Hi fellows!!! Hope everything fine for you and yours!!! How the title of this post says, my system freezes for a few seconds, perhaps 10 seconds, after boot…just one time…then everything works fine (except suspension, but thats theme of other post). I let you here my system info:
Kernel: 6.1.29-1-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 12.2.1
root=UUID=034cce20-46f0-4762-a989-90f4125f7af9 rw quiet splash apparmor=1
security=apparmor resume=UUID=35dedb6e-40ca-4832-b4a1-6fa39675484b
udev.log_priority=3
Desktop: GNOME v: 43.5 tk: GTK v: 3.24.37 wm: gnome-shell dm: GDM v: 44.0
Type: Laptop System: ASUSTeK product: ASUS EXPERTBOOK B1500CEAEY_B1500CEAE
v: 1.0 serial: <superuser required>
Mobo: ASUSTeK model: B1500CEAEY v: 1.0 serial: <superuser required>
UEFI: ASUSTeK v: B1500CEAEY.312 date: 03/14/2022
ID-1: BAT0 charge: 30.5 Wh (72.1%) condition: 42.3/42.1 Wh (100.5%)
volts: 11.8 min: 11.8 model: ASUSTeK ASUS Battery type: Li-ion serial: N/A
status: charging cycles: 1
System RAM: available: 15.32 GiB used: 2.59 GiB (16.9%)
Info: model: 11th Gen Intel Core i7-1165G7 bits: 64 type: MT MCP
arch: Tiger Lake gen: core 11 level: v4 note: check built: 2020
process: Intel 10nm family: 6 model-id: 0x8C (140) stepping: 1
microcode: 0xA6
L1: 320 KiB desc: d-4x48 KiB; i-4x32 KiB L2: 5 MiB desc: 4x1.2 MiB L3: 12 MiB
desc: 1x12 MiB
Speed (MHz): avg: 2126 high: 2800 min/max: 400/4700 scaling:
driver: intel_pstate governor: powersave cores: 1: 716 2: 2800 3: 1140
4: 2800 5: 1153 6: 2800 7: 2800 8: 2800 bogomips: 44864
arch_capabilities arch_perfmon art avx avx2 avx512_bitalg avx512_vbmi2
avx512_vnni avx512_vp2intersect avx512_vpopcntdq avx512bw avx512cd
avx512dq avx512f avx512ifma avx512vbmi avx512vl bmi1 bmi2 bts cat_l2
cdp_l2 clflush clflushopt clwb cmov constant_tsc cpuid cpuid_fault cx16
cx8 de ds_cpl dtes64 dtherm dts epb ept ept_ad erms est f16c flexpriority
flush_l1d fma fpu fsgsbase fsrm fxsr gfni ht hwp hwp_act_window hwp_epp
hwp_notify hwp_pkg_req ibpb ibrs ibrs_enhanced ibt ida intel_pt invpcid
invpcid_single lahf_lm lm mca mce md_clear mmx monitor movbe movdir64b
movdiri msr mtrr nonstop_tsc nopl nx ospke pae pat pbe pcid pclmulqdq pdcm
rdt_a rdtscp rep_good sdbg sep sha_ni smap smep split_lock_detect ss ssbd
sse sse2 sse4_1 sse4_2 ssse3 stibp syscall tm tm2 tpr_shadow tsc
tsc_adjust tsc_deadline_timer tsc_known_freq umip vaes vme vmx vnmi
vpclmulqdq vpid x2apic xgetbv1 xsave xsavec xsaveopt xsaves xtopology xtpr
Type: spectre_v2 mitigation: Enhanced IBRS, IBPB: conditional, RSB
filling, PBRSB-eIBRS: SW sequence
Device-1: Intel TigerLake-LP GT2 [Iris Xe Graphics] vendor: ASUSTeK
driver: i915 v: kernel arch: Gen-12.1 process: Intel 10nm built: 2020-21
ports: active: DP-3,eDP-1 empty: DP-1,DP-2,HDMI-A-1 bus-ID: 0000:00:02.0
chip-ID: 8086:9a49 class-ID: 0300
Device-2: IMC Networks USB2.0 HD UVC WebCam driver: uvcvideo type: USB
