Today i changed kernels from 518 to 519 and started experiencing weird things like: my screen freezes after 5-10 mins from boot… any thoughts on what might be wrong?
I used 5.19 since it was released and never experiened issues with KDE like you described. I have now swtiched to 6.0 and all is well.
Should of already been on 5.19 and now 6.0. Has to be system specific. That said you should of followed the instructions for creating a proper help request thread.
Have you tried any other kernels? You could try 6.0 or the latest LTS which is 5.15
I have 515 installed but when i boot into i need to install wifi adapter driver rtw89 so i cant access internet, im gonna try that though and if the issue wont occur then i’ll try to get around the driver problem, thanks for your time man ![]()
You could install the driver for that kernel before switching to it.
Yea but i cant desktop freezes after like seconds , its worse now than it was before
installed 6.0 works thus far, lets see <3
Does it work well with suspend or hibernation when using your AMD GPU?
Sorry I can’t comment. I have suspend and hibernation disabled as I use it on my desktop.
No, because you’ve given us nothing to go on.
Please see [HowTo] Request support
I’m sorry but i don’t know what else to say, when I boot in i do my usual stuff like opening brave, browsing through internet, watch some youtube videos, write some code for work, and suddenly everything freezes, i cant do anything, i cant click on anything, i cant use shortcuts. I have to force shut down my laptop start it and then pray that it wont happen again. this doesn’t happen every time, but when it happens it is really annoying.
im new here so could you tell me what info do you need me to supply?
does it happens also with the 5.15 kernel?
provide system info:
inxi -Faz
use formatting, click this icon in editor: </>
yes i didnt like it, because i needed help and all you did was to make me feel lesser but that doesn’t matter as long as my question wasnt asked correctly. you could have said something like “cant help, need more info” and then could have specified what info could i have supplied, because i dont know… i really dont, i was just experiencing problems and i posted about it. anyways still you took your time to look at my post thanks for that, no need to reply further.
Kernel: 6.0.2-2-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 12.2.0
parameters: BOOT_IMAGE=/boot/vmlinuz-6.0-x86_64
root=UUID=25786796-5001-4c96-99cf-308604424635 rw quiet apparmor=1
security=apparmor resume=UUID=4ebdb13f-69b9-4042-b71d-ab5432cad1f1
udev.log_priority=3
Desktop: KDE Plasma v: 5.25.5 tk: Qt v: 5.15.6 info: latte-dock
wm: kwin_x11 vt: 1 dm: SDDM Distro: Manjaro Linux base: Arch Linux
Type: Laptop System: LENOVO product: 20UH003ART v: ThinkPad T14s Gen 1
Mobo: LENOVO model: 20UH003ART serial: <superuser required> UEFI: LENOVO
v: R1CET63W(1.32 ) date: 04/09/2021
ID-1: BAT0 charge: 40.3 Wh (76.6%) condition: 52.6/57.0 Wh (92.3%)
volts: 12.0 min: 11.5 model: SMP 5B10W139 type: Li-poly serial: <filter>
status: discharging cycles: 253
Info: model: AMD Ryzen 7 PRO 4750U with Radeon Graphics bits: 64
type: MT MCP arch: Zen 2 gen: 3 level: v3 note: check built: 2020-22
process: TSMC n7 (7nm) family: 0x17 (23) model-id: 0x60 (96) stepping: 1
microcode: 0x8600106
Topology: cpus: 1x cores: 8 tpc: 2 threads: 16 smt: enabled cache:
L1: 512 KiB desc: d-8x32 KiB; i-8x32 KiB L2: 4 MiB desc: 8x512 KiB
L3: 8 MiB desc: 2x4 MiB
Speed (MHz): avg: 1418 high: 1700 min/max: 1400/1700 boost: enabled
scaling: driver: acpi-cpufreq governor: schedutil cores: 1: 1700 2: 1400
3: 1400 4: 1400 5: 1397 6: 1400 7: 1400 8: 1400 9: 1400 10: 1400 11: 1400
12: 1397 13: 1400 14: 1400 15: 1400 16: 1400 bogomips: 54319
Type: retbleed mitigation: untrained return thunk; SMT enabled with STIBP
protection
Type: spectre_v2 mitigation: Retpolines, IBPB: conditional, STIBP:
always-on, RSB filling, PBRSB-eIBRS: Not affected
Device-1: AMD Renoir vendor: Lenovo driver: amdgpu v: kernel arch: GCN-5.1
code: Vega-2 process: TSMC n7 (7nm) built: 2018-21 pcie: gen: 4
speed: 16 GT/s lanes: 16 ports: active: eDP-1 empty: DP-1,DP-2,HDMI-A-1
bus-ID: 06:00.0 chip-ID: 1002:1636 class-ID: 0300 temp: 38.0 C
Device-2: IMC Networks Integrated Camera type: USB driver: uvcvideo
bus-ID: 2-2:2 chip-ID: 13d3:5415 class-ID: 0e02
Display: x11 server: X.Org v: 21.1.4 compositor: kwin_x11 driver: X:
loaded: amdgpu unloaded: modesetting alternate: fbdev,vesa dri: radeonsi
gpu: amdgpu display-ID: :0 screens: 1
s-diag: 582mm (22.93")
Monitor-1: eDP-1 mapped: eDP model: LG Display 0x0676 built: 2020
res: 1920x1080 hz: 60 dpi: 158 gamma: 1.2 size: 309x174mm (12.17x6.85")
diag: 355mm (14") ratio: 16:9 modes: max: 1920x1080 min: 640x480
OpenGL: renderer: AMD RENOIR (LLVM 14.0.6 DRM 3.48 6.0.2-2-MANJARO) v: 4.6
Mesa 22.1.7 direct render: Yes
Device-1: AMD Renoir Radeon High Definition Audio vendor: Lenovo
bus-ID: 06:00.1 chip-ID: 1002:1637 class-ID: 0403
Device-2: AMD ACP/ACP3X/ACP6x Audio Coprocessor vendor: Lenovo
driver: snd_rn_pci_acp3x v: kernel
alternate: snd_pci_acp3x,snd_pci_acp5x,snd_pci_acp6x,snd_acp_pci,snd_sof_amd_renoir
pcie: gen: 4 speed: 16 GT/s lanes: 16 bus-ID: 06:00.5 chip-ID: 1022:15e2
class-ID: 0480
Device-3: AMD Family 17h/19h HD Audio vendor: Lenovo
bus-ID: 06:00.6 chip-ID: 1022:15e3 class-ID: 0403
Sound API: ALSA v: k6.0.2-2-MANJARO running: yes
Sound Server-3: PipeWire v: 0.3.58 running: yes
vendor: Lenovo driver: r8169 v: kernel pcie: gen: 1 speed: 2.5 GT/s
lanes: 1 port: 3400 bus-ID: 02:00.0 chip-ID: 10ec:8168 class-ID: 0200
IF: enp2s0f0 state: down mac: <filter>
Device-2: Realtek RTL8852AE 802.11ax PCIe Wireless Network Adapter
vendor: Lenovo driver: rtw89_8852ae v: kernel pcie: gen: 1 speed: 2.5 GT/s
lanes: 1 port: 2000 bus-ID: 03:00.0 chip-ID: 10ec:8852 class-ID: 0280
Device-1: Realtek Bluetooth Radio type: USB driver: btusb v: 0.8
bus-ID: 6-4:3 chip-ID: 0bda:4852 class-ID: e001 serial: <filter>
Local Storage: total: 476.94 GiB used: 112.73 GiB (23.6%)
model: MZVLB512HBJQ-000L7 size: 476.94 GiB block-size: physical: 512 B
rev: 5M2QEXF7 temp: 33.9 C scheme: GPT
ID-1: / raw-size: 46.33 GiB size: 45.3 GiB (97.78%) used: 24.03 GiB (53.0%)
fs: ext4 dev: /dev/nvme0n1p8 maj-min: 259:8
ID-2: /boot/efi raw-size: 512 MiB size: 511 MiB (99.80%) used: 292 KiB
(0.1%) fs: vfat dev: /dev/nvme0n1p9 maj-min: 259:9
ID-3: /home raw-size: 97.66 GiB size: 95.56 GiB (97.86%) used: 88.7 GiB
(92.8%) fs: ext4 dev: /dev/nvme0n1p7 maj-min: 259:7
ID-1: swap-1 type: partition size: 2 GiB used: 0 KiB (0.0%) priority: -2
dev: /dev/nvme0n1p6 maj-min: 259:6
System Temperatures: cpu: 39.0 C mobo: N/A gpu: amdgpu temp: 38.0 C
Fan Speeds (RPM): fan-1: 0 fan-2: 0
Processes: 314 Uptime: 27m wakeups: 3 Memory: 14.86 GiB used: 2.8 GiB
(18.9%) Init: systemd v: 251 default: graphical tool: systemctl
Compilers: gcc: 12.2.0 clang: 14.0.6 Packages: 1351 pm: pacman pkgs: 1341
libs: 344 tools: pamac,yay pm: flatpak pkgs: 0 pm: snap pkgs: 10
Shell: fish v: 3.5.1 running-in: konsole inxi: 3.3.22
here is the info you requested, I haven’t had the chance to test it I’ll test and then reply thanks for your time.
you are running plasma so do this:
kate /etc/environment
and add there this line:
QT_LOGGING_RULES='*=false'
save it and reboot! … this will disable useless kwin/qt logs so that the logs that we need will be more readable.
ok, so switch to the 5.15LTS kernel and test… if the freeze happens again, force reboot, and then provide logs from the freeze:
journalctl -b-1 -p4 --no-pager
journalctl -b-1 -p5 --no-pager | tail -20
will do sir, thanks
Thread tidied. ![]()
Please keep the discussion on topic and be excellent to each other. ![]()
Please see:
Any further violations will result in an official warning. ![]()
