My desktop OS/computer keeps suspending or causing my monitor to turn off and my monitor just goes to a “no input” screen when I turn my monitor back on. This is happening while I walk away and let rsync copy over 1 partition/HD and all associated files and folders to another HD. As long as I’m using my computer, while rsync is running, it doesn’t turn off. However, if I walk away for a few hours and come back I find my screen off. I have already gone into “workspace behavior” > “screen locking” and unchecked “lock screen automatically”. I also went into “power management” > “energy saving” and unchecked everything in there. In activity power settings “do not use special settings” is selected. Even after all of this my computer still seems to suspend or stop doing what I had it doing. Anyone know how to stop Manjaro from suspending or turning off the monitor while afk?
inxi -Fxz
Kernel: 6.6.19-1-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 13.2.1
Desktop: KDE Plasma v: 5.27.10 Distro: Manjaro base: Arch Linux
Type: Desktop Mobo: ASUSTeK model: P8P67 DELUXE v: Rev 1.xx
serial: <superuser required> UEFI: American Megatrends v: 1503
date: 03/11/2011
Info: quad core model: Intel Core i5-2500K bits: 64 type: MCP
arch: Sandy Bridge rev: 7 cache: L1: 256 KiB L2: 1024 KiB L3: 6 MiB
Speed (MHz): avg: 2079 high: 3140 min/max: 1600/5900 cores: 1: 1600
2: 1600 3: 1978 4: 3140 bogomips: 26413
Flags: avx ht lm nx pae sse sse2 sse3 sse4_1 sse4_2 ssse3 vmx
Device-1: NVIDIA GF100 [GeForce GTX 470] driver: nouveau v: kernel
arch: Fermi bus-ID: 01:00.0 temp: 52.0 C
Display: wayland server: X.org v: 1.21.1.11 with: Xwayland v: 23.2.4
compositor: kwin_wayland driver: X: loaded: modesetting dri: nouveau
gpu: nouveau resolution: 1920x1080
API: EGL v: 1.5 drivers: nouveau,swrast platforms:
active: gbm,wayland,x11,surfaceless,device inactive: N/A
API: OpenGL v: 4.5 compat-v: 4.3 vendor: mesa v: 24.0.2-manjaro1.1
glx-v: 1.4 direct-render: yes renderer: NVC0
vendor: ASUSTeK P8P67 Deluxe driver: snd_hda_intel v: kernel bus-ID: 00:1b.0
Device-2: NVIDIA GF100 High Definition Audio driver: snd_hda_intel
v: kernel bus-ID: 01:00.1
API: ALSA v: k6.6.19-1-MANJARO status: kernel-api
Server-1: JACK v: 1.9.22 status: off
Server-2: PipeWire v: 1.0.3 status: active
Device-1: Intel 82579V Gigabit Network vendor: ASUSTeK P8P67 Deluxe
driver: e1000e v: kernel port: f040 bus-ID: 00:19.0
Device-2: Intel Wi-Fi 6E AX210/AX1675 2x2 [Typhoon Peak] driver: iwlwifi
v: kernel bus-ID: 02:00.0
Device-3: Realtek RTL8111/8168/8211/8411 PCI Express Gigabit Ethernet
vendor: ASUSTeK P8P67 and other motherboards driver: r8169 v: kernel
port: a000 bus-ID: 0f:00.0
IF: enp15s0 state: down mac: <filter>
Device-1: Intel AX210 Bluetooth driver: btusb v: 0.8 type: USB
bus-ID: 1-1.5:4
Local Storage: total: 7.28 TiB used: 3.41 TiB (46.9%)
ID-1: /dev/sda vendor: Western Digital model: WD10EZEX-08WN4A0
ID-2: /dev/sdb vendor: Western Digital model: WD4003FZEX-00Z4SA0
ID-3: /dev/sdc vendor: Western Digital model: WD10EZEX-08WN4A0
ID-4: /dev/sdd vendor: Western Digital model: WD20SDRW-11VUUS0
size: 1.82 TiB type: USB
ID-1: / size: 881.61 GiB used: 21.61 GiB (2.5%) fs: ext4 dev: /dev/sda2
ID-2: /boot/efi size: 299.4 MiB used: 296 KiB (0.1%) fs: vfat
dev: /dev/sda1
ID-1: swap-1 type: partition size: 34.46 GiB used: 0 KiB (0.0%)
dev: /dev/sda3
System Temperatures: cpu: 39.0 C mobo: N/A gpu: nouveau temp: 52.0 C
Fan Speeds (rpm): N/A gpu: nouveau fan: 0
Memory: total: 32 GiB available: 31.33 GiB used: 6.76 GiB (21.6%)
Processes: 280 Uptime: 59m Init: systemd
Packages: 1286 Compilers: clang: 16.0.6 gcc: 13.2.1 Shell: Zsh v: 5.9
inxi: 3.3.33
Systemctl status systemd-logind
systemd-logind.service - User Login Management
Loaded: loaded (/usr/lib/systemd/system/systemd-logind.service; static)
Active: active (running) since Wed 2024-03-13 16:53:29 EDT; 1h 1min ago
Docs: man:sd-login(3)
man:systemd-logind.service(8)
man:logind.conf(5)
man:org.freedesktop.login1(5)
Main PID: 555 (systemd-logind)
Status: "Processing requests..."
