My laptop blacked out after installing the hybrid driver
Installed Manjaro on my old Dell Vostro-3449 laptop. While playing
Minecraft, I noticed the dedicated GPU wasn’t working. Searched online
and learned I needed hybrid drivers. Used mhwd to install them, but after removing the default open-source drivers, my screen turned black with an error: ​Loadkmap: Short read. Any fixes?
Update Announcements
System Information
inxi --filter --verbosity=8
or the short form:
inxi -zv8
Required reading
Resources
inxi -zv8
  Kernel: 6.12.4-1-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 14.2.1 clocksource: tsc
    avail: acpi_pm parameters: BOOT_IMAGE=/@/boot/vmlinuz-6.12-x86_64
    root=UUID=fb771b47-3901-4457-a974-2c2625519d54 rw rootflags=subvol=@ quiet splash
    resume=UUID=4b85da62-c480-4ab3-ac61-7524621bd842 udev.log_priority=3
  Console: pty pts/0 DM: SDDM Distro: Manjaro base: Arch Linux
  Type: Portable System: Dell product: Vostro 3449 v: A14 serial: <superuser required> Chassis:
    type: 8 serial: <superuser required>
  Mobo: Dell model: 010VNF v: A00 serial: <superuser required> part-nu: 065E
    uuid: <superuser required> UEFI: Dell v: A14 date: 09/02/2020
  ID-1: BAT0 charge: 24.4 Wh (100.0%) condition: 24.4/41.4 Wh (59.0%) volts: 16.7 min: 14.8
    model: Samsung SD DELL XRDW253 type: Unknown serial: <filter> status: full
  System RAM: total: 8 GiB available: 7.67 GiB used: 464.1 MiB (5.9%)
  Array-1: capacity: 8 GiB slots: 1 modules: 1 EC: None max-module-size: 8 GiB note: est.
  Device-1: DIMM_A type: DDR3 detail: synchronous size: 8 GiB speed: 1600 MT/s volts: N/A
    width (bits): data: 64 total: 64 manufacturer: Samsung part-no: M471B5273DH0-YK0
    serial: <filter>
  Info: model: Intel Core i5-5200U bits: 64 type: MT MCP arch: Broadwell gen: core 5 level: v3
    note: check built: 2015-18 process: Intel 14nm family: 6 model-id: 0x3D (61) stepping: 4
    microcode: 0x2F
  Topology: cpus: 1x dies: 1 clusters: 2 cores: 2 threads: 4 tpc: 2 smt: enabled cache:
    L1: 128 KiB desc: d-2x32 KiB; i-2x32 KiB L2: 512 KiB desc: 2x256 KiB L3: 3 MiB desc: 1x3 MiB
  Speed (MHz): avg: 2700 min/max: 500/2700 scaling: driver: intel_cpufreq governor: schedutil
    cores: 1: 2700 2: 2700 3: 2700 4: 2700 bogomips: 17567
  Flags: 3dnowprefetch abm acpi adx aes aperfmperf apic arat arch_perfmon avx avx2 bmi1 bmi2
    bts clflush cmov constant_tsc cpuid cpuid_fault cx16 cx8 de ds_cpl dtes64 dtherm dts epb ept
    ept_ad erms est f16c flexpriority flush_l1d fma fpu fsgsbase fxsr ht ibpb ibrs ida intel_pt
    invpcid lahf_lm lm mca mce md_clear mmx monitor movbe msr mtrr nonstop_tsc nopl nx pae pat
    pbe pcid pclmulqdq pdcm pdpe1gb pebs pge pln pni popcnt pse pse36 pti pts rdrand rdseed
    rdtscp rep_good sdbg sep smap smep ss ssbd sse sse2 sse4_1 sse4_2 ssse3 stibp syscall tm tm2
    tpr_shadow tsc tsc_adjust tsc_deadline_timer vme vmx vnmi vpid x2apic xsave xsaveopt
    xtopology xtpr
  Type: l1tf mitigation: PTE Inversion; VMX: conditional cache flushes, SMT vulnerable
  Type: spec_store_bypass mitigation: Speculative Store Bypass disabled via prctl
  Type: spectre_v2 mitigation: Retpolines; IBPB: conditional; IBRS_FW; STIBP: conditional; RSB
    filling; PBRSB-eIBRS: Not affected; BHI: Not affected
  Device-1: Intel HD Graphics 5500 vendor: Dell driver: i915 v: kernel arch: Gen-8
    process: Intel 14nm built: 2014-15 ports: active: eDP-1 empty: DP-1,HDMI-A-1 bus-ID: 00:02.0
    chip-ID: 8086:1616 class-ID: 0300
  Device-2: NVIDIA GF117M [GeForce 610M/710M/810M/820M / GT 620M/625M/630M/720M] vendor: Dell
