Hej there!
I installed Manjaro GNOME some weeks ago on my Thinkpad X230. Suddenly, it became incredibly slow and laggy, sometimes takes 1 second for letters to appear when I type, volumebuttons also take their time, RAM is 6,5/8 GB plus some GB in SWAP file, it affects every bit of software. updating and rebooting doesn’t change anything. I have gone through some different setups with this machine, but now it is the slowest it ever was! Would appreciate some help
~ >>> inxi -Fza
System: Kernel: 5.7.15-1-MANJARO x86_64 bits: 64 compiler: gcc v: 10.1.0
parameters: BOOT_IMAGE=/boot/vmlinuz-5.7-x86_64 root=UUID=45cc9148-4826-498d-a298-0d2a04986429 rw quiet apparmor=1
Desktop: GNOME 3.36.5 tk: GTK 3.24.23 wm: gnome-shell dm: GDM 3.36.3 Distro: Manjaro Linux
Machine: Type: Laptop System: LENOVO product: 2325ZKJ v: ThinkPad X230 serial: <filter> Chassis: type: 10 serial: <filter>
Mobo: LENOVO model: 2325ZKJ serial: <filter> UEFI [Legacy]: LENOVO v: G2ETB7WW (2.77 ) date: 09/24/2019
Battery: ID-1: BAT0 charge: 42.4 Wh condition: 42.6/62.6 Wh (68%) volts: 12.3/10.8 model: SANYO 45N1172 type: Li-ion
serial: <filter> status: Charging
CPU: Topology: Dual Core model: Intel Core i5-3320M bits: 64 type: MT MCP arch: Ivy Bridge family: 6 model-id: 3A (58)
stepping: 9 microcode: 21 L2 cache: 3072 KiB
flags: avx lm nx pae sse sse2 sse3 sse4_1 sse4_2 ssse3 vmx bogomips: 20759
Speed: 1197 MHz min/max: 1200/3300 MHz Core speeds (MHz): 1: 1198 2: 1197 3: 1197 4: 1198
Type: l1tf mitigation: PTE Inversion; VMX: conditional cache flushes, SMT vulnerable
Type: spectre_v2 mitigation: Full generic retpoline, IBPB: conditional, IBRS_FW, STIBP: conditional, RSB filling
Type: srbds status: Vulnerable: No microcode
Graphics: Device-1: Intel 3rd Gen Core processor Graphics vendor: Lenovo driver: i915 v: kernel bus ID: 00:02.0
chip ID: 8086:0166
Device-2: Acer ThinkPad Integrated Camera type: USB driver: uvcvideo bus ID: 1-1.6:5 chip ID: 5986:02d2
Display: x11 server: X.org 1.20.8 compositor: gnome-shell driver: intel unloaded: modesetting alternate: fbdev,vesa
resolution: <xdpyinfo missing>
OpenGL: renderer: Mesa DRI Intel HD Graphics 4000 (IVB GT2) v: 4.2 Mesa 20.1.7 compat-v: 3.0 direct render: Yes
Audio: Device-1: Intel 7 Series/C216 Family High Definition Audio vendor: Lenovo driver: snd_hda_intel v: kernel
bus ID: 00:1b.0 chip ID: 8086:1e20
Sound Server: ALSA v: k5.7.15-1-MANJARO
Network: Device-1: Intel 82579LM Gigabit Network vendor: Lenovo driver: e1000e v: 3.2.6-k port: 6080 bus ID: 00:19.0
chip ID: 8086:1502
IF: enp0s25 state: down mac: <filter>
Device-2: Intel Centrino Advanced-N 6205 [Taylor Peak] driver: iwlwifi v: kernel port: efa0 bus ID: 03:00.0
chip ID: 8086:0085
Drives: Local Storage: total: 931.52 GiB used: 78.92 GiB (8.5%)
ID-1: /dev/sda vendor: Crucial model: CT500MX500SSD1 size: 465.76 GiB block size: physical: 512 B logical: 512 B
speed: 6.0 Gb/s serial: <filter> rev: 023 scheme: MBR
ID-2: /dev/sdb vendor: Samsung model: SSD 860 EVO mSATA 500GB size: 465.76 GiB block size: physical: 512 B
logical: 512 B speed: 3.0 Gb/s serial: <filter> rev: 2B6Q scheme: GPT
Partition: ID-1: / raw size: 340.90 GiB size: 334.54 GiB (98.14%) used: 44.79 GiB (13.4%) fs: ext4 dev: /dev/sda3
Swap: Kernel: swappiness: 10 (default 60) cache pressure: 100 (default)
ID-1: swap-1 type: file size: 12.00 GiB used: 2.86 GiB (23.9%) priority: -2 file: /swapfile
Sensors: System Temperatures: cpu: 47.0 C mobo: 0.0 C
Fan Speeds (RPM): cpu: 2970
Info: Processes: 275 Uptime: 11d 7h 50m Memory: 7.46 GiB used: 6.57 GiB (88.0%) Init: systemd v: 246 Compilers:
gcc: 10.2.0 Packages: pacman: 1275 lib: 358 flatpak: 0 Shell: Zsh v: 5.8 running in: guake inxi: 3.1.05
Check the output from top/htop - see what’s using your CPU cycles.
