Over an hour ago, pamac showed that I have 581 available updates, 2.3 GB worth.
The update process hardly started and failed, as shown below.
Preparing...
Checking shiboken2 dependencies...
Checking pyside2 dependencies...
Checking pyside2-tools dependencies...
Checking python-shiboken2 dependencies...
Checking python-hid-parser dependencies...
Resolving dependencies...
Checking inter-conflicts...
Failed to prepare transaction:
could not satisfy dependencies:
- unable to satisfy dependency 'clang=16.0.6' required by shiboken2
Cloning shiboken2 build files...
Generating shiboken2 information...
Failed to clone shiboken2 build files
I searched Manjaro.org and the web but have found nothing yet.
Pamac shows that I have clang 16.0.6-2 installed.
My machine info is as follows:
[ultra@ultra-ms7b86 ~]$ inxi -zv8
Kernel: 6.5.13-7-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 13.2.1
parameters: BOOT_IMAGE=/boot/vmlinuz-6.5-x86_64
root=UUID=121a5a27-095d-4c7a-8853-3a2b6e097b5c rw quiet splash apparmor=1
Desktop: Xfce v: 4.18.1 tk: Gtk v: 3.24.36 wm: xfwm4 v: 4.18.0
with: xfce4-panel tools: light-locker vt: 7 dm: LightDM v: 1.32.0
Type: Desktop System: Micro-Star product: MS-7B86 v: 3.0
serial: <superuser required>
Mobo: Micro-Star model: B450 GAMING PLUS MAX (MS-7B86) v: 3.0
serial: <superuser required> uuid: <superuser required> UEFI: American
Megatrends LLC. v: H.D3 date: 09/28/2021
Device-1: hidpp_battery_0 model: Logitech Wireless Mouse serial: <filter>
charge: 55% (should be ignored) rechargeable: yes status: discharging
Device-2: hidpp_battery_1 model: Logitech K520 serial: <filter>
charge: 70% (should be ignored) rechargeable: yes status: discharging
System RAM: total: 16 GiB available: 15.54 GiB used: 1.97 GiB (12.7%)
Device-1: Channel-A DIMM 0 type: no module installed
(unregistered) size: 8 GiB speed: 2933 MT/s volts: note: check curr: 1
min: 1 max: 1 width (bits): data: 64 total: 64 manufacturer: G.Skill
part-no: F4-3200C16-8GVKB serial: N/A
Device-3: Channel-B DIMM 0 type: no module installed
Info: model: AMD Ryzen 5 2600 bits: 64 type: MT MCP arch: Zen+ gen: 2
level: v3 note: check built: 2018-21 process: GF 12nm family: 0x17 (23)
model-id: 8 stepping: 2 microcode: 0x800820D
L1: 576 KiB desc: d-6x32 KiB; i-6x64 KiB L2: 3 MiB desc: 6x512 KiB
L3: 16 MiB desc: 2x8 MiB
Speed (MHz): avg: 1783 high: 3400 min/max: 1550/3400 boost: enabled
scaling: driver: acpi-cpufreq governor: schedutil cores: 1: 3400 2: 1391
3: 1550 4: 1550 5: 1550 6: 1550 7: 2800 8: 1550 9: 1550 10: 1550 11: 1410
12: 1550 bogomips: 81625
bmi2 bpext clflush clflushopt clzero cmov cmp_legacy constant_tsc cpb
cpuid cr8_legacy cx16 cx8 de decodeassists extapic extd_apicid f16c
flushbyasid fma fpu fsgsbase fxsr fxsr_opt ht hw_pstate ibpb irperf
lahf_lm lbrv lm mca mce misalignsse mmx mmxext monitor movbe msr mtrr
mwaitx nonstop_tsc nopl npt nrip_save nx osvw overflow_recov pae pat
pausefilter pclmulqdq pdpe1gb perfctr_core perfctr_llc perfctr_nb
pfthreshold pge pni popcnt pse pse36 rapl rdrand rdseed rdtscp rep_good
sep sev sev_es sha_ni skinit smap smca smep ssbd sse sse2 sse4_1 sse4_2
sse4a ssse3 succor svm svm_lock syscall tce topoext tsc tsc_scale
v_vmsave_vmload vgif vmcb_clean vme vmmcall wdt xgetbv1 xsave xsavec
