When I close my labtop screen after sometime, or when my labtop attached to type c usb dock and not used sometime, when I start using the labtop again, after sometime, network goes away, commands ip a does not respond, systemctl commands freezes, finally my whole desktop freezes. My capslock button led starts flashing quickly. I presume it signifies kernel panic
Following shows my journalctl -b -1 -p -4 output, which shows the journal of the frozen boot… I have not seen anything that could impact kernel panic.
Mar 12 20:04:02 archlinux kernel: x86/cpu: SGX disabled by BIOS.
Mar 12 20:04:02 archlinux kernel: MDS CPU bug present and SMT on, data leak possible. See https://www.kernel.org/doc/html/latest/admin-guide/hw-vuln/mds.html for more details.
Mar 12 20:04:02 archlinux kernel: MMIO Stale Data CPU bug present and SMT on, data leak possible. See https://www.kernel.org/doc/html/latest/admin-guide/hw-vuln/processor_mmio_stale_data.html for more details.
Mar 12 20:04:02 archlinux kernel: ENERGY_PERF_BIAS: Set to 'normal', was 'performance'
Mar 12 20:04:02 archlinux kernel: hpet_acpi_add: no address or irqs in _CRS
Mar 12 20:04:02 archlinux kernel: i8042: Warning: Keylock active
Mar 12 20:04:02 archlinux systemd-cryptsetup[184]: Encountered unknown /etc/crypttab option 'discard=async', ignoring.
Mar 12 20:04:15 vostro systemd[1]: systemd-networkd.socket: Socket service systemd-networkd.service not loaded, refusing.
Mar 12 20:04:15 vostro systemd[1]: Failed to listen on Network Service Netlink Socket.
Mar 12 20:04:15 vostro kernel: vboxdrv: loading out-of-tree module taints kernel.
Mar 12 20:04:15 vostro kernel: VBoxNetAdp: Successfully started.
Mar 12 20:04:15 vostro kernel: VBoxNetFlt: Successfully started.
Mar 12 20:04:15 vostro systemd-journald[413]: File /var/log/journal/2d3f1b9480f14e94abf8f2ffec257ac9/system.journal corrupted or uncleanly shut down, renaming and replacing.
Mar 12 20:04:15 vostro kernel: wmi_bus wmi_bus-PNP0C14:02: WQBC data block query control method not found
Mar 12 20:04:16 vostro kernel: dell_smm_hwmon: SMM call took 359504 usecs!
Mar 12 20:04:16 vostro kernel: FAT-fs (nvme0n1p1): Volume was not properly unmounted. Some data may be corrupt. Please run fsck.
Mar 12 20:04:16 vostro (udev-worker)[481]: cfg80211: Process '/usr/bin/set-wireless-regdom' failed with exit code 1.
Mar 12 20:04:16 vostro kernel: r8169 0000:01:00.0: can't disable ASPM; OS doesn't have ASPM control
Mar 12 20:04:16 vostro kernel: iwlwifi 0000:00:14.3: WRT: Overriding region id 0
Mar 12 20:04:16 vostro kernel: iwlwifi 0000:00:14.3: WRT: Overriding region id 1
Mar 12 20:04:16 vostro kernel: iwlwifi 0000:00:14.3: WRT: Overriding region id 2
Mar 12 20:04:16 vostro kernel: iwlwifi 0000:00:14.3: WRT: Overriding region id 3
Mar 12 20:04:16 vostro kernel: iwlwifi 0000:00:14.3: WRT: Overriding region id 4
Mar 12 20:04:16 vostro kernel: iwlwifi 0000:00:14.3: WRT: Overriding region id 6
Mar 12 20:04:16 vostro kernel: iwlwifi 0000:00:14.3: WRT: Overriding region id 8
Mar 12 20:04:16 vostro kernel: iwlwifi 0000:00:14.3: WRT: Overriding region id 9
Mar 12 20:04:16 vostro kernel: iwlwifi 0000:00:14.3: WRT: Overriding region id 10
Mar 12 20:04:16 vostro kernel: iwlwifi 0000:00:14.3: WRT: Overriding region id 11
Mar 12 20:04:16 vostro kernel: iwlwifi 0000:00:14.3: WRT: Overriding region id 15
Mar 12 20:04:16 vostro kernel: iwlwifi 0000:00:14.3: WRT: Overriding region id 16
Mar 12 20:04:16 vostro kernel: iwlwifi 0000:00:14.3: WRT: Overriding region id 18
Mar 12 20:04:16 vostro kernel: iwlwifi 0000:00:14.3: WRT: Overriding region id 19
Mar 12 20:04:16 vostro kernel: iwlwifi 0000:00:14.3: WRT: Overriding region id 20
Mar 12 20:04:16 vostro kernel: iwlwifi 0000:00:14.3: WRT: Overriding region id 21
Mar 12 20:04:16 vostro kernel: iwlwifi 0000:00:14.3: WRT: Overriding region id 28
Mar 12 20:04:16 vostro bootctl[602]: ! Mount point '/boot' which backs the random seed file is world accessible, which is a security hole! !
