.000574] last_pfn = 0xce000 max_arch_pfn = 0x400000000
[ 0.004610] esrt: Reserving ESRT space from 0x00000000b6640a18 to 0x00000000b6640a78.
[ 0.004615] e820: update [mem 0xb6640000-0xb6640fff] usable ==> reserved
[ 0.004628] Using GB pages for direct mapping
[ 0.004993] Secure boot disabled
[ 0.004994] RAMDISK: [mem 0x344e3000-0x36268fff]
[ 0.005021] ACPI: Early table checksum verification disabled
[ 0.005024] ACPI: RSDP 0x00000000CDFFE014 000024 (v02 LENOVO)
[ 0.005028] ACPI: XSDT 0x00000000CDFC5188 000124 (v01 LENOVO CB-01 00000001 01000013)
[ 0.005032] ACPI: FACP 0x00000000CDFEC000 00010C (v05 LENOVO CB-01 00000001 01000013)
[ 0.005036] ACPI: DSDT 0x00000000CDFD9000 00FAAA (v01 LENOVO CB-01 00000001 01000013)
[ 0.005038] ACPI: FACS 0x00000000CDEF9000 000040
[ 0.005040] ACPI: UEFI 0x00000000CDF7E000 000236 (v01 LENOVO CB-01 00000001 ACPI 00040000)
[ 0.005043] ACPI: SSDT 0x00000000CDFFC000 000C5D (v01 LENOVO CB-01 00000001 INTL 20130117)
[ 0.005045] ACPI: SSDT 0x00000000CDFF4000 007216 (v02 LENOVO CB-01 00000001 MSFT 04000000)
[ 0.005047] ACPI: IVRS 0x00000000CDFF3000 0001A4 (v02 LENOVO CB-01 00000001 AMD 00000000)
[ 0.005049] ACPI: SSDT 0x00000000CDFF2000 000228 (v01 LENOVO CB-01 00000001 INTL 20130117)
[ 0.005051] ACPI: SSDT 0x00000000CDFF1000 00047E (v01 LENOVO CB-01 00000001 INTL 20130117)
[ 0.005053] ACPI: TPM2 0x00000000CDFF0000 000034 (v04 LENOVO CB-01 00000001 01000013)
[ 0.005055] ACPI: MSDM 0x00000000CDFEF000 000055 (v03 LENOVO CB-01 00000001 ACPI 00040000)
[ 0.005057] ACPI: ASF! 0x00000000CDFEE000 0000A5 (v32 LENOVO CB-01 00000001 01000013)
[ 0.005059] ACPI: BOOT 0x00000000CDFED000 000028 (v01 LENOVO CB-01 00000001 01000013)
[ 0.005061] ACPI: HPET 0x00000000CDFEB000 000038 (v01 LENOVO CB-01 00000001 01000013)
[ 0.005063] ACPI: APIC 0x00000000CDFEA000 000138 (v03 LENOVO CB-01 00000001 01000013)
[ 0.005066] ACPI: MCFG 0x00000000CDFE9000 00003C (v01 LENOVO CB-01 00000001 01000013)
[ 0.005068] ACPI: SSDT 0x00000000CDFD8000 000080 (v01 LENOVO CB-01 00000001 01000013)
[ 0.005070] ACPI: SSDT 0x00000000CDFD7000 000D0C (v01 LENOVO CB-01 00000001 INTL 20130117)
[ 0.005072] ACPI: VFCT 0x00000000CDFC9000 00D484 (v01 LENOVO CB-01 00000001 AMD 31504F47)
[ 0.005074] ACPI: SSDT 0x00000000CDFC8000 00005C (v02 LENOVO CB-01 00000001 INTL 20160527)
[ 0.005076] ACPI: SSDT 0x00000000CDFC7000 00005C (v02 LENOVO CB-01 00000001 INTL 20160527)
[ 0.005078] ACPI: SSDT 0x00000000CDFC6000 0000F8 (v01 LENOVO CB-01 00000001 INTL 20130117)
[ 0.005080] ACPI: SSDT 0x00000000CDFC2000 002B80 (v01 LENOVO CB-01 00000001 AMD 00000001)
[ 0.005082] ACPI: CRAT 0x00000000CDFFD000 000BA8 (v01 LENOVO CB-01 00000001 AMD 00000001)
[ 0.005084] ACPI: CDIT 0x00000000CDFC1000 000029 (v01 LENOVO CB-01 00000001 AMD 00000001)
[ 0.005086] ACPI: SSDT 0x00000000CDFC0000 00028D (v01 LENOVO CB-01 00000001 INTL 20130117)
[ 0.005088] ACPI: SSDT 0x00000000CDFBF000 000D37 (v01 LENOVO CB-01 00000001 INTL 20130117)
[ 0.005090] ACPI: SSDT 0x00000000CDFBD000 0010A5 (v01 LENOVO CB-01 00000001 INTL 20130117)
[ 0.005092] ACPI: SSDT 0x00000000CDFB9000 0030C8 (v01 LENOVO CB-01 00000001 INTL 20130117)
[ 0.005094] ACPI: FPDT 0x00000000CDFB8000 000044 (v01 LENOVO CB-01 00000001 01000013)
[ 0.005096] ACPI: WSMT 0x00000000CDFB6000 000028 (v01 LENOVO CB-01 00000001 ACPI 00040000)
[ 0.005099] ACPI: SSDT 0x00000000CDFB5000 00007D (v01 LENOVO CB-01 00000001 INTL 20130117)
[ 0.005101] ACPI: SSDT 0x00000000CDFB4000 000517 (v01 LENOVO CB-01 00000001 INTL 20130117)
[ 0.005103] ACPI: BGRT 0x00000000CDFB7000 000038 (v01 LENOVO CB-01 00000001 ACPI 00040000)
[ 0.005104] ACPI: Reserving FACP table memory at [mem 0xcdfec000-0xcdfec10b]
[ 0.005106] ACPI: Reserving DSDT table memory at [mem 0xcdfd9000-0xcdfe8aa9]
[ 0.005106] ACPI: Reserving FACS table memory at [mem 0xcdef9000-0xcdef903f]
[ 0.005107] ACPI: Reserving UEFI table memory at [mem 0xcdf7e000-0xcdf7e235]
[ 0.005108] ACPI: Reserving SSDT table memory at [mem 0xcdffc000-0xcdffcc5c]
[ 0.005108] ACPI: Reserving SSDT table memory at [mem 0xcdff4000-0xcdffb215]
[ 0.005109] ACPI: Reserving IVRS table memory at [mem 0xcdff3000-0xcdff31a3]
[ 0.005109] ACPI: Reserving SSDT table memory at [mem 0xcdff2000-0xcdff2227]
[ 0.005110] ACPI: Reserving SSDT table memory at [mem 0xcdff1000-0xcdff147d]
[ 0.005111] ACPI: Reserving TPM2 table memory at [mem 0xcdff0000-0xcdff0033]
[ 0.005111] ACPI: Reserving MSDM table memory at [mem 0xcdfef000-0xcdfef054]
[ 0.005112] ACPI: Reserving ASF! table memory at [mem 0xcdfee000-0xcdfee0a4]
[ 0.005112] ACPI: Reserving BOOT table memory at [mem 0xcdfed000-0xcdfed027]
[ 0.005113] ACPI: Reserving HPET table memory at [mem 0xcdfeb000-0xcdfeb037]
[ 0.005114] ACPI: Reserving APIC table memory at [mem 0xcdfea000-0xcdfea137]
[ 0.005114] ACPI: Reserving MCFG table memory at [mem 0xcdfe9000-0xcdfe903b]
[ 0.005115] ACPI: Reserving SSDT table memory at [mem 0xcdfd8000-0xcdfd807f]
[ 0.005115] ACPI: Reserving SSDT table memory at [mem 0xcdfd7000-0xcdfd7d0b]
[ 0.005116] ACPI: Reserving VFCT table memory at [mem 0xcdfc9000-0xcdfd6483]
[ 0.005116] ACPI: Reserving SSDT table memory at [mem 0xcdfc8000-0xcdfc805b]
[ 0.005117] ACPI: Reserving SSDT table memory at [mem 0xcdfc7000-0xcdfc705b]
[ 0.005118] ACPI: Reserving SSDT table memory at [mem 0xcdfc6000-0xcdfc60f7]
[ 0.005118] ACPI: Reserving SSDT table memory at [mem 0xcdfc2000-0xcdfc4b7f]
[ 0.005119] ACPI: Reserving CRAT table memory at [mem 0xcdffd000-0xcdffdba7]
[ 0.005119] ACPI: Reserving CDIT table memory at [mem 0xcdfc1000-0xcdfc1028]
[ 0.005120] ACPI: Reserving SSDT table memory at [mem 0xcdfc0000-0xcdfc028c]
[ 0.005121] ACPI: Reserving SSDT table memory at [mem 0xcdfbf000-0xcdfbfd36]
[ 0.005121] ACPI: Reserving SSDT table memory at [mem 0xcdfbd000-0xcdfbe0a4]
[ 0.005122] ACPI: Reserving SSDT table memory at [mem 0xcdfb9000-0xcdfbc0c7]
[ 0.005122] ACPI: Reserving FPDT table memory at [mem 0xcdfb8000-0xcdfb8043]
[ 0.005123] ACPI: Reserving WSMT table memory at [mem 0xcdfb6000-0xcdfb6027]
[ 0.005123] ACPI: Reserving SSDT table memory at [mem 0xcdfb5000-0xcdfb507c]
[ 0.005124] ACPI: Reserving SSDT table memory at [mem 0xcdfb4000-0xcdfb4516]
[ 0.005125] ACPI: Reserving BGRT table memory at [mem 0xcdfb7000-0xcdfb7037]
[ 0.005179] No NUMA configuration found
[ 0.005180] Faking a node at [mem 0x0000000000000000-0x000000040f33ffff]
[ 0.005182] NODE_DATA(0) allocated [mem 0x40f33b000-0x40f33ffff]
[ 0.005205] Zone ranges:
[ 0.005206] DMA [mem 0x0000000000001000-0x0000000000ffffff]
[ 0.005207] DMA32 [mem 0x0000000001000000-0x00000000ffffffff]
[ 0.005209] Normal [mem 0x0000000100000000-0x000000040f33ffff]
[ 0.005210] Device empty
[ 0.005210] Movable zone start for each node
[ 0.005211] Early memory node ranges
[ 0.005211] node 0: [mem 0x0000000000001000-0x000000000009efff]
[ 0.005212] node 0: [mem 0x0000000000100000-0x0000000009afffff]
[ 0.005213] node 0: [mem 0x0000000009e00000-0x0000000009efffff]
[ 0.005214] node 0: [mem 0x0000000009f0d000-0x00000000bab68fff]
[ 0.005215] node 0: [mem 0x00000000bbd69000-0x00000000c9f7efff]
[ 0.005215] node 0: [mem 0x00000000cdfff000-0x00000000cdffffff]
[ 0.005216] node 0: [mem 0x0000000100000000-0x000000040f33ffff]
[ 0.005218] Initmem setup node 0 [mem 0x0000000000001000-0x000000040f33ffff]
[ 0.005221] On node 0, zone DMA: 1 pages in unavailable ranges
[ 0.005238] On node 0, zone DMA: 97 pages in unavailable ranges
[ 0.005383] On node 0, zone DMA32: 768 pages in unavailable ranges
[ 0.010353] On node 0, zone DMA32: 13 pages in unavailable ranges
[ 0.010801] On node 0, zone DMA32: 4608 pages in unavailable ranges
[ 0.010957] On node 0, zone DMA32: 16512 pages in unavailable ranges
[ 0.033402] On node 0, zone Normal: 8192 pages in unavailable ranges
[ 0.033435] On node 0, zone Normal: 3264 pages in unavailable ranges
[ 0.034170] ACPI: PM-Timer IO Port: 0x408
[ 0.034176] ACPI: LAPIC_NMI (acpi_id[0x00] high edge lint[0x1])
[ 0.034177] ACPI: LAPIC_NMI (acpi_id[0x01] high edge lint[0x1])
[ 0.034178] ACPI: LAPIC_NMI (acpi_id[0x02] high edge lint[0x1])
[ 0.034179] ACPI: LAPIC_NMI (acpi_id[0x03] high edge lint[0x1])
[ 0.034179] ACPI: LAPIC_NMI (acpi_id[0x04] high edge lint[0x1])
[ 0.034180] ACPI: LAPIC_NMI (acpi_id[0x05] high edge lint[0x1])
[ 0.034181] ACPI: LAPIC_NMI (acpi_id[0x06] high edge lint[0x1])
[ 0.034181] ACPI: LAPIC_NMI (acpi_id[0x07] high edge lint[0x1])
[ 0.034182] ACPI: LAPIC_NMI (acpi_id[0x08] high edge lint[0x1])
[ 0.034182] ACPI: LAPIC_NMI (acpi_id[0x09] high edge lint[0x1])
[ 0.034183] ACPI: LAPIC_NMI (acpi_id[0x0a] high edge lint[0x1])
[ 0.034183] ACPI: LAPIC_NMI (acpi_id[0x0b] high edge lint[0x1])
[ 0.034184] ACPI: LAPIC_NMI (acpi_id[0x0c] high edge lint[0x1])
[ 0.034184] ACPI: LAPIC_NMI (acpi_id[0x0d] high edge lint[0x1])
[ 0.034185] ACPI: LAPIC_NMI (acpi_id[0x0e] high edge lint[0x1])
[ 0.034186] ACPI: LAPIC_NMI (acpi_id[0x0f] high edge lint[0x1])
[ 0.034198] IOAPIC[0]: apic_id 33, version 33, address 0xfec00000, GSI 0-23
[ 0.034204] IOAPIC[1]: apic_id 34, version 33, address 0xfec01000, GSI 24-55
[ 0.034206] ACPI: INT_SRC_OVR (bus 0 bus_irq 0 global_irq 2 dfl dfl)
[ 0.034208] ACPI: INT_SRC_OVR (bus 0 bus_irq 9 global_irq 9 low level)
[ 0.034211] ACPI: Using ACPI (MADT) for SMP configuration information
[ 0.034212] ACPI: HPET id: 0x10228210 base: 0xfed00000
[ 0.034219] e820: update [mem 0xb528a000-0xb52aefff] usable ==> reserved
[ 0.034229] smpboot: Allowing 16 CPUs, 4 hotplug CPUs
[ 0.034248] PM: hibernation: Registered nosave memory: [mem 0x00000000-0x00000fff]
[ 0.034250] PM: hibernation: Registered nosave memory: [mem 0x0009f000-0x000bffff]
[ 0.034251] PM: hibernation: Registered nosave memory: [mem 0x000c0000-0x000fffff]
[ 0.034252] PM: hibernation: Registered nosave memory: [mem 0x09b00000-0x09dfffff]
[ 0.034253] PM: hibernation: Registered nosave memory: [mem 0x09f00000-0x09f0cfff]
[ 0.034255] PM: hibernation: Registered nosave memory: [mem 0xb528a000-0xb52aefff]
[ 0.034256] PM: hibernation: Registered nosave memory: [mem 0xb6640000-0xb6640fff]
[ 0.034257] PM: hibernation: Registered nosave memory: [mem 0xbab69000-0xbbd68fff]
[ 0.034259] PM: hibernation: Registered nosave memory: [mem 0xc9f7f000-0xcaf7efff]
[ 0.034259] PM: hibernation: Registered nosave memory: [mem 0xcaf7f000-0xccf7efff]
[ 0.034260] PM: hibernation: Registered nosave memory: [mem 0xccf7f000-0xcdf7efff]
[ 0.034260] PM: hibernation: Registered nosave memory: [mem 0xcdf7f000-0xcdffefff]
[ 0.034262] PM: hibernation: Registered nosave memory: [mem 0xce000000-0xceffffff]
[ 0.034262] PM: hibernation: Registered nosave memory: [mem 0xcf000000-0xfebfffff]
[ 0.034263] PM: hibernation: Registered nosave memory: [mem 0xfec00000-0xfec00fff]
[ 0.034263] PM: hibernation: Registered nosave memory: [mem 0xfec01000-0xfec0ffff]
[ 0.034264] PM: hibernation: Registered nosave memory: [mem 0xfec10000-0xfec10fff]
[ 0.034264] PM: hibernation: Registered nosave memory: [mem 0xfec11000-0xfed7ffff]
[ 0.034265] PM: hibernation: Registered nosave memory: [mem 0xfed80000-0xfed80fff]
[ 0.034265] PM: hibernation: Registered nosave memory: [mem 0xfed81000-0xfedfffff]
[ 0.034266] PM: hibernation: Registered nosave memory: [mem 0xfee00000-0xfee00fff]
[ 0.034266] PM: hibernation: Registered nosave memory: [mem 0xfee01000-0xffffffff]
[ 0.034268] [mem 0xcf000000-0xfebfffff] available for PCI devices
[ 0.034269] Booting paravirtualized kernel on bare hardware
[ 0.034272] clocksource: refined-jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 6370452778343963 ns
[ 0.038631] setup_percpu: NR_CPUS:320 nr_cpumask_bits:16 nr_cpu_ids:16 nr_node_ids:1
[ 0.039166] percpu: Embedded 64 pages/cpu s225280 r8192 d28672 u262144
[ 0.039173] pcpu-alloc: s225280 r8192 d28672 u262144 alloc=1*2097152
[ 0.039175] pcpu-alloc: [0] 00 01 02 03 04 05 06 07 [0] 08 09 10 11 12 13 14 15
[ 0.039197] Kernel command line: BOOT_IMAGE=/boot/vmlinuz-6.6-x86_64 root=UUID=b395b351-d6f7-40f1-88ff-43ee89d7e608 rw quiet acpi_osi=Linux apparmor=1 security=apparmor udev.log_priority=3 acpi_backlight=native nowatchdog
[ 0.039301] Unknown kernel command line parameters "BOOT_IMAGE=/boot/vmlinuz-6.6-x86_64", will be passed to user space.
