Thank you!
In pavucontrol my microphone is marked as unplugged…
I repeat, this problem appeared with version 24.2.*
My system:
Kernel: 6.11.11-1-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 14.2.1
parameters: BOOT_IMAGE=/boot/vmlinuz-6.11-x86_64
root=UUID=9ab82011-5801-4ee8-8f24-1b1f941594ef rw
resume=UUID=c357d08a-5f1b-4b09-9189-126adde2132e udev.log_priority=3
Desktop: Xfce v: 4.18.1 tk: Gtk v: 3.24.43 wm: xfwm4 v: 4.18.0
with: xfce4-panel tools: xfce4-screensaver avail: light-locker vt: 7
dm: LightDM v: 1.32.0 Distro: Manjaro base: Arch Linux
Type: Laptop System: TIMI product: Redmi Book Pro 15 2022 v: N/A
Mobo: TIMI model: TM2113 v: V14H2 serial: <superuser required>
part-nu: TM2113-39463 uuid: <superuser required> UEFI: TIMI v: RMARB5B0P1111
date: 02/27/2024
ID-1: BAT0 charge: 21.0 Wh (34.8%) condition: 60.3/72.0 Wh (83.8%)
power: 23.5 W volts: 14.3 min: 15.4 model: SUNWODA R15B06W type: Li-ion
serial: <filter> status: discharging
System RAM: total: 16 GiB available: 14.81 GiB used: 4.4 GiB (29.7%)
Array-1: capacity: 64 GiB slots: 4 modules: 4 EC: None
Device-1: Channel-A DIMM 0 type: LPDDR5 detail: synchronous unbuffered
(unregistered) size: 4 GiB speed: 6400 MT/s volts: curr: 0.5 min: 0.5
max: 0.5 width (bits): data: 32 total: 32 manufacturer: Samsung
part-no: K3LKBKB0BM-MGCP serial: N/A
Device-2: Channel-B DIMM 0 type: LPDDR5 detail: synchronous unbuffered
Device-3: Channel-C DIMM 0 type: LPDDR5 detail: synchronous unbuffered
Device-4: Channel-D DIMM 0 type: LPDDR5 detail: synchronous unbuffered
Info: model: AMD Ryzen 7 6800H with Radeon Graphics bits: 64 type: MT MCP
arch: Zen 3+ gen: 3 level: v3 note: check built: 2022 process: TSMC n6 (7nm)
family: 0x19 (25) model-id: 0x44 (68) stepping: 1 microcode: 0xA404107
desc: 8x512 KiB L3: 16 MiB desc: 1x16 MiB
Speed (MHz): avg: 1397 min/max: 400/4785 boost: enabled scaling:
driver: amd-pstate-epp governor: powersave cores: 1: 1397 2: 1397 3: 1397
4: 1397 5: 1397 6: 1397 7: 1397 8: 1397 9: 1397 10: 1397 11: 1397 12: 1397
13: 1397 14: 1397 15: 1397 16: 1397 bogomips: 102250
cqm_occup_llc cr8_legacy cx16 cx8 de debug_swap decodeassists extapic
extd_apicid f16c flushbyasid fma fpu fsgsbase fxsr fxsr_opt ht hw_pstate
ibpb ibrs ibs invpcid irperf lahf_lm lbrv lm mba mca mce misalignsse mmx
mmxext monitor movbe msr mtrr mwaitx nonstop_tsc nopl npt nrip_save nx
ospke osvw overflow_recov pae pat pausefilter pclmulqdq pdpe1gb
perfctr_core perfctr_llc perfctr_nb pfthreshold pge pku pni popcnt pse
pse36 rapl rdpid rdpru rdrand rdseed rdt_a rdtscp rep_good sep sha_ni
skinit smap smca smep ssbd sse sse2 sse4_1 sse4_2 sse4a ssse3 stibp succor
svm svm_lock syscall tce topoext tsc tsc_scale umip user_shstk v_spec_ctrl
v_vmsave_vmload vaes vgif vmcb_clean vme vmmcall vpclmulqdq wbnoinvd wdt
x2apic xgetbv1 xsave xsavec xsaveerptr xsaveopt xsaves xtopology
affected
Device-1: Advanced Micro Devices [AMD/ATI] Rembrandt [Radeon 680M]