rev: 2.0 speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 3-5:5 chip-ID: 13d3:56a2
Display: wayland server: X.org v: 1.21.1.8 with: Xwayland v: 23.1.1
compositor: gnome-shell driver: gpu: i915 display-ID: 0
Monitor-1: DP-3 model: Dell E178FP serial: <filter> built: 2009
res: 1280x1024 dpi: 96 gamma: 1.2 size: 338x270mm (13.31x10.63")
diag: 433mm (17") ratio: 5:4 modes: max: 1280x1024 min: 720x400
Monitor-2: eDP-1 model: ChiMei InnoLux 0x15f5 built: 2017 res: 1920x1080
dpi: 142 gamma: 1.2 size: 344x193mm (13.54x7.6") diag: 394mm (15.5")
ratio: 16:9 modes: 1920x1080
API: OpenGL v: 4.6 Mesa 23.0.3 renderer: Mesa Intel Xe Graphics (TGL GT2)
direct-render: Yes
Device-1: Intel Tiger Lake-LP Smart Sound Audio vendor: ASUSTeK
driver: sof-audio-pci-intel-tgl
alternate: snd_hda_intel,snd_sof_pci_intel_tgl bus-ID: 0000:00:1f.3
chip-ID: 8086:a0c8 class-ID: 0401
API: ALSA v: k6.1.29-1-MANJARO status: kernel-api with: aoss
Server-2: PipeWire v: 0.3.70 status: off tools: pw-cli
Device-1: Intel Wi-Fi 6 AX201 driver: iwlwifi v: kernel bus-ID: 0000:00:14.3
chip-ID: 8086:a0f0 class-ID: 0280
Device-2: Intel Ethernet I219-V driver: e1000e v: kernel port: N/A
bus-ID: 0000:00:1f.6 chip-ID: 8086:15fc class-ID: 0200
IF: eno2 state: down mac: <filter>
speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 3-10:8 chip-ID: 8087:0026
class-ID: e001
Report: rfkill ID: hci0 rfk-id: 2 state: down bt-service: enabled,running
Hardware-1: Intel Volume Management Device NVMe RAID Controller driver: vmd
v: 0.6 port: N/A bus-ID: 0000:00:0e.0 chip-ID: 8086:9a0b rev: class-ID: 0104
Local Storage: total: 1.15 TiB used: 479.55 GiB (40.8%)
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Western Digital model: PC SN530
SDBPNPZ-512G-1002 size: 476.94 GiB block-size: physical: 512 B
fw-rev: 21106000 temp: 52.9 C scheme: GPT
ID-2: /dev/sda maj-min: 8:0 vendor: Seagate model: Expansion
size: 698.64 GiB block-size: physical: 4096 B logical: 512 B type: USB
rev: 3.0 spd: 5 Gb/s lanes: 1 mode: 3.2 gen-1x1 tech: N/A serial: <filter>
fw-rev: 9300 scheme: GPT
ID-1: / raw-size: 39.06 GiB size: 38.15 GiB (97.67%) used: 15.87 GiB (41.6%)
fs: ext4 dev: /dev/nvme0n1p3 maj-min: 259:3 label: N/A
uuid: 034cce20-46f0-4762-a989-90f4125f7af9
ID-2: /boot/efi raw-size: 513 MiB size: 512 MiB (99.80%)
used: 288 KiB (0.1%) fs: vfat dev: /dev/nvme0n1p2 maj-min: 259:2 label: N/A
uuid: 6D27-E14D
ID-3: /home raw-size: 29.3 GiB size: 28.67 GiB (97.86%)
used: 598.8 MiB (2.0%) fs: ext4 dev: /dev/nvme0n1p6 maj-min: 259:6
label: Home uuid: eefcea03-6127-40e9-935c-c00395787289
ID-4: /mnt/Ocio raw-size: 192.99 GiB size: 188.9 GiB (97.88%)
used: 2.44 GiB (1.3%) fs: ext4 dev: /dev/nvme0n1p8 maj-min: 259:8 label: Ocio
uuid: c4fcea3d-9d4c-4c00-af62-9feed8cf3d2d
ID-5: /mnt/Trabajo raw-size: 205.08 GiB size: 200.8 GiB (97.91%)
used: 70.91 GiB (35.3%) fs: ext4 dev: /dev/nvme0n1p7 maj-min: 259:7
label: Trabajo uuid: c79f5441-4c29-470e-be18-d9d1166dae00