[ 0.039325] random: crng init done
[ 0.041016] Dentry cache hash table entries: 2097152 (order: 12, 16777216 bytes, linear)
[ 0.041877] Inode-cache hash table entries: 1048576 (order: 11, 8388608 bytes, linear)
[ 0.041979] Fallback order for Node 0: 0
[ 0.041985] Built 1 zonelists, mobility grouping on. Total pages: 3966652
[ 0.041986] Policy zone: Normal
[ 0.042222] mem auto-init: stack:all(zero), heap alloc:on, heap free:off
[ 0.042265] software IO TLB: area num 16.
[ 0.084081] Memory: 15578384K/16119108K available (16384K kernel code, 2155K rwdata, 13096K rodata, 3436K init, 3724K bss, 540464K reserved, 0K cma-reserved)
[ 0.084284] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=16, Nodes=1
[ 0.084313] ftrace: allocating 49075 entries in 192 pages
[ 0.091205] ftrace: allocated 192 pages with 2 groups
[ 0.091291] Dynamic Preempt: full
[ 0.091346] rcu: Preemptible hierarchical RCU implementation.
[ 0.091346] rcu: RCU restricting CPUs from NR_CPUS=320 to nr_cpu_ids=16.
[ 0.091347] rcu: RCU priority boosting: priority 1 delay 500 ms.
[ 0.091348] Trampoline variant of Tasks RCU enabled.
[ 0.091348] Rude variant of Tasks RCU enabled.
[ 0.091349] Tracing variant of Tasks RCU enabled.
[ 0.091349] rcu: RCU calculated value of scheduler-enlistment delay is 30 jiffies.
[ 0.091350] rcu: Adjusting geometry for rcu_fanout_leaf=16, nr_cpu_ids=16
[ 0.093302] NR_IRQS: 20736, nr_irqs: 1096, preallocated irqs: 16
[ 0.093502] rcu: srcu_init: Setting srcu_struct sizes based on contention.
[ 0.093605] kfence: initialized - using 2097152 bytes for 255 objects at 0x(____ptrval____)-0x(____ptrval____)
[ 0.093638] Console: colour dummy device 80x25
[ 0.093640] printk: console [tty0] enabled
[ 0.093680] ACPI: Core revision 20230628
[ 0.093874] clocksource: hpet: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 133484873504 ns
[ 0.093891] APIC: Switch to symmetric I/O mode setup
[ 0.094729] AMD-Vi: ivrs, add hid:AMDI0020, uid:\_SB.FUR0, rdevid:160
[ 0.094731] AMD-Vi: ivrs, add hid:AMDI0020, uid:\_SB.FUR1, rdevid:160
[ 0.094732] AMD-Vi: ivrs, add hid:AMDI0020, uid:\_SB.FUR2, rdevid:160
[ 0.094733] AMD-Vi: ivrs, add hid:AMDI0020, uid:\_SB.FUR3, rdevid:160
[ 0.094734] AMD-Vi: Using global IVHD EFR:0x206d73ef22254ade, EFR2:0x0
[ 0.095023] APIC: Switched APIC routing to: physical flat
[ 0.095752] ..TIMER: vector=0x30 apic1=0 pin1=2 apic2=-1 pin2=-1
[ 0.110562] clocksource: tsc-early: mask: 0xffffffffffffffff max_cycles: 0x2b29cd2227a, max_idle_ns: 440795226017 ns
[ 0.110568] Calibrating delay loop (skipped), value calculated using timer frequency.. 5991.44 BogoMIPS (lpj=9981510)
[ 0.110577] Zenbleed: please update your microcode for the most optimal fix
[ 0.110582] x86/cpu: User Mode Instruction Prevention (UMIP) activated
[ 0.110608] LVT offset 1 assigned for vector 0xf9
[ 0.110663] LVT offset 2 assigned for vector 0xf4
[ 0.110679] process: using mwait in idle threads
[ 0.110680] Last level iTLB entries: 4KB 1024, 2MB 1024, 4MB 512
[ 0.110681] Last level dTLB entries: 4KB 2048, 2MB 2048, 4MB 1024, 1GB 0
[ 0.110684] Spectre V1 : Mitigation: usercopy/swapgs barriers and __user pointer sanitization
[ 0.110686] Spectre V2 : Mitigation: Retpolines
[ 0.110686] Spectre V2 : Spectre v2 / SpectreRSB mitigation: Filling RSB on context switch
[ 0.110687] Spectre V2 : Spectre v2 / SpectreRSB : Filling RSB on VMEXIT
[ 0.110687] Spectre V2 : Enabling Speculation Barrier for firmware calls
[ 0.110688] RETBleed: Mitigation: untrained return thunk
[ 0.110689] Spectre V2 : mitigation: Enabling conditional Indirect Branch Prediction Barrier
[ 0.110690] Spectre V2 : Selecting STIBP always-on mode to complement retbleed mitigation
[ 0.110690] Spectre V2 : User space: Mitigation: STIBP always-on protection
[ 0.110691] Speculative Store Bypass: Mitigation: Speculative Store Bypass disabled via prctl
[ 0.110692] Speculative Return Stack Overflow: Mitigation: Safe RET
[ 0.110695] x86/fpu: Supporting XSAVE feature 0x001: 'x87 floating point registers'
[ 0.110696] x86/fpu: Supporting XSAVE feature 0x002: 'SSE registers'
[ 0.110697] x86/fpu: Supporting XSAVE feature 0x004: 'AVX registers'
[ 0.110698] x86/fpu: xstate_offset[2]: 576, xstate_sizes[2]: 256
[ 0.110699] x86/fpu: Enabled xstate features 0x7, context size is 832 bytes, using 'compacted' format.
[ 0.133517] Freeing SMP alternatives memory: 40K
[ 0.133522] pid_max: default: 32768 minimum: 301
[ 0.140604] LSM: initializing lsm=capability,landlock,lockdown,yama,bpf,apparmor,integrity
[ 0.140616] landlock: Up and running.
[ 0.140618] Yama: becoming mindful.
[ 0.140622] LSM support for eBPF active
[ 0.140643] AppArmor: AppArmor initialized
[ 0.140694] Mount-cache hash table entries: 32768 (order: 6, 262144 bytes, linear)
[ 0.140716] Mountpoint-cache hash table entries: 32768 (order: 6, 262144 bytes, linear)
[ 0.248741] smpboot: CPU0: AMD Ryzen 5 4600H with Radeon Graphics (family: 0x17, model: 0x60, stepping: 0x1)
[ 0.248976] RCU Tasks: Setting shift to 4 and lim to 1 rcu_task_cb_adjust=1.
[ 0.248995] RCU Tasks Rude: Setting shift to 4 and lim to 1 rcu_task_cb_adjust=1.
[ 0.249013] RCU Tasks Trace: Setting shift to 4 and lim to 1 rcu_task_cb_adjust=1.
[ 0.249041] Performance Events: Fam17h+ core perfctr, AMD PMU driver.
[ 0.249049] ... version: 0
[ 0.249050] ... bit width: 48
[ 0.249051] ... generic registers: 6
[ 0.249052] ... value mask: 0000ffffffffffff
[ 0.249053] ... max period: 00007fffffffffff
[ 0.249054] ... fixed-purpose events: 0
[ 0.249055] ... event mask: 000000000000003f
[ 0.249163] signal: max sigframe size: 1776
[ 0.249193] rcu: Hierarchical SRCU implementation.
[ 0.249194] rcu: Max phase no-delay instances is 1000.
[ 0.251196] smp: Bringing up secondary CPUs ...
[ 0.251332] smpboot: x86: Booting SMP configuration:
[ 0.251333] .... node #0, CPUs: #2 #4 #6 #8 #10 #1 #3 #5 #7 #9 #11
[ 0.265901] Spectre V2 : Update user space SMT mitigation: STIBP always-on
[ 0.275901] smp: Brought up 1 node, 12 CPUs
[ 0.275901] smpboot: Max logical packages: 2
[ 0.275901] smpboot: Total of 12 processors activated (71895.32 BogoMIPS)
[ 0.277936] devtmpfs: initialized
[ 0.277936] x86/mm: Memory block size: 128MB
[ 0.282194] ACPI: PM: Registering ACPI NVS region [mem 0x09f00000-0x09f0cfff] (53248 bytes)
[ 0.282194] ACPI: PM: Registering ACPI NVS region [mem 0xccf7f000-0xcdf7efff] (16777216 bytes)
[ 0.282194] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 6370867519511994 ns
[ 0.282194] futex hash table entries: 4096 (order: 6, 262144 bytes, linear)
[ 0.282194] pinctrl core: initialized pinctrl subsystem
[ 0.282194] PM: RTC time: 21:24:17, date: 2024-07-04
[ 0.282194] NET: Registered PF_NETLINK/PF_ROUTE protocol family
[ 0.282194] DMA: preallocated 2048 KiB GFP_KERNEL pool for atomic allocations
[ 0.282194] DMA: preallocated 2048 KiB GFP_KERNEL|GFP_DMA pool for atomic allocations
[ 0.282194] DMA: preallocated 2048 KiB GFP_KERNEL|GFP_DMA32 pool for atomic allocations
[ 0.282194] audit: initializing netlink subsys (disabled)
[ 0.283940] audit: type=2000 audit(1720128257.189:1): state=initialized audit_enabled=0 res=1
[ 0.284059] thermal_sys: Registered thermal governor 'fair_share'
[ 0.284061] thermal_sys: Registered thermal governor 'bang_bang'
[ 0.284063] thermal_sys: Registered thermal governor 'step_wise'
[ 0.284064] thermal_sys: Registered thermal governor 'user_space'
[ 0.284065] thermal_sys: Registered thermal governor 'power_allocator'
[ 0.284087] cpuidle: using governor ladder
[ 0.284087] cpuidle: using governor menu
[ 0.284087] Simple Boot Flag at 0x44 set to 0x1
[ 0.284087] acpiphp: ACPI Hot Plug PCI Controller Driver version: 0.5
[ 0.284127] PCI: MMCONFIG for domain 0000 [bus 00-3f] at [mem 0xf8000000-0xfbffffff] (base 0xf8000000)
[ 0.284141] PCI: Using configuration type 1 for base access
[ 0.284766] kprobes: kprobe jump-optimization is enabled. All kprobes are optimized if possible.
[ 0.284773] HugeTLB: registered 1.00 GiB page size, pre-allocated 0 pages
[ 0.284773] HugeTLB: 16380 KiB vmemmap can be freed for a 1.00 GiB page
[ 0.284773] HugeTLB: registered 2.00 MiB page size, pre-allocated 0 pages
[ 0.284773] HugeTLB: 28 KiB vmemmap can be freed for a 2.00 MiB page
[ 0.284773] ACPI: Added _OSI(Module Device)
[ 0.284773] ACPI: Added _OSI(Processor Device)
[ 0.284773] ACPI: Added _OSI(3.0 _SCP Extensions)
[ 0.284773] ACPI: Added _OSI(Processor Aggregator Device)
[ 0.284773] ACPI: Added _OSI(Linux)
[ 0.311852] ACPI: 16 ACPI AML tables successfully acquired and loaded
[ 0.314959] ACPI: [Firmware Bug]: BIOS _OSI(Linux) query honored via cmdline
[ 0.320685] ACPI: _OSC evaluation for CPUs failed, trying _PDC
[ 0.321643] ACPI: EC: EC started
[ 0.321644] ACPI: EC: interrupt blocked
[ 0.337542] ACPI: EC: EC_CMD/EC_SC=0x66, EC_DATA=0x62
[ 0.337550] ACPI: \_SB_.PCI0.LPC0.EC0_: Boot DSDT EC used to handle transactions
[ 0.337555] ACPI: Interpreter enabled
[ 0.337608] ACPI: PM: (supports S0 S3 S4 S5)
[ 0.337612] ACPI: Using IOAPIC for interrupt routing
[ 0.341002] PCI: Using host bridge windows from ACPI; if necessary, use "pci=nocrs" and report a bug
[ 0.341008] PCI: Using E820 reservations for host bridge windows
[ 0.343181] ACPI: Enabled 4 GPEs in block 00 to 1F
[ 0.347186] ACPI: \_SB_.PCI0.GPP0.PG00: New power resource
[ 0.371163] ACPI: \_SB_.P0S0: New power resource
[ 0.371285] ACPI: \_SB_.P3S0: New power resource
[ 0.371769] ACPI: \_SB_.P0S1: New power resource
[ 0.371887] ACPI: \_SB_.P3S1: New power resource
[ 0.384088] ACPI: PCI Root Bridge [PCI0] (domain 0000 [bus 00-ff])
[ 0.384095] acpi PNP0A08:00: _OSC: OS supports [ExtendedConfig ASPM ClockPM Segments MSI EDR HPX-Type3]
[ 0.384249] acpi PNP0A08:00: _OSC: platform does not support [SHPCHotplug LTR DPC]
[ 0.384533] acpi PNP0A08:00: _OSC: OS now controls [PCIeHotplug PME AER PCIeCapability]
[ 0.384546] acpi PNP0A08:00: [Firmware Info]: MMCONFIG for domain 0000 [bus 00-3f] only partially covers this bridge
[ 0.385021] PCI host bridge to bus 0000:00
[ 0.385023] pci_bus 0000:00: root bus resource [io 0x0000-0x0cf7 window]
[ 0.385026] pci_bus 0000:00: root bus resource [io 0x0d00-0xffff window]
[ 0.385029] pci_bus 0000:00: root bus resource [mem 0x000a0000-0x000bffff window]
[ 0.385032] pci_bus 0000:00: root bus resource [mem 0x000c0000-0x000cffff window]
[ 0.385034] pci_bus 0000:00: root bus resource [mem 0x000d0000-0x000effff window]
[ 0.385036] pci_bus 0000:00: root bus resource [mem 0xd0000000-0xf7ffffff window]
[ 0.385038] pci_bus 0000:00: root bus resource [mem 0xfc000000-0xfed3ffff window]
[ 0.385040] pci_bus 0000:00: root bus resource [mem 0x450200000-0xfcffffffff window]
[ 0.385043] pci_bus 0000:00: root bus resource [bus 00-ff]
[ 0.385059] pci 0000:00:00.0: [1022:1630] type 00 class 0x060000
[ 0.385144] pci 0000:00:00.2: [1022:1631] type 00 class 0x080600
[ 0.385223] pci 0000:00:01.0: [1022:1632] type 00 class 0x060000
[ 0.385284] pci 0000:00:01.1: [1022:1633] type 01 class 0x060400
[ 0.385344] pci 0000:00:01.1: PME# supported from D0 D3hot D3cold
[ 0.385491] pci 0000:00:01.2: [1022:1634] type 01 class 0x060400
[ 0.385550] pci 0000:00:01.2: PME# supported from D0 D3hot D3cold
[ 0.385692] pci 0000:00:02.0: [1022:1632] type 00 class 0x060000
[ 0.385756] pci 0000:00:02.1: [1022:1634] type 01 class 0x060400
[ 0.385816] pci 0000:00:02.1: PME# supported from D0 D3hot D3cold
[ 0.385949] pci 0000:00:02.2: [1022:1634] type 01 class 0x060400
[ 0.386008] pci 0000:00:02.2: PME# supported from D0 D3hot D3cold
[ 0.386155] pci 0000:00:08.0: [1022:1632] type 00 class 0x060000
[ 0.386215] pci 0000:00:08.1: [1022:1635] type 01 class 0x060400
[ 0.386236] pci 0000:00:08.1: enabling Extended Tags
[ 0.386268] pci 0000:00:08.1: PME# supported from D0 D3hot D3cold
[ 0.386407] pci 0000:00:08.2: [1022:1635] type 01 class 0x060400
[ 0.386428] pci 0000:00:08.2: enabling Extended Tags
[ 0.386459] pci 0000:00:08.2: PME# supported from D0 D3hot D3cold
[ 0.386591] pci 0000:00:14.0: [1022:790b] type 00 class 0x0c0500
[ 0.386728] pci 0000:00:14.3: [1022:790e] type 00 class 0x060100
[ 0.386885] pci 0000:00:18.0: [1022:1448] type 00 class 0x060000
[ 0.386928] pci 0000:00:18.1: [1022:1449] type 00 class 0x060000
[ 0.386972] pci 0000:00:18.2: [1022:144a] type 00 class 0x060000
[ 0.387013] pci 0000:00:18.3: [1022:144b] type 00 class 0x060000
[ 0.387052] pci 0000:00:18.4: [1022:144c] type 00 class 0x060000
[ 0.387091] pci 0000:00:18.5: [1022:144d] type 00 class 0x060000
[ 0.387130] pci 0000:00:18.6: [1022:144e] type 00 class 0x060000
[ 0.387171] pci 0000:00:18.7: [1022:144f] type 00 class 0x060000
[ 0.387274] pci 0000:01:00.0: [10de:1f95] type 00 class 0x030000
[ 0.387285] pci 0000:01:00.0: reg 0x10: [mem 0xd0000000-0xd0ffffff]
[ 0.387295] pci 0000:01:00.0: reg 0x14: [mem 0xfcc0000000-0xfccfffffff 64bit pref]
[ 0.387304] pci 0000:01:00.0: reg 0x1c: [mem 0xfcd0000000-0xfcd1ffffff 64bit pref]
[ 0.387310] pci 0000:01:00.0: reg 0x24: [io 0x3000-0x307f]
[ 0.387316] pci 0000:01:00.0: reg 0x30: [mem 0xfff80000-0xffffffff pref]
[ 0.387375] pci 0000:01:00.0: PME# supported from D0 D3hot D3cold
[ 0.387450] pci 0000:01:00.0: 63.008 Gb/s available PCIe bandwidth, limited by 8.0 GT/s PCIe x8 link at 0000:00:01.1 (capable of 126.016 Gb/s with 8.0 GT/s PCIe x16 link)
