My laptop it's not charging anymore
Hi guys!!! Hope all fine!! I’m writing today asking for help cause since couple days ago my laptop it’s not charging (battery charge percentage remains constant)…
  Kernel: 6.13.0-1-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 14.2.1
    parameters: BOOT_IMAGE=/boot/vmlinuz-6.13-x86_64
    root=UUID=034cce20-46f0-4762-a989-90f4125f7af9 rw apparmor=1
    security=apparmor resume=UUID=35dedb6e-40ca-4832-b4a1-6fa39675484b
    udev.log_priority=3
  Desktop: GNOME v: 47.3 tk: GTK v: 3.24.43 wm: gnome-shell
    tools: gsd-screensaver-proxy dm: GDM v: 47.0 Distro: Manjaro
    base: Arch Linux
  Type: Laptop System: ASUSTeK product: ASUS EXPERTBOOK B1500CEAEY_B1500CEAE
    v: 1.0 serial: <superuser required>
  Mobo: ASUSTeK model: B1500CEAEY v: 1.0 serial: <superuser required>
    uuid: <superuser required> UEFI: ASUSTeK v: B1500CEAEY.321 date: 12/22/2022
  ID-1: BAT0 charge: 8.5 Wh (86.7%) condition: 9.8/42.1 Wh (23.2%) volts: 11.8
    min: 11.8 model: ASUSTeK ASUS Battery type: Li-ion serial: N/A
    status: not charging cycles: 180
  System RAM: total: 24 GiB available: 23.17 GiB used: 3.51 GiB (15.1%)
  Array-1: capacity: 128 GiB slots: 2 modules: 2 EC: None
    max-module-size: 64 GiB note: est.
  Device-1: Controller0-ChannelA-DIMM0 type: DDR4 detail: synchronous
    size: 8 GiB speed: 3200 MT/s volts: note: check curr: 1 min: 1 max: 1
    width (bits): data: 64 total: 64 manufacturer: Samsung
    part-no: M471A1G44AB0-CWE serial: <filter>
  Device-2: Controller1-ChannelA type: DDR4 detail: synchronous size: 16 GiB
    speed: 3200 MT/s volts: note: check curr: 1 min: 1 max: 1 width (bits):
    data: 64 total: 64 manufacturer: SK Hynix part-no: HMAB2GS6AMR6N-XN
    serial: N/A
  Info: model: 11th Gen Intel Core i7-1165G7 bits: 64 type: MT MCP
    arch: Tiger Lake gen: core 11 level: v4 note: check built: 2020
    process: Intel 10nm family: 6 model-id: 0x8C (140) stepping: 1
    microcode: 0xB8
  Topology: cpus: 1x dies: 1 clusters: 4 cores: 4 threads: 8 tpc: 2
    smt: enabled cache: L1: 320 KiB desc: d-4x48 KiB; i-4x32 KiB L2: 5 MiB
    desc: 4x1.2 MiB L3: 12 MiB desc: 1x12 MiB
  Speed (MHz): avg: 400 min/max: 400/4700 scaling: driver: intel_pstate
    governor: powersave cores: 1: 400 2: 400 3: 400 4: 400 5: 400 6: 400 7: 400
    8: 400 bogomips: 44864
    arch_capabilities arch_perfmon art avx avx2 avx512_bitalg avx512_vbmi2
    avx512_vnni avx512_vp2intersect avx512_vpopcntdq avx512bw avx512cd
    avx512dq avx512f avx512ifma avx512vbmi avx512vl bmi1 bmi2 bts cat_l2
    cdp_l2 clflush clflushopt clwb cmov constant_tsc cpuid cpuid_fault cx16
    cx8 de ds_cpl dtes64 dtherm dts epb ept ept_ad erms est f16c flexpriority
    flush_l1d fma fpu fsgsbase fsrm fxsr gfni ht hwp hwp_act_window hwp_epp
    hwp_notify hwp_pkg_req ibpb ibrs ibrs_enhanced ibt ida intel_pt invpcid
