I have to update 544 packages but every time I attempt to do so it fails and the amount I need to update keeps piling up.
The messages I get are
“Failed to perform transaction.” Failed to clone ceph-libs build files could not satisfy dependencies: - unable to satisfy dependency 'ocaml<=4.14' required by ocamlnet - unable to satisfy dependency 'ocaml-base>=0.16.0' required by ocaml-ppx_let
A - Dont keep unsupported packages.
B - Dont do your updates as a batch - instead update repo packages then the AUR if used.
C - Do both of the above.
This will at least let you update your system.
As to
This probably means you dont have the prerequisites for using the AUR. See the first section. The packages trying to be updated are not in the repos. If you intend to use the AUR then you must read some things;