[ 0.388166] pci 0000:01:00.1: [10de:10fa] type 00 class 0x040300
[ 0.388177] pci 0000:01:00.1: reg 0x10: [mem 0xd1000000-0xd1003fff]
[ 0.388311] pci 0000:00:01.1: PCI bridge to [bus 01]
[ 0.388315] pci 0000:00:01.1: bridge window [io 0x3000-0x3fff]
[ 0.388317] pci 0000:00:01.1: bridge window [mem 0xd0000000-0xd10fffff]
[ 0.388321] pci 0000:00:01.1: bridge window [mem 0xfcc0000000-0xfcd1ffffff 64bit pref]
[ 0.388625] pci 0000:02:00.0: [144d:a808] type 00 class 0x010802
[ 0.388642] pci 0000:02:00.0: reg 0x10: [mem 0xd1800000-0xd1803fff 64bit]
[ 0.389147] pci 0000:00:01.2: PCI bridge to [bus 02]
[ 0.389151] pci 0000:00:01.2: bridge window [mem 0xd1800000-0xd18fffff]
[ 0.389217] pci 0000:03:00.0: [10ec:8168] type 00 class 0x020000
[ 0.389235] pci 0000:03:00.0: reg 0x10: [io 0x2000-0x20ff]
[ 0.389257] pci 0000:03:00.0: reg 0x18: [mem 0xd1704000-0xd1704fff 64bit]
[ 0.389272] pci 0000:03:00.0: reg 0x20: [mem 0xd1700000-0xd1703fff 64bit]
[ 0.389362] pci 0000:03:00.0: supports D1 D2
[ 0.389363] pci 0000:03:00.0: PME# supported from D0 D1 D2 D3hot D3cold
[ 0.389573] pci 0000:00:02.1: PCI bridge to [bus 03]
[ 0.389577] pci 0000:00:02.1: bridge window [io 0x2000-0x2fff]
[ 0.389579] pci 0000:00:02.1: bridge window [mem 0xd1700000-0xd17fffff]
[ 0.389873] pci 0000:04:00.0: [8086:2723] type 00 class 0x028000
[ 0.389928] pci 0000:04:00.0: reg 0x10: [mem 0xd1600000-0xd1603fff 64bit]
[ 0.390099] pci 0000:04:00.0: PME# supported from D0 D3hot D3cold
[ 0.390721] pci 0000:00:02.2: PCI bridge to [bus 04]
[ 0.390725] pci 0000:00:02.2: bridge window [mem 0xd1600000-0xd16fffff]
[ 0.390826] pci 0000:05:00.0: [1002:1636] type 00 class 0x030000
[ 0.390837] pci 0000:05:00.0: reg 0x10: [mem 0xfce0000000-0xfcefffffff 64bit pref]
[ 0.390845] pci 0000:05:00.0: reg 0x18: [mem 0xfcf0000000-0xfcf01fffff 64bit pref]
[ 0.390851] pci 0000:05:00.0: reg 0x20: [io 0x1000-0x10ff]
[ 0.390857] pci 0000:05:00.0: reg 0x24: [mem 0xd1500000-0xd157ffff]
[ 0.390866] pci 0000:05:00.0: enabling Extended Tags
[ 0.390879] pci 0000:05:00.0: BAR 0: assigned to efifb
[ 0.390916] pci 0000:05:00.0: PME# supported from D1 D2 D3hot D3cold
[ 0.391047] pci 0000:05:00.2: [1022:15df] type 00 class 0x108000
[ 0.391060] pci 0000:05:00.2: reg 0x18: [mem 0xd1400000-0xd14fffff]
[ 0.391070] pci 0000:05:00.2: reg 0x24: [mem 0xd15c8000-0xd15c9fff]
[ 0.391078] pci 0000:05:00.2: enabling Extended Tags
[ 0.391187] pci 0000:05:00.3: [1022:1639] type 00 class 0x0c0330
[ 0.391198] pci 0000:05:00.3: reg 0x10: [mem 0xd1300000-0xd13fffff 64bit]
[ 0.391222] pci 0000:05:00.3: enabling Extended Tags
[ 0.391255] pci 0000:05:00.3: PME# supported from D0 D3hot D3cold
[ 0.391347] pci 0000:05:00.4: [1022:1639] type 00 class 0x0c0330
[ 0.391358] pci 0000:05:00.4: reg 0x10: [mem 0xd1200000-0xd12fffff 64bit]
[ 0.391382] pci 0000:05:00.4: enabling Extended Tags
[ 0.391414] pci 0000:05:00.4: PME# supported from D0 D3hot D3cold
[ 0.391513] pci 0000:05:00.5: [1022:15e2] type 00 class 0x048000
[ 0.391521] pci 0000:05:00.5: reg 0x10: [mem 0xd1580000-0xd15bffff]
[ 0.391542] pci 0000:05:00.5: enabling Extended Tags
[ 0.391572] pci 0000:05:00.5: PME# supported from D0 D3hot D3cold
[ 0.391659] pci 0000:05:00.6: [1022:15e3] type 00 class 0x040300
[ 0.391667] pci 0000:05:00.6: reg 0x10: [mem 0xd15c0000-0xd15c7fff]
[ 0.391688] pci 0000:05:00.6: enabling Extended Tags
[ 0.391718] pci 0000:05:00.6: PME# supported from D0 D3hot D3cold
[ 0.391831] pci 0000:00:08.1: PCI bridge to [bus 05]
[ 0.391834] pci 0000:00:08.1: bridge window [io 0x1000-0x1fff]
[ 0.391837] pci 0000:00:08.1: bridge window [mem 0xd1200000-0xd15fffff]
[ 0.391840] pci 0000:00:08.1: bridge window [mem 0xfce0000000-0xfcf01fffff 64bit pref]
[ 0.391899] pci 0000:06:00.0: [1022:7901] type 00 class 0x010601
[ 0.391928] pci 0000:06:00.0: reg 0x24: [mem 0xd1101000-0xd11017ff]
[ 0.391937] pci 0000:06:00.0: enabling Extended Tags
[ 0.392089] pci 0000:06:00.1: [1022:7901] type 00 class 0x010601
[ 0.392117] pci 0000:06:00.1: reg 0x24: [mem 0xd1100000-0xd11007ff]
[ 0.392125] pci 0000:06:00.1: enabling Extended Tags
[ 0.392246] pci 0000:00:08.2: PCI bridge to [bus 06]
[ 0.392250] pci 0000:00:08.2: bridge window [mem 0xd1100000-0xd11fffff]
[ 0.393412] ACPI: PCI: Interrupt link LNKA configured for IRQ 0
[ 0.393414] ACPI: PCI: Interrupt link LNKA disabled
[ 0.393524] ACPI: PCI: Interrupt link LNKB configured for IRQ 0
[ 0.393526] ACPI: PCI: Interrupt link LNKB disabled
[ 0.393613] ACPI: PCI: Interrupt link LNKC configured for IRQ 0
[ 0.393614] ACPI: PCI: Interrupt link LNKC disabled
[ 0.393723] ACPI: PCI: Interrupt link LNKD configured for IRQ 0
[ 0.393724] ACPI: PCI: Interrupt link LNKD disabled
[ 0.393954] ACPI: PCI: Interrupt link LNKE configured for IRQ 0
[ 0.393955] ACPI: PCI: Interrupt link LNKE disabled
[ 0.394036] ACPI: PCI: Interrupt link LNKF configured for IRQ 0
[ 0.394038] ACPI: PCI: Interrupt link LNKF disabled
[ 0.394122] ACPI: PCI: Interrupt link LNKG configured for IRQ 0
[ 0.394123] ACPI: PCI: Interrupt link LNKG disabled
[ 0.394204] ACPI: PCI: Interrupt link LNKH configured for IRQ 0
[ 0.394205] ACPI: PCI: Interrupt link LNKH disabled
[ 0.396078] ACPI: EC: interrupt unblocked
[ 0.396079] ACPI: EC: event unblocked
[ 0.397234] ACPI: EC: EC_CMD/EC_SC=0x66, EC_DATA=0x62
[ 0.397234] ACPI: EC: GPE=0x3
[ 0.397234] ACPI: \_SB_.PCI0.LPC0.EC0_: Boot DSDT EC initialization complete
[ 0.397234] ACPI: \_SB_.PCI0.LPC0.EC0_: EC: Used to handle transactions and events
[ 0.397258] iommu: Default domain type: Translated
[ 0.397258] iommu: DMA domain TLB invalidation policy: lazy mode
[ 0.397463] SCSI subsystem initialized
[ 0.397473] libata version 3.00 loaded.
[ 0.397473] ACPI: bus type USB registered
[ 0.397473] usbcore: registered new interface driver usbfs
[ 0.397473] usbcore: registered new interface driver hub
[ 0.397473] usbcore: registered new device driver usb
[ 0.404447] pps_core: LinuxPPS API ver. 1 registered
[ 0.404448] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it>
[ 0.404452] PTP clock support registered
[ 0.404462] EDAC MC: Ver: 3.0.0
[ 0.404984] efivars: Registered efivars operations
[ 0.404984] NetLabel: Initializing
[ 0.404984] NetLabel: domain hash size = 128
[ 0.404984] NetLabel: protocols = UNLABELED CIPSOv4 CALIPSO
[ 0.404984] NetLabel: unlabeled traffic allowed by default
[ 0.404984] mctp: management component transport protocol core
[ 0.404984] NET: Registered PF_MCTP protocol family
[ 0.404984] PCI: Using ACPI for IRQ routing
[ 0.405074] PCI: pci_cache_line_size set to 64 bytes
[ 0.406012] e820: reserve RAM buffer [mem 0x0009f000-0x0009ffff]
[ 0.406014] e820: reserve RAM buffer [mem 0x09b00000-0x0bffffff]
[ 0.406016] e820: reserve RAM buffer [mem 0x09f00000-0x0bffffff]
[ 0.406017] e820: reserve RAM buffer [mem 0xb528a000-0xb7ffffff]
[ 0.406019] e820: reserve RAM buffer [mem 0xb6640000-0xb7ffffff]
[ 0.406020] e820: reserve RAM buffer [mem 0xbab69000-0xbbffffff]
[ 0.406021] e820: reserve RAM buffer [mem 0xc9f7f000-0xcbffffff]
[ 0.406022] e820: reserve RAM buffer [mem 0xce000000-0xcfffffff]
[ 0.406024] e820: reserve RAM buffer [mem 0x40f340000-0x40fffffff]
[ 0.407273] pci 0000:01:00.0: vgaarb: setting as boot VGA device
[ 0.407273] pci 0000:01:00.0: vgaarb: bridge control possible
[ 0.407273] pci 0000:01:00.0: vgaarb: VGA device added: decodes=io+mem,owns=none,locks=none
[ 0.407273] pci 0000:05:00.0: vgaarb: setting as boot VGA device (overriding previous)
[ 0.407273] pci 0000:05:00.0: vgaarb: bridge control possible
[ 0.407273] pci 0000:05:00.0: vgaarb: VGA device added: decodes=io+mem,owns=none,locks=none
[ 0.407273] vgaarb: loaded
[ 0.407343] hpet0: at MMIO 0xfed00000, IRQs 2, 8, 0
[ 0.407348] hpet0: 3 comparators, 32-bit 14.318180 MHz counter
[ 0.410613] clocksource: Switched to clocksource tsc-early
[ 0.410613] VFS: Disk quotas dquot_6.6.0
[ 0.410613] VFS: Dquot-cache hash table entries: 512 (order 0, 4096 bytes)
[ 0.410613] AppArmor: AppArmor Filesystem Enabled
[ 0.410613] pnp: PnP ACPI init
[ 0.410613] system 00:00: [mem 0xfec00000-0xfec01fff] could not be reserved
[ 0.410613] system 00:00: [mem 0xfee00000-0xfee00fff] has been reserved
[ 0.410613] system 00:00: [mem 0xfde00000-0xfdefffff] has been reserved
[ 0.410613] system 00:03: [io 0x0400-0x04cf] has been reserved
[ 0.410613] system 00:03: [io 0x04d0-0x04d1] has been reserved
[ 0.410613] system 00:03: [io 0x04d6] has been reserved
[ 0.410613] system 00:03: [io 0x0c00-0x0c01] has been reserved
[ 0.410613] system 00:03: [io 0x0c14] has been reserved
[ 0.410613] system 00:03: [io 0x0c50-0x0c52] has been reserved
[ 0.410613] system 00:03: [io 0x0c6c] has been reserved
[ 0.410613] system 00:03: [io 0x0c6f] has been reserved
[ 0.410613] system 00:03: [io 0x0cd0-0x0cdb] has been reserved
[ 0.410613] system 00:04: [mem 0x000e0000-0x000fffff] could not be reserved
[ 0.410613] system 00:04: [mem 0xff000000-0xffffffff] has been reserved
[ 0.410613] pnp: PnP ACPI: found 5 devices
[ 0.419136] clocksource: acpi_pm: mask: 0xffffff max_cycles: 0xffffff, max_idle_ns: 2085701024 ns
[ 0.419301] NET: Registered PF_INET protocol family
[ 0.419499] IP idents hash table entries: 262144 (order: 9, 2097152 bytes, linear)
[ 0.422410] tcp_listen_portaddr_hash hash table entries: 8192 (order: 5, 131072 bytes, linear)
[ 0.422448] Table-perturb hash table entries: 65536 (order: 6, 262144 bytes, linear)
[ 0.422539] TCP established hash table entries: 131072 (order: 8, 1048576 bytes, linear)
[ 0.422865] TCP bind hash table entries: 65536 (order: 9, 2097152 bytes, linear)
[ 0.423026] TCP: Hash tables configured (established 131072 bind 65536)
[ 0.423175] MPTCP token hash table entries: 16384 (order: 6, 393216 bytes, linear)
[ 0.423247] UDP hash table entries: 8192 (order: 6, 262144 bytes, linear)
[ 0.423297] UDP-Lite hash table entries: 8192 (order: 6, 262144 bytes, linear)
[ 0.423396] NET: Registered PF_UNIX/PF_LOCAL protocol family
[ 0.423408] NET: Registered PF_XDP protocol family
[ 0.423413] pci 0000:01:00.0: can't claim BAR 6 [mem 0xfff80000-0xffffffff pref]: no compatible bridge window
[ 0.423433] pci 0000:01:00.0: BAR 6: assigned [mem 0xd1080000-0xd10fffff pref]
[ 0.423438] pci 0000:00:01.1: PCI bridge to [bus 01]
[ 0.423441] pci 0000:00:01.1: bridge window [io 0x3000-0x3fff]
[ 0.423445] pci 0000:00:01.1: bridge window [mem 0xd0000000-0xd10fffff]
[ 0.423449] pci 0000:00:01.1: bridge window [mem 0xfcc0000000-0xfcd1ffffff 64bit pref]
[ 0.423454] pci 0000:00:01.2: PCI bridge to [bus 02]
[ 0.423457] pci 0000:00:01.2: bridge window [mem 0xd1800000-0xd18fffff]
[ 0.423463] pci 0000:00:02.1: PCI bridge to [bus 03]
[ 0.423465] pci 0000:00:02.1: bridge window [io 0x2000-0x2fff]
[ 0.423469] pci 0000:00:02.1: bridge window [mem 0xd1700000-0xd17fffff]
[ 0.423483] pci 0000:00:02.2: PCI bridge to [bus 04]
[ 0.423553] pci 0000:00:02.2: bridge window [mem 0xd1600000-0xd16fffff]
[ 0.423560] pci 0000:00:08.1: PCI bridge to [bus 05]
[ 0.423563] pci 0000:00:08.1: bridge window [io 0x1000-0x1fff]
[ 0.423566] pci 0000:00:08.1: bridge window [mem 0xd1200000-0xd15fffff]
[ 0.423569] pci 0000:00:08.1: bridge window [mem 0xfce0000000-0xfcf01fffff 64bit pref]
[ 0.423574] pci 0000:00:08.2: PCI bridge to [bus 06]
[ 0.423578] pci 0000:00:08.2: bridge window [mem 0xd1100000-0xd11fffff]
[ 0.423585] pci_bus 0000:00: resource 4 [io 0x0000-0x0cf7 window]
[ 0.423588] pci_bus 0000:00: resource 5 [io 0x0d00-0xffff window]
[ 0.423590] pci_bus 0000:00: resource 6 [mem 0x000a0000-0x000bffff window]
[ 0.423593] pci_bus 0000:00: resource 7 [mem 0x000c0000-0x000cffff window]
[ 0.423595] pci_bus 0000:00: resource 8 [mem 0x000d0000-0x000effff window]
[ 0.423597] pci_bus 0000:00: resource 9 [mem 0xd0000000-0xf7ffffff window]
[ 0.423599] pci_bus 0000:00: resource 10 [mem 0xfc000000-0xfed3ffff window]
[ 0.423602] pci_bus 0000:00: resource 11 [mem 0x450200000-0xfcffffffff window]
[ 0.423604] pci_bus 0000:01: resource 0 [io 0x3000-0x3fff]
[ 0.423606] pci_bus 0000:01: resource 1 [mem 0xd0000000-0xd10fffff]
[ 0.423608] pci_bus 0000:01: resource 2 [mem 0xfcc0000000-0xfcd1ffffff 64bit pref]
[ 0.423611] pci_bus 0000:02: resource 1 [mem 0xd1800000-0xd18fffff]
[ 0.423614] pci_bus 0000:03: resource 0 [io 0x2000-0x2fff]
[ 0.423616] pci_bus 0000:03: resource 1 [mem 0xd1700000-0xd17fffff]
[ 0.423618] pci_bus 0000:04: resource 1 [mem 0xd1600000-0xd16fffff]
[ 0.423620] pci_bus 0000:05: resource 0 [io 0x1000-0x1fff]
[ 0.423622] pci_bus 0000:05: resource 1 [mem 0xd1200000-0xd15fffff]
[ 0.423624] pci_bus 0000:05: resource 2 [mem 0xfce0000000-0xfcf01fffff 64bit pref]
[ 0.423627] pci_bus 0000:06: resource 1 [mem 0xd1100000-0xd11fffff]
[ 0.429749] pci 0000:01:00.1: extending delay after power-on from D3hot to 20 msec
[ 0.429790] pci 0000:01:00.1: D0 power state depends on 0000:01:00.0
[ 0.430284] pci 0000:05:00.3: extending delay after power-on from D3hot to 20 msec
[ 0.452092] pci 0000:05:00.3: quirk_usb_early_handoff+0x0/0x7b0 took 21293 usecs
[ 0.452101] pci 0000:05:00.4: extending delay after power-on from D3hot to 20 msec
[ 0.500843] pci 0000:05:00.4: quirk_usb_early_handoff+0x0/0x7b0 took 47597 usecs
[ 0.500858] PCI: CLS 64 bytes, default 64
[ 0.500871] pci 0000:00:00.2: AMD-Vi: IOMMU performance counters supported
[ 0.500914] Trying to unpack rootfs image as initramfs...
