I have been using manajro for almost a month and what i most liked i it was the speed it got.But weirdly it has become sluggish from last 3 days.Everything is super slow despite rebooting many times and running the update command.
vscode, barve, spotify everything is slow and i use snap version of spotify and brave
Please help me to make it better again
System: Kernel: 5.10.52-1-MANJARO x86_64 bits: 64 compiler: gcc v: 11.1.0
parameters: BOOT_IMAGE=/boot/vmlinuz-5.10-x86_64 root=UUID=aa4d9fcb-4495-4a66-8937-d731b635eb9c
rw quiet splash apparmor=1 security=apparmor resume=UUID=65639684-1860-4f53-85f3-ef1b7ed9900b
udev.log_priority=3
Desktop: GNOME 40.3 tk: GTK 3.24.30 wm: gnome-shell dm: GDM 40.0 Distro: Manjaro Linux
base: Arch Linux
Machine: Type: Laptop System: LENOVO product: 81SY v: Lenovo Legion Y540-15IRH-PG0 serial: <filter>
Chassis: type: 10 v: Lenovo Legion Y540-15IRH-PG0 serial: <filter>
Mobo: LENOVO model: LNVNB161216 v: SDK0Q55722 WIN serial: <filter> UEFI: LENOVO v: BHCN41WW
date: 11/30/2020
Battery: ID-1: BAT0 charge: 43.2 Wh (100.0%) condition: 43.2/52.5 Wh (82.3%) volts: 12.8 min: 11.2
model: SMP L17M3PG1 type: Li-poly serial: <filter> status: Full cycles: 590
CPU: Info: Quad Core model: Intel Core i5-9300H bits: 64 type: MT MCP arch: Kaby Lake note: check
family: 6 model-id: 9E (158) stepping: A (10) microcode: EA cache: L2: 8 MiB
flags: avx avx2 lm nx pae sse sse2 sse3 sse4_1 sse4_2 ssse3 vmx bogomips: 38408
Speed: 2631 MHz min/max: 800/4100 MHz Core speeds (MHz): 1: 2631 2: 2510 3: 2304 4: 2915
5: 2536 6: 2650 7: 2435 8: 2026
Type: l1tf mitigation: PTE Inversion; VMX: conditional cache flushes, SMT vulnerable
Type: spectre_v2
mitigation: Full generic retpoline, IBPB: conditional, IBRS_FW, STIBP: conditional, RSB filling
Graphics: Device-1: Intel CoffeeLake-H GT2 [UHD Graphics 630] vendor: Lenovo driver: i915 v: kernel
bus-ID: 00:02.0 chip-ID: 8086:3e9b class-ID: 0300
Device-2: NVIDIA TU117M [GeForce GTX 1650 Mobile / Max-Q] vendor: Lenovo driver: nvidia
v: 470.57.02 alternate: nouveau,nvidia_drm bus-ID: 01:00.0 chip-ID: 10de:1f91 class-ID: 0300
Device-3: Chicony Integrated Camera (1280x720@30) type: USB driver: uvcvideo bus-ID: 1-6:4
chip-ID: 04f2:b604 class-ID: 0e02 serial: <filter>
Display: x11 server: X.org 1.20.11 compositor: gnome-shell driver: loaded: modesetting,nvidia
alternate: fbdev,intel,nouveau,nv,vesa resolution: <missing: xdpyinfo>
OpenGL: renderer: Mesa Intel UHD Graphics 630 (CFL GT2) v: 4.6 Mesa 21.1.5 direct render: Yes
Audio: Device-1: Intel Cannon Lake PCH cAVS vendor: Lenovo driver: snd_hda_intel v: kernel
alternate: snd_soc_skl,snd_sof_pci bus-ID: 00:1f.3 chip-ID: 8086:a348 class-ID: 0403
Sound Server-1: ALSA v: k5.10.52-1-MANJARO running: yes
Sound Server-4: PipeWire v: 0.3.32 running: yes
Network: Device-1: Intel Cannon Lake PCH CNVi WiFi driver: iwlwifi v: kernel port: 5000 bus-ID: 00:14.3
chip-ID: 8086:a370 class-ID: 0280
Device-2: Realtek RTL8111/8168/8411 PCI Express Gigabit Ethernet vendor: Lenovo driver: r8168
v: 8.049.02-NAPI modules: r8169 port: 3000 bus-ID: 07:00.0 chip-ID: 10ec:8168 class-ID: 0200
IF: enp7s0 state: down mac: <filter>
Bluetooth: Device-1: Intel Bluetooth 9460/9560 Jefferson Peak (JfP) type: USB driver: btusb v: 0.8
bus-ID: 1-14:6 chip-ID: 8087:0aaa class-ID: e001
Report: rfkill ID: hci0 rfk-id: 3 state: up address: see --recommends
Drives: Local Storage: total: 1.03 TiB used: 65.77 GiB (6.3%)
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Western Digital model: PC SN520 SDAPMUW-128G-1101
size: 119.24 GiB block-size: physical: 512 B logical: 512 B speed: 15.8 Gb/s lanes: 2
rotation: SSD serial: <filter> rev: 20210001 temp: 44.9 C scheme: GPT
ID-2: /dev/sda maj-min: 8:0 vendor: Seagate model: ST1000LM049-2GH172 size: 931.51 GiB
block-size: physical: 4096 B logical: 512 B speed: 6.0 Gb/s rotation: 7200 rpm serial: <filter>
rev: LXM3 scheme: GPT
Partition: ID-1: / raw-size: 91.51 GiB size: 89.52 GiB (97.82%) used: 65.77 GiB (73.5%) fs: ext4
dev: /dev/sda8 maj-min: 8:8
ID-2: /boot/efi raw-size: 500 MiB size: 499 MiB (99.80%) used: 316 KiB (0.1%) fs: vfat
dev: /dev/sda6 maj-min: 8:6
Swap: Kernel: swappiness: 10 (default 60) cache-pressure: 100 (default)
ID-1: swap-1 type: partition size: 8 GiB used: 0 KiB (0.0%) priority: -2 dev: /dev/sda7
maj-min: 8:7
Sensors: System Temperatures: cpu: 50.0 C mobo: N/A
Info: Processes: 323 Uptime: 14m wakeups: 1 Memory: 15.51 GiB used: 5.6 GiB (36.1%) Init: systemd
v: 248 tool: systemctl Compilers: gcc: 11.1.0 clang: 12.0.1 Packages: 1246 pacman: 1238
lib: 304 flatpak: 0 snap: 8 Shell: Zsh v: 5.8 running-in: gnome-terminal inxi: 3.3.05
Since your Laptop has a Hybrid GPUs setup, have you tried making use of that? From terminal:
prime-run vscode
prime-run barve
or
prime-run spotify
does make them respond faster?
