I was just told randomly to do that. He told me to create a post for it that he can’t really help.
This is the output.
upload=true&script=true&cardinfo=
!!ALSA Information Script v 0.5.1
!!Script ran on: Sat Apr 8 17:04:08 UTC 2023
!!Linux Distribution
ID_LIKE=arch
!!DMI Information
Manufacturer: Dell Inc.
Product Name: Latitude E5530 non-vPro
Product Version: 01
Firmware Version: A18
System SKU: Latitude E5530 non-vPro
Board Vendor: Dell Inc.
Board Name: 0VP63H
!!ACPI Device Status Information
/sys/bus/acpi/devices/ACPI0003:00/status 15
/sys/bus/acpi/devices/DELLABCE:00/status 15
/sys/bus/acpi/devices/DLLK053D:00/status 15
/sys/bus/acpi/devices/INT3F0D:00/status 15
/sys/bus/acpi/devices/PNP0103:00/status 15
/sys/bus/acpi/devices/PNP0401:00/status 13
/sys/bus/acpi/devices/PNP0C01:00/status 15
/sys/bus/acpi/devices/PNP0C01:01/status 15
/sys/bus/acpi/devices/PNP0C09:00/status 15
/sys/bus/acpi/devices/PNP0C0A:00/status 31
/sys/bus/acpi/devices/PNP0C0A:01/status 15
/sys/bus/acpi/devices/PNP0C0F:00/status 9
/sys/bus/acpi/devices/PNP0C0F:01/status 9
/sys/bus/acpi/devices/PNP0C0F:02/status 9
/sys/bus/acpi/devices/PNP0C0F:03/status 9
/sys/bus/acpi/devices/PNP0C0F:04/status 9
/sys/bus/acpi/devices/PNP0C0F:05/status 9
/sys/bus/acpi/devices/PNP0C0F:06/status 9
/sys/bus/acpi/devices/PNP0C0F:07/status 9
/sys/bus/acpi/devices/SMO8810:00/status 15
!!Kernel Information
Kernel release: 6.1.22-1-MANJARO
Operating System: GNU/Linux
Architecture: x86_64
Processor: unknown
SMP Enabled: Yes
!!ALSA Version
Driver version: k6.1.22-1-MANJARO
Library version: 1.2.8
Utilities version: 1.2.8
!!Loaded ALSA modules
snd_hda_intel (card 0)
!!Sound Servers on this system
PipeWire:
Installed - Yes (/usr/bin/pipewire)
Running - Yes
Jack:
Installed - Yes (/usr/bin/jackd)
Running - No
!!Soundcards recognised by ALSA
0 [PCH ]: HDA-Intel - HDA Intel PCH
HDA Intel PCH at 0xf7f10000 irq 28
!!PCI Soundcards installed in the system
00:1b.0 Audio device [0403]: Intel Corporation 7 Series/C216 Chipset Family High Definition Audio Controller [8086:1e20] (rev 04)
Subsystem: Dell Device [1028:053d]
!!Loaded sound module options
!!Module: snd_hda_intel
align_buffer_size : -1
bdl_pos_adj : -1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1
beep_mode : N,N,N,N,N,N,N,N,N,N,N,N,N,N,N,N,N,N,N,N,N,N,N,N,N,N,N,N,N,N,N,N
ctl_dev_id : N
dmic_detect : Y
enable : Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y
enable_msi : -1
id : (null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null)
index : -1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1
jackpoll_ms : 0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0
model : (null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null)
patch : (null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null)
pm_blacklist : Y
position_fix : -1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1
power_save : 1
power_save_controller : Y
probe_mask : -1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1
probe_only : 0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0
single_cmd : -1
snoop : -1
!!Sysfs card info