[ 0.500942] pci 0000:00:01.0: Adding to iommu group 0
[ 0.500966] pci 0000:00:01.1: Adding to iommu group 1
[ 0.500985] pci 0000:00:01.2: Adding to iommu group 2
[ 0.501014] pci 0000:00:02.0: Adding to iommu group 3
[ 0.501034] pci 0000:00:02.1: Adding to iommu group 4
[ 0.501055] pci 0000:00:02.2: Adding to iommu group 5
[ 0.501099] pci 0000:00:08.0: Adding to iommu group 6
[ 0.501117] pci 0000:00:08.1: Adding to iommu group 6
[ 0.501135] pci 0000:00:08.2: Adding to iommu group 6
[ 0.501170] pci 0000:00:14.0: Adding to iommu group 7
[ 0.501193] pci 0000:00:14.3: Adding to iommu group 7
[ 0.501281] pci 0000:00:18.0: Adding to iommu group 8
[ 0.501300] pci 0000:00:18.1: Adding to iommu group 8
[ 0.501320] pci 0000:00:18.2: Adding to iommu group 8
[ 0.501342] pci 0000:00:18.3: Adding to iommu group 8
[ 0.501364] pci 0000:00:18.4: Adding to iommu group 8
[ 0.501383] pci 0000:00:18.5: Adding to iommu group 8
[ 0.501402] pci 0000:00:18.6: Adding to iommu group 8
[ 0.501422] pci 0000:00:18.7: Adding to iommu group 8
[ 0.501457] pci 0000:01:00.0: Adding to iommu group 9
[ 0.501479] pci 0000:01:00.1: Adding to iommu group 9
[ 0.501498] pci 0000:02:00.0: Adding to iommu group 10
[ 0.501518] pci 0000:03:00.0: Adding to iommu group 11
[ 0.501537] pci 0000:04:00.0: Adding to iommu group 12
[ 0.501555] pci 0000:05:00.0: Adding to iommu group 6
[ 0.501562] pci 0000:05:00.2: Adding to iommu group 6
[ 0.501569] pci 0000:05:00.3: Adding to iommu group 6
[ 0.501576] pci 0000:05:00.4: Adding to iommu group 6
[ 0.501582] pci 0000:05:00.5: Adding to iommu group 6
[ 0.501590] pci 0000:05:00.6: Adding to iommu group 6
[ 0.501597] pci 0000:06:00.0: Adding to iommu group 6
[ 0.501605] pci 0000:06:00.1: Adding to iommu group 6
[ 0.503680] pci 0000:00:00.2: AMD-Vi: Found IOMMU cap 0x40
[ 0.503687] AMD-Vi: Extended features (0x206d73ef22254ade, 0x0): PPR X2APIC NX GT IA GA PC GA_vAPIC
[ 0.503699] AMD-Vi: Interrupt remapping enabled
[ 0.503700] AMD-Vi: X2APIC enabled
[ 0.504126] AMD-Vi: Virtual APIC enabled
[ 0.504138] PCI-DMA: Using software bounce buffering for IO (SWIOTLB)
[ 0.504141] software IO TLB: mapped [mem 0x00000000c5065000-0x00000000c9065000] (64MB)
[ 0.504414] LVT offset 0 assigned for vector 0x400
[ 0.507896] perf: AMD IBS detected (0x000003ff)
[ 0.507925] perf/amd_iommu: Detected AMD IOMMU #0 (2 banks, 4 counters/bank).
[ 0.515977] Initialise system trusted keyrings
[ 0.515993] Key type blacklist registered
[ 0.516052] workingset: timestamp_bits=41 max_order=22 bucket_order=0
[ 0.516064] zbud: loaded
[ 0.516302] integrity: Platform Keyring initialized
[ 0.516305] integrity: Machine keyring initialized
[ 0.524884] Key type asymmetric registered
[ 0.524886] Asymmetric key parser 'x509' registered
[ 0.524908] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 242)
[ 0.524985] io scheduler mq-deadline registered
[ 0.524987] io scheduler kyber registered
[ 0.524998] io scheduler bfq registered
[ 0.527151] pcieport 0000:00:01.1: PME: Signaling with IRQ 28
[ 0.527289] pcieport 0000:00:01.2: PME: Signaling with IRQ 29
[ 0.527415] pcieport 0000:00:02.1: PME: Signaling with IRQ 30
[ 0.527534] pcieport 0000:00:02.2: PME: Signaling with IRQ 31
[ 0.527648] pcieport 0000:00:08.1: PME: Signaling with IRQ 32
[ 0.527847] pcieport 0000:00:08.2: PME: Signaling with IRQ 33
[ 0.527953] shpchp: Standard Hot Plug PCI Controller Driver version: 0.4
[ 0.529797] ACPI: AC: AC Adapter [ADP0] (off-line)
[ 0.529888] input: Lid Switch as /devices/LNXSYSTM:00/LNXSYBUS:00/PNP0C0D:00/input/input0
[ 0.529910] ACPI: button: Lid Switch [LID0]
[ 0.529940] input: Power Button as /devices/LNXSYSTM:00/LNXSYBUS:00/PNP0C0C:00/input/input1
[ 0.529960] ACPI: button: Power Button [PWRB]
[ 0.530000] input: Power Button as /devices/LNXSYSTM:00/LNXPWRBN:00/input/input2
[ 0.531606] ACPI: button: Power Button [PWRF]
[ 0.533040] Monitor-Mwait will be used to enter C-1 state
[ 0.533380] ACPI: \_SB_.PLTF.C000: Found 3 idle states
[ 0.533398] ACPI: FW issue: working around C-state latencies out of order
[ 0.535672] ACPI: \_SB_.PLTF.C001: Found 3 idle states
[ 0.535683] ACPI: FW issue: working around C-state latencies out of order
[ 0.536791] ACPI: \_SB_.PLTF.C002: Found 3 idle states
[ 0.536800] ACPI: FW issue: working around C-state latencies out of order
[ 0.536894] ACPI: \_SB_.PLTF.C003: Found 3 idle states
[ 0.536899] ACPI: FW issue: working around C-state latencies out of order
[ 0.537069] ACPI: \_SB_.PLTF.C004: Found 3 idle states
[ 0.537078] ACPI: FW issue: working around C-state latencies out of order
[ 0.537170] ACPI: \_SB_.PLTF.C005: Found 3 idle states
[ 0.537175] ACPI: FW issue: working around C-state latencies out of order
[ 0.537307] ACPI: \_SB_.PLTF.C006: Found 3 idle states
[ 0.537319] ACPI: FW issue: working around C-state latencies out of order
[ 0.537636] ACPI: \_SB_.PLTF.C007: Found 3 idle states
[ 0.537647] ACPI: FW issue: working around C-state latencies out of order
[ 0.537945] ACPI: \_SB_.PLTF.C008: Found 3 idle states
[ 0.537956] ACPI: FW issue: working around C-state latencies out of order
[ 0.538267] ACPI: \_SB_.PLTF.C009: Found 3 idle states
[ 0.538276] ACPI: FW issue: working around C-state latencies out of order
[ 0.538519] ACPI: \_SB_.PLTF.C00A: Found 3 idle states
[ 0.538524] ACPI: FW issue: working around C-state latencies out of order
[ 0.538668] ACPI: \_SB_.PLTF.C00B: Found 3 idle states
[ 0.538674] ACPI: FW issue: working around C-state latencies out of order
[ 0.539204] Serial: 8250/16550 driver, 32 ports, IRQ sharing enabled
[ 0.543076] Non-volatile memory driver v1.3
[ 0.543083] Linux agpgart interface v0.103
[ 0.557242] tpm_crb MSFT0101:00: Disabling hwrng
[ 0.558214] AMD-Vi: AMD IOMMUv2 loaded and initialized
[ 0.558298] ACPI: bus type drm_connector registered
[ 0.561936] ahci 0000:06:00.0: version 3.0
[ 0.562271] ahci 0000:06:00.0: AHCI 0001.0301 32 slots 1 ports 6 Gbps 0x1 impl SATA mode
[ 0.562281] ahci 0000:06:00.0: flags: 64bit ncq sntf ilck pm led clo only pmp fbs pio slum part
[ 0.562700] scsi host0: ahci
[ 0.562762] ata1: SATA max UDMA/133 abar m2048@0xd1101000 port 0xd1101100 irq 35
[ 0.562906] ahci 0000:06:00.1: AHCI 0001.0301 32 slots 1 ports 6 Gbps 0x1 impl SATA mode
[ 0.562909] ahci 0000:06:00.1: flags: 64bit ncq sntf ilck pm led clo only pmp fbs pio slum part
[ 0.563135] scsi host1: ahci
[ 0.563182] ata2: SATA max UDMA/133 abar m2048@0xd1100000 port 0xd1100100 irq 37
[ 0.563277] usbcore: registered new interface driver usbserial_generic
[ 0.563282] usbserial: USB Serial support registered for generic
[ 0.563418] rtc_cmos 00:01: RTC can wake from S4
[ 0.563678] rtc_cmos 00:01: registered as rtc0
[ 0.563705] rtc_cmos 00:01: setting system clock to 2024-07-04T21:24:18 UTC (1720128258)
[ 0.563734] rtc_cmos 00:01: alarms up to one month, 114 bytes nvram
[ 0.563779] amd_pstate: the _CPC object is not present in SBIOS or ACPI disabled
[ 0.563987] ledtrig-cpu: registered to indicate activity on CPUs
[ 0.564399] [drm] Initialized simpledrm 1.0.0 20200625 for simple-framebuffer.0 on minor 0
[ 0.565512] fbcon: Deferring console take-over
[ 0.565517] simple-framebuffer simple-framebuffer.0: [drm] fb0: simpledrmdrmfb frame buffer device
[ 0.565596] hid: raw HID events driver (C) Jiri Kosina
[ 0.565795] drop_monitor: Initializing network drop monitor service
[ 0.578613] Initializing XFRM netlink socket
[ 0.578659] NET: Registered PF_INET6 protocol family
[ 0.626089] Freeing initrd memory: 30232K
[ 0.634217] Segment Routing with IPv6
[ 0.634223] RPL Segment Routing with IPv6
[ 0.634250] In-situ OAM (IOAM) with IPv6
[ 0.634320] NET: Registered PF_PACKET protocol family
[ 0.636511] microcode: CPU3: patch_level=0x08600106
[ 0.636516] microcode: CPU2: patch_level=0x08600106
[ 0.636527] microcode: CPU0: patch_level=0x08600106
[ 0.636530] microcode: CPU5: patch_level=0x08600106
[ 0.636530] microcode: CPU4: patch_level=0x08600106
[ 0.636543] microcode: CPU6: patch_level=0x08600106
[ 0.636543] microcode: CPU7: patch_level=0x08600106
[ 0.636544] microcode: CPU9: patch_level=0x08600106
[ 0.636544] microcode: CPU8: patch_level=0x08600106
[ 0.636546] microcode: CPU11: patch_level=0x08600106
[ 0.636546] microcode: CPU10: patch_level=0x08600106
[ 0.636570] microcode: CPU1: patch_level=0x08600106
[ 0.636591] microcode: Microcode Update Driver: v2.2.
[ 0.636855] resctrl: L3 allocation detected
[ 0.636858] resctrl: MB allocation detected
[ 0.636859] resctrl: L3 monitoring detected
[ 0.636864] IPI shorthand broadcast: enabled
[ 0.639441] sched_clock: Marking stable (636829975, 369363)->(639143175, -1943837)
[ 0.639666] ACPI: battery: Slot [BAT0] (battery present)
[ 0.639703] registered taskstats version 1
[ 0.640296] Loading compiled-in X.509 certificates
[ 0.643117] Loaded X.509 cert 'Build time autogenerated kernel key: 84e8afd491dc3efc8f0a15bf4c506be3343b72d8'
[ 0.647627] zswap: loaded using pool zstd/zsmalloc
[ 0.651177] Key type .fscrypt registered
[ 0.651178] Key type fscrypt-provisioning registered
[ 0.651224] AppArmor: AppArmor sha1 policy hashing enabled
[ 0.652382] integrity: Loading X.509 certificate: UEFI:db
[ 0.652410] integrity: Loaded X.509 cert 'Microsoft Windows Production PCA 2011: a92902398e16c49778cd90f99e4f9ae17c55af53'
[ 0.652412] integrity: Loading X.509 certificate: UEFI:db
[ 0.652429] integrity: Loaded X.509 cert 'Microsoft Corporation UEFI CA 2011: 13adbf4309bd82709c8cd54f316ed522988a1bd4'
[ 0.652430] integrity: Loading X.509 certificate: UEFI:db
[ 0.652727] integrity: Loaded X.509 cert 'OK Certificate: c8c73a37546046ab495c33f4d0856052'
[ 0.652729] integrity: Loading X.509 certificate: UEFI:db
[ 0.652732] integrity: Problem loading X.509 certificate -65
[ 0.652734] integrity: Error adding keys to platform keyring UEFI:db
[ 0.652735] integrity: Loading X.509 certificate: UEFI:db
[ 0.652746] integrity: Loaded X.509 cert 'EUJinn: 2d9ec14a26c9fcae420ef406a6e9492b'
[ 0.656749] PM: Magic number: 0:908:448
[ 0.662645] RAS: Correctable Errors collector initialized.
[ 0.662738] clk: Disabling unused clocks
[ 1.167916] ata2: SATA link down (SStatus 0 SControl 300)
[ 1.332047] ata1: SATA link up 6.0 Gbps (SStatus 133 SControl 300)
[ 1.332572] ata1.00: ATA-10: WDC WD10SPSX-08A6W, 01.01A01, max UDMA/133
[ 1.334384] ata1.00: 1953525168 sectors, multi 16: LBA48 NCQ (depth 32), AA
[ 1.334398] ata1.00: Features: NCQ-prio
[ 1.337022] ata1.00: configured for UDMA/133
[ 1.349059] scsi 0:0:0:0: Direct-Access ATA WDC WD10SPSX-08A 1A01 PQ: 0 ANSI: 5
[ 1.349806] sd 0:0:0:0: [sda] 1953525168 512-byte logical blocks: (1.00 TB/932 GiB)
[ 1.349815] sd 0:0:0:0: [sda] 4096-byte physical blocks
[ 1.349838] sd 0:0:0:0: [sda] Write Protect is off
[ 1.349843] sd 0:0:0:0: [sda] Mode Sense: 00 3a 00 00
[ 1.349877] sd 0:0:0:0: [sda] Write cache: enabled, read cache: enabled, doesn't support DPO or FUA
[ 1.349923] sd 0:0:0:0: [sda] Preferred minimum I/O size 4096 bytes
[ 1.482052] sda: sda1 sda2 sda3
[ 1.482390] sd 0:0:0:0: [sda] Attached SCSI disk
[ 1.486007] Freeing unused decrypted memory: 2028K
[ 1.486583] Freeing unused kernel image (initmem) memory: 3436K
[ 1.486586] Write protecting the kernel read-only data: 30720k
[ 1.487058] clocksource: tsc: mask: 0xffffffffffffffff max_cycles: 0x2b29cd2227a, max_idle_ns: 440795226017 ns
[ 1.487107] clocksource: Switched to clocksource tsc
[ 1.487239] Freeing unused kernel image (rodata/data gap) memory: 1240K
[ 1.558633] x86/mm: Checked W+X mappings: passed, no W+X pages found.