    lahf_lm lm mca mce md_clear mmx monitor movbe movdir64b movdiri msr mtrr
    nonstop_tsc nopl nx ospke pae pat pbe pcid pclmulqdq pdcm pdpe1gb pebs
    pge pku pln pni popcnt pse pse36 pts rdpid rdrand rdseed rdt_a rdtscp
    rep_good sdbg sep sha_ni smap smep split_lock_detect ss ssbd sse sse2
    tsc_deadline_timer tsc_known_freq umip user_shstk vaes vme vmx vnmi
    vpclmulqdq vpid x2apic xgetbv1 xsave xsavec xsaveopt xsaves xtopology
    xtpr
    conditional; RSB filling; PBRSB-eIBRS: SW sequence; BHI: SW loop, KVM: SW
    loop
  Device-1: Intel TigerLake-LP GT2 [Iris Xe Graphics] vendor: ASUSTeK
    driver: i915 v: kernel alternate: xe arch: Xe process: Intel 10nm
    built: 2020-21 ports: active: HDMI-A-1,eDP-1 empty: DP-1,DP-2,DP-3
    bus-ID: 0000:00:02.0 chip-ID: 8086:9a49 class-ID: 0300
  Device-2: IMC Networks USB2.0 HD UVC WebCam driver: uvcvideo type: USB
    rev: 2.0 speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 3-5:5 chip-ID: 13d3:56a2
  Display: x11 server: X.org v: 1.21.1.15 with: Xwayland v: 24.1.4
    compositor: gnome-shell driver: X: loaded: modesetting alternate: fbdev,vesa
    dri: iris gpu: i915 display-ID: :0 screens: 1
  Screen-1: 0 s-res: 3840x1080 s-size: <missing: xdpyinfo>
  Monitor-1: HDMI-A-1 mapped: HDMI-1 pos: primary,right
    model: Philips PHL 221V8 serial: <filter> built: 2024 res: mode: 1920x1080
    hz: 60 scale: 100% (1) dpi: 102 gamma: 1.2 chroma: red: x: 0.659 y: 0.333
    green: x: 0.314 y: 0.616 blue: x: 0.149 y: 0.063 white: x: 0.314 y: 0.329
    size: 477x268mm (18.78x10.55") diag: 547mm (21.5") ratio: 16:9
    modes: 1920x1080, 1680x1050, 1280x1024, 1440x900, 1280x960, 1280x720,
    1024x768, 832x624, 800x600, 720x576, 720x480, 640x480, 720x400
  Monitor-2: eDP-1 pos: left model: ChiMei InnoLux 0x15f5 built: 2017 res:
    mode: 1920x1080 hz: 60 scale: 100% (1) dpi: 142 gamma: 1.2 chroma: red:
    x: 0.592 y: 0.349 green: x: 0.329 y: 0.557 blue: x: 0.153 y: 0.118 white:
    x: 0.314 y: 0.329 size: 344x193mm (13.54x7.6") diag: 394mm (15.5")
    ratio: 16:9 modes: 1920x1080
    device: 1 drv: swrast gbm: drv: iris surfaceless: drv: iris x11: drv: iris
    inactive: wayland
  API: OpenGL v: 4.6 compat-v: 4.5 vendor: intel mesa v: 24.3.4-arch1.1
    glx-v: 1.4 direct-render: yes renderer: Mesa Intel Iris Xe Graphics (TGL
    GT2) device-ID: 8086:9a49 memory: 11.31 GiB unified: yes
  Info: Tools: api: eglinfo,glxinfo x11: xprop,xrandr
  Device-1: Intel Tiger Lake-LP Smart Sound Audio vendor: ASUSTeK
    driver: sof-audio-pci-intel-tgl alternate: snd_hda_intel, snd_soc_avs,
    snd_sof_pci_intel_tgl bus-ID: 0000:00:1f.3 chip-ID: 8086:a0c8
    class-ID: 0401
  API: ALSA v: k6.13.0-1-MANJARO status: kernel-api with: aoss
  Server-2: PipeWire v: 1.2.7 status: off with: wireplumber status: active
    tools: pw-cli,wpctl
  Server-3: PulseAudio v: 17.0-43-g3e2bb status: active
