New to Arch/Man, coming from Deb. Please show me to the important files and settings to investigate. Thank you.
you must be more precise !
explain what the issue is !
no one is wasting his time for questions like “it does not work”
I figured the quickest way to troubleshoot is to examine the differences between the display settings in both instances. Can you direct me to those?
Welcome to Manjaro!
- Please read the information behind this link. It will help you to post necessary information.
- Please press the three dots … below your post and then press the
- If you give us information about your system, we can see what we’re talking about and make better suggestions.
- You can do this by using
inxiin a terminal or in console.
- Personally identifiable information such as serial numbers and MAC addresses are filtered out by this command
- Presenting the information in this way allows everyone to be familiar with the format and quickly find the items they need without missing anything.
- Copy the output from inxi (including the command) and paste it into your post.
- To make it more readable, add 3 backticks ``` on an extra line before and after the pasted text.
Have you already
for your problem in the forum ? (Wisdom lies in asking → listening → reading
Welcome to the forum! ![]()
Please use actual words and proper pronouns, not invented abbreviations.
We have no idea what you “display setup” is.
Please see the following and edit your first post accordingly:
There is no default - it is determined at boot time by mhwd
Xorg configs are placed same location /etc/X11/xorg.conf.d
If you are using Nvidia - mhwd - if booted with proprietary drivers - may have created a config in /etc/X11/mhwd.d - which is symlinked into /etc/X11/xorg.conf.d
As for the display arrangement - multiple displays - any configuration will exist in /home/manjaro/.config
Plasma Wayland doesn’t require any configuration - and stores configuration in /home/manjaro/.config
I don’t know for Gnome - I lost patience in that regard years ago ![]()
Thank you, very useful info
Other info which may be useful
The ISO enables kms - and ISO releases from 2024 enables kms for the final installation.
However - early kms must be enabled manually as described in
Also, very, very useful info, thank you
