OP system has GT 730 GPU but was using nouveau driver in a previous topic instead of
video-nvidia-470xx driver
As far as I know there have been no issues with GT 730 and legacy driver
… and I don’t know either - I just constantly read about problems people have with Nvidia
It’s likely a distorted view of reality, because those without problems do not post here … ![]()
I don’t have Nividia hardware myself - zero experience with it.
mkay
I have no idea what that might mean ![]()
I knew and used Antergos
and EOS afterwards -
both where and are essentially Arch with some pre-configuration
more easy and less time consuming to deploy
but I never had Nvidia hardware …
Manjaro is the only Linux distribution that I know of that has a non-free option in GRUB to use latest nVidia proprietary drivers (linux-nvidia) on a Live ISO
It will be sitting there forever - if you typed what you posted here.
There is a character at the end of the line → `
which does not belong there and makes the command fail.
Try without that.
Did you reboot after (apparently sucessfully) installing the proprietary Nvidia driver?