Mar 12 20:04:16 vostro bootctl[602]: ! Random seed file '/boot/loader/random-seed' is world accessible, which is a security hole! !
Mar 12 20:04:17 vostro kernel: thermal thermal_zone7: failed to read out thermal zone (-61)
Mar 12 20:04:18 vostro (uetoothd)[848]: bluetooth.service: ConfigurationDirectory 'bluetooth' already exists but the mode is different. (File system: 755 ConfigurationDirectoryMode: 555)
Mar 12 20:04:18 vostro bluetoothd[848]: src/plugin.c:plugin_init() System does not support csip plugin
Mar 12 20:04:18 vostro bluetoothd[848]: profiles/audio/micp.c:micp_init() D-Bus experimental not enabled
Mar 12 20:04:18 vostro bluetoothd[848]: src/plugin.c:plugin_init() System does not support micp plugin
Mar 12 20:04:18 vostro bluetoothd[848]: src/plugin.c:plugin_init() System does not support vcp plugin
Mar 12 20:04:18 vostro bluetoothd[848]: src/plugin.c:plugin_init() System does not support mcp plugin
Mar 12 20:04:18 vostro bluetoothd[848]: src/plugin.c:plugin_init() System does not support bass plugin
Mar 12 20:04:18 vostro bluetoothd[848]: src/plugin.c:plugin_init() System does not support bap plugin
Mar 12 20:04:19 vostro kernel: Bluetooth: hci0: Malformed MSFT vendor event: 0x02
Mar 12 20:04:19 vostro kernel: Bluetooth: hci0: HCI LE Coded PHY feature bit is set, but its usage is not supported.
Mar 12 20:04:22 vostro dbus-broker-launch[833]: Activation request for 'org.freedesktop.home1' failed: The systemd unit 'dbus-org.freedesktop.home1.service' could not be found.
Mar 12 20:04:23 vostro dbus-broker-launch[1089]: Service file '/usr/share/dbus-1/services/io.elementary.files.Filemanager1.service' is not named after the D-Bus name 'org.freedesktop.FileManager1'.
Mar 12 20:04:23 vostro dbus-broker-launch[1089]: Service file '/usr/share/dbus-1/services/io.elementary.files.service' is not named after the D-Bus name 'io.elementary.files.db'.
Mar 12 20:04:23 vostro dbus-broker-launch[1089]: Service file '/usr/share/dbus-1/services/org.kde.dolphin.FileManager1.service' is not named after the D-Bus name 'org.freedesktop.FileManager1'.
Mar 12 20:04:23 vostro dbus-broker-launch[1089]: Ignoring duplicate name 'org.freedesktop.FileManager1' in service file '/usr/share/dbus-1/services/org.kde.dolphin.FileManager1.service'
Mar 12 20:04:23 vostro dbus-broker-launch[1089]: Service file '/usr/share/dbus-1/services/org.kde.kscreen.service' is not named after the D-Bus name 'org.kde.KScreen'.