xsaveerptr xsaveopt
Type: retbleed mitigation: untrained return thunk; SMT vulnerable
Type: spectre_v2 mitigation: Retpolines, IBPB: conditional, STIBP:
disabled, RSB filling, PBRSB-eIBRS: Not affected
Device-1: NVIDIA GP107 [GeForce GTX 1050 Ti] vendor: Gigabyte
driver: nouveau v: kernel non-free: 545.xx+ status: current (as of 2024-04;
EOL~2026-12-xx) arch: Pascal code: GP10x process: TSMC 16nm
built: 2016-2021 pcie: gen: 1 speed: 2.5 GT/s lanes: 16 link-max: gen: 3
speed: 8 GT/s ports: active: HDMI-A-1 empty: DP-1,DVI-D-1 bus-ID: 26:00.0
chip-ID: 10de:1c82 class-ID: 0300 temp: 49.0 C
Display: x11 server: X.org v: 1.21.1.12 compositor: xfwm4 v: 4.18.0
driver: X: loaded: modesetting alternate: fbdev,vesa dri: nouveau
gpu: nouveau display-ID: :0.0 note: <missing: xdpyinfo/xrandr>
Monitor-1: HDMI-A-1 model: HP w2207 serial: <filter> built: 2007
res: 1680x1050 dpi: 90 gamma: 1.2 chroma: red: x: 0.647 y: 0.337 green:
x: 0.290 y: 0.604 blue: x: 0.145 y: 0.063 white: x: 0.314 y: 0.329
size: 473x296mm (18.62x11.65") diag: 558mm (22") ratio: 16:10
modes: 1680x1050, 1920x1080, 1920x1080i, 1600x1000, 1280x1024, 1440x900,
1280x960, 1152x864, 1280x720, 1152x720, 1024x768, 832x624, 800x600,
720x576, 720x480, 640x480, 720x400
API: EGL v: 1.5 hw: drv: nvidia nouveau platforms: device: 0 drv: nouveau
device: 1 drv: swrast gbm: drv: nouveau surfaceless: drv: nouveau x11:
drv: nouveau inactive: wayland
API: OpenGL v: 4.5 compat-v: 4.3 vendor: mesa v: 24.0.2-manjaro1.1
glx-v: 1.4 direct-render: yes renderer: NV137 device-ID: 10de:1c82
memory: 3.9 GiB unified: no
Device-1: NVIDIA GP107GL High Definition Audio vendor: Gigabyte
driver: snd_hda_intel v: kernel pcie: gen: 1 speed: 2.5 GT/s lanes: 16
link-max: gen: 3 speed: 8 GT/s bus-ID: 26:00.1 chip-ID: 10de:0fb9
class-ID: 0403
Device-2: AMD Family 17h HD Audio vendor: Micro-Star MSI
bus-ID: 28:00.3 chip-ID: 1022:1457 class-ID: 0403
API: ALSA v: k6.5.13-7-MANJARO status: kernel-api with: aoss
Server-2: PipeWire v: 1.0.3 status: off with: pipewire-media-session
status: active tools: pw-cli
Server-3: PulseAudio v: 17.0 status: active with: pulseaudio-alsa
type: plugin tools: pacat,pactl,pavucontrol
vendor: Micro-Star MSI RTL8111/8168/8411 driver: r8169 v: kernel pcie:
gen: 1 speed: 2.5 GT/s lanes: 1 port: f000 bus-ID: 22:00.0
IF: enp34s0 state: up speed: 100 Mbps duplex: full mac: <filter>
Info: services: mld,NetworkManager
Local Storage: total: 2.5 TiB used: 1.73 TiB (69.2%)
ID-1: /dev/sda maj-min: 8:0 vendor: Crucial model: CT250MX500SSD1
size: 232.89 GiB block-size: physical: 4096 B logical: 512 B speed: 6.0 Gb/s
tech: SSD serial: <filter> fw-rev: 043 scheme: GPT
ID-2: /dev/sdb maj-min: 8:16 vendor: Seagate model: ST3500418AS
size: 465.76 GiB block-size: physical: 512 B logical: 512 B speed: 1.5 Gb/s
tech: HDD rpm: 7200 serial: <filter> fw-rev: CC46 scheme: MBR
ID-3: /dev/sdc maj-min: 8:32 vendor: Hitachi model: HUA723020ALA641
size: 1.82 TiB block-size: physical: 512 B logical: 512 B speed: 6.0 Gb/s
tech: HDD rpm: 7200 serial: <filter> fw-rev: A840 scheme: MBR
Optical-1: /dev/sr0 vendor: HL-DT-ST model: DVDRAM GH24NSC0 rev: LI00
dev-links: cdrom
Features: speed: 12 multisession: yes audio: yes dvd: yes