[ 1.558638] rodata_test: all tests were successful
[ 1.558658] Run /init as init process
[ 1.558660] with arguments:
[ 1.558661] /init
[ 1.558663] with environment:
[ 1.558664] HOME=/
[ 1.558665] TERM=linux
[ 1.558667] BOOT_IMAGE=/boot/vmlinuz-6.6-x86_64
[ 1.809192] ACPI: video: [Firmware Bug]: ACPI(PEGP) defines _DOD but not _DOS
[ 1.809321] ACPI: video: Video Device [PEGP] (multi-head: yes rom: no post: no)
[ 1.810117] input: Video Bus as /devices/LNXSYSTM:00/LNXSYBUS:00/PNP0A08:00/device:00/LNXVIDEO:00/input/input3
[ 1.810244] i8042: PNP: PS/2 Controller [PNP0303:KBC0] at 0x60,0x64 irq 1
[ 1.810250] i8042: PNP: PS/2 appears to have AUX port disabled, if this is incorrect please boot with i8042.nopnp
[ 1.810290] ACPI: video: Video Device [VGA] (multi-head: yes rom: no post: no)
[ 1.810422] input: Video Bus as /devices/LNXSYSTM:00/LNXSYBUS:00/PNP0A08:00/device:0e/LNXVIDEO:01/input/input4
[ 1.811390] serio: i8042 KBD port at 0x60,0x64 irq 1
[ 1.834519] input: AT Translated Set 2 keyboard as /devices/platform/i8042/serio0/input/input5
[ 1.906289] xhci_hcd 0000:05:00.3: xHCI Host Controller
[ 1.906342] xhci_hcd 0000:05:00.3: new USB bus registered, assigned bus number 1
[ 1.906444] xhci_hcd 0000:05:00.3: hcc params 0x0268ffe5 hci version 0x110 quirks 0x0000020000000410
[ 1.907080] xhci_hcd 0000:05:00.3: xHCI Host Controller
[ 1.907087] xhci_hcd 0000:05:00.3: new USB bus registered, assigned bus number 2
[ 1.907092] xhci_hcd 0000:05:00.3: Host supports USB 3.1 Enhanced SuperSpeed
[ 1.907159] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 6.06
[ 1.907163] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 1.907167] usb usb1: Product: xHCI Host Controller
[ 1.907169] usb usb1: Manufacturer: Linux 6.6.34-1-MANJARO xhci-hcd
[ 1.907172] usb usb1: SerialNumber: 0000:05:00.3
[ 1.907416] hub 1-0:1.0: USB hub found
[ 1.907435] hub 1-0:1.0: 4 ports detected
[ 1.907917] usb usb2: We don't know the algorithms for LPM for this host, disabling LPM.
[ 1.907959] usb usb2: New USB device found, idVendor=1d6b, idProduct=0003, bcdDevice= 6.06
[ 1.907963] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 1.907966] usb usb2: Product: xHCI Host Controller
[ 1.907969] usb usb2: Manufacturer: Linux 6.6.34-1-MANJARO xhci-hcd
[ 1.907972] usb usb2: SerialNumber: 0000:05:00.3
[ 1.908170] hub 2-0:1.0: USB hub found
[ 1.908187] hub 2-0:1.0: 2 ports detected
[ 1.908583] xhci_hcd 0000:05:00.4: xHCI Host Controller
[ 1.908591] xhci_hcd 0000:05:00.4: new USB bus registered, assigned bus number 3
[ 1.908685] xhci_hcd 0000:05:00.4: hcc params 0x0268ffe5 hci version 0x110 quirks 0x0000020000000410
[ 1.909258] xhci_hcd 0000:05:00.4: xHCI Host Controller
[ 1.909264] xhci_hcd 0000:05:00.4: new USB bus registered, assigned bus number 4
[ 1.909268] xhci_hcd 0000:05:00.4: Host supports USB 3.1 Enhanced SuperSpeed
[ 1.909334] usb usb3: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 6.06
[ 1.909339] usb usb3: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 1.909343] usb usb3: Product: xHCI Host Controller
[ 1.909346] usb usb3: Manufacturer: Linux 6.6.34-1-MANJARO xhci-hcd
[ 1.909349] usb usb3: SerialNumber: 0000:05:00.4
[ 1.909583] hub 3-0:1.0: USB hub found
[ 1.909603] hub 3-0:1.0: 4 ports detected
[ 1.910027] usb usb4: We don't know the algorithms for LPM for this host, disabling LPM.
[ 1.910080] usb usb4: New USB device found, idVendor=1d6b, idProduct=0003, bcdDevice= 6.06
[ 1.910084] usb usb4: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 1.910087] usb usb4: Product: xHCI Host Controller
[ 1.910090] usb usb4: Manufacturer: Linux 6.6.34-1-MANJARO xhci-hcd
[ 1.910092] usb usb4: SerialNumber: 0000:05:00.4
[ 1.910271] hub 4-0:1.0: USB hub found
[ 1.910290] hub 4-0:1.0: 2 ports detected
[ 1.923964] nvme 0000:02:00.0: platform quirk: setting simple suspend
[ 1.924141] nvme nvme0: pci function 0000:02:00.0
[ 1.930951] nvme nvme0: missing or invalid SUBNQN field.
[ 1.931180] nvme nvme0: Shutdown timeout set to 8 seconds
[ 1.949125] nvme nvme0: 16/0/0 default/read/poll queues
[ 1.955233] nvme0n1: p1 p2 p3 p4 p5 p6 p7
[ 2.157328] usb 1-3: new high-speed USB device number 2 using xhci_hcd
[ 2.160821] usb 3-1: new high-speed USB device number 2 using xhci_hcd
[ 2.305700] usb 3-1: New USB device found, idVendor=05e3, idProduct=0610, bcdDevice=23.07
[ 2.305712] usb 3-1: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[ 2.305718] usb 3-1: Product: USB2.1 Hub
[ 2.305723] usb 3-1: Manufacturer: GenesysLogic
[ 2.309397] usb 1-3: New USB device found, idVendor=5986, idProduct=212b, bcdDevice=56.14
[ 2.309407] usb 1-3: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[ 2.309413] usb 1-3: Product: Integrated Camera
[ 2.309417] usb 1-3: Manufacturer: SunplusIT Inc
[ 2.358832] hub 3-1:1.0: USB hub found
[ 2.359319] hub 3-1:1.0: 2 ports detected
[ 2.425025] usb 4-1: new SuperSpeed USB device number 2 using xhci_hcd
[ 2.443286] usb 4-1: New USB device found, idVendor=05e3, idProduct=0620, bcdDevice=23.07
[ 2.443299] usb 4-1: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[ 2.443305] usb 4-1: Product: USB3.2 Hub
[ 2.443310] usb 4-1: Manufacturer: GenesysLogic
[ 2.469829] hub 4-1:1.0: USB hub found
[ 2.470122] hub 4-1:1.0: 2 ports detected
[ 2.563748] usb 3-3: new full-speed USB device number 3 using xhci_hcd
[ 2.731588] usb 3-3: New USB device found, idVendor=8087, idProduct=0029, bcdDevice= 0.01
[ 2.731599] usb 3-3: New USB device strings: Mfr=0, Product=0, SerialNumber=0
[ 2.860650] usb 3-4: new full-speed USB device number 4 using xhci_hcd
[ 3.044571] usb 3-4: New USB device found, idVendor=048d, idProduct=c100, bcdDevice=10.00
[ 3.044582] usb 3-4: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[ 3.044588] usb 3-4: Product: ITE Device(8910)
[ 3.044593] usb 3-4: Manufacturer: ITE Tech. Inc.
[ 5.082195] [drm] amdgpu kernel modesetting enabled.
[ 5.082241] amdgpu: vga_switcheroo: detected switching method \_SB_.PCI0.GP17.VGA_.ATPX handle
[ 5.083211] amdgpu: ATPX version 1, functions 0x00000001
[ 5.083329] amdgpu: ATPX Hybrid Graphics
[ 5.085784] input: ITE Tech. Inc. ITE Device(8910) Keyboard as /devices/pci0000:00/0000:00:08.1/0000:05:00.4/usb3/3-4/3-4:1.0/0003:048D:C100.0001/input/input6
[ 5.090136] amdgpu: Virtual CRAT table created for CPU
[ 5.090163] amdgpu: Topology: Add CPU node
[ 5.090442] amdgpu 0000:05:00.0: enabling device (0006 -> 0007)
[ 5.090526] [drm] initializing kernel modesetting (RENOIR 0x1002:0x1636 0x17AA:0x3A3E 0xC7).
[ 5.141066] input: ITE Tech. Inc. ITE Device(8910) Wireless Radio Control as /devices/pci0000:00/0000:00:08.1/0000:05:00.4/usb3/3-4/3-4:1.0/0003:048D:C100.0001/input/input7
[ 5.141550] hid-generic 0003:048D:C100.0001: input,hiddev96,hidraw0: USB HID v1.10 Keyboard [ITE Tech. Inc. ITE Device(8910)] on usb-0000:05:00.4-4/input0
[ 5.141662] usbcore: registered new interface driver usbhid
[ 5.141667] usbhid: USB HID core driver
[ 5.184392] [drm] register mmio base: 0xD1500000
[ 5.184403] [drm] register mmio size: 524288
[ 5.188466] [drm] add ip block number 0 <soc15_common>
[ 5.188470] [drm] add ip block number 1 <gmc_v9_0>
[ 5.188473] [drm] add ip block number 2 <vega10_ih>
[ 5.188476] [drm] add ip block number 3 <psp>
[ 5.188478] [drm] add ip block number 4 <smu>
[ 5.188482] [drm] add ip block number 5 <dm>
[ 5.188484] [drm] add ip block number 6 <gfx_v9_0>
[ 5.188487] [drm] add ip block number 7 <sdma_v4_0>
[ 5.188489] [drm] add ip block number 8 <vcn_v2_0>
[ 5.188492] [drm] add ip block number 9 <jpeg_v2_0>
[ 5.188534] amdgpu 0000:05:00.0: amdgpu: Fetched VBIOS from VFCT
[ 5.188539] amdgpu: ATOM BIOS: 113-RENOIR-026
[ 5.193305] [drm] VCN decode is enabled in VM mode
[ 5.193308] [drm] VCN encode is enabled in VM mode
[ 5.195756] [drm] JPEG decode is enabled in VM mode
[ 5.241869] amdgpu 0000:05:00.0: vgaarb: deactivate vga console
[ 5.241886] amdgpu 0000:05:00.0: amdgpu: Trusted Memory Zone (TMZ) feature enabled
[ 5.241896] amdgpu 0000:05:00.0: amdgpu: MODE2 reset
[ 5.242583] [drm] vm size is 262144 GB, 4 levels, block size is 9-bit, fragment size is 9-bit
[ 5.242594] amdgpu 0000:05:00.0: amdgpu: VRAM: 512M 0x000000F400000000 - 0x000000F41FFFFFFF (512M used)
[ 5.242599] amdgpu 0000:05:00.0: amdgpu: GART: 1024M 0x0000000000000000 - 0x000000003FFFFFFF
[ 5.242602] amdgpu 0000:05:00.0: amdgpu: AGP: 267419648M 0x000000F800000000 - 0x0000FFFFFFFFFFFF
[ 5.242611] [drm] Detected VRAM RAM=512M, BAR=512M
[ 5.242614] [drm] RAM width 128bits DDR4
[ 5.242850] [drm] amdgpu: 512M of VRAM memory ready
[ 5.242853] [drm] amdgpu: 7679M of GTT memory ready.
[ 5.242882] [drm] GART: num cpu pages 262144, num gpu pages 262144
[ 5.243066] [drm] PCIE GART of 1024M enabled.
[ 5.243068] [drm] PTB located at 0x000000F41FC00000
[ 5.243519] [drm] Loading DMUB firmware via PSP: version=0x01010028
[ 5.244445] [drm] Found VCN firmware Version ENC: 1.22 DEC: 7 VEP: 0 Revision: 1
[ 5.244459] amdgpu 0000:05:00.0: amdgpu: Will use PSP to load VCN firmware
[ 5.942970] [drm] reserve 0x400000 from 0xf41f800000 for PSP TMR
[ 6.039953] amdgpu 0000:05:00.0: amdgpu: RAS: optional ras ta ucode is not available
[ 6.049743] amdgpu 0000:05:00.0: amdgpu: RAP: optional rap ta ucode is not available
[ 6.054903] [drm] psp gfx command LOAD_TA(0x1) failed and response status is (0x7)
[ 6.055024] [drm] psp gfx command INVOKE_CMD(0x3) failed and response status is (0x4)
[ 6.055029] amdgpu 0000:05:00.0: amdgpu: Secure display: Generic Failure.
[ 6.055033] amdgpu 0000:05:00.0: amdgpu: SECUREDISPLAY: query securedisplay TA failed. ret 0x0
[ 6.055250] amdgpu 0000:05:00.0: amdgpu: SMU is initialized successfully!
[ 6.056193] [drm] Display Core v3.2.247 initialized on DCN 2.1
[ 6.056198] [drm] DP-HDMI FRL PCON supported
[ 6.056986] [drm] DMUB hardware initialized: version=0x01010028
[ 6.167829] [drm] kiq ring mec 2 pipe 1 q 0
[ 6.170495] [drm] VCN decode and encode initialized successfully(under DPG Mode).
[ 6.170524] [drm] JPEG decode initialized successfully.
[ 6.208264] amdgpu: HMM registered 512MB device memory
[ 6.211354] kfd kfd: amdgpu: Allocated 3969056 bytes on gart
[ 6.211392] kfd kfd: amdgpu: Total number of KFD nodes to be created: 1
[ 6.211553] amdgpu: Virtual CRAT table created for GPU
[ 6.211696] amdgpu: Topology: Add dGPU node [0x1636:0x1002]
[ 6.211700] kfd kfd: amdgpu: added device 1002:1636
[ 6.211717] amdgpu 0000:05:00.0: amdgpu: SE 1, SH per SE 1, CU per SH 8, active_cu_number 6
[ 6.212425] amdgpu 0000:05:00.0: amdgpu: ring gfx uses VM inv eng 0 on hub 0
[ 6.212429] amdgpu 0000:05:00.0: amdgpu: ring gfx_low uses VM inv eng 1 on hub 0
[ 6.212432] amdgpu 0000:05:00.0: amdgpu: ring gfx_high uses VM inv eng 4 on hub 0
[ 6.212435] amdgpu 0000:05:00.0: amdgpu: ring comp_1.0.0 uses VM inv eng 5 on hub 0
[ 6.212438] amdgpu 0000:05:00.0: amdgpu: ring comp_1.1.0 uses VM inv eng 6 on hub 0
[ 6.212440] amdgpu 0000:05:00.0: amdgpu: ring comp_1.2.0 uses VM inv eng 7 on hub 0
[ 6.212443] amdgpu 0000:05:00.0: amdgpu: ring comp_1.3.0 uses VM inv eng 8 on hub 0
[ 6.212446] amdgpu 0000:05:00.0: amdgpu: ring comp_1.0.1 uses VM inv eng 9 on hub 0
[ 6.212449] amdgpu 0000:05:00.0: amdgpu: ring comp_1.1.1 uses VM inv eng 10 on hub 0
[ 6.212451] amdgpu 0000:05:00.0: amdgpu: ring comp_1.2.1 uses VM inv eng 11 on hub 0
[ 6.212454] amdgpu 0000:05:00.0: amdgpu: ring comp_1.3.1 uses VM inv eng 12 on hub 0
[ 6.212457] amdgpu 0000:05:00.0: amdgpu: ring kiq_0.2.1.0 uses VM inv eng 13 on hub 0
[ 6.212460] amdgpu 0000:05:00.0: amdgpu: ring sdma0 uses VM inv eng 0 on hub 8
[ 6.212463] amdgpu 0000:05:00.0: amdgpu: ring vcn_dec uses VM inv eng 1 on hub 8
[ 6.212465] amdgpu 0000:05:00.0: amdgpu: ring vcn_enc0 uses VM inv eng 4 on hub 8
[ 6.212468] amdgpu 0000:05:00.0: amdgpu: ring vcn_enc1 uses VM inv eng 5 on hub 8
[ 6.212471] amdgpu 0000:05:00.0: amdgpu: ring jpeg_dec uses VM inv eng 6 on hub 8
[ 6.306482] [drm] Initialized amdgpu 3.54.0 20150101 for 0000:05:00.0 on minor 1
[ 6.313513] fbcon: amdgpudrmfb (fb0) is primary device
[ 6.313516] fbcon: Deferring console take-over
[ 6.313522] amdgpu 0000:05:00.0: [drm] fb0: amdgpudrmfb frame buffer device
[ 6.398829] fbcon: Taking over console
[ 6.399458] [drm] DSC precompute is not needed.