    with: pulseaudio-alsa type: plugin tools: pacat,pactl,pamixer,pavucontrol
  Device-1: Intel Wi-Fi 6 AX201 driver: iwlwifi v: kernel bus-ID: 0000:00:14.3
    chip-ID: 8086:a0f0 class-ID: 0280
  Device-2: Intel Ethernet I219-V driver: e1000e v: kernel port: N/A
    bus-ID: 0000:00:1f.6 chip-ID: 8086:15fc class-ID: 0200
  IF: eno2 state: down mac: <filter>
  Info: services: httpd, NetworkManager, systemd-timesyncd, wpa_supplicant
    speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 3-10:8 chip-ID: 8087:0026
    class-ID: e001
  Hardware-1: Intel Volume Management Device NVMe RAID Controller driver: vmd
    v: 0.6 port: N/A bus-ID: 0000:00:0e.0 chip-ID: 8086:9a0b rev: class-ID: 0104
  Local Storage: total: 476.94 GiB used: 332.36 GiB (69.7%)
  ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Western Digital model: PC SN530
    SDBPNPZ-512G-1002 size: 476.94 GiB block-size: physical: 512 B
    fw-rev: 21106000 temp: 23.9 C scheme: GPT
  ID-1: / raw-size: 39.06 GiB size: 38.15 GiB (97.67%) used: 31.62 GiB (82.9%)
    fs: ext4 dev: /dev/nvme0n1p3 maj-min: 259:3 label: N/A
    uuid: 034cce20-46f0-4762-a989-90f4125f7af9
  ID-2: /boot/efi raw-size: 513 MiB size: 512 MiB (99.80%)
    used: 288 KiB (0.1%) fs: vfat dev: /dev/nvme0n1p2 maj-min: 259:2 label: N/A
    uuid: 6D27-E14D
  ID-3: /home raw-size: 29.3 GiB size: 28.67 GiB (97.86%)
    used: 21.73 GiB (75.8%) fs: ext4 dev: /dev/nvme0n1p6 maj-min: 259:6
    label: Home uuid: eefcea03-6127-40e9-935c-c00395787289
  ID-4: /mnt/Ocio raw-size: 192.99 GiB size: 188.9 GiB (97.88%)
    used: 147.59 GiB (78.1%) fs: ext4 dev: /dev/nvme0n1p8 maj-min: 259:8
    label: Ocio uuid: c4fcea3d-9d4c-4c00-af62-9feed8cf3d2d
  ID-5: /mnt/Trabajo raw-size: 205.08 GiB size: 200.8 GiB (97.91%)
    used: 131.42 GiB (65.4%) fs: ext4 dev: /dev/nvme0n1p7 maj-min: 259:7
    label: Trabajo uuid: c79f5441-4c29-470e-be18-d9d1166dae00
  Kernel: swappiness: 10 (default 60) cache-pressure: 100 (default) zswap: no
  ID-1: swap-1 type: partition size: 8.79 GiB used: 0 KiB (0.0%)
    priority: -2 dev: /dev/nvme0n1p1 maj-min: 259:1 label: N/A
    uuid: 35dedb6e-40ca-4832-b4a1-6fa39675484b
  ID-1: /dev/nvme0n1p4 maj-min: 259:4 size: 1.03 GiB fs: ntfs label: RECOVERY
    uuid: 1E7A889E7A8873F5
  ID-2: /dev/nvme0n1p5 maj-min: 259:5 size: 200 MiB fs: vfat label: MYASUS
    uuid: 8276-1117
  Hub-1: 1-0:1 info: hi-speed hub with single TT ports: 1 rev: 2.0
  Hub-3: 3-0:1 info: hi-speed hub with single TT ports: 12 rev: 2.0
  Hub-4: 3-2:2 info: VIA Labs VL812 Hub ports: 4 rev: 2.1
    speed: 480 Mb/s (57.2 MiB/s) lanes: 1 mode: 2.0 chip-ID: 2109:2812
  Device-1: 3-2.1:4 info: HP USB Optical Mouse type: mouse
    chip-ID: 03f0:0b4a class-ID: 0301
  Device-2: 3-2.2:6 info: Logitech Keyboard K120 type: keyboard,HID
    speed: 1.5 Mb/s (183 KiB/s) lanes: 1 mode: 1.0 power: 90mA
    chip-ID: 046d:c31c class-ID: 0300