ID-6: /run/media/boris/Ocio raw-size: 356.46 GiB size: 349.79 GiB (98.13%)
used: 183.21 GiB (52.4%) fs: ext4 dev: /dev/sda4 maj-min: 8:4 label: Ocio
uuid: 05b90c5e-ace5-4fc9-9fc2-5714472e1c3e
ID-7: /run/media/boris/Trabajo raw-size: 341.88 GiB
size: 335.45 GiB (98.12%) used: 206.55 GiB (61.6%) fs: ext4 dev: /dev/sda2
maj-min: 8:2 label: Trabajo uuid: 40f24dd8-62f9-4525-90a4-4f9984ce15d7
Kernel: swappiness: 10 (default 60) cache-pressure: 100 (default)
ID-1: swap-1 type: partition size: 8.79 GiB used: 0 KiB (0.0%) priority: -2
dev: /dev/nvme0n1p1 maj-min: 259:1 label: N/A
uuid: 35dedb6e-40ca-4832-b4a1-6fa39675484b
ID-1: /dev/nvme0n1p4 maj-min: 259:4 size: 1.03 GiB fs: ntfs label: RECOVERY
uuid: 1E7A889E7A8873F5
ID-2: /dev/nvme0n1p5 maj-min: 259:5 size: 200 MiB fs: vfat label: MYASUS
uuid: 8276-1117
Hub-1: 1-0:1 info: hi-speed hub with single TT ports: 1 rev: 2.0
Hub-3: 3-0:1 info: hi-speed hub with single TT ports: 12 rev: 2.0
Hub-4: 3-2:2 info: VIA Labs VL812 Hub ports: 4 rev: 2.1
speed: 480 Mb/s (57.2 MiB/s) lanes: 1 mode: 2.0 chip-ID: 2109:2812
Device-1: 3-2.1:4 info: Logitech Optical Wheel Mouse type: mouse
driver: hid-generic,usbhid interfaces: 1 rev: 2.0 speed: 1.5 Mb/s (183 KiB/s)
lanes: 1 mode: 1.0 power: 100mA chip-ID: 046d:c018 class-ID: 0301
Device-2: 3-2.4:6 info: Logitech Keyboard K120 type: keyboard,HID
driver: hid-generic,usbhid interfaces: 2 rev: 1.1 speed: 1.5 Mb/s (183 KiB/s)
lanes: 1 mode: 1.0 power: 90mA chip-ID: 046d:c31c class-ID: 0300
Device-3: 3-4:3 info: Realtek RTS5129 Card Reader Controller
power: 500mA chip-ID: 0bda:0129 class-ID: ff00 serial: <filter>
Device-4: 3-5:5 info: IMC Networks USB2.0 HD UVC WebCam type: video
driver: uvcvideo interfaces: 3 rev: 2.0 speed: 480 Mb/s (57.2 MiB/s) lanes: 1
mode: 2.0 power: 500mA chip-ID: 13d3:56a2 class-ID: fe01 serial: <filter>
Device-5: 3-7:7 info: Elan Micro ELAN:ARM-M4 type: <vendor specific>
driver: N/A interfaces: 1 rev: 2.0 speed: 12 Mb/s (1.4 MiB/s) lanes: 1
mode: 1.1 power: 100mA chip-ID: 04f3:0c6c class-ID: 0000
Device-6: 3-10:8 info: Intel AX201 Bluetooth type: bluetooth driver: btusb
power: 100mA chip-ID: 8087:0026 class-ID: e001
Hub-5: 4-0:1 info: super-speed hub ports: 4 rev: 3.1
Device-1: 4-1:2 info: Seagate RSS LLC SRD0NF1 Expansion Portable (STEA)
type: mass storage driver: uas interfaces: 1 rev: 3.0
speed: 5 Gb/s (596.0 MiB/s) lanes: 1 mode: 3.2 gen-1x1 power: 144mA
chip-ID: 0bc2:2322 class-ID: 0806 serial: <filter>
Hub-6: 4-2:3 info: VIA Labs VL812 Hub ports: 4 rev: 3.0
speed: 5 Gb/s (596.0 MiB/s) lanes: 1 mode: 3.2 gen-1x1 chip-ID: 2109:0812
System Temperatures: cpu: 46.0 C mobo: N/A
Fan Speeds (RPM): cpu: 2300
Processes: 275 Uptime: 27m wakeups: 1 Init: systemd v: 252 default: graphical
tool: systemctl Compilers: gcc: 12.2.1 clang: 15.0.7 Packages: pm: pacman
pkgs: 1280 libs: 364 tools: gnome-software,pamac pm: flatpak pkgs: 0
Shell: Zsh v: 5.9 running-in: gnome-terminal inxi: 3.3.27
Thanks