[ 6.409906] Console: switching to colour frame buffer device 240x67
[ 6.690700] EXT4-fs (nvme0n1p5): mounted filesystem b395b351-d6f7-40f1-88ff-43ee89d7e608 r/w with ordered data mode. Quota mode: none.
[ 6.755168] systemd[1]: RTC configured in localtime, applying delta of 180 minutes to system time.
[ 6.809608] systemd[1]: systemd 256.1-1-arch-g34ba18b^ running in system mode (+PAM +AUDIT -SELINUX -APPARMOR -IMA +SMACK +SECCOMP +GCRYPT +GNUTLS +OPENSSL +ACL +BLKID +CURL +ELFUTILS +FIDO2 +IDN2 -IDN +IPTC +KMOD +LIBCRYPTSETUP +LIBCRYPTSETUP_PLUGINS +LIBFDISK +PCRE2 +PWQUALITY +P11KIT +QRENCODE +TPM2 +BZIP2 +LZ4 +XZ +ZLIB +ZSTD +BPF_FRAMEWORK +XKBCOMMON +UTMP -SYSVINIT +LIBARCHIVE)
[ 6.809622] systemd[1]: Detected architecture x86-64.
[ 6.810813] systemd[1]: Hostname set to <Yamo-Legion5>.
[ 6.845882] systemd[1]: memfd_create() called without MFD_EXEC or MFD_NOEXEC_SEAL set
[ 7.400795] systemd[1]: bpf-restrict-fs: LSM BPF program attached
[ 7.695759] systemd[1]: Queued start job for default target Graphical Interface.
[ 7.753598] systemd[1]: Created slice Slice /system/dirmngr.
[ 7.754235] systemd[1]: Created slice Slice /system/getty.
[ 7.754771] systemd[1]: Created slice Slice /system/gpg-agent.
[ 7.755311] systemd[1]: Created slice Slice /system/gpg-agent-browser.
[ 7.755848] systemd[1]: Created slice Slice /system/gpg-agent-extra.
[ 7.756380] systemd[1]: Created slice Slice /system/gpg-agent-ssh.
[ 7.756913] systemd[1]: Created slice Slice /system/keyboxd.
[ 7.757470] systemd[1]: Created slice Slice /system/modprobe.
[ 7.758021] systemd[1]: Created slice Slice /system/systemd-fsck.
[ 7.758418] systemd[1]: Created slice User and Session Slice.
[ 7.758524] systemd[1]: Started Dispatch Password Requests to Console Directory Watch.
[ 7.758605] systemd[1]: Started Forward Password Requests to Wall Directory Watch.
[ 7.758895] systemd[1]: Set up automount Arbitrary Executable File Formats File System Automount Point.
[ 7.758923] systemd[1]: Expecting device /dev/disk/by-diskseq/2-part6...
[ 7.758935] systemd[1]: Expecting device /dev/disk/by-uuid/0C75-E2CB...
[ 7.758948] systemd[1]: Expecting device /dev/nvme0n1p3...
[ 7.758960] systemd[1]: Expecting device /dev/nvme0n1p7...
[ 7.758969] systemd[1]: Expecting device /dev/sda2...
[ 7.758978] systemd[1]: Expecting device /dev/sda3...
[ 7.758995] systemd[1]: Reached target Local Encrypted Volumes.
[ 7.759015] systemd[1]: Reached target Login Prompts.
[ 7.759035] systemd[1]: Reached target Local Integrity Protected Volumes.
[ 7.759073] systemd[1]: Reached target Remote File Systems.
[ 7.759088] systemd[1]: Reached target Slice Units.
[ 7.759110] systemd[1]: Reached target Mounting snaps.
[ 7.759152] systemd[1]: Reached target Local Verity Protected Volumes.
[ 7.759287] systemd[1]: Listening on Device-mapper event daemon FIFOs.
[ 7.759422] systemd[1]: Listening on LVM2 poll daemon socket.
[ 7.762358] systemd[1]: Listening on Process Core Dump Socket.
[ 7.763513] systemd[1]: Listening on Credential Encryption/Decryption.
[ 7.763646] systemd[1]: Listening on Journal Socket (/dev/log).
[ 7.763782] systemd[1]: Listening on Journal Sockets.
[ 7.763946] systemd[1]: Listening on Network Service Netlink Socket.
[ 7.763993] systemd[1]: TPM PCR Measurements was skipped because of an unmet condition check (ConditionSecurity=measured-uki).
[ 7.764014] systemd[1]: Make TPM PCR Policy was skipped because of an unmet condition check (ConditionSecurity=measured-uki).
[ 7.764128] systemd[1]: Listening on udev Control Socket.
[ 7.764208] systemd[1]: Listening on udev Kernel Socket.
[ 7.765749] systemd[1]: Mounting Huge Pages File System...
[ 7.766783] systemd[1]: Mounting POSIX Message Queue File System...
[ 7.767884] systemd[1]: Mounting Kernel Debug File System...
[ 7.768953] systemd[1]: Mounting Kernel Trace File System...
[ 7.770572] systemd[1]: Starting Load AppArmor profiles...
[ 7.772113] systemd[1]: Starting Create List of Static Device Nodes...
[ 7.773845] systemd[1]: Starting Monitoring of LVM2 mirrors, snapshots etc. using dmeventd or progress polling...
[ 7.775653] systemd[1]: Starting Load Kernel Module configfs...
[ 7.777592] systemd[1]: Starting Load Kernel Module dm_mod...
[ 7.779381] systemd[1]: Starting Load Kernel Module drm...
[ 7.781257] systemd[1]: Starting Load Kernel Module fuse...
[ 7.783024] systemd[1]: Starting Load Kernel Module loop...
[ 7.783162] systemd[1]: File System Check on Root Device was skipped because of an unmet condition check (ConditionPathIsReadWrite=!/).
[ 7.783219] systemd[1]: Clear Stale Hibernate Storage Info was skipped because of an unmet condition check (ConditionPathExists=/sys/firmware/efi/efivars/HibernateLocation-8cf2644b-4b0b-428f-9387-6d876050dc67).
[ 7.785527] systemd[1]: Starting Load Kernel Modules...
[ 7.787405] systemd[1]: Starting Generate network units from Kernel command line...
[ 7.787485] systemd[1]: TPM PCR Machine ID Measurement was skipped because of an unmet condition check (ConditionSecurity=measured-uki).
[ 7.789294] systemd[1]: Starting Remount Root and Kernel File Systems...
[ 7.789416] systemd[1]: Early TPM SRK Setup was skipped because of an unmet condition check (ConditionSecurity=measured-uki).
[ 7.791443] systemd[1]: Starting Load udev Rules from Credentials...
[ 7.793182] systemd[1]: Starting Coldplug All udev Devices...
[ 7.797135] systemd[1]: Mounted Huge Pages File System.
[ 7.797363] systemd[1]: Mounted POSIX Message Queue File System.
[ 7.797516] systemd[1]: Mounted Kernel Debug File System.
[ 7.798345] systemd[1]: Mounted Kernel Trace File System.
[ 7.807791] device-mapper: uevent: version 1.0.3
[ 7.807845] loop: module loaded
[ 7.808084] device-mapper: ioctl: 4.48.0-ioctl (2023-03-01) initialised: dm-devel@redhat.com
[ 7.812592] fuse: init (API version 7.39)
[ 7.827129] sd 0:0:0:0: Attached scsi generic sg0 type 0
[ 7.836423] i2c_dev: i2c /dev entries driver
[ 7.838892] acpi_call: loading out-of-tree module taints kernel.
[ 7.838902] acpi_call: module verification failed: signature and/or required key missing - tainting kernel
[ 7.841192] systemd[1]: Finished Create List of Static Device Nodes.
[ 7.843129] systemd[1]: modprobe@configfs.service: Deactivated successfully.
[ 7.857850] EXT4-fs (nvme0n1p5): re-mounted b395b351-d6f7-40f1-88ff-43ee89d7e608 r/w. Quota mode: none.
[ 7.864606] audit: type=1400 audit(1720117465.798:2): apparmor="STATUS" operation="profile_load" profile="unconfined" name="lsb_release" pid=392 comm="apparmor_parser"
[ 7.865642] audit: type=1400 audit(1720117465.798:3): apparmor="STATUS" operation="profile_load" profile="unconfined" name="nvidia_modprobe" pid=395 comm="apparmor_parser"
[ 7.866420] audit: type=1400 audit(1720117465.798:4): apparmor="STATUS" operation="profile_load" profile="unconfined" name="nvidia_modprobe//kmod" pid=395 comm="apparmor_parser"
[ 7.877079] audit: type=1400 audit(1720117465.808:5): apparmor="STATUS" operation="profile_load" profile="unconfined" name="ping" pid=391 comm="apparmor_parser"
[ 7.883501] audit: type=1400 audit(1720117465.814:6): apparmor="STATUS" operation="profile_load" profile="unconfined" name="samba-rpcd" pid=400 comm="apparmor_parser"
[ 7.884568] audit: type=1400 audit(1720117465.818:7): apparmor="STATUS" operation="profile_load" profile="unconfined" name="samba-rpcd-classic" pid=402 comm="apparmor_parser"
[ 7.891869] audit: type=1400 audit(1720117465.824:8): apparmor="STATUS" operation="profile_load" profile="unconfined" name="samba-rpcd-spoolss" pid=403 comm="apparmor_parser"
[ 7.893275] audit: type=1400 audit(1720117465.824:9): apparmor="STATUS" operation="profile_load" profile="unconfined" name="klogd" pid=404 comm="apparmor_parser"
[ 7.895481] audit: type=1400 audit(1720117465.828:10): apparmor="STATUS" operation="profile_load" profile="unconfined" name="php-fpm" pid=396 comm="apparmor_parser"
[ 7.896073] audit: type=1400 audit(1720117465.828:11): apparmor="STATUS" operation="profile_load" profile="unconfined" name="samba-dcerpcd" pid=399 comm="apparmor_parser"
[ 7.903888] systemd[1]: Finished Load Kernel Module configfs.
[ 7.906120] systemd[1]: modprobe@dm_mod.service: Deactivated successfully.
[ 7.974477] systemd[1]: Finished Load Kernel Module dm_mod.
[ 8.034716] systemd[1]: Finished Monitoring of LVM2 mirrors, snapshots etc. using dmeventd or progress polling.
[ 8.035426] systemd[1]: modprobe@drm.service: Deactivated successfully.
[ 8.124587] systemd[1]: Finished Load Kernel Module drm.
[ 8.125307] systemd[1]: modprobe@fuse.service: Deactivated successfully.
[ 8.181449] systemd[1]: Finished Load Kernel Module fuse.
[ 8.182208] systemd[1]: modprobe@loop.service: Deactivated successfully.
[ 8.240948] systemd[1]: Finished Load Kernel Module loop.
[ 8.298290] systemd[1]: Finished Generate network units from Kernel command line.
[ 8.337899] systemd[1]: Finished Remount Root and Kernel File Systems.
[ 8.371079] systemd[1]: Finished Load AppArmor profiles.
[ 8.390970] systemd[1]: Finished Load udev Rules from Credentials.
[ 8.414183] systemd[1]: Finished Coldplug All udev Devices.
[ 8.414881] systemd[1]: Reached target Preparation for Network.
[ 8.416429] systemd[1]: Mounting FUSE Control File System...
[ 8.417620] systemd[1]: Mounting Kernel Configuration File System...
[ 8.418250] systemd[1]: Rebuild Hardware Database was skipped because no trigger condition checks were met.
[ 8.419928] systemd[1]: Starting Load/Save OS Random Seed...
[ 8.420015] systemd[1]: Repartition Root Disk was skipped because no trigger condition checks were met.
[ 8.421386] systemd[1]: Starting Create Static Device Nodes in /dev gracefully...
[ 8.421412] systemd[1]: TPM SRK Setup was skipped because of an unmet condition check (ConditionSecurity=measured-uki).
[ 8.448220] systemd[1]: Mounted FUSE Control File System.
[ 8.448385] systemd[1]: Mounted Kernel Configuration File System.
[ 8.497688] systemd[1]: Finished Load/Save OS Random Seed.
[ 8.544184] systemd[1]: Finished Create Static Device Nodes in /dev gracefully.
[ 8.546394] systemd[1]: Starting Create System Users...
[ 8.650807] systemd[1]: Finished Create System Users.
[ 8.652836] systemd[1]: Starting Create Static Device Nodes in /dev...
[ 8.764353] systemd[1]: Finished Create Static Device Nodes in /dev.
[ 8.764669] systemd[1]: Reached target Preparation for Local File Systems.
[ 8.764984] systemd[1]: Entropy Daemon based on the HAVEGE algorithm was skipped because of an unmet condition check (ConditionKernelVersion=<5.6).
[ 8.768327] systemd[1]: Starting Journal Service...
[ 8.769842] systemd[1]: Starting Rule-based Manager for Device Events and Files...
[ 8.795933] systemd[1]: Virtual Machine and Container Storage (Compatibility) was skipped because of an unmet condition check (ConditionPathExists=/var/lib/machines.raw).
[ 8.832629] systemd[1]: Mounting Mount unit for android-file-transfer-linux, revision 199...
[ 8.834848] systemd[1]: Mounting Mount unit for bare, revision 5...
[ 8.836873] systemd[1]: Mounting Mount unit for core, revision 16928...
[ 8.839148] systemd[1]: Mounting Mount unit for core, revision 17200...
[ 8.841295] systemd[1]: Mounting Mount unit for core18, revision 2823...
[ 8.842648] loop0: detected capacity change from 0 to 214984
[ 8.843609] systemd[1]: Mounting Mount unit for core18, revision 2829...
[ 8.844441] loop1: detected capacity change from 0 to 8
[ 8.846260] systemd[1]: Mounting Mount unit for core20, revision 2264...
[ 8.847761] loop2: detected capacity change from 0 to 212976
[ 8.848654] systemd[1]: Mounting Mount unit for core20, revision 2318...
[ 8.849993] systemd-journald[457]: Collecting audit messages is disabled.
[ 8.850829] loop3: detected capacity change from 0 to 213384
[ 8.851478] systemd[1]: Mounting Mount unit for gnome-3-28-1804, revision 194...
[ 8.852668] loop4: detected capacity change from 0 to 113992
[ 8.853607] systemd[1]: Mounting Mount unit for gnome-3-28-1804, revision 198...
[ 8.856367] loop5: detected capacity change from 0 to 113992
[ 8.857297] systemd[1]: Mounting Mount unit for gtk-common-themes, revision 1534...
[ 8.857614] squashfs: version 4.0 (2009/01/31) Phillip Lougher
[ 8.858784] loop6: detected capacity change from 0 to 130960
[ 8.860041] systemd[1]: Mounting Mount unit for gtk-common-themes, revision 1535...
[ 8.861622] loop7: detected capacity change from 0 to 130960
[ 8.862918] systemd[1]: Mounting Mount unit for playlist-dl, revision 12...
[ 8.864065] loop8: detected capacity change from 0 to 337560
[ 8.865030] systemd[1]: Mounting Mount unit for playlist-dl, revision 13...
[ 8.867153] loop9: detected capacity change from 0 to 337560
[ 8.867483] systemd[1]: Mounting Mount unit for qt513, revision 24...
[ 8.869939] loop10: detected capacity change from 0 to 166424
[ 8.870219] systemd[1]: Mounting Mount unit for qt515-core20, revision 31...
[ 8.872345] systemd[1]: Mounting Mount unit for qt515-core20, revision 32...
[ 8.872437] loop11: detected capacity change from 0 to 187776
[ 8.874004] loop12: detected capacity change from 0 to 5240
[ 8.875179] systemd[1]: Mounting Mount unit for rofi-snap, revision 3...
[ 8.876958] loop13: detected capacity change from 0 to 5240
[ 8.877345] systemd[1]: Mounting Mount unit for snapd, revision 21465...
[ 8.879318] systemd[1]: Mounting Mount unit for snapd, revision 21759...
[ 8.879788] loop14: detected capacity change from 0 to 741888
[ 8.881177] loop15: detected capacity change from 0 to 884528
[ 8.884316] loop16: detected capacity change from 0 to 2224
[ 8.884921] loop17: detected capacity change from 0 to 884888
[ 8.889955] loop18: detected capacity change from 0 to 79328
[ 8.890182] loop19: detected capacity change from 0 to 79520
[ 8.904748] systemd[1]: Mounted Mount unit for android-file-transfer-linux, revision 199.
[ 8.904970] systemd[1]: Mounted Mount unit for bare, revision 5.
[ 8.905163] systemd[1]: Mounted Mount unit for core, revision 16928.
[ 8.905358] systemd[1]: Mounted Mount unit for core, revision 17200.
[ 8.905544] systemd[1]: Mounted Mount unit for core18, revision 2823.
[ 8.905727] systemd[1]: Mounted Mount unit for core18, revision 2829.
[ 8.905907] systemd[1]: Mounted Mount unit for core20, revision 2264.
[ 8.906090] systemd[1]: Mounted Mount unit for core20, revision 2318.
