My system gets stuck at boot screen (sometimes)
manjaro installed on a chromebook, sd card
here is inxi:
  Kernel: 6.1.25-1-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 12.2.1
    root=UUID=2410c264-0307-4f55-beb5-adefb07773c4 rw quiet splash
    udev.log_priority=3
  Desktop: KDE Plasma v: 5.27.4 tk: Qt v: 5.15.8 wm: kwin_x11 vt: 1 dm: SDDM
  Type: Laptop System: Google product: Bobba v: rev5
    serial: <superuser required> Chassis: type: 9 serial: <superuser required>
  Mobo: Google model: Bobba v: rev5 serial: <superuser required>
    UEFI: coreboot v: Google_Bobba.11297.357.0 date: 12/24/2021
  ID-1: BAT0 charge: 12.2 Wh (54.0%) condition: 22.6/38.2 Wh (59.3%)
    volts: 11.3 min: 11.6 model: LGC KT0 AP19A8K type: Li-ion serial: <filter>
    status: discharging cycles: 316
  RAM: total: 3.7 GiB used: 2.15 GiB (58.2%)
  Info: model: Intel Celeron N4020 bits: 64 type: MCP arch: Goldmont Plus
    level: v2 built: 2017 process: Intel 14nm family: 6 model-id: 0x7A (122)
    stepping: 8 microcode: 0x22
  Topology: cpus: 1x cores: 2 smt: <unsupported> cache: L1: 112 KiB
    desc: d-2x24 KiB; i-2x32 KiB L2: 4 MiB desc: 1x4 MiB
  Speed (MHz): avg: 1094 min/max: 800/2800 scaling: driver: intel_cpufreq
    governor: schedutil cores: 1: 1094 2: 1094 bogomips: 4378
  Flags: 3dnowprefetch acpi aes aperfmperf apic arat arch_capabilities
    arch_perfmon art bts cat_l2 cdp_l2 clflush clflushopt cmov constant_tsc
    cpuid cpuid_fault cx16 cx8 de ds_cpl dtes64 dtherm dts ept ept_ad erms est
    flexpriority fpu fsgsbase fxsr ht ibpb ibrs ibrs_enhanced ida intel_pt
    lahf_lm lm mca mce md_clear mmx monitor movbe mpx msr mtrr nonstop_tsc
    nopl nx pae pat pbe pclmulqdq pdcm pdpe1gb pebs pge pln pni popcnt pse
    pse36 pts rdpid rdrand rdseed rdt_a rdtscp rep_good sdbg sep sgx sgx_lc
    sha_ni smap smep ss ssbd sse sse2 sse4_1 sse4_2 ssse3 stibp syscall tm tm2
    tpr_shadow tsc tsc_adjust tsc_deadline_timer tsc_known_freq umip vme vmx
    vnmi vpid x2apic xgetbv1 xsave xsavec xsaveopt xsaves xtopology xtpr
  Type: spectre_v2 mitigation: Enhanced IBRS, IBPB: conditional, RSB
    filling, PBRSB-eIBRS: Not affected
  Device-1: Intel GeminiLake [UHD Graphics 600] driver: i915 v: kernel
    arch: Gen-9 process: Intel 14n built: 2015-16 ports: active: eDP-1
    empty: DP-1,DP-2 bus-ID: 00:02.0 chip-ID: 8086:3185 class-ID: 0300
  Device-2: Chicony HD WebCam type: USB driver: uvcvideo bus-ID: 1-7:2
    chip-ID: 04f2:b567 class-ID: 0e02
  Device-3: Chicony 5MP World Facing type: USB driver: uvcvideo bus-ID: 1-8:3
    chip-ID: 04f2:b6bd class-ID: 0e02 serial: <filter>
  Display: x11 server: X.Org v: 21.1.8 compositor: kwin_x11 driver: X:
    loaded: modesetting alternate: fbdev,vesa dri: iris gpu: i915 display-ID: :0
    screens: 1
  Screen-1: 0 s-res: 1366x768 s-dpi: 96 s-size: 361x203mm (14.21x7.99")
    s-diag: 414mm (16.31")
  Monitor-1: eDP-1 model: AU Optronics 0x145c built: 2016 res: 1366x768
    hz: 60 dpi: 136 gamma: 1.2 size: 256x144mm (10.08x5.67") diag: 294mm (11.6")
    ratio: 16:9 modes: 1366x768
  API: OpenGL v: 4.6 Mesa 23.0.2 renderer: Mesa Intel UHD Graphics 600 (GLK
    2) direct-render: Yes
  Device-1: Intel Celeron/Pentium Silver Processor High Definition Audio
    driver: sof-audio-pci-intel-apl alternate: snd_hda_intel, snd_soc_skl,
    snd_soc_avs, snd_sof_pci_intel_apl bus-ID: 00:0e.0 chip-ID: 8086:3198
    class-ID: 0401
  API: ALSA v: k6.1.25-1-MANJARO status: kernel-api with: aoss
    type: oss-emulator tools: alsamixer,amixer
  Server-2: PipeWire v: 0.3.70 status: off with: wireplumber status: active
    tools: pw-cli,wpctl
  Server-3: PulseAudio v: 16.1 status: active tools: pacat,pactl
  Device-1: Intel Gemini Lake PCH CNVi WiFi driver: iwlwifi v: kernel
    bus-ID: 00:0c.0 chip-ID: 8086:31dc class-ID: 0280
  IF: wlp0s12f0 state: up mac: <filter>
  Device-2: TP-Link UE300 10/100/1000 LAN (ethernet mode) [Realtek RTL8153]
    type: USB driver: r8152 bus-ID: 1-4:5 chip-ID: 2357:0601 class-ID: 0000
    serial: <filter>
  IF: enp0s21f0u4 state: up speed: 100 Mbps duplex: full mac: <filter>
  Device-1: Intel Bluetooth 9460/9560 Jefferson Peak (JfP) type: USB
    driver: btusb v: 0.8 bus-ID: 1-9:4 chip-ID: 8087:0aaa class-ID: e001
  Local Storage: total: 88.57 GiB used: 41.35 GiB (46.7%)
  ID-1: /dev/mmcblk0 maj-min: 179:0 vendor: SanDisk model: DA4032
    size: 29.12 GiB block-size: physical: 512 B logical: 512 B type: SSD
    serial: <filter> rev: 0x8 scheme: GPT
  SMART Message: Unknown smartctl error. Unable to generate data.