ID-1: / raw-size: 232.59 GiB size: 227.88 GiB (97.98%)
used: 104.48 GiB (45.8%) fs: ext4 dev: /dev/sda2 maj-min: 8:2 label: N/A
uuid: 121a5a27-095d-4c7a-8853-3a2b6e097b5c
used: 288 KiB (0.1%) fs: vfat dev: /dev/sda1 maj-min: 8:1 label: N/A
uuid: 2C95-A40A
ID-3: /run/media/ultra/DDrive2 raw-size: 232.88 GiB
size: 228.17 GiB (97.98%) used: 580.9 MiB (0.2%) fs: ext4 dev: /dev/sdb2
maj-min: 8:18 label: DDrive2 uuid: 353601dc-0eb6-45f9-9475-50f8fb8def2c
ID-4: /run/media/ultra/Ht1 raw-size: 550 GiB size: 540.3 GiB (98.24%)
used: 451.25 GiB (83.5%) fs: ext4 dev: /dev/sdc2 maj-min: 8:34 label: Ht1
uuid: 48d40e11-d416-4079-9abd-c3115f9bdfc3
ID-5: /run/media/ultra/Ht2 raw-size: 640 GiB size: 628.89 GiB (98.26%)
used: 590.4 GiB (93.9%) fs: ext4 dev: /dev/sdc3 maj-min: 8:35 label: Ht2
uuid: db9f7c41-b09a-462e-a202-e0cd136c5ee7
ID-6: /run/media/ultra/Ht3 raw-size: 673.02 GiB size: 661.39 GiB (98.27%)
used: 626.56 GiB (94.7%) fs: ext4 dev: /dev/sdc4 maj-min: 8:36 label: Ht3
uuid: dc1ff585-f270-4de5-ae19-45a09aa1bbb7
ID-1: swap-1 type: file size: 512 MiB used: 256 KiB (0.0%) priority: -2
file: /swapfile
ID-1: /dev/sdb1 maj-min: 8:17 size: 232.88 GiB fs: ext4 label: DDrive1
uuid: 6e4c97b7-826e-445e-8796-72d0e38f7e36
Device-1: 1-8:2 info: Logitech Unifying Receiver type: keyboard,mouse,HID
driver: logitech-djreceiver,usbhid interfaces: 3 rev: 2.0
chip-ID: 046d:c52b class-ID: 0300
Hub-4: 4-0:1 info: super-speed hub ports: 4 rev: 3.0
System Temperatures: cpu: 41.1 C mobo: N/A gpu: nouveau temp: 49.0 C
Fan Speeds (rpm): N/A gpu: nouveau fan: 0
Packages: 1598 pm: pacman pkgs: 1557 libs: 385 tools: pamac pm: flatpak
pkgs: 41
1: https://forksystems.mm.fcix.net/manjaro/stable/$repo/$arch
2: https://coresite.mm.fcix.net/manjaro/stable/$repo/$arch
3: https://mirrors.gigenet.com/manjaro/stable/$repo/$arch
4: https://southfront.mm.fcix.net/manjaro/stable/$repo/$arch
5: https://irltoolkit.mm.fcix.net/manjaro/stable/$repo/$arch
6: https://ridgewireless.mm.fcix.net/manjaro/stable/$repo/$arch
7: https://opencolo.mm.fcix.net/manjaro/stable/$repo/$arch
8: http://mirror.fcix.net/manjaro/stable/$repo/$arch
Processes:
CPU top: 5 of 469
1: cpu: 200% command: ps pid: 18112 mem: 4.36 MiB (0.0%)
2: cpu: 7.5% command: 1 started-by: firefox pid: 17501
mem: 408.4 MiB (2.5%)
3: cpu: 3.2% command: firefox pid: 17607 mem: 160.1 MiB (1.0%)
4: cpu: 3.0% command: Xorg pid: 896 mem: 110.5 MiB (0.6%)
5: cpu: 2.9% command: xfce4-terminal pid: 18074 mem: 47.6 MiB (0.2%)
Memory top: 5 of 469
1: mem: 408.4 MiB (2.5%) command: 1 started-by: firefox pid: 17501
cpu: 7.5%
2: mem: 258.6 MiB (1.6%) command: firefox pid: 17728 cpu: 1.1%
3: mem: 160.1 MiB (1.0%) command: firefox pid: 17607 cpu: 3.2%
4: mem: 160.0 MiB (1.0%) command: firefox pid: 17665 cpu: 0.3%
5: mem: 110.5 MiB (0.6%) command: Xorg pid: 896 cpu: 3.0%
Processes: 469 Power: uptime: 6h 42m states: freeze,mem,disk suspend: deep
suspend, test_resume image: 6.21 GiB services: upowerd,xfce4-power-manager
Init: systemd v: 255 default: graphical tool: systemctl
Compilers: clang: 16.0.6 gcc: 13.2.1 Shell: Bash v: 5.2.26
running-in: xfce4-terminal inxi: 3.3.34
What do I do next?
Mod edit: See [HowTo] Post command output and file content as formatted text