[ 8.906280] systemd[1]: Mounted Mount unit for gnome-3-28-1804, revision 194.
[ 8.906469] systemd[1]: Mounted Mount unit for gnome-3-28-1804, revision 198.
[ 8.906653] systemd[1]: Mounted Mount unit for gtk-common-themes, revision 1534.
[ 8.906842] systemd[1]: Mounted Mount unit for gtk-common-themes, revision 1535.
[ 8.907029] systemd[1]: Mounted Mount unit for playlist-dl, revision 12.
[ 8.907225] systemd[1]: Mounted Mount unit for playlist-dl, revision 13.
[ 8.907419] systemd[1]: Mounted Mount unit for qt513, revision 24.
[ 8.907609] systemd[1]: Mounted Mount unit for qt515-core20, revision 31.
[ 8.907792] systemd[1]: Mounted Mount unit for qt515-core20, revision 32.
[ 8.907975] systemd[1]: Mounted Mount unit for rofi-snap, revision 3.
[ 8.908156] systemd[1]: Mounted Mount unit for snapd, revision 21465.
[ 8.908345] systemd[1]: Mounted Mount unit for snapd, revision 21759.
[ 8.909262] systemd[1]: Reached target Mounted snaps.
[ 8.911225] systemd[1]: Starting Load AppArmor profiles managed internally by snapd...
[ 8.926224] systemd[1]: proc-sys-fs-binfmt_misc.automount: Got automount request for /proc/sys/fs/binfmt_misc, triggered by 489 (snapd-apparmor)
[ 8.927716] systemd[1]: Mounting Arbitrary Executable File Formats File System...
[ 8.939835] systemd[1]: Mounted Arbitrary Executable File Formats File System.
[ 8.949400] systemd[1]: Started Journal Service.
[ 8.968321] systemd-journald[457]: Received client request to flush runtime journal.
[ 8.970468] systemd-journald[457]: File /var/log/journal/c52ffaf037bd4d0cb4d83003f1157b57/system.journal corrupted or uncleanly shut down, renaming and replacing.
[ 9.158397] nvidia: module license 'NVIDIA' taints kernel.
[ 9.158407] Disabling lock debugging due to kernel taint
[ 9.158414] nvidia: module license taints kernel.
[ 9.210913] ccp 0000:05:00.2: enabling device (0000 -> 0002)
[ 9.216670] ccp 0000:05:00.2: ccp: unable to access the device: you might be running a broken BIOS.
[ 9.230120] ccp 0000:05:00.2: tee enabled
[ 9.230191] ccp 0000:05:00.2: psp enabled
[ 9.237377] input: MSFT0001:00 04F3:3186 Mouse as /devices/platform/AMDI0010:03/i2c-0/i2c-MSFT0001:00/0018:04F3:3186.0002/input/input8
[ 9.240061] piix4_smbus 0000:00:14.0: SMBus Host Controller at 0xb00, revision 0
[ 9.240072] piix4_smbus 0000:00:14.0: Using register 0x02 for SMBus port selection
[ 9.240103] input: MSFT0001:00 04F3:3186 Touchpad as /devices/platform/AMDI0010:03/i2c-0/i2c-MSFT0001:00/0018:04F3:3186.0002/input/input9
[ 9.246758] acpi_cpufreq: overriding BIOS provided _PSD data
[ 9.247635] hid-generic 0018:04F3:3186.0002: input,hidraw1: I2C HID v1.00 Mouse [MSFT0001:00 04F3:3186] on i2c-MSFT0001:00
[ 9.258675] piix4_smbus 0000:00:14.0: Auxiliary SMBus Host Controller at 0xb20
[ 9.288082] input: PC Speaker as /devices/platform/pcspkr/input/input10
[ 9.333781] cfg80211: Loading compiled-in X.509 certificates for regulatory database
[ 9.334068] Loaded X.509 cert 'sforshee: 00b28ddf47aef9cea7'
[ 9.334309] Loaded X.509 cert 'wens: 61c038651aabdcf94bd0ac7ff06c7248db18c600'
[ 9.419770] Adding 21472252k swap on /dev/nvme0n1p6. Priority:-2 extents:1 across:21472252k SS
[ 9.744880] EXT4-fs (nvme0n1p7): 22 orphan inodes deleted
[ 9.744891] EXT4-fs (nvme0n1p7): recovery complete
[ 9.765832] EXT4-fs (nvme0n1p7): mounted filesystem 8688e415-56b2-481d-827b-210e7dfd1197 r/w with ordered data mode. Quota mode: none.
[ 10.111749] input: Ideapad extra buttons as /devices/pci0000:00/0000:00:14.3/PNP0C09:00/VPC2004:00/input/input11
[ 10.119095] nvidia-nvlink: Nvlink Core is being initialized, major device number 508
[ 10.121859] sp5100_tco: SP5100/SB800 TCO WatchDog Timer Driver
[ 10.123295] sp5100-tco sp5100-tco: Using 0xfeb00000 for watchdog MMIO address
[ 10.124818] ideapad_acpi VPC2004:00: DYTC interface is not available
[ 10.125490] Intel(R) Wireless WiFi driver for Linux
[ 10.127532] RAPL PMU: API unit is 2^-32 Joules, 1 fixed counters, 163840 ms ovfl timer
[ 10.127561] RAPL PMU: hw unit of domain package 2^-16 Joules
[ 10.133418] sp5100-tco sp5100-tco: initialized. heartbeat=60 sec (nowayout=0)
[ 10.134268] snd_rn_pci_acp3x 0000:05:00.5: enabling device (0000 -> 0002)
[ 10.138708] iwlwifi 0000:04:00.0: enabling device (0000 -> 0002)
[ 10.144179] cryptd: max_cpu_qlen set to 1000
[ 10.156858] iwlwifi 0000:04:00.0: Detected crf-id 0x3617, cnv-id 0x100530 wfpm id 0x80000000
[ 10.156889] iwlwifi 0000:04:00.0: PCI dev 2723/0084, rev=0x340, rfid=0x10a100
[ 10.170461] AVX2 version of gcm_enc/dec engaged.
[ 10.170581] AES CTR mode by8 optimization enabled
[ 10.171708] iwlwifi 0000:04:00.0: api flags index 2 larger than supported by driver
[ 10.171755] iwlwifi 0000:04:00.0: TLV_FW_FSEQ_VERSION: FSEQ Version: 89.3.35.37
[ 10.172074] r8169 0000:03:00.0 eth0: RTL8168h/8111h, 90:2e:16:1d:1a:a8, XID 541, IRQ 94
[ 10.172089] r8169 0000:03:00.0 eth0: jumbo features [frames: 9194 bytes, tx checksumming: ko]
[ 10.172810] iwlwifi 0000:04:00.0: loaded firmware version 77.a20fb07d.0 cc-a0-77.ucode op_mode iwlmvm
[ 10.409466] r8169 0000:03:00.0 eno1: renamed from eth0
[ 10.422044] iwlwifi 0000:04:00.0: Detected Intel(R) Wi-Fi 6 AX200 160MHz, REV=0x340
[ 10.422268] thermal thermal_zone0: failed to read out thermal zone (-61)
[ 10.478691] input: MSFT0001:00 04F3:3186 Mouse as /devices/platform/AMDI0010:03/i2c-0/i2c-MSFT0001:00/0018:04F3:3186.0002/input/input12
[ 10.479061] input: MSFT0001:00 04F3:3186 Touchpad as /devices/platform/AMDI0010:03/i2c-0/i2c-MSFT0001:00/0018:04F3:3186.0002/input/input13
[ 10.480106] hid-multitouch 0018:04F3:3186.0002: input,hidraw1: I2C HID v1.00 Mouse [MSFT0001:00 04F3:3186] on i2c-MSFT0001:00
[ 10.565606] mousedev: PS/2 mouse device common for all mice
[ 10.577711] iwlwifi 0000:04:00.0: Detected RF HR B3, rfid=0x10a100
[ 10.583105] kvm_amd: TSC scaling supported
[ 10.583111] kvm_amd: Nested Virtualization enabled
[ 10.583113] kvm_amd: Nested Paging enabled
[ 10.583129] kvm_amd: Virtual VMLOAD VMSAVE supported
[ 10.583131] kvm_amd: Virtual GIF supported
[ 10.583132] kvm_amd: LBR virtualization supported
[ 10.600503] MCE: In-kernel MCE decoding enabled.
[ 10.610697] nvidia 0000:01:00.0: enabling device (0000 -> 0003)
[ 10.610717] snd_hda_intel 0000:01:00.1: enabling device (0000 -> 0002)
[ 10.611118] snd_hda_intel 0000:01:00.1: Disabling MSI
[ 10.611145] snd_hda_intel 0000:01:00.1: Handle vga_switcheroo audio client
[ 10.611185] nvidia 0000:01:00.0: vgaarb: VGA decodes changed: olddecodes=io+mem,decodes=none:owns=none
[ 10.611347] snd_hda_intel 0000:05:00.6: enabling device (0000 -> 0002)
[ 10.643172] input: HDA NVidia HDMI/DP,pcm=3 as /devices/pci0000:00/0000:00:01.1/0000:01:00.1/sound/card0/input14
[ 10.643309] input: HDA NVidia HDMI/DP,pcm=7 as /devices/pci0000:00/0000:00:01.1/0000:01:00.1/sound/card0/input15
[ 10.643421] input: HDA NVidia HDMI/DP,pcm=8 as /devices/pci0000:00/0000:00:01.1/0000:01:00.1/sound/card0/input16
[ 10.643530] input: HDA NVidia HDMI/DP,pcm=9 as /devices/pci0000:00/0000:00:01.1/0000:01:00.1/sound/card0/input17
[ 10.643584] iwlwifi 0000:04:00.0: base HW address: c4:23:60:0a:2f:b2
[ 10.662034] NVRM: loading NVIDIA UNIX x86_64 Kernel Module 550.90.07 Fri May 31 09:35:42 UTC 2024
[ 10.671759] snd_hda_codec_realtek hdaudioC1D0: autoconfig for ALC257: line_outs=1 (0x14/0x0/0x0/0x0/0x0) type:speaker
[ 10.671773] snd_hda_codec_realtek hdaudioC1D0: speaker_outs=0 (0x0/0x0/0x0/0x0/0x0)
[ 10.671779] snd_hda_codec_realtek hdaudioC1D0: hp_outs=1 (0x21/0x0/0x0/0x0/0x0)
[ 10.671784] snd_hda_codec_realtek hdaudioC1D0: mono: mono_out=0x0
[ 10.671788] snd_hda_codec_realtek hdaudioC1D0: inputs:
[ 10.671792] snd_hda_codec_realtek hdaudioC1D0: Mic=0x19
[ 10.671797] snd_hda_codec_realtek hdaudioC1D0: Internal Mic=0x12
[ 10.688621] iwlwifi 0000:04:00.0 wlp4s0: renamed from wlan0
[ 10.745960] intel_rapl_common: Found RAPL domain package
[ 10.745970] intel_rapl_common: Found RAPL domain core
[ 10.772389] nvidia-modeset: Loading NVIDIA Kernel Mode Setting Driver for UNIX platforms 550.90.07 Fri May 31 09:30:47 UTC 2024
[ 10.817502] Bluetooth: Core ver 2.22
[ 10.817555] NET: Registered PF_BLUETOOTH protocol family
[ 10.817558] Bluetooth: HCI device and connection manager initialized
[ 10.817567] Bluetooth: HCI socket layer initialized
[ 10.817571] Bluetooth: L2CAP socket layer initialized
[ 10.817579] Bluetooth: SCO socket layer initialized
[ 10.852415] [drm] [nvidia-drm] [GPU ID 0x00000100] Loading driver
[ 10.852423] [drm] Initialized nvidia-drm 0.0.0 20160202 for 0000:01:00.0 on minor 0
[ 10.934129] input: HD-Audio Generic Mic as /devices/pci0000:00/0000:00:08.1/0000:05:00.6/sound/card1/input18
[ 10.934304] input: HD-Audio Generic Headphone as /devices/pci0000:00/0000:00:08.1/0000:05:00.6/sound/card1/input19
[ 10.969783] usbcore: registered new interface driver btusb
[ 10.972381] Bluetooth: hci0: Bootloader revision 0.3 build 0 week 24 2017
[ 10.974377] Bluetooth: hci0: Device revision is 1
[ 10.974384] Bluetooth: hci0: Secure boot is enabled
[ 10.974387] Bluetooth: hci0: OTP lock is enabled
[ 10.974389] Bluetooth: hci0: API lock is enabled
[ 10.974391] Bluetooth: hci0: Debug lock is disabled
[ 10.974394] Bluetooth: hci0: Minimum firmware build 1 week 10 2014
[ 10.977427] Bluetooth: hci0: Found device firmware: intel/ibt-20-1-3.sfi
[ 10.977451] Bluetooth: hci0: Boot Address: 0x24800
[ 10.977455] Bluetooth: hci0: Firmware Version: 132-3.24
[ 11.585488] nvidia_uvm: module uses symbols nvUvmInterfaceDisableAccessCntr from proprietary module nvidia, inheriting taint.
[ 11.832113] nvidia-uvm: Loaded the UVM driver, major device number 506.
[ 11.891787] vboxdrv: Found 12 processor cores/threads
[ 11.917421] vboxdrv: TSC mode is Invariant, tentative frequency 2994452636 Hz
[ 11.917431] vboxdrv: Successfully loaded version 7.0.18 r162988 (interface 0x00330004)
[ 11.921687] VBoxNetAdp: Successfully started.
[ 11.926890] VBoxNetFlt: Successfully started.
[ 12.257145] Generic FE-GE Realtek PHY r8169-0-300:00: attached PHY driver (mii_bus:phy_addr=r8169-0-300:00, irq=MAC)
[ 12.335348] Bluetooth: BNEP (Ethernet Emulation) ver 1.3
[ 12.335359] Bluetooth: BNEP filters: protocol multicast
[ 12.335371] Bluetooth: BNEP socket layer initialized
[ 12.457200] r8169 0000:03:00.0 eno1: Link is Down
[ 12.532700] Bluetooth: hci0: Waiting for firmware download to complete
[ 12.533313] Bluetooth: hci0: Firmware loaded in 1519411 usecs
[ 12.533420] Bluetooth: hci0: Waiting for device to boot
[ 12.548325] Bluetooth: hci0: Device booted in 14580 usecs
[ 12.548330] Bluetooth: hci0: Malformed MSFT vendor event: 0x02
[ 12.548642] Bluetooth: hci0: Found Intel DDC parameters: intel/ibt-20-1-3.ddc
[ 12.554339] Bluetooth: hci0: Applying Intel DDC parameters completed
[ 12.555995] loop20: detected capacity change from 0 to 8
[ 12.557353] Bluetooth: hci0: Firmware revision 0.3 build 132 week 3 2024
[ 12.563353] Bluetooth: hci0: HCI LE Coded PHY feature bit is set, but its usage is not supported.
[ 12.730737] Bluetooth: MGMT ver 1.22
[ 12.742608] NET: Registered PF_ALG protocol family
[ 12.746131] NET: Registered PF_QIPCRTR protocol family
[ 12.859593] ACPI: \: failed to evaluate _DSM bf0212f2-788f-c64d-a5b3-1f738e285ade (0x1001)
[ 12.859610] ACPI: \: failed to evaluate _DSM bf0212f2-788f-c64d-a5b3-1f738e285ade (0x1001)
[ 12.859617] ACPI: \: failed to evaluate _DSM bf0212f2-788f-c64d-a5b3-1f738e285ade (0x1001)
[ 12.859623] ACPI: \: failed to evaluate _DSM bf0212f2-788f-c64d-a5b3-1f738e285ade (0x1001)
[ 12.859629] ACPI: \: failed to evaluate _DSM bf0212f2-788f-c64d-a5b3-1f738e285ade (0x1001)
[ 12.859635] ACPI: \: failed to evaluate _DSM bf0212f2-788f-c64d-a5b3-1f738e285ade (0x1001)
[ 12.859641] ACPI: \: failed to evaluate _DSM bf0212f2-788f-c64d-a5b3-1f738e285ade (0x1001)
[ 12.862239] iwlwifi 0000:04:00.0: Registered PHC clock: iwlwifi-PTP, with index: 0
[ 13.099758] ACPI: \: failed to evaluate _DSM bf0212f2-788f-c64d-a5b3-1f738e285ade (0x1001)
[ 13.099774] ACPI: \: failed to evaluate _DSM bf0212f2-788f-c64d-a5b3-1f738e285ade (0x1001)
[ 13.099781] ACPI: \: failed to evaluate _DSM bf0212f2-788f-c64d-a5b3-1f738e285ade (0x1001)
[ 13.099787] ACPI: \: failed to evaluate _DSM bf0212f2-788f-c64d-a5b3-1f738e285ade (0x1001)
[ 13.099793] ACPI: \: failed to evaluate _DSM bf0212f2-788f-c64d-a5b3-1f738e285ade (0x1001)
[ 13.099799] ACPI: \: failed to evaluate _DSM bf0212f2-788f-c64d-a5b3-1f738e285ade (0x1001)
[ 13.099804] ACPI: \: failed to evaluate _DSM bf0212f2-788f-c64d-a5b3-1f738e285ade (0x1001)
[ 13.145805] mc: Linux media interface: v0.10
[ 13.182941] videodev: Linux video capture interface: v2.00
[ 13.365077] usb 1-3: Found UVC 1.00 device Integrated Camera (5986:212b)
[ 13.385520] usbcore: registered new interface driver uvcvideo
[ 14.919749] ACPI Warning: \_SB.PCI0.GPP0.PEGP._DSM: Argument #4 type mismatch - Found [Buffer], ACPI requires [Package] (20230628/nsarguments-61)
[ 30.074111] systemd-journald[457]: File /var/log/journal/c52ffaf037bd4d0cb4d83003f1157b57/user-1000.journal corrupted or uncleanly shut down, renaming and replacing.