!!Card: /sys/class/sound/card0
Driver: /sys/bus/pci/drivers/snd_hda_intel
Tree:
!!HDA-Intel Codec information
--startcollapse--
Codec: IDT 92HD93BXX
Address: 0
AFG Function Id: 0x1 (unsol 1)
Vendor Id: 0x111d76df
Subsystem Id: 0x1028053d
Revision Id: 0x100203
No Modem Function Group found
Default PCM:
rates [0x5e0]: 44100 48000 88200 96000 192000
bits [0xe]: 16 20 24
formats [0x1]: PCM
Default Amp-In caps: ofs=0x00, nsteps=0x03, stepsize=0x27, mute=0
Default Amp-Out caps: ofs=0x7f, nsteps=0x7f, stepsize=0x02, mute=1
State of AFG node 0x01:
Power states: D0 D1 D2 D3 D3cold S3D3cold CLKSTOP EPSS
Power: setting=D0, actual=D0
GPIO: io=5, o=0, i=0, unsolicited=1, wake=1
IO[0]: enable=0, dir=0, wake=0, sticky=0, data=0, unsol=0
IO[1]: enable=0, dir=0, wake=0, sticky=0, data=0, unsol=0
IO[2]: enable=0, dir=0, wake=0, sticky=0, data=0, unsol=0
IO[3]: enable=0, dir=0, wake=0, sticky=0, data=0, unsol=0
IO[4]: enable=0, dir=0, wake=0, sticky=0, data=0, unsol=0
Power-Map: 0x47
Node 0x0a [Pin Complex] wcaps 0x400583: Stereo Amp-In
Control: name="Headset Mic Boost Volume", index=0, device=0
ControlAmp: chs=3, dir=In, idx=0, ofs=0
Amp-In caps: N/A
Amp-In vals: [0x03 0x03]
Pincap 0x0001173c: IN OUT HP EAPD Detect
Vref caps: HIZ 50 GRD 80
EAPD 0x2: EAPD
Pin Default 0x04a11020: [Jack] Mic at Ext Right
Conn = 1/8, Color = Black
DefAssociation = 0x2, Sequence = 0x0
Pin-ctls: 0x24: IN VREF_80
Unsolicited: tag=04, enabled=1
Power states:
Power: setting=D3, actual=D3
Connection: 3
0x13* 0x14 0x1c
Node 0x0b [Pin Complex] wcaps 0x400581: Stereo
Pincap 0x0001001c: OUT HP EAPD Detect
EAPD 0x2: EAPD
Pin Default 0x0421101f: [Jack] HP Out at Ext Right
DefAssociation = 0x1, Sequence = 0xf
Pin-ctls: 0xc0: OUT HP
Unsolicited: tag=02, enabled=1
Power states:
Connection: 3
0x13 0x14* 0x1c
Node 0x0c [Pin Complex] wcaps 0x400583: Stereo Amp-In
Amp-In caps: N/A
Amp-In vals: [0x00 0x00]
Pincap 0x00010034: IN OUT EAPD Detect
EAPD 0x2: EAPD
Pin Default 0x400000f0: [N/A] Line Out at Ext N/A
Conn = Unknown, Color = Unknown
DefAssociation = 0xf, Sequence = 0x0
Pin-ctls: 0x00:
Unsolicited: tag=00, enabled=0
Power states:
Connection: 3
0x13* 0x14 0x1c
Node 0x0d [Pin Complex] wcaps 0x400501: Stereo
Pincap 0x00010050: OUT EAPD Balanced
EAPD 0x2: EAPD
Pin Default 0x90170110: [Fixed] Speaker at Int N/A
Conn = Analog, Color = Unknown
DefAssociation = 0x1, Sequence = 0x0
Misc = NO_PRESENCE
Pin-ctls: 0x40: OUT
Power states:
Connection: 3
0x13* 0x14 0x1c
Node 0x0e [Pin Complex] wcaps 0x400581: Stereo
EAPD 0x2: EAPD
Pin Default 0x23011050: [Jack] Line Out at Sep Left
DefAssociation = 0x5, Sequence = 0x0
Pin-ctls: 0x40: OUT
Unsolicited: tag=01, enabled=1
Power states:
Connection: 3
0x13* 0x14 0x1c
Node 0x0f [Pin Complex] wcaps 0x400483: Stereo Amp-In
Control: name="Dock Mic Boost Volume", index=0, device=0
Amp-In caps: N/A
Pincap 0x00000024: IN Detect
Pin Default 0x23a1102e: [Jack] Mic at Sep Left
DefAssociation = 0x2, Sequence = 0xe
Pin-ctls: 0x20: IN
Unsolicited: tag=03, enabled=1
Power states:
Node 0x10 [Pin Complex] wcaps 0x400500: Mono
Pincap 0x00000010: OUT
