My screens flickers after upgrade Manjaro Gnome 5.11.2. My inxi -Fxza --no-host output is:
Kernel: 5.4.101-1-MANJARO x86_64 bits: 64 compiler: gcc v: 10.2.1
root=UUID=3e56f450-cdc8-415b-bb53-88599061b419 ro quiet splash apparmor=1
Desktop: GNOME 3.38.3 tk: GTK 3.24.26 wm: gnome-shell dm: GDM 3.38.2.1
Distro: Manjaro Linux
Type: Desktop System: TSINGHUA TONGFANG product: H81-M1 v: N/A
serial: <filter> Chassis: type: 3 serial: <filter>
Mobo: PEGATRON model: H81-M1 v: 1.02 serial: <filter>
UEFI: American Megatrends v: P014AP0M date: 01/03/2014
RAM: total: 7.61 GiB used: 1.99 GiB (26.1%)
Info: Quad Core model: Intel Core i5-4440 bits: 64 type: MCP arch: Haswell
family: 6 model-id: 3C (60) stepping: 3 microcode: 28 L2 cache: 6 MiB
bogomips: 24753
Speed: 898 MHz min/max: 800/3300 MHz Core speeds (MHz): 1: 898 2: 898 3: 898
4: 898
Flags: abm acpi aes aperfmperf apic arat arch_perfmon avx avx2 bmi1 bmi2 bts
clflush cmov constant_tsc cpuid cpuid_fault cx16 cx8 de ds_cpl dtes64 dtherm
dts epb ept ept_ad erms est f16c flexpriority flush_l1d fma fpu fsgsbase
fxsr ht ibpb ibrs ida invpcid invpcid_single lahf_lm lm mca mce md_clear mmx
monitor movbe msr mtrr nonstop_tsc nopl nx pae pat pbe pcid pclmulqdq pdcm
pdpe1gb pebs pge pln pni popcnt pse pse36 pti pts rdrand rdtscp rep_good
sdbg sep smep ss ssbd sse sse2 sse4_1 sse4_2 ssse3 stibp syscall tm tm2
tpr_shadow tsc tsc_adjust tsc_deadline_timer vme vmx vnmi vpid x2apic xsave
xsaveopt xtopology xtpr
Type: l1tf
Device-1: Intel Xeon E3-1200 v3/4th Gen Core Processor Integrated Graphics
vendor: Pegatron driver: i915 v: kernel bus ID: 00:02.0 chip ID: 8086:0412
class ID: 0300
Display: wayland server: X.org 1.20.10 compositor: gnome-shell driver:
loaded: i915 note: n/a (using device driver) - try sudo/root display ID: 0
OpenGL: renderer: Mesa DRI Intel HD Graphics 4600 (HSW GT2)
v: 4.5 Mesa 20.3.4 compat-v: 3.0 direct render: Yes
Device-1: Intel Xeon E3-1200 v3/4th Gen Core Processor HD Audio
vendor: Pegatron driver: snd_hda_intel v: kernel bus ID: 00:03.0
chip ID: 8086:0c0c class ID: 0403
Device-2: Intel 8 Series/C220 Series High Definition Audio vendor: Pegatron
driver: snd_hda_intel v: kernel bus ID: 00:1b.0 chip ID: 8086:8c20
class ID: 0403
Device-3: C-Media Audio Adapter type: USB
driver: hid-generic,snd-usb-audio,usbhid bus ID: 2-7:3 chip ID: 0d8c:000c
class ID: 0300
Device-4: Pinnacle Systems Dazzle DVC100 Audio Device type: USB
driver: em28xx,snd-usb-audio bus ID: 2-10:5 chip ID: 2304:021a
class ID: 0102
Sound Server: ALSA v: k5.4.101-1-MANJARO
vendor: Pegatron driver: r8169 v: kernel port: e000 bus ID: 03:00.0
chip ID: 10ec:8168 class ID: 0200
IF: enp3s0 state: up speed: 100 Mbps duplex: full mac: <filter>
IP v6: <filter> type: noprefixroute scope: global
Message: No Bluetooth data was found.