Tasks: 1 (limit: 38455)
FD Store: 13 (limit: 512)
Memory: 3.2M (peak: 6.3M)
CPU: 112ms
CGroup: /system.slice/systemd-logind.service
└─555 /usr/lib/systemd/systemd-logind
Mar 13 16:53:29 Manjaro-PC systemd-logind[555]: Watching system buttons on /dev/input/event3 (HID 1bcf:08a0 Keyboar>
Mar 13 16:53:29 Manjaro-PC systemd-logind[555]: Watching system buttons on /dev/input/event5 (Macally Peripherals M>
Mar 13 16:53:29 Manjaro-PC systemd-logind[555]: Watching system buttons on /dev/input/event6 (Macally Peripherals M>
Mar 13 16:53:29 Manjaro-PC systemd-logind[555]: Watching system buttons on /dev/input/event7 (Macally Peripherals M>
Mar 13 16:53:29 Manjaro-PC systemd[1]: Started User Login Management.
Mar 13 16:53:38 Manjaro-PC systemd-logind[555]: New session c1 of user sddm.
Mar 13 16:53:52 Manjaro-PC systemd-logind[555]: New session 2 of user dragon.
Mar 13 16:53:53 Manjaro-PC systemd-logind[555]: Session c1 logged out. Waiting for processes to exit.
Mar 13 16:53:53 Manjaro-PC systemd-logind[555]: Removed session c1.
Mar 13 17:29:37 Manjaro-PC systemd-logind[555]: Watching system buttons on /dev/input/event24 (WH-1000XM4 (AVRCP)
xset q
Keyboard Control:
auto repeat: on key click percent: 0 LED mask: 00000000
XKB indicators:
00: Caps Lock: off 01: Num Lock: off 02: Scroll Lock: off
03: Compose: off 04: Kana: off 05: Sleep: off
06: Suspend: off 07: Mute: off 08: Misc: off
09: Mail: off 10: Charging: off 11: Shift Lock: off
12: Group 2: off 13: Mouse Keys: off
auto repeat delay: 660 repeat rate: 25
auto repeating keys: 00ffffffdffffbbf
fadfffefffedffff
9fffffffffffffff
fff7ffffffffffff
bell percent: 50 bell pitch: 400 bell duration: 100
Pointer Control:
acceleration: 2/1 threshold: 4
Screen Saver:
prefer blanking: yes allow exposures: yes
timeout: 0 cycle: 0
Colors:
default colormap: 0x3f BlackPixel: 0x0 WhitePixel: 0xffffff
Font Path:
/usr/share/fonts/misc,/usr/share/fonts/TTF,built-ins
DPMS (Display Power Management Signaling):
Server does not have the DPMS Extension
journalctl | grep -iE “suspend|sleep|blank” (Issue happened today March 13 only included a snipit starting yesterday night till today when I tried to use the suspend key to try and wake up the monitor and it didn’t work.)
Mar 12 20:13:09 Manjaro-PC libddcutil[881]: busno=4, sleep-multiplier = 1.00. Testing for supported feature 0x10 returned Error_Info[ENXIO in ddc_write_read_with_retry, causes: ENXIO]
Mar 12 20:21:00 Manjaro-PC CROND[638]: (root) CMDEND (sleep 10m && timeshift --create --scripted --tags B)
Mar 13 10:46:44 Manjaro-PC CROND[648]: (root) CMD (sleep 10m && timeshift --create --scripted --tags B)
Mar 13 10:58:05 Manjaro-PC CROND[647]: (root) CMDEND (sleep 10m && timeshift --create --scripted --tags B)
Mar 13 16:36:49 Manjaro-PC systemd-logind[564]: Suspend key pressed short.
Mar 13 16:36:49 Manjaro-PC systemd-logind[564]: Suspending...
Mar 13 16:36:49 Manjaro-PC ModemManager[621]: <msg> [sleep-monitor-systemd] system is about to suspend