  ID-2: /dev/sda maj-min: 8:0 type: USB vendor: Generic model: STORAGE DEVICE
    size: 59.45 GiB block-size: physical: 512 B logical: 512 B type: N/A
    serial: <filter> rev: 0819 scheme: GPT
  ID-1: / raw-size: 59.15 GiB size: 57.92 GiB (97.92%) used: 41.35 GiB (71.4%)
    fs: ext4 dev: /dev/sda2 maj-min: 8:2 label: N/A
    uuid: 2410c264-0307-4f55-beb5-adefb07773c4
    used: 312 KiB (0.1%) fs: vfat dev: /dev/sda1 maj-min: 8:1 label: N/A
    uuid: 779B-4C87
  ID-1: swap-1 type: file size: 4 GiB used: 503.9 MiB (12.3%) priority: -2
    file: /swapfile
  ID-1: /dev/mmcblk0boot0 maj-min: 179:8 size: 4 MiB fs: <superuser required>
    label: N/A uuid: N/A
  ID-2: /dev/mmcblk0boot1 maj-min: 179:16 size: 4 MiB
    fs: <superuser required> label: N/A uuid: N/A
  ID-3: /dev/mmcblk0p1 maj-min: 179:1 size: 20.94 GiB fs: ext4 label: N/A
    uuid: 9177d5d4-43c5-4998-a56f-69c61eadcc42
  ID-4: /dev/mmcblk0p10 maj-min: 259:2 size: 0 KiB fs: <superuser required>
  ID-5: /dev/mmcblk0p11 maj-min: 259:3 size: 8 MiB fs: <superuser required>
  ID-6: /dev/mmcblk0p12 maj-min: 259:4 size: 32 MiB fs: vfat
    label: EFI-SYSTEM uuid: 8C17-B000
  ID-7: /dev/mmcblk0p2 maj-min: 179:2 size: 32 MiB fs: <superuser required>
  ID-8: /dev/mmcblk0p3 maj-min: 179:3 size: 4 GiB fs: ext4 label: ROOT-A
    uuid: N/A
  ID-9: /dev/mmcblk0p4 maj-min: 179:4 size: 32 MiB fs: <superuser required>
  ID-10: /dev/mmcblk0p5 maj-min: 179:5 size: 4 GiB fs: ext4 label: ROOT-A
    uuid: N/A
  ID-11: /dev/mmcblk0p6 maj-min: 179:6 size: 0 KiB fs: <superuser required>
  ID-12: /dev/mmcblk0p7 maj-min: 179:7 size: 0 KiB fs: <superuser required>
  ID-13: /dev/mmcblk0p8 maj-min: 259:0 size: 16 MiB fs: ext4 label: OEM
    uuid: 4ef4492e-7383-4179-8f63-2319d93ab4d5
  ID-14: /dev/mmcblk0p9 maj-min: 259:1 size: 0 KiB fs: <superuser required>
  Hub-1: 1-0:1 info: Hi-speed hub with single TT ports: 9 rev: 2.0
  Device-1: 1-1:7 info: USB OPTICAL MOUSE type: Mouse,Keyboard
    power: 100mA chip-ID: 4e53:5406 class-ID: 0301
  Device-2: 1-4:5 info: TP-Link UE300 10/100/1000 LAN (ethernet mode)
    [Realtek RTL8153] type: Network driver: r8152 interfaces: 1 rev: 2.1
    speed: 480 Mb/s power: 180mA chip-ID: 2357:0601 class-ID: 0000
    serial: <filter>
  Device-3: 1-7:2 info: Chicony HD WebCam type: Video driver: uvcvideo
    interfaces: 2 rev: 2.0 speed: 480 Mb/s power: 500mA chip-ID: 04f2:b567
    class-ID: 0e02
  Device-4: 1-8:3 info: Chicony 5MP World Facing type: Video driver: uvcvideo
    interfaces: 2 rev: 2.0 speed: 480 Mb/s power: 500mA chip-ID: 04f2:b6bd
  Device-5: 1-9:4 info: Intel Bluetooth 9460/9560 Jefferson Peak (JfP)
    type: Bluetooth driver: btusb interfaces: 2 rev: 2.0 speed: 12 Mb/s
    power: 100mA chip-ID: 8087:0aaa class-ID: e001
  Hub-2: 2-0:1 info: Super-speed hub ports: 7 rev: 3.0 speed: 5 Gb/s
  Device-1: 2-6:2 info: Genesys Logic USB Storage type: Mass Storage
    driver: usb-storage interfaces: 1 rev: 3.0 speed: 5 Gb/s power: 896mA
    chip-ID: 05e3:0747 class-ID: 0806 serial: <filter>
  System Temperatures: cpu: 50.0 C mobo: N/A
  Processes: 175 Uptime: 1h 6m wakeups: 31165 Init: systemd v: 252