  Device-3: 3-4:3 info: Realtek RTS5129 Card Reader Controller
    power: 500mA chip-ID: 0bda:0129 class-ID: ff00 serial: <filter>
  Device-4: 3-5:5 info: IMC Networks USB2.0 HD UVC WebCam type: video
    driver: uvcvideo interfaces: 3 rev: 2.0 speed: 480 Mb/s (57.2 MiB/s)
    lanes: 1 mode: 2.0 power: 500mA chip-ID: 13d3:56a2 class-ID: fe01
    serial: <filter>
  Device-5: 3-7:7 info: Elan Micro ELAN:ARM-M4 type: <vendor specific>
    driver: N/A interfaces: 1 rev: 2.0 speed: 12 Mb/s (1.4 MiB/s) lanes: 1
    mode: 1.1 power: 100mA chip-ID: 04f3:0c6c class-ID: 0000
  Device-6: 3-10:8 info: Intel AX201 Bluetooth type: bluetooth driver: btusb
    power: 100mA chip-ID: 8087:0026 class-ID: e001
  Hub-5: 4-0:1 info: super-speed hub ports: 4 rev: 3.1
  Hub-6: 4-2:2 info: VIA Labs VL812 Hub ports: 4 rev: 3.0
    speed: 5 Gb/s (596.0 MiB/s) lanes: 1 mode: 3.2 gen-1x1 chip-ID: 2109:0812
  System Temperatures: cpu: 46.0 C mobo: N/A
  Fan Speeds (rpm): cpu: 0
  Packages: pm: pacman pkgs: 1507 libs: 346 tools: gnome-software,pamac,yay
    pm: flatpak pkgs: 0
    1: http://manjaro.mirrors.uk2.net/stable/$repo/$arch
    2: https://fosszone.csd.auth.gr/manjaro/stable/$repo/$arch
    3: https://mirrors.dotsrc.org/manjaro/stable/$repo/$arch
    4: https://nocix.mm.fcix.net/manjaro/stable/$repo/$arch
    5: https://mirror.xenyth.net/manjaro/stable/$repo/$arch
    6: https://manjaro.mirror.liquidtelecom.com/stable/$repo/$arch
    7: https://mirror.kamtv.ru/manjaro/stable/$repo/$arch
    8: https://mirror.kku.ac.th/manjaro/stable/$repo/$arch
Processes:
  CPU top: 5 of 304
  1: cpu: 7.3% command: chromium pid: 3628 mem: 390.3 MiB (1.6%)
  2: cpu: 6.7% command: strawberry pid: 3412 mem: 179.9 MiB (0.7%)
  3: cpu: 5.6% command: chromium pid: 4822 mem: 292.7 MiB (1.2%)
  4: cpu: 5.3% command: chromium pid: 4536 mem: 269.7 MiB (1.1%)
  5: cpu: 4.0% command: chromium pid: 3944 mem: 326.5 MiB (1.3%)
  Memory top: 5 of 304
  1: mem: 390.3 MiB (1.6%) command: chromium pid: 3628 cpu: 7.3%
  2: mem: 375.3 MiB (1.5%) command: gnome-shell pid: 2586 cpu: 3.5%
  3: mem: 326.5 MiB (1.3%) command: chromium pid: 3944 cpu: 4.0%
  4: mem: 292.7 MiB (1.2%) command: chromium pid: 4822 cpu: 5.6%
  5: mem: 281.7 MiB (1.1%) command: chromium pid: 3668 cpu: 3.9%
  Processes: 304 Power: uptime: 1h 23m states: freeze,mem,disk suspend: s2idle
    avail: deep wakeups: 2 hibernate: platform avail: shutdown, reboot,
    suspend, test_resume image: 9.25 GiB services: gsd-power,
    tool: systemctl
  Compilers: clang: 19.1.7 gcc: 14.2.1 Shell: Zsh v: 5.9
    running-in: gnome-terminal inxi: 3.3.37
Possibly because the battery is next to dead …
You cannot revive this kind of battery
As for power-off - I have no idea
I be afraid to hear that…but that was suddenly…sorry…i has edited my post after send it but i did not edit title…power-off thing, solved