vendor: Xiaomi driver: amdgpu v: kernel arch: RDNA-2 code: Navi-2x
process: TSMC n7 (7nm) built: 2020-22 pcie: gen: 4 speed: 16 GT/s lanes: 16
ports: active: eDP-1 empty: DP-1, DP-2, DP-3, DP-4, DP-5, HDMI-A-1,
Writeback-1 bus-ID: 04:00.0 chip-ID: 1002:1681 class-ID: 0300 temp: 46.0 C
Device-2: SunplusIT XiaoMi USB 2.0 Webcam driver: uvcvideo type: USB
rev: 2.0 speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 5-1:2 chip-ID: 2b7e:b557
Display: x11 server: X.org v: 1.21.1.14 compositor: xfwm4 v: 4.18.0 driver:
X: loaded: amdgpu unloaded: modesetting alternate: fbdev,vesa dri: radeonsi
gpu: amdgpu display-ID: :0.0 screens: 1
Screen-1: 0 s-res: 3200x2000 s-size: <missing: xdpyinfo>
Monitor-1: eDP-1 mapped: eDP model: TL156MDMP11-0 built: 2021
res: 3200x2000 dpi: 242 gamma: 1.2 chroma: red: x: 0.639 y: 0.329 green:
x: 0.298 y: 0.600 blue: x: 0.149 y: 0.059 white: x: 0.306 y: 0.318
size: 336x210mm (13.23x8.27") diag: 396mm (15.6") ratio: 16:10
modes: 3200x2000, 1920x1200, 1920x1080, 1600x1200, 1680x1050, 1280x1024,
1440x900, 1280x800, 1280x720, 1024x768, 800x600, 640x480
device: 1 drv: swrast gbm: drv: kms_swrast surfaceless: drv: radeonsi x11:
API: OpenGL v: 4.6 compat-v: 4.5 vendor: amd mesa v: 24.2.8-arch1.1
rembrandt LLVM 18.1.8 DRM 3.59 6.11.11-1-MANJARO) device-ID: 1002:1681
memory: 500 MiB unified: no
Device-1: Advanced Micro Devices [AMD/ATI] Rembrandt Radeon High Definition
Audio vendor: Xiaomi driver: snd_hda_intel v: kernel pcie: gen: 4
speed: 16 GT/s lanes: 16 bus-ID: 04:00.1 chip-ID: 1002:1640 class-ID: 0403
Device-2: Advanced Micro Devices [AMD] ACP/ACP3X/ACP6x Audio Coprocessor
vendor: Xiaomi driver: snd_pci_acp6x v: kernel alternate: snd_pci_acp3x,
snd_rn_pci_acp3x, snd_pci_acp5x, snd_acp_pci, snd_rpl_pci_acp6x,
snd_pci_ps, snd_sof_amd_renoir, snd_sof_amd_rembrandt,
snd_sof_amd_vangogh, snd_sof_amd_acp63 pcie: gen: 4 speed: 16 GT/s
lanes: 16 bus-ID: 04:00.5 chip-ID: 1022:15e2 class-ID: 0480
vendor: Xiaomi driver: snd_hda_intel v: kernel pcie: gen: 4 speed: 16 GT/s
lanes: 16 bus-ID: 04:00.6 chip-ID: 1022:15e3 class-ID: 0403
API: ALSA v: k6.11.11-1-MANJARO status: kernel-api with: aoss
Server-2: PipeWire v: 1.2.7 status: active with: 1: pipewire-pulse
Device-1: Intel Wi-Fi 6E AX210/AX1675 2x2 [Typhoon Peak] driver: iwlwifi
v: kernel pcie: gen: 2 speed: 5 GT/s lanes: 1 bus-ID: 01:00.0
chip-ID: 8086:2725 class-ID: 0280
Device-1: Intel AX210 Bluetooth driver: btusb v: 0.8 type: USB rev: 2.0
speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 3-3:2 chip-ID: 8087:0032
class-ID: e001
Report: rfkill ID: hci0 rfk-id: 3 state: up address: see --recommends
Local Storage: total: 476.94 GiB used: 133.03 GiB (27.9%)
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Phison model: CFESR512GMTCT-E9C-2
size: 476.94 GiB block-size: physical: 512 B logical: 512 B speed: 63.2 Gb/s
lanes: 4 tech: SSD serial: <filter> fw-rev: EJFM31.2 temp: 29.9 C
scheme: GPT
ID-1: / raw-size: 360.53 GiB size: 353.81 GiB (98.13%)
