I just recently reinstalled Manjaro and I’m having an issue with my GPU.
Basically, if I leave my computer alone for too long, my GPU crashes (I think)
Basically, when I come back, the screen is frozen on the “welcome” page (Win+L page). I see my drives are still writing data tho, so I don’t think it’s a full crash.
inxi output
CPU: 10-core Intel Core i9-10850K (-MT MCP-) speed/min/max: 2913/800/5200 MHz
Kernel: 5.15.81-1-MANJARO x86_64 Up: 13m Mem: 3985.2/32015.0 MiB (12.4%)
Storage: 4.09 TiB (58.9% used) Procs: 403 Shell: Zsh inxi: 3.3.23
I have an AMD RX 6600 XT sapphire GPU for reference.
I had a very similar bug on Linux Mint, and it’s one of the reason I decided to go back to manjaro… but the bug is still there… haunting me… It doesn’t do it on my Windows Install tho, so it’s a linux bug
Thanks for any help <3
brahma
December 13, 2022, 7:51am
2
provide the full inxi output:
inxi -Faz
does it happen with different kernels?
Kernel: 5.15.81-1-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 12.2.0
root=UUID=8843859d-7877-43b6-9166-696503ea7471 rw quiet
udev.log_priority=3
Desktop: KDE Plasma v: 5.26.4 tk: Qt v: 5.15.7 wm: kwin_x11 vt: 1 dm: SDDM
Type: Desktop Mobo: Gigabyte model: Z490 AORUS ELITE AC v: x.x
serial: <superuser required> UEFI: American Megatrends v: F4
date: 06/17/2020
Info: model: Intel Core i9-10850K bits: 64 type: MT MCP arch: Comet Lake
gen: core 10 level: v3 note: check built: 2020 process: Intel 14nm family: 6
model-id: 0xA5 (165) stepping: 5 microcode: 0xF4
Topology: cpus: 1x cores: 10 tpc: 2 threads: 20 smt: enabled cache:
L1: 640 KiB desc: d-10x32 KiB; i-10x32 KiB L2: 2.5 MiB desc: 10x256 KiB
L3: 20 MiB desc: 1x20 MiB
Speed (MHz): avg: 4375 high: 4907 min/max: 800/5200 scaling:
driver: intel_pstate governor: powersave cores: 1: 4904 2: 4907 3: 4675
4: 4906 5: 4143 6: 4731 7: 4136 8: 4901 9: 4046 10: 4891 11: 4902 12: 4518
13: 4709 14: 3370 15: 4059 16: 2952 17: 4697 18: 4637 19: 3029 20: 4387
bogomips: 144040
Type: retbleed mitigation: Enhanced IBRS
prctl and seccomp
Type: spectre_v2 status: Vulnerable: eIBRS with unprivileged eBPF
Device-1: AMD Navi 23 [Radeon RX 6600/6600 XT/6600M] vendor: Sapphire
driver: amdgpu v: kernel arch: RDNA-2 code: Navi-2x process: TSMC n7 (7nm)
built: 2020-22 pcie: gen: 4 speed: 16 GT/s lanes: 16 ports:
active: DP-1,DP-2 off: HDMI-A-1 empty: DP-3 bus-ID: 03:00.0
chip-ID: 1002:73ff class-ID: 0300
Device-2: HTC (High Tech ) Vive type: USB driver: snd-usb-audio,uvcvideo
bus-ID: 1-7.1.2:14 chip-ID: 0bb4:2c87 class-ID: 0102
Display: x11 server: X.Org v: 21.1.4 compositor: kwin_x11 driver: X:
loaded: amdgpu unloaded: modesetting,radeon alternate: fbdev,vesa
dri: radeonsi gpu: amdgpu display-ID: :0 screens: 1
Screen-1: 0 s-res: 3840x1080 s-dpi: 96 s-size: 1016x285mm (40.00x11.22")
s-diag: 1055mm (41.54")
Monitor-1: DisplayPort-0 pos: right res: 1920x1080 dpi: 92
size: 531x299mm (20.91x11.77") diag: 609mm (23.99") modes: N/A
Monitor-2: DisplayPort-1 pos: primary,left res: 1920x1080 dpi: 90
size: 544x303mm (21.42x11.93") diag: 623mm (24.52") modes: N/A
API: OpenGL v: 4.6 Mesa 22.2.4 renderer: AMD Radeon RX 6600 XT (navi23
LLVM 14.0.6 DRM 3.42 5.15.81-1-MANJARO) direct render: Yes
Device-1: Intel Comet Lake PCH cAVS vendor: Gigabyte driver: snd_hda_intel