Pin Default 0x400000f3: [N/A] Line Out at Ext N/A
DefAssociation = 0xf, Sequence = 0x3
Pin-ctls: 0x00:
Power states:
Connection: 1
0x1a
Node 0x11 [Pin Complex] wcaps 0x400483: Stereo Amp-In
Amp-In caps: N/A
Pin-ctls: 0x00:
Power states:
Node 0x12 [Vendor Defined Widget] wcaps 0xf00503: Stereo Amp-In
Control: name="Internal Mic Boost Volume", index=0, device=0
Amp-In caps: N/A
Power states:
Connection: 1
0x20
Node 0x13 [Audio Output] wcaps 0xd0c05: Stereo Amp-Out R/L
Control: name="Speaker+LO Playback Volume", index=0, device=0
ControlAmp: chs=3, dir=Out, idx=0, ofs=0
Control: name="Speaker+LO Playback Switch", index=0, device=0
Device: name="92HD93BXX Analog", type="Audio", device=0
Amp-Out caps: N/A
Amp-Out vals: [0x7f 0x7f]
Converter: stream=0, channel=0
Power states:
Delay: 13 samples
Node 0x14 [Audio Output] wcaps 0xd0c05: Stereo Amp-Out R/L
Control: name="Headphone Playback Volume", index=0, device=0
Control: name="Headphone Playback Switch", index=0, device=0
Amp-Out caps: N/A
Amp-Out vals: [0x80 0x80]
Power states:
Delay: 13 samples
Node 0x15 [Audio Input] wcaps 0x1d0541: Stereo
SDI-Select: 0
Power states:
Delay: 13 samples
Connection: 1
0x17
Processing caps: benign=0, ncoeff=0
Node 0x16 [Audio Input] wcaps 0x1d0541: Stereo
SDI-Select: 0
Power states:
Delay: 13 samples
Connection: 1
0x18
Node 0x17 [Audio Selector] wcaps 0x300d0d: Stereo Amp-Out R/L
Control: name="Capture Volume", index=0, device=0
Control: name="Capture Switch", index=0, device=0
Amp-Out caps: ofs=0x10, nsteps=0x2e, stepsize=0x03, mute=1
Amp-Out vals: [0x2e 0x2e]
Power states:
Connection: 6
0x1b 0x0a 0x0c 0x0f 0x11 0x12*
Node 0x18 [Audio Selector] wcaps 0x300d0d: Stereo Amp-Out R/L
Amp-Out vals: [0x90 0x90]
Power states:
Connection: 6
0x1b* 0x0a 0x0c 0x0f 0x11 0x12
Node 0x19 [Audio Selector] wcaps 0x300501: Stereo
Power states:
Connection: 3
0x13* 0x14 0x1c
Node 0x1a [Audio Mixer] wcaps 0x200500: Mono
Power states:
Connection: 1
0x19
Node 0x1b [Audio Mixer] wcaps 0x20050b: Stereo Amp-In
Control: name="Dock Mic Playback Volume", index=0, device=0
ControlAmp: chs=3, dir=In, idx=4, ofs=0
Control: name="Dock Mic Playback Switch", index=0, device=0
Control: name="Headset Mic Playback Volume", index=0, device=0
ControlAmp: chs=3, dir=In, idx=2, ofs=0
Control: name="Headset Mic Playback Switch", index=0, device=0
Amp-In caps: ofs=0x17, nsteps=0x1f, stepsize=0x05, mute=1
Amp-In vals: [0x80 0x80] [0x80 0x80] [0x80 0x80] [0x80 0x80] [0x80 0x80]
Power states:
Connection: 5
0x13 0x14 0x0a 0x0c 0x0f
Node 0x1c [Audio Selector] wcaps 0x30050d: Stereo Amp-Out
Amp-Out caps: ofs=0x1f, nsteps=0x1f, stepsize=0x05, mute=1
Power states:
Connection: 1
0x1b
Node 0x1d [Audio Output] wcaps 0x4061d: Stereo Digital Amp-Out
Amp-Out caps: ofs=0x00, nsteps=0x00, stepsize=0x00, mute=1
Amp-Out vals: [0x00 0x00]
Digital:
Digital category: 0x0
IEC Coding Type: 0x0
PCM:
formats [0x5]: PCM AC3
Power states:
Delay: 4 samples
Node 0x1e [Audio Output] wcaps 0x4061d: Stereo Digital Amp-Out
Digital:
PCM:
Power states:
Delay: 4 samples
Node 0x1f [Pin Complex] wcaps 0x400781: Stereo Digital
Pincap 0x00000014: OUT Detect