Local Storage: total: 2.73 TiB used: 759.8 GiB (27.2%)
ID-1: /dev/sda maj-min: 8:0 vendor: Seagate model: ST1000DM003-1CH162
size: 931.51 GiB block size: physical: 4096 B logical: 512 B speed: 6.0 Gb/s
rotation: 7200 rpm serial: <filter> rev: CC47 scheme: GPT
ID-2: /dev/sdb maj-min: 8:16 vendor: Seagate model: ST1000DM003-1ER162
size: 931.51 GiB block size: physical: 4096 B logical: 512 B speed: 3.0 Gb/s
rotation: 7200 rpm serial: <filter> rev: CC45 scheme: MBR
ID-3: /dev/sdc maj-min: 8:32 type: USB vendor: Seagate model: Expansion
serial: <filter> rev: 060E scheme: MBR
ID-1: / raw size: 60 GiB size: 58.81 GiB (98.01%) used: 17.03 GiB (29.0%)
fs: ext4 dev: /dev/sda2 maj-min: 8:2 label: N/A
uuid: 3e56f450-cdc8-415b-bb53-88599061b419
ID-2: /boot/efi raw size: 570 MiB size: 568.8 MiB (99.80%)
used: 312 KiB (0.1%) fs: vfat dev: /dev/sda5 maj-min: 8:5 label: N/A
uuid: 6407-0824
ID-3: /home raw size: 30 GiB size: 29.4 GiB (98.01%) used: 2.47 GiB (8.4%)
fs: ext4 dev: /dev/sda3 maj-min: 8:3 label: N/A
uuid: 3c41e050-f993-4d02-8b46-1a5374b6b235
ID-4: /mnt/Cosas raw size: 498.76 GiB size: 498.76 GiB (100.00%)
used: 245.82 GiB (49.3%) fs: ntfs dev: /dev/sdb6 maj-min: 8:22 label: Cosas
uuid: 5B88BB3935ED0CB9
ID-5: /mnt/Trabajo1 raw size: 220.23 GiB size: 220.23 GiB (100.00%)
used: 133.09 GiB (60.4%) fs: ntfs dev: /dev/sdb5 maj-min: 8:21
label: Trabajo1 uuid: 74F37E206086A289
ID-6: /mnt/Trabajo2 raw size: 156.25 GiB size: 156.25 GiB (100.00%)
used: 83.04 GiB (53.1%) fs: ntfs dev: /dev/sdb7 maj-min: 8:23
label: Trabajo2 uuid: 045DFFE75DF35099
ID-7: /mnt/Trabajo3 raw size: 832.85 GiB size: 818.78 GiB (98.31%)
used: 76 MiB (0.0%) fs: ext4 dev: /dev/sda4 maj-min: 8:4 label: Trabajo3
uuid: a1f55991-2e81-4153-82a6-fc2adb53f56a
ID-8: /run/media/boris/HDOcio raw size: 585.94 GiB size: 575.74 GiB (98.26%)
used: 199.77 GiB (34.7%) fs: ext4 dev: /dev/sdc2 maj-min: 8:34 label: HDOcio
uuid: be156cef-32af-4df8-90c0-17b770979205
ID-9: /run/media/boris/HDWork raw size: 345.58 GiB size: 339.15 GiB (98.14%)
used: 78.5 GiB (23.1%) fs: ext4 dev: /dev/sdc1 maj-min: 8:33 label: HDWork
uuid: c539c530-6430-4817-bbc0-30f936f900f4
ID-1: swap-1 type: partition size: 8.1 GiB used: 0 KiB (0.0%) priority: -2
dev: /dev/sda1 maj-min: 8:1 label: N/A
uuid: 1dd8f952-9877-40ac-aca2-00c9c38d1ecd
ID-1: /dev/sdb3 maj-min: 8:19 size: 1 KiB fs: <superuser required>
label: N/A uuid: N/A
Hub-1: 1-0:1 info: Full speed (or root) Hub ports: 2 rev: 2.0
speed: 480 Mb/s chip ID: 1d6b:0002 class ID: 0900
Hub-2: 1-1:2 info: Intel Integrated Rate Matching Hub ports: 4 rev: 2.0
speed: 480 Mb/s chip ID: 8087:8008 class ID: 0900
Hub-3: 2-0:1 info: Full speed (or root) Hub ports: 10 rev: 2.0
Device-1: 2-5:2 info: Realtek RTS5182 Card Reader type: Mass Storage
driver: ums-realtek interfaces: 1 rev: 2.0 speed: 480 Mb/s
chip ID: 0bda:0184 class ID: 0806 serial: <filter>
Device-2: 2-7:3 info: C-Media Audio Adapter type: Audio,HID
driver: hid-generic,snd-usb-audio,usbhid interfaces: 4 rev: 1.1
speed: 12 Mb/s chip ID: 0d8c:000c class ID: 0300
Device-3: 2-9:4
info: Seagate RSS LLC USB 3.0 bridge [Portable Expansion Drive]
type: Mass Storage driver: uas interfaces: 1 rev: 2.1 speed: 480 Mb/s
chip ID: 0bc2:2320 class ID: 0806 serial: <filter>
Device-4: 2-10:5 info: Pinnacle Systems Dazzle DVC100 Audio Device
type: Audio driver: em28xx,snd-usb-audio interfaces: 3 rev: 2.0
speed: 480 Mb/s chip ID: 2304:021a class ID: 0102
Hub-4: 3-0:1 info: Full speed (or root) Hub ports: 2 rev: 2.0
Hub-5: 3-1:2 info: Intel Integrated Rate Matching Hub ports: 6 rev: 2.0
speed: 480 Mb/s chip ID: 8087:8000 class ID: 0900
Hub-6: 4-0:1 info: Full speed (or root) Hub ports: 2 rev: 3.0 speed: 5 Gb/s
chip ID: 1d6b:0003 class ID: 0900
System Temperatures: cpu: 29.8 C mobo: 27.8 C
Processes: 215 Uptime: 5m wakeups: 0 Init: systemd v: 247 Compilers:
gcc: 10.2.0 Packages: pacman: 1233 lib: 276 flatpak: 0 Shell: Zsh v: 5.8
running in: gnome-terminal inxi: 3.3.0
Thanks …