  default: graphical tool: systemctl Compilers: gcc: 12.2.1 clang: 15.0.7
  Packages: pm: pacman pkgs: 1204 libs: 353 tools: pamac pm: flatpak pkgs: 0
  Shell: Zsh v: 5.9 default: Bash v: 5.1.16 running-in: konsole inxi: 3.3.26
also here is the journalctl:
journalctl --boot=-1  --priority=3 --catalog --no-pager         ✔  4s 
abr 25 18:56:46 pato-bobba kernel: ACPI Error: AE_ERROR, Returned by Handler for [PCI_Config] (20220331/evregion-291)
abr 25 18:56:46 pato-bobba kernel: ACPI Error: Aborting method \_SB.PCI0.RP01.PXP._ON due to previous error (AE_ERROR) (20220331/psparse-529)
abr 25 18:56:46 pato-bobba kernel: ACPI Error: Aborting method \_SB.PCI0.RP03.PXP._ON due to previous error (AE_ERROR) (20220331/psparse-529)
abr 25 18:56:46 pato-bobba kernel: sgx: There are zero EPC sections.
abr 25 18:56:47 pato-bobba kernel: raydium_ts i2c-RAYD0001:00: failed to get reset gpio: -16
abr 25 18:56:47 pato-bobba kernel: elants_i2c i2c-ELAN0001:00: nothing at this address
abr 25 18:56:48 pato-bobba kernel: sx9310 i2c-STH9310:00: error -EREMOTEIO: error reading WHOAMI
abr 25 18:56:49 pato-bobba systemd[1]: Failed to start pkgfile database update.
-- Subject: A start job for unit pkgfile-update.service has failed
-- Defined-By: systemd
-- Support: https://forum.manjaro.org/c/support
-- A start job for unit pkgfile-update.service has finished with a failure.
-- The job identifier is 370 and the job result is failed.
abr 25 18:56:49 pato-bobba bluetoothd[407]: src/plugin.c:plugin_init() Failed to init vcp plugin
abr 25 18:56:49 pato-bobba bluetoothd[407]: src/plugin.c:plugin_init() Failed to init mcp plugin
abr 25 18:56:49 pato-bobba bluetoothd[407]: src/plugin.c:plugin_init() Failed to init bap plugin
abr 25 18:56:50 pato-bobba kernel: intel_punit_ipc intel_punit_ipc.2.auto: invalid resource
abr 25 18:56:50 pato-bobba kernel: bxt_da7219_max98357a glk_da7219_mx98357a: ASoC: driver name too long 'sof-glkda7219max' -> 'sof-glkda7219ma'
abr 25 18:56:50 pato-bobba kernel: Bluetooth: hci0: Malformed MSFT vendor event: 0x02
abr 25 18:56:51 pato-bobba bluetoothd[407]: Failed to set mode: Failed (0x03)
abr 25 18:57:09 pato-bobba systemd[1]: Failed to start Terminate Plymouth Boot Screen.
-- Subject: A start job for unit plymouth-quit.service has failed
-- A start job for unit plymouth-quit.service has finished with a failure.
-- The job identifier is 100 and the job result is failed.
abr 25 18:57:10 pato-bobba sddm[505]: Failed to read display number from pipe
abr 25 18:57:12 pato-bobba sddm[505]: Failed to read display number from pipe
abr 25 18:57:14 pato-bobba sddm[505]: Failed to read display number from pipe
abr 25 18:57:14 pato-bobba sddm[505]: Could not start Display server on vt 1
also for some reason it doesn’t do anything when i press ctrl + alt +F2 so i need to hard power off, any help? it’s not that important because if the first try it doesn’t boot, the next time does, but i don’t like to turn off it like that
This suggests a hardware failure of some sorts. The ACPI errors are also pointing in that direction.