[ 31.807160] warning: `kdeconnectd' uses wireless extensions which will stop working for Wi-Fi 7 hardware; use nl80211
[ 32.671861] Bluetooth: RFCOMM TTY layer initialized
[ 32.671886] Bluetooth: RFCOMM socket layer initialized
[ 32.671898] Bluetooth: RFCOMM ver 1.11
[ 33.463819] kauditd_printk_skb: 79 callbacks suppressed
[ 33.463829] audit: type=1400 audit(1720117491.398:91): apparmor="DENIED" operation="open" class="file" profile="mariadbd_akonadi" name="/sys/block/" pid=6492 comm="mysqld" requested_mask="r" denied_mask="r" fsuid=1000 ouid=0
[ 33.547855] audit: type=1400 audit(1720117491.481:92): apparmor="DENIED" operation="open" class="file" profile="mariadbd_akonadi" name="/proc/6492/cgroup" pid=6492 comm="mysqld" requested_mask="r" denied_mask="r" fsuid=1000 ouid=1000
[ 33.831612] wlp4s0: authenticate with 2c:78:0e:33:24:59
[ 33.831659] wlp4s0: 80 MHz not supported, disabling VHT
[ 33.836463] wlp4s0: send auth to 2c:78:0e:33:24:59 (try 1/3)
[ 33.872113] wlp4s0: authenticated
[ 33.877088] wlp4s0: associate with 2c:78:0e:33:24:59 (try 1/3)
[ 33.880937] wlp4s0: RX AssocResp from 2c:78:0e:33:24:59 (capab=0x431 status=0 aid=3)
[ 33.893074] wlp4s0: associated
journalctl --boot=-2 --priority=3 --catalog --no-pager :
Jul 03 21:19:53 Yamo-Legion5 kernel: integrity: Problem loading X.509 certificate -65
Jul 03 21:19:53 Yamo-Legion5 kernel: amdgpu 0000:05:00.0: amdgpu: Secure display: Generic Failure.
Jul 03 21:19:53 Yamo-Legion5 kernel: amdgpu 0000:05:00.0: amdgpu: SECUREDISPLAY: query securedisplay TA failed. ret 0x0
Jul 03 21:19:53 Yamo-Legion5 systemd-udevd[454]: /etc/udev/rules.d/40-libsane.rules:26 GOTO="libsane_rules_end" has no matching label, ignoring.
Jul 03 21:19:53 Yamo-Legion5 systemd-udevd[454]: /etc/udev/rules.d/S99-2000S1.rules:26 GOTO="libsane_rules_end" has no matching label, ignoring.
Jul 03 21:19:54 Yamo-Legion5 kernel: Bluetooth: hci0: FW download error recovery failed (-19)
Jul 03 21:19:54 Yamo-Legion5 kernel: Bluetooth: hci0: sending frame failed (-19)
Jul 03 21:19:54 Yamo-Legion5 kernel: Bluetooth: hci0: Reading supported features failed (-19)
Jul 03 21:19:54 Yamo-Legion5 kernel: Bluetooth: hci0: Failed to read MSFT supported features (-19)
Jul 03 21:19:56 Yamo-Legion5 kernel: Bluetooth: hci0: Malformed MSFT vendor event: 0x02
Jul 03 21:19:57 Yamo-Legion5 bluetoothd[2693]: Failed to load LTKs for hci0: Invalid Parameters (0x0d)
Jul 03 21:19:57 Yamo-Legion5 bluetoothd[2693]: Failed to load IRKs for hci0: Invalid Parameters (0x0d)
Jul 03 21:20:00 Yamo-Legion5 dbus-broker-launch[4240]: Ignoring duplicate name 'org.freedesktop.FileManager1' in service file '/usr/share//dbus-1/services/org.kde.dolphin.FileManager1.service'
░░ Subject: Invalid service file
░░ Defined-By: dbus-broker
░░ Support: https://groups.google.com/forum/#!forum/bus1-devel
░░ A service file is a ini-type configuration file.
░░ It has one required section
░░ named [D-BUS Service]. The section contains the required key 'Name', which
░░ must be a valid D-Bus name that is unique across all service files. It also
░░ contains at least one of the two optional keys 'SystemdService' and 'Exec',
░░ as well as optionally the key 'User'. Exec must be a valid shell command and
░░ User must be a valid user on the system.
░░ A service file should be named after the D-Bus name it configures. That is
░░ a file containing Name=org.foo.bar1 should be named org.foo.bar1.service.
░░ For backwards compatibility, we only warn when files do not follow this
░░ convention when run as a user bus. The system bus considers this an error
░░ and ignores the service file.
Jul 03 21:20:13 Yamo-Legion5 dbus-broker-launch[4359]: Ignoring duplicate name 'org.freedesktop.FileManager1' in service file '/usr/share//dbus-1/services/org.kde.dolphin.FileManager1.service'
Jul 03 21:20:20 Yamo-Legion5 akonadiserver[5169]: org.kde.pim.akonadiserver: database server stopped unexpectedly
Jul 03 21:20:20 Yamo-Legion5 akonadiserver[5169]: org.kde.pim.akonadiserver: Database process exited unexpectedly during initial connection!
Jul 03 21:20:20 Yamo-Legion5 akonadiserver[5169]: org.kde.pim.akonadiserver: executable: "/usr/bin/mysqld"
Jul 03 21:20:20 Yamo-Legion5 akonadiserver[5169]: org.kde.pim.akonadiserver: arguments: QList("--defaults-file=/home/yamo/.local/share/akonadi/mysql.conf", "--datadir=/home/yamo/.local/share/akonadi/db_data/", "--socket=/run/user/1000/akonadi/mysql.socket", "--pid-file=/run/user/1000/akonadi/mysql.pid")
Jul 03 21:20:20 Yamo-Legion5 akonadiserver[5169]: org.kde.pim.akonadiserver: stdout: ""
Jul 03 21:20:20 Yamo-Legion5 akonadiserver[5169]: org.kde.pim.akonadiserver: stderr: "/usr/bin/mysqld: Deprecated program name. It will be removed in a future release, use '/usr/bin/mariadbd' instead\n"
Jul 03 21:20:20 Yamo-Legion5 akonadiserver[5169]: org.kde.pim.akonadiserver: exit code: 1
Jul 03 21:20:20 Yamo-Legion5 akonadiserver[5169]: org.kde.pim.akonadiserver: process error: "Unknown error"
Jul 03 21:20:30 Yamo-Legion5 kioworker[8830]: libKExiv2: Cannot load metadata from file (Error # %1: The file contains data of an unknown image type )
Jul 03 21:20:30 Yamo-Legion5 kioworker[8836]: libKExiv2: Cannot load metadata from file (Error # %1: The file contains data of an unknown image type )
Jul 03 21:21:55 Yamo-Legion5 systemd-networkd-wait-online[2621]: Timeout occurred while waiting for network connectivity.
Jul 03 21:21:55 Yamo-Legion5 systemd[1]: Failed to start Wait for Network to be Configured.
░░ Subject: A start job for unit systemd-networkd-wait-online.service has failed
░░ Defined-By: systemd
░░ A start job for unit systemd-networkd-wait-online.service has finished with a failure.
░░ The job identifier is 168 and the job result is failed.
Jul 04 03:55:37 Yamo-Legion5 pulseaudio[4502]: org.bluez.BatteryProviderManager1.UnregisterBatteryProvider() Failed: org.freedesktop.DBus.Error.UnknownObject:Method "UnregisterBatteryProvider" with signature "o" on interface "org.bluez.BatteryProviderManager1" doesn't exist
Jul 04 03:55:38 Yamo-Legion5 kernel: Bluetooth: hci0: Malformed MSFT vendor event: 0x02
Jul 04 03:55:38 Yamo-Legion5 bluetoothd[2693]: Failed to load LTKs for hci0: Invalid Parameters (0x0d)
Jul 04 03:55:38 Yamo-Legion5 bluetoothd[2693]: Failed to load IRKs for hci0: Invalid Parameters (0x0d)
Jul 04 10:10:51 Yamo-Legion5 ksmserver[4617]: kscreenlocker: Could not establish screen lock
Jul 04 18:05:52 Yamo-Legion5 pulseaudio[4502]: org.bluez.BatteryProviderManager1.UnregisterBatteryProvider() Failed: org.freedesktop.DBus.Error.UnknownObject:Method "UnregisterBatteryProvider" with signature "o" on interface "org.bluez.BatteryProviderManager1" doesn't exist
Jul 04 18:05:52 Yamo-Legion5 kernel: nvidia-modeset: ERROR: GPU:0: Unsupported base display class
Jul 04 18:05:52 Yamo-Legion5 kernel: nvidia-modeset: ERROR: GPU:0: Failed to allocate display engine base channels
Jul 04 18:05:53 Yamo-Legion5 kernel: Bluetooth: hci0: Malformed MSFT vendor event: 0x02
Jul 04 18:05:54 Yamo-Legion5 bluetoothd[2693]: Failed to load LTKs for hci0: Invalid Parameters (0x0d)
Jul 04 18:05:54 Yamo-Legion5 bluetoothd[2693]: Failed to load IRKs for hci0: Invalid Parameters (0x0d)
Jul 04 18:06:02 Yamo-Legion5 kernel: BUG: kernel NULL pointer dereference, address: 0000000000000008
Jul 04 18:06:02 Yamo-Legion5 kernel: #PF: supervisor read access in kernel mode
Jul 04 18:06:02 Yamo-Legion5 kernel: #PF: error_code(0x0000) - not-present page
journalctl --boot=-3 --priority=3 --catalog --no-pager :
Jul 03 12:47:43 Yamo-Legion5 kernel: integrity: Problem loading X.509 certificate -65
Jul 03 12:47:43 Yamo-Legion5 kernel: amdgpu 0000:05:00.0: amdgpu: Secure display: Generic Failure.
Jul 03 12:47:43 Yamo-Legion5 kernel: amdgpu 0000:05:00.0: amdgpu: SECUREDISPLAY: query securedisplay TA failed. ret 0x0
Jul 03 12:47:43 Yamo-Legion5 systemd-udevd[454]: /etc/udev/rules.d/40-libsane.rules:26 GOTO="libsane_rules_end" has no matching label, ignoring.
Jul 03 12:47:43 Yamo-Legion5 systemd-udevd[454]: /etc/udev/rules.d/S99-2000S1.rules:26 GOTO="libsane_rules_end" has no matching label, ignoring.
Jul 03 12:47:44 Yamo-Legion5 kernel:
Jul 03 12:47:47 Yamo-Legion5 kernel: Bluetooth: hci0: command 0xfc09 tx timeout
Jul 03 12:47:47 Yamo-Legion5 kernel: Bluetooth: hci0: Failed to send firmware data (-110)
Jul 03 12:47:47 Yamo-Legion5 kernel: Bluetooth: hci0: Reading supported features failed (-56)
Jul 03 12:47:47 Yamo-Legion5 kernel: Bluetooth: hci0: Failed to read MSFT supported features (-56)
Jul 03 12:47:50 Yamo-Legion5 dbus-broker-launch[4586]: Ignoring duplicate name 'org.freedesktop.FileManager1' in service file '/usr/share//dbus-1/services/org.kde.dolphin.FileManager1.service'
Jul 03 12:49:45 Yamo-Legion5 systemd-networkd-wait-online[2403]: Timeout occurred while waiting for network connectivity.
Jul 03 12:49:45 Yamo-Legion5 systemd[1]: Failed to start Wait for Network to be Configured.
░░ The job identifier is 183 and the job result is failed.
Jul 03 12:55:18 Yamo-Legion5 dbus-broker-launch[4833]: Ignoring duplicate name 'org.freedesktop.FileManager1' in service file '/usr/share//dbus-1/services/org.kde.dolphin.FileManager1.service'
Jul 03 12:55:25 Yamo-Legion5 akonadiserver[5645]: org.kde.pim.akonadiserver: database server stopped unexpectedly
Jul 03 12:55:25 Yamo-Legion5 akonadiserver[5645]: org.kde.pim.akonadiserver: Database process exited unexpectedly during initial connection!
Jul 03 12:55:25 Yamo-Legion5 akonadiserver[5645]: org.kde.pim.akonadiserver: executable: "/usr/bin/mysqld"
Jul 03 12:55:25 Yamo-Legion5 akonadiserver[5645]: org.kde.pim.akonadiserver: arguments: QList("--defaults-file=/home/yamo/.local/share/akonadi/mysql.conf", "--datadir=/home/yamo/.local/share/akonadi/db_data/", "--socket=/run/user/1000/akonadi/mysql.socket", "--pid-file=/run/user/1000/akonadi/mysql.pid")
Jul 03 12:55:25 Yamo-Legion5 akonadiserver[5645]: org.kde.pim.akonadiserver: stdout: ""
Jul 03 12:55:25 Yamo-Legion5 akonadiserver[5645]: org.kde.pim.akonadiserver: stderr: "/usr/bin/mysqld: Deprecated program name. It will be removed in a future release, use '/usr/bin/mariadbd' instead\n"
Jul 03 12:55:25 Yamo-Legion5 akonadiserver[5645]: org.kde.pim.akonadiserver: exit code: 1
Jul 03 12:55:25 Yamo-Legion5 akonadiserver[5645]: org.kde.pim.akonadiserver: process error: "Unknown error"
Jul 03 13:24:36 Yamo-Legion5 kioworker[23333]: libKExiv2: Cannot load metadata from file (Error # %1: The file contains data of an unknown image type )
Jul 03 17:30:57 Yamo-Legion5 kioworker[128853]: libKExiv2: Cannot load metadata from file (Error # %1: The file contains data of an unknown image type )
Jul 03 18:18:00 Yamo-Legion5 kernel: device offline error, dev sdb, sector 59497360 op 0x1:(WRITE) flags 0x104000 phys_seg 46 prio class 2
Jul 03 18:18:00 Yamo-Legion5 kernel: device offline error, dev sdb, sector 59499408 op 0x1:(WRITE) flags 0x104000 phys_seg 45 prio class 2
Jul 03 18:18:00 Yamo-Legion5 kernel: device offline error, dev sdb, sector 59501456 op 0x1:(WRITE) flags 0x104000 phys_seg 95 prio class 2
Jul 03 18:18:00 Yamo-Legion5 kernel: device offline error, dev sdb, sector 59503504 op 0x1:(WRITE) flags 0x100000 phys_seg 253 prio class 2
Jul 03 18:18:00 Yamo-Legion5 kernel: device offline error, dev sdb, sector 59505552 op 0x1:(WRITE) flags 0x0 phys_seg 256 prio class 2
Jul 03 18:18:00 Yamo-Legion5 kernel: device offline error, dev sdb, sector 59507600 op 0x1:(WRITE) flags 0x4000 phys_seg 60 prio class 2
Jul 03 18:18:00 Yamo-Legion5 kernel: device offline error, dev sdb, sector 59509648 op 0x1:(WRITE) flags 0x4000 phys_seg 184 prio class 2
Jul 03 18:18:00 Yamo-Legion5 kernel: device offline error, dev sdb, sector 59511696 op 0x1:(WRITE) flags 0x0 phys_seg 12 prio class 2
Jul 03 18:18:00 Yamo-Legion5 kernel: device offline error, dev sdb, sector 59512080 op 0x1:(WRITE) flags 0x4000 phys_seg 238 prio class 2
Jul 03 18:18:00 Yamo-Legion5 kernel: device offline error, dev sdb, sector 59514128 op 0x1:(WRITE) flags 0x0 phys_seg 18 prio class 2
Jul 03 18:18:01 Yamo-Legion5 kernel: Buffer I/O error on dev sdb1, logical block 786432, lost sync page write
Jul 03 18:18:01 Yamo-Legion5 kernel: ntfs3: sdb1: ino=3, ntfs_set_state failed, -5.
Jul 03 18:18:01 Yamo-Legion5 kernel: ntfs3: sdb1: ino=3, ntfs3_write_inode failed, -5.
Jul 03 18:36:33 Yamo-Legion5 pulseaudio[4976]: Assertion 'pa_atomic_load(&(y)->_ref) > 0' failed at ../pulseaudio/src/modules/bluetooth/bluez5-util.c:2207, function pa_bluetooth_discovery_hook(). Aborting.
Jul 03 18:36:33 Yamo-Legion5 dbus-broker-launch[2408]: Activation request for 'org.bluez' failed.
So, If I’m able to interpret correctly, the last freeze was caused due to Vivaldi-bin dumping 1000 cores, but that’s not what causes the freeze every time.
I have also put the last 3 boots logs, I am guessing that I need to change the thermal paste to the laptop as the heat is rising and it’s getting super hot.
Any help would be highly appreciated, thanks.
