My microphone is not working in MSI GF63
External microphone not working on MSI GF63…I have tried many solution in this forum…but not working…Any one know the proper working solution as of now…please reply…
cat /proc/asound/card0/codec# | grep Codec*
Codec: Realtek ALC233
Codec: Intel Kabylake HDMI
Please don’t post the previous answers…none is working
Which previous answers? And what did you already try?
What is an “external” microphone? How is it connected?
If you read all previous posts, you should know how to properly add necessary information about your system.
  Kernel: 5.15.49-1-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 12.1.0
    root=UUID=b89d6ba3-3f12-491a-96f8-2c1757db24f9 rw quiet apparmor=1
  Desktop: KDE Plasma v: 5.24.5 tk: Qt v: 5.15.5 wm: kwin_x11 vt: 1
  Type: Laptop System: Micro-Star product: GF63 Thin 9SCXR v: REV:1.0
  Mobo: Micro-Star model: MS-16R4 v: REV:1.0 serial: <superuser required>
    UEFI: American Megatrends v: E16R4IMS.504 date: 04/21/2020
  ID-1: BAT1 charge: 22.3 Wh (49.9%) condition: 44.7/51.3 Wh (87.2%)
    volts: 11.0 min: 11.4 model: MSI Corp. MS-16R4 type: Li-ion serial: N/A
    status: discharging
  Info: model: Intel Core i7-9750H bits: 64 type: MT MCP arch: Coffee Lake
    gen: core 9 built: 2018 process: Intel 14nm family: 6 model-id: 0x9E (158)
    stepping: 0xA (10) microcode: 0xF0
    L1: 384 KiB desc: d-6x32 KiB; i-6x32 KiB L2: 1.5 MiB desc: 6x256 KiB
    L3: 12 MiB desc: 1x12 MiB
  Speed (MHz): avg: 800 min/max: 800/4500 scaling: driver: intel_pstate
    governor: powersave cores: 1: 800 2: 800 3: 800 4: 800 5: 800 6: 800 7: 800
    8: 800 9: 800 10: 800 11: 800 12: 800 bogomips: 62431
  Type: l1tf
  Device-1: Intel CoffeeLake-H GT2 [UHD Graphics 630] vendor: Micro-Star MSI
    driver: i915 v: kernel arch: Gen9.5 process: Intel 14nm built: 2016-20
    ports: active: eDP-1 empty: DP-1,HDMI-A-1,HDMI-A-2 bus-ID: 00:02.0
    chip-ID: 8086:3e9b class-ID: 0300
  Device-2: NVIDIA TU117M vendor: Micro-Star MSI driver: nvidia
    v: 515.48.07 alternate: nouveau,nvidia_drm non-free: 515.xx+
    status: current (as of 2022-06) arch: Turing process: TSMC 12nm
    built: 2018-22 pcie: speed: Unknown lanes: 63 link-max: gen: 6
    speed: 64 GT/s bus-ID: 01:00.0 chip-ID: 10de:1f99 class-ID: 0302
  Display: x11 server: X.Org v: 21.1.3 compositor: kwin_x11 driver: X:
    loaded: modesetting unloaded: nouveau,nvidia alternate: fbdev,nv,vesa
    gpu: i915 display-ID: :0 screens: 1
    s-diag: 582mm (22.93")
  Monitor-1: eDP-1 model: AU Optronics 0x21ed built: 2016 res: 1920x1080
    hz: 60 dpi: 142 gamma: 1.2 size: 344x193mm (13.54x7.6") diag: 394mm (15.5")
    ratio: 16:9 modes: 1920x1080
  OpenGL: renderer: Mesa Intel UHD Graphics 630 (CFL GT2)
    v: 4.6 Mesa 22.1.2 direct render: Yes
  Device-1: Intel Cannon Lake PCH cAVS vendor: Micro-Star MSI
    driver: snd_hda_intel v: kernel
    alternate: snd_soc_skl,snd_sof_pci_intel_cnl bus-ID: 00:1f.3
  Sound Server-1: ALSA v: k5.15.49-1-MANJARO running: yes
  Sound Server-4: PipeWire v: 0.3.52 running: yes
  Device-1: Intel Cannon Lake PCH CNVi WiFi driver: iwlwifi v: kernel
    bus-ID: 00:14.3 chip-ID: 8086:a370 class-ID: 0280
    vendor: Micro-Star MSI driver: r8169 v: kernel pcie: gen: 1 speed: 2.5 GT/s
    lanes: 1 port: 3000 bus-ID: 03:00.0 chip-ID: 10ec:8168 class-ID: 0200
  Device-1: Intel Bluetooth 9460/9560 Jefferson Peak (JfP) type: USB
    driver: btusb v: 0.8 bus-ID: 1-14:3 chip-ID: 8087:0aaa class-ID: e001
  Local Storage: total: 476.94 GiB used: 128.7 GiB (27.0%)
  ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Kingston model: OM8PCP3512F-AI1
    size: 476.94 GiB block-size: physical: 512 B logical: 512 B
    speed: 31.6 Gb/s lanes: 4 type: SSD serial: <filter> rev: ECFK52.8
    temp: 33.9 C scheme: GPT
  ID-1: / raw-size: 254.88 GiB size: 249.82 GiB (98.01%)
    used: 41.39 GiB (16.6%) fs: ext4 dev: /dev/nvme0n1p6 maj-min: 259:6
  ID-2: /boot/efi raw-size: 300 MiB size: 296 MiB (98.67%)
    used: 27.7 MiB (9.4%) fs: vfat dev: /dev/nvme0n1p1 maj-min: 259:1
  System Temperatures: cpu: 41.0 C pch: 55.0 C mobo: N/A
  Processes: 304 Uptime: 11m wakeups: 1 Memory: 7.61 GiB
  used: 2.38 GiB (31.3%) Init: systemd v: 251 default: graphical
  tool: systemctl Compilers: gcc: 12.1.0 clang: 13.0.1 Packages: pacman: 1339
  lib: 350 flatpak: 0 Shell: Zsh v: 5.9 running-in: konsole inxi: 3.3.19
list-sources
2 source(s) available.
