yes, enter bios and change the sata mode from RAID to AHCI, save the changes and thats it
That also worked! Thanks again for your help!!!
so now test the enegy consumption in sleep mode ā¦ if its still high, verify again in bios if the ahci mode is set
will do. ill let you know in a few hours
After two hours the battery has only dropped one percent. So the AHCI trick also worked
Thank you so much for your help!!