bus-ID: 1-10:6 v: kernel alternate: snd_soc_skl,snd_sof_pci_intel_cnl
chip-ID: 0951:1718 bus-ID: 00:1f.3 class-ID: 0300 chip-ID: 8086:06c8
serial: <filter> class-ID: 0403
Device-2: AMD Navi 21/23 HDMI/DP Audio driver: snd_hda_intel v: kernel
pcie: gen: 4 speed: 16 GT/s lanes: 16 bus-ID: 03:00.1 chip-ID: 1002:ab28
class-ID: 0403
Device-3: Kingston HyperX Cloud II Wireless type: USB
driver: hid-generic,snd-usb-audio,usbhid
Device-4: HTC (High Tech ) Vive type: USB driver: snd-usb-audio,uvcvideo
Device-5: HTC (High Tech ) Vive type: USB driver: hid-generic,usbhid
bus-ID: 1-7.1.5:18 chip-ID: 0bb4:2c87 class-ID: 0300 serial: <filter>
Sound API: ALSA v: k5.15.81-1-MANJARO running: yes
Sound Server-3: PipeWire v: 0.3.61 running: yes
Device-1: Intel Comet Lake PCH CNVi WiFi driver: iwlwifi v: kernel
bus-ID: 00:14.3 chip-ID: 8086:06f0 class-ID: 0280
IF: wlo1 state: down mac: <filter>
Device-2: Realtek RTL8125 2.5GbE vendor: Gigabyte driver: r8169 v: kernel
pcie: gen: 2 speed: 5 GT/s lanes: 1 port: 3000 bus-ID: 07:00.0
IF: enp7s0 state: up speed: 1000 Mbps duplex: full mac: <filter>
Device-1: Intel Bluetooth 9460/9560 Jefferson Peak (JfP) type: USB
driver: btusb v: 0.8 bus-ID: 1-14:15 chip-ID: 8087:0aaa class-ID: e001
Report: rfkill ID: hci1 rfk-id: 2 state: up address: see --recommends
Report-ID: ID: hci0 rfk-id: 1 state: up address: N/A
Local Storage: total: 4.09 TiB used: 2.41 TiB (59.0%)
ID-1: /dev/nvme0n1 maj-min: 259:1 vendor: Samsung
model: SSD 970 EVO Plus 500GB size: 465.76 GiB block-size: physical: 512 B
rev: 2B2QEXM7 temp: 43.9 C scheme: GPT
ID-2: /dev/nvme1n1 maj-min: 259:0 vendor: Samsung
rev: 2B2QEXM7 temp: 37.9 C scheme: GPT
ID-3: /dev/sda maj-min: 8:0 vendor: Crucial model: CT500BX100SSD1
type: SSD serial: <filter> rev: MU02 scheme: GPT
ID-4: /dev/sdb maj-min: 8:16 vendor: Seagate model: ST3000DM008-2DM166
size: 2.73 TiB block-size: physical: 4096 B logical: 512 B speed: 6.0 Gb/s
type: HDD rpm: 7200 serial: <filter> rev: CC26 scheme: GPT
ID-1: / raw-size: 465.46 GiB size: 457.09 GiB (98.20%)
used: 99.17 GiB (21.7%) fs: ext4 dev: /dev/nvme0n1p2 maj-min: 259:4
used: 316 KiB (0.1%) fs: vfat dev: /dev/nvme0n1p1 maj-min: 259:3
System Temperatures: cpu: 41.0 C pch: 39.0 C mobo: N/A gpu: amdgpu
temp: 58.0 C mem: 60.0 C
Fan Speeds (RPM): N/A gpu: amdgpu fan: 0
Processes: 433 Uptime: 4h 19m wakeups: 0 Memory: 31.26 GiB
used: 8.29 GiB (26.5%) Init: systemd v: 251 default: graphical
tool: systemctl Compilers: gcc: 12.2.0 clang: 14.0.6 Packages: pm: pacman
pkgs: 1376 libs: 414 tools: pamac pm: flatpak pkgs: 0 Shell: Zsh v: 5.9
default: Bash v: 5.1.16 running-in: konsole inxi: 3.3.24
It also happened with Linux Mint 20.3
Currently using Manjaro 22.0.0
felixnya:
Manjaro 22.0.0
Whatever that is.
With a rolling release distro you’re either up-to-date or you’re not: threre are no (meaningful) version numbers.
That would suggest it’s not Manjaro specific but a general problem, perhaps even hardware related (same machine).
check your RAM
try other kernels
disable power management (altogether!)
It never really crash on Windows for idling too long tho o3o;
So maybe it’s a kernel thingy… ?
brahma
December 15, 2022, 7:32am
6
yes, try the 6.0 kernel:
sudo mhwd-kernel -i linux60
reboot, and test…
if the freeze happens again, reboot and provide logs from it:
journalctl -b-1 -p4 --no-pager