used: 132.62 GiB (37.5%) fs: ext4 dev: /dev/nvme0n1p5 maj-min: 259:5
label: N/A uuid: 9ab82011-5801-4ee8-8f24-1b1f941594ef
used: 308 KiB (0.1%) fs: vfat dev: /dev/nvme0n1p6 maj-min: 259:6 label: N/A
uuid: EF8D-11E3
ID-1: swap-1 type: partition size: 16 GiB used: 428.4 MiB (2.6%)
priority: -2 dev: /dev/nvme0n1p4 maj-min: 259:4 label: N/A
uuid: c357d08a-5f1b-4b09-9189-126adde2132e
ID-1: /dev/nvme0n1p1 maj-min: 259:1 size: 100 MiB fs: vfat label: N/A
uuid: B842-12BF
ID-2: /dev/nvme0n1p2 maj-min: 259:2 size: 16 MiB fs: <superuser required>
label: N/A uuid: N/A
ID-3: /dev/nvme0n1p3 maj-min: 259:3 size: 100 GiB fs: ntfs label: N/A
uuid: 3AD24719D246D931
Device-1: 1-3:2 info: FPC Sensor Controller L:0001 FW:021.26.2.031
type: <vendor specific> driver: N/A interfaces: 1 rev: 1.1
chip-ID: 10a5:9201 class-ID: 0000
Hub-3: 3-0:1 info: hi-speed hub with single TT ports: 3 rev: 2.0
Device-1: 3-3:2 info: Intel AX210 Bluetooth type: bluetooth driver: btusb
power: 100mA chip-ID: 8087:0032 class-ID: e001
Hub-5: 5-0:1 info: hi-speed hub with single TT ports: 1 rev: 2.0
Device-1: 5-1:2 info: SunplusIT XiaoMi USB 2.0 Webcam type: video
driver: uvcvideo interfaces: 2 rev: 2.0 speed: 480 Mb/s (57.2 MiB/s) lanes: 1
mode: 2.0 power: 500mA chip-ID: 2b7e:b557 class-ID: 0e02 serial: <filter>
Hub-6: 6-0:1 info: Linux Foundation 3.0 root hub ports: N/A rev: 3.0
Hub-7: 7-0:1 info: hi-speed hub with single TT ports: 1 rev: 2.0
Hub-8: 8-0:1 info: super-speed hub ports: 1 rev: 3.1
Hub-9: 9-0:1 info: hi-speed hub with single TT ports: 1 rev: 2.0
Hub-10: 10-0:1 info: super-speed hub ports: 1 rev: 3.1
System Temperatures: cpu: 47.2 C mobo: N/A gpu: amdgpu temp: 46.0 C
Fan Speeds (rpm): N/A
Packages: pm: pacman pkgs: 1318 libs: 491 tools: pamac
1: https://mirrors.cicku.me/manjaro/stable/$repo/$arch
2: https://mirrors.manjaro.org/repo/stable/$repo/$arch
3: https://mirrors2.manjaro.org/stable/$repo/$arch
Processes:
CPU top: 5 of 373
1: cpu: 10.5% command: chromium pid: 345746 mem: 225.1 MiB (1.4%)
2: cpu: 2.4% command: chromium pid: 1577 mem: 227.0 MiB (1.4%)
3: cpu: 2.2% command: chromium pid: 338990 mem: 238.8 MiB (1.5%)
4: cpu: 1.8% command: htop pid: 114034 mem: 8.10 MiB (0.0%)
5: cpu: 1.4% command: chromium pid: 338732 mem: 219.3 MiB (1.4%)
Memory top: 5 of 373
1: mem: 1281.1 MiB (8.4%) command: telegram-desktop pid: 258060 cpu: 0.7%
2: mem: 296.4 MiB (1.9%) command: chromium pid: 1538 cpu: 0.9%
3: mem: 290.7 MiB (1.9%) command: chromium pid: 1855 cpu: 0.0%
4: mem: 238.8 MiB (1.5%) command: chromium pid: 338990 cpu: 2.2%
5: mem: 227.0 MiB (1.4%) command: chromium pid: 1577 cpu: 2.4%
Processes: 373 Power: uptime: 1d 22h 32m states: freeze,mem,disk
suspend: s2idle wakeups: 6 hibernate: platform avail: shutdown, reboot,
suspend, test_resume image: 5.91 GiB services: upowerd,xfce4-power-manager
Init: systemd v: 256 default: graphical tool: systemctl
Compilers: clang: 18.1.8 gcc: 14.2.1 Shell: Bash v: 5.2.37
running-in: tilix inxi: 3.3.36