Mar 12 20:04:23 vostro dbus-broker-launch[1089]: Service file '/usr/share/dbus-1/services/org.kde.plasma.Notifications.service' is not named after the D-Bus name 'org.freedesktop.Notifications'.
Mar 12 20:04:23 vostro kernel: sddm-greeter[1085]: memfd_create() called without MFD_EXEC or MFD_NOEXEC_SEAL set
Mar 12 20:04:24 vostro sddm-greeter[1085]: QObject: Cannot create children for a parent that is in a different thread.
(Parent is QGuiApplication(0x7fff03915250), parent's thread is QThread(0x555ef3ab2be0), current thread is QThread(0x555ef3bd7030)
Mar 12 20:04:24 vostro sddm-greeter[1085]: QObject::installEventFilter(): Cannot filter events for objects in a different thread.
Mar 12 20:04:25 vostro kernel: block nvme0n1: No UUID available providing old NGUID
Mar 12 20:04:27 vostro sddm-greeter[1085]: file:///usr/share/sddm/themes/breath/components/VirtualKeyboard.qml:11:1: Type InputPanel unavailable
Mar 12 20:04:27 vostro sddm-greeter[1085]: qrc:/QtQuick/VirtualKeyboard/content/InputPanel.qml:138:5: Type Keyboard unavailable
Mar 12 20:04:27 vostro sddm-greeter[1085]: qrc:/QtQuick/VirtualKeyboard/content/components/Keyboard.qml:38:1: module "QtQuick.VirtualKeyboard.Plugins" is not installed
Mar 12 20:04:28 vostro sddm-greeter[1085]: file:///usr/share/sddm/themes/breath/Main.qml:465:13: Unable to assign [undefined] to QUrl
Mar 12 20:04:28 vostro sddm-greeter[1085]: QDBusConnection: name 'org.freedesktop.UDisks2' had owner '' but we thought it was ':1.21'
Mar 12 20:04:28 vostro sddm-greeter[1085]: QDBusConnection: name 'org.freedesktop.UPower' had owner '' but we thought it was ':1.22'
Mar 12 20:04:35 vostro dbus-broker-launch[833]: Activation request for 'org.freedesktop.resolve1' failed: The systemd unit 'dbus-org.freedesktop.resolve1.service' could not be found.
Mar 12 20:04:35 vostro pam_ssh[1124]: /tmp/ssh-XXXXXX3ySWhK/agent.1943: Connection refused
Mar 12 20:04:35 vostro dbus-broker-launch[1194]: Service file '/usr/share/dbus-1/services/io.elementary.files.Filemanager1.service' is not named after the D-Bus name 'org.freedesktop.FileManager1'.
Mar 12 20:04:35 vostro dbus-broker-launch[1194]: Service file '/usr/share/dbus-1/services/io.elementary.files.service' is not named after the D-Bus name 'io.elementary.files.db'.
Mar 12 20:04:35 vostro dbus-broker-launch[1194]: Service file '/usr/share/dbus-1/services/org.kde.dolphin.FileManager1.service' is not named after the D-Bus name 'org.freedesktop.FileManager1'.
Mar 12 20:04:35 vostro dbus-broker-launch[1194]: Ignoring duplicate name 'org.freedesktop.FileManager1' in service file '/usr/share/dbus-1/services/org.kde.dolphin.FileManager1.service'
Mar 12 20:04:35 vostro dbus-broker-launch[1194]: Service file '/usr/share/dbus-1/services/org.kde.kscreen.service' is not named after the D-Bus name 'org.kde.KScreen'.
Mar 12 20:04:35 vostro dbus-broker-launch[1194]: Service file '/usr/share/dbus-1/services/org.kde.plasma.Notifications.service' is not named after the D-Bus name 'org.freedesktop.Notifications'.
Mar 12 20:04:37 vostro xdg-desktop-por[1233]: No skeleton to export
Mar 12 20:04:44 vostro kernel: warning: `ThreadPoolForeg' uses wireless extensions which will stop working for Wi-Fi 7 hardware; use nl80211
I am using Kernel: 6.6.16-2-MANJARO x86_64
I appreciate any help.