Pin-ctls: 0x00:
Power states:
Connection: 1
0x1d
Node 0x20 [Pin Complex] wcaps 0x400781: Stereo Digital
Pincap 0x00000034: IN OUT Detect
Pin Default 0xd5a301a0: [Both] Mic at Int Top
Conn = ATAPI, Color = Unknown
DefAssociation = 0xa, Sequence = 0x0
Misc = NO_PRESENCE
Pin-ctls: 0x20: IN
Power states:
Connection: 1
0x1e
Node 0x21 [Beep Generator Widget] wcaps 0x70040c: Mono Amp-Out
Control: name="Beep Playback Switch", index=0, device=0
ControlAmp: chs=1, dir=Out, idx=0, ofs=0
Control: name="Beep Playback Volume", index=0, device=0
Amp-Out caps: ofs=0x03, nsteps=0x03, stepsize=0x17, mute=1
Amp-Out vals: [0x01]
Power states:
Node 0x22 [Vendor Defined Widget] wcaps 0xf00001: Stereo
Codec: Intel PantherPoint HDMI
Address: 3
AFG Function Id: 0x1 (unsol 0)
Vendor Id: 0x80862806
Subsystem Id: 0x80860101
Revision Id: 0x100000
Default PCM:
rates [0x0]:
bits [0x0]:
formats [0x0]:
Default Amp-In caps: N/A
Default Amp-Out caps: N/A
Power states: D0 D3 CLKSTOP EPSS
Power: setting=D0, actual=D0, Clock-stop-OK
GPIO: io=0, o=0, i=0, unsolicited=0, wake=0
Node 0x02 [Audio Output] wcaps 0x6611: 8-Channels Digital
Digital: Enabled
PCM:
rates [0x7f0]: 32000 44100 48000 88200 96000 176400 192000
bits [0x1e]: 16 20 24 32
Power states: D0 D3 EPSS
Node 0x03 [Audio Output] wcaps 0x6611: 8-Channels Digital
Digital: Enabled
PCM:
Node 0x04 [Audio Output] wcaps 0x6611: 8-Channels Digital
Digital: Enabled
PCM:
Node 0x05 [Pin Complex] wcaps 0x40778d: 8-Channels Digital Amp-Out CP
Pincap 0x09000094: OUT Detect HBR HDMI DP
Pin Default 0x18560010: [Jack] Digital Out at Int HDMI
Conn = Digital, Color = Unknown
Pin-ctls: 0x40: OUT
Connection: 1
0x02
Node 0x06 [Pin Complex] wcaps 0x40778d: 8-Channels Digital Amp-Out CP
Pin Default 0x18560020: [Jack] Digital Out at Int HDMI
Pin-ctls: 0x40: OUT
Connection: 1
0x03
Node 0x07 [Pin Complex] wcaps 0x40778d: 8-Channels Digital Amp-Out CP
Pin Default 0x18560030: [Jack] Digital Out at Int HDMI
DefAssociation = 0x3, Sequence = 0x0
Pin-ctls: 0x40: OUT
Connection: 1
0x04
Node 0x08 [Vendor Defined Widget] wcaps 0xf00000: Mono
--endcollapse--
!!Aplay/Arecord output
APLAY
**** List of PLAYBACK Hardware Devices ****
card 0: PCH [HDA Intel PCH], device 0: 92HD93BXX Analog [92HD93BXX Analog]
Subdevices: 1/1
Subdevice #0: subdevice #0
card 0: PCH [HDA Intel PCH], device 3: HDMI 0 [HDMI 0]
Subdevices: 1/1
card 0: PCH [HDA Intel PCH], device 7: HDMI 1 [HDMI 1]
Subdevices: 1/1
card 0: PCH [HDA Intel PCH], device 8: HDMI 2 [HDMI 2]
Subdevices: 1/1
ARECORD
**** List of CAPTURE Hardware Devices ****
Subdevices: 1/1
!!Amixer output
!!-------Mixer controls for card PCH
Card sysdefault:0 'PCH'/'HDA Intel PCH at 0xf7f10000 irq 28'
Mixer name : 'IDT 92HD93BXX'
Components : 'HDA:111d76df,1028053d,00100203 HDA:80862806,80860101,00100000'
Controls : 49
Simple ctrls : 16
Simple mixer control 'Master',0
Capabilities: pvolume pvolume-joined pswitch pswitch-joined
Playback channels: Mono
Limits: Playback 0 - 127
Mono: Playback 127 [100%] [0.00dB] [on]
Simple mixer control 'Headphone',0
Capabilities: pvolume pswitch
Mono:
Front Left: Playback 0 [0%] [-99999.99dB] [off]
Front Right: Playback 0 [0%] [-99999.99dB] [off]
Simple mixer control 'Speaker+LO',0
Mono:
Front Left: Playback 127 [100%] [0.00dB] [on]
Front Right: Playback 127 [100%] [0.00dB] [on]
Simple mixer control 'PCM',0
Limits: Playback 0 - 255
Mono:
Front Left: Playback 255 [100%] [0.00dB]
Front Right: Playback 255 [100%] [0.00dB]
Simple mixer control 'IEC958',0
Capabilities: pswitch pswitch-joined
Mono: Playback [off]
Simple mixer control 'IEC958',1
Mono: Playback [on]
Simple mixer control 'IEC958',2
Mono: Playback [on]
Simple mixer control 'Beep',0
Limits: Playback 0 - 3
Mono: Playback 1 [33%] [-12.00dB] [on]
Simple mixer control 'Capture',0
Capabilities: cvolume cswitch
Limits: Capture 0 - 46
Front Left: Capture 46 [100%] [30.00dB] [on]
Front Right: Capture 46 [100%] [30.00dB] [on]
Simple mixer control 'Auto-Mute Mode',0
Capabilities: enum
Items: 'Disabled' 'Speaker Only' 'Line Out+Speaker'
Item0: 'Disabled'
Simple mixer control 'Dock Mic',0
Limits: Playback 0 - 31
Mono:
Front Left: Playback 0 [0%] [-34.50dB] [off]
Front Right: Playback 0 [0%] [-34.50dB] [off]
Simple mixer control 'Dock Mic Boost',0
Capabilities: volume
Limits: 0 - 3
Front Left: 0 [0%] [0.00dB]
Front Right: 0 [0%] [0.00dB]
Simple mixer control 'Headset Mic',0
Mono:
Simple mixer control 'Headset Mic Boost',0
Limits: 0 - 3
Front Left: 3 [100%] [30.00dB]
Front Right: 3 [100%] [30.00dB]
Simple mixer control 'Internal Mic Boost',0
Limits: 0 - 3
Simple mixer control 'Loopback Mixing',0
Capabilities: enum
Items: 'Disabled' 'Enabled'
Item0: 'Disabled'
!!ALSA/HDA dmesg
[ 25.769812] i915 0000:00:02.0: [drm] fb0: i915drmfb frame buffer device
[ 25.942482] snd_hda_intel 0000:00:1b.0: bound 0000:00:02.0 (ops i915_audio_component_bind_ops [i915])
[ 26.297477] snd_hda_codec_idt hdaudioC0D0: autoconfig for 92HD93BXX: line_outs=1 (0xe/0x0/0x0/0x0/0x0) type:line
[ 26.297503] snd_hda_codec_idt hdaudioC0D0: speaker_outs=1 (0xd/0x0/0x0/0x0/0x0)
[ 26.297523] snd_hda_codec_idt hdaudioC0D0: hp_outs=1 (0xb/0x0/0x0/0x0/0x0)
[ 26.297526] snd_hda_codec_idt hdaudioC0D0: mono: mono_out=0x0
[ 26.297529] snd_hda_codec_idt hdaudioC0D0: inputs:
[ 26.297531] snd_hda_codec_idt hdaudioC0D0: Dock Mic=0xf
[ 26.297534] snd_hda_codec_idt hdaudioC0D0: Headset Mic=0xa
[ 26.297537] snd_hda_codec_idt hdaudioC0D0: Internal Mic=0x20
[ 26.361543] input: HDA Intel PCH Dock Mic as /devices/pci0000:00/0000:00:1b.0/sound/card0/input10
[ 26.361617] input: HDA Intel PCH Headset Mic as /devices/pci0000:00/0000:00:1b.0/sound/card0/input11
[ 26.361671] input: HDA Intel PCH Dock Line Out as /devices/pci0000:00/0000:00:1b.0/sound/card0/input12
[ 26.361725] input: HDA Intel PCH Headphone as /devices/pci0000:00/0000:00:1b.0/sound/card0/input13
[ 26.361781] input: HDA Intel PCH HDMI/DP,pcm=3 as /devices/pci0000:00/0000:00:1b.0/sound/card0/input14
[ 26.361834] input: HDA Intel PCH HDMI/DP,pcm=7 as /devices/pci0000:00/0000:00:1b.0/sound/card0/input15
[ 26.361899] input: HDA Intel PCH HDMI/DP,pcm=8 as /devices/pci0000:00/0000:00:1b.0/sound/card0/input16
[ 26.548087] cryptd: max_cpu_qlen set to 1000