  * index: 0
        driver: <module-alsa-card.c>
        flags: DECIBEL_VOLUME LATENCY DYNAMIC_LATENCY
        state: SUSPENDED
        suspend cause: IDLE
        priority: 1030
        volume: front-left: 65536 / 100% / 0.00 dB,   front-right: 65536 / 100% / 0.00 dB
                balance 0.00
        base volume: 65536 / 100% / 0.00 dB
        volume steps: 65537
        muted: no
        current latency: 0.00 ms
        max rewind: 0 KiB
        sample spec: s16le 2ch 44100Hz
        channel map: front-left,front-right
                     Stereo
        used by: 0
        linked by: 0
        configured latency: 0.00 ms; range is 0.50 .. 2000.00 ms
        monitor_of: 0
        card: 0 <alsa_card.pci-0000_00_1f.3>
        module: 6
        properties:
                device.description = "Monitor of Built-in Audio Analog Stereo"
                device.class = "monitor"
                alsa.card = "0"
                alsa.long_card_name = "HDA Intel PCH at 0xa4410000 irq 147"
                sysfs.path = "/devices/pci0000:00/0000:00:1f.3/sound/card0"
                device.bus = "pci"
                device.vendor.id = "8086"
                device.product.id = "a348"
                device.product.name = "Cannon Lake PCH cAVS"
                device.string = "0"
                module-udev-detect.discovered = "1"
                device.icon_name = "audio-card-pci"
    index: 1
        flags: HARDWARE HW_MUTE_CTRL HW_VOLUME_CTRL DECIBEL_VOLUME LATENCY DYNAMIC_LATENCY
        state: SUSPENDED
        suspend cause: IDLE
        priority: 9039
        volume: front-left: 30421 /  46% / -20.00 dB,   front-right: 30421 /  46% / -20.00 dB
                balance 0.00
        base volume: 6554 /  10% / -60.00 dB
        volume steps: 65537
        muted: no
        max rewind: 0 KiB
                     Stereo
        used by: 0
        linked by: 0
        module: 6
        properties:
                alsa.resolution_bits = "16"
                device.api = "alsa"
                device.class = "sound"
                alsa.class = "generic"
                alsa.subclass = "generic-mix"
                alsa.name = "ALC233 Analog"
                alsa.id = "ALC233 Analog"
                alsa.subdevice = "0"
                alsa.subdevice_name = "subdevice #0"
                alsa.device = "0"
                alsa.card = "0"
                device.bus = "pci"
                device.string = "front:0"
                device.buffering.buffer_size = "352800"
                device.buffering.fragment_size = "176400"
                device.access_mode = "mmap+timer"
                device.profile.name = "analog-stereo"
                device.profile.description = "Analog Stereo"
                device.description = "Built-in Audio Analog Stereo"
        ports:
                analog-input-rear-mic: Rear Microphone (priority 8200, latency offset 0 usec, available: no)
                        properties:
                analog-input-internal-mic: Internal Microphone (priority 8900, latency offset 0 usec, available: unknown)
                        properties:
                analog-input-mic: Microphone (priority 8700, latency offset 0 usec, available: no)
                        properties:
        active port: <analog-input-rear-mic>
alsa-info.sh
http://alsa-project.org/db/?f=3153258c91452ea88f19a4e8d6bce7e594d3982e
anymore information needed please tell me…MSI GF63 model…microphone shows unplugged…
Try using only pipewire: pamac install manjaro-pipewire
Did you install sof-firmware?
Did you plug the microphone fully into the correct port? Sometimes it’s the really silly ones.
sof-firmware is installed…instead of pipewire, pulse audio is preinstalled…
Are you sure will it work with pipewire?
If you want to to continue using PulseAudio instead of replacing it, pipewire.service can be disabled
 systemctl --user disable --now pipewire.socket pipewire.service
Switching between PulseAudio & PipeWire will not help if audio issue is at a lower level in ALSA
Data from alsa-info is showing 2 internal and 2 external microphones detected
[    3.476918] snd_hda_codec_realtek hdaudioC0D0:      Rear Mic=0x18
[    3.476920] snd_hda_codec_realtek hdaudioC0D0:      Internal Mic=0x19
[    3.476921] snd_hda_codec_realtek hdaudioC0D0:      Mic=0x1a
[    3.476922] snd_hda_codec_realtek hdaudioC0D0:      Internal Mic=0x12
Specifications on MSI website state there is only one audio jack for microphone input and/or headphone output, so either Rear Mic or Microphone could be a misdetection/misconfiguration in ALSA
ALSA data is showing conflicting modprobe options
!!Modprobe options (Sound related)
snd_hda_intel: index=0 model=dell-headset-multi
snd_intel_dspcfg: dsp_driver=1
snd_hda_intel: dmic_detect=0
snd_hda_intel: model=laptop-amic enable=yes
I suggest you find the file(s) created to add these modprobe options
grep snd ~/etc/modprobe.d/*.conf
delete all of them, reboot system to ensure no modprobe options are loaded and check if external microphone is detected/working with unmodified configuration
If microphone is not working as expected use
sudo alsa-info.sh --upload
to get ALSA data without modprobe changes