Wollie
September 8, 2020, 11:09pm
#3
How do you know as you obviously did not update for a while as you are still on
kernel 5.7.15 (which is EOL by the way)? But main reason for your problem is that you are running in using the swapfile which always slows down the system dramatically, you need to reduce you memory consumption, how to do is mentioned by @anothermindbomb already.
I’m definitely curious about the issue you are facing. I also have a Thinkpad x230 and have not experienced any performance issues. Just at the moment I don’t have enough parameters to simulate what you are experiencing.
You will notice in my setup that I am using an older kernel (4.19.143-1 because there are problems with the Intel e1000e LAN driver an the 5.4.6.2-1 LTS Kernel.
This is my setup:
Kernel: 4.19.143-1-MANJARO x86_64 bits: 64 compiler: gcc v: 10.2.0
parameters: BOOT_IMAGE=/boot/vmlinuz-4.19-x86_64
root=UUID=85ccbb8b-086b-4c3b-a6c8-a45951356c8e rw apparmor=1 security=apparmor
usbcore.autosuspend=-1
Type: Laptop System: LENOVO product: 2325XXX v: ThinkPad X230 serial: <filter>
Mobo: LENOVO model: 2325XXX serial: <filter> UEFI [Legacy]: LENOVO
ID-1: BAT0 charge: 33.9 Wh condition: 34.9/57.7 Wh (60%) volts: 12.5/11.1
model: LGC 45N1025 type: Li-ion serial: <filter> status: Charging
arch: Ivy Bridge family: 6 model-id: 3A (58) stepping: 9 microcode: 21
L2 cache: 3072 KiB
flags: avx lm nx pae sse sse2 sse3 sse4_1 sse4_2 ssse3 vmx bogomips: 20751
Speed: 1755 MHz min/max: 1200/3300 MHz Core speeds (MHz): 1: 2389 2: 3235
3: 2579 4: 1269
Type: l1tf
v: kernel bus ID: 00:02.0 chip ID: 8086:0166
Display: x11 server: X.Org 1.20.8 compositor: gnome-shell driver: intel
display ID: :0 screens: 1
Screen-1: 0 s-res: 1366x768 s-dpi: 96 s-size: 361x203mm (14.2x8.0")
s-diag: 414mm (16.3")
Monitor-1: LVDS1 res: 1366x768 hz: 60 dpi: 124 size: 280x160mm (11.0x6.3")
diag: 322mm (12.7")
driver: snd_hda_intel v: kernel bus ID: 00:1b.0 chip ID: 8086:1e20
Sound Server: ALSA v: k4.19.143-1-MANJARO
v: 3.8.4-NAPI port: 6080 bus ID: 00:19.0 chip ID: 8086:1502
v: kernel port: efa0 bus ID: 03:00.0 chip ID: 8086:0085
Local Storage: total: 465.76 GiB used: 51.00 GiB (10.9%)
ID-1: /dev/sda vendor: Samsung model: SSD 860 EVO 500GB size: 465.76 GiB
block size: physical: 512 B logical: 512 B speed: 6.0 Gb/s serial: <filter>
rev: 1B6Q scheme: MBR
SMART Message: Unknown smartctl error. Unable to get data.
ID-1: / raw size: 147.46 GiB size: 144.15 GiB (97.75%) used: 51.00 GiB (35.4%)
fs: ext4 block size: 4096 B dev: /dev/sda4
System Temperatures: cpu: 48.0 C mobo: N/A
Fan Speeds (RPM): cpu: 0
Processes: 207 Uptime: 1h 55m Memory: 11.43 GiB used: 1.57 GiB (13.8%)
Init: systemd v: 246 Compilers: gcc: 10.2.0 Packages: 1478 pacman: 1467
lib: 415 flatpak: 11 Shell: fish v: 3.1.2 running in: alacritty inxi: 3.1.05