    driver: nouveau v: kernel non-free: series: 390.xx+ status: legacy (EOL~2022-11-22) last:
    release: 390.157 kernel: 6.0 xorg: 1.21 arch: Fermi code: GF1xx process: 40/28nm
    built: 2010-2016 pcie: gen: 1 speed: 2.5 GT/s lanes: 4 link-max: lanes: 8 bus-ID: 08:00.0
    chip-ID: 10de:1140 class-ID: 0302
  Device-3: Sunplus Innovation Integrated_Webcam_HD driver: uvcvideo type: USB rev: 2.0
    speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 3-1.5:3 chip-ID: 1bcf:2b8b class-ID: 0e02
  Display: server: X.org v: 1.21.1.14 with: Xwayland v: 24.1.4 driver: X: loaded: N/A
    alternate: intel gpu: i915 tty: 243x32
  Monitor-1: eDP-1 model: AU Optronics 0x9b8c built: 2019 res: 1366x768 dpi: 112 gamma: 1.2
    chroma: red: x: 0.561 y: 0.337 green: x: 0.345 y: 0.576 blue: x: 0.161 y: 0.125 white: x: 0.314
    y: 0.329 size: 309x173mm (12.17x6.81") diag: 354mm (13.9") ratio: 16:9 modes: 1366x768
  EDID-Warnings: 1: parse_edid: unknown flag 2
  API: EGL v: 1.5 hw: drv: intel iris drv: nvidia nouveau platforms: device: 0 drv: iris
    device: 1 drv: nouveau device: 2 drv: swrast surfaceless: drv: iris inactive: gbm,wayland,x11
  API: OpenGL v: 4.6 compat-v: 4.3 vendor: mesa v: 24.2.8-arch1.1 note: console (EGL sourced)
    renderer: Mesa Intel HD Graphics 5500 (BDW GT2), NVD7, llvmpipe (LLVM 18.1.8 256 bits)
  Device-1: Intel Broadwell-U Audio vendor: Dell driver: snd_hda_intel v: kernel bus-ID: 00:03.0
    chip-ID: 8086:160c class-ID: 0403
  Device-2: Intel Wildcat Point-LP High Definition Audio vendor: Dell driver: snd_hda_intel
    v: kernel bus-ID: 00:1b.0 chip-ID: 8086:9ca0 class-ID: 0403
  API: ALSA v: k6.12.4-1-MANJARO status: kernel-api with: aoss type: oss-emulator
  Server-2: PipeWire v: 1.2.7 status: off with: 1: pipewire-pulse status: off 2: wireplumber
    status: off 3: pipewire-alsa type: plugin tools: pactl,pw-cat,pw-cli,wpctl
  Device-1: Qualcomm Atheros QCA9565 / AR9565 Wireless Network Adapter vendor: Dell driver: ath9k
    v: kernel pcie: gen: 1 speed: 2.5 GT/s lanes: 1 bus-ID: 06:00.0 chip-ID: 168c:0036
    class-ID: 0280
  IF: wlp6s0 state: up mac: <filter>
  IP v4: <filter> type: dynamic noprefixroute scope: global broadcast: <filter>
  Device-2: Realtek RTL8111/8168/8211/8411 PCI Express Gigabit Ethernet vendor: Dell
    driver: r8169 v: kernel pcie: gen: 1 speed: 2.5 GT/s lanes: 1 port: 4000 bus-ID: 07:00.0
  IF: enp7s0 state: down mac: <filter>
  Device-1: Qualcomm Atheros AR9462 Bluetooth driver: btusb v: 0.8 type: USB rev: 1.1
    speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 3-1.6:6 chip-ID: 0cf3:0036 class-ID: e001
  Local Storage: total: 689.33 GiB used: 4.53 GiB (0.7%)
  ID-1: /dev/sda maj-min: 8:0 vendor: Crucial model: CT240BX500SSD1 size: 223.57 GiB block-size:
    physical: 512 B logical: 512 B speed: 6.0 Gb/s tech: SSD serial: <filter> fw-rev: R013
    scheme: GPT
  ID-2: /dev/sdb maj-min: 8:16 vendor: Western Digital model: WD5000LPVX-75V0TT0
    size: 465.76 GiB block-size: physical: 4096 B logical: 512 B speed: 6.0 Gb/s tech: HDD rpm: 5400
    serial: <filter> fw-rev: 1A01 scheme: GPT
  ID-1: / raw-size: 214.48 GiB size: 214.48 GiB (100.00%) used: 4.52 GiB (2.1%) fs: btrfs
    dev: /dev/sda2 maj-min: 8:2 label: N/A uuid: fb771b47-3901-4457-a974-2c2625519d54
  ID-2: /boot/efi raw-size: 300 MiB size: 299.4 MiB (99.80%) used: 584 KiB (0.2%) fs: vfat
    dev: /dev/sda1 maj-min: 8:1 label: N/A uuid: 7727-6524
  ID-3: /home raw-size: 214.48 GiB size: 214.48 GiB (100.00%) used: 4.52 GiB (2.1%) fs: btrfs
  ID-4: /var/cache raw-size: 214.48 GiB size: 214.48 GiB (100.00%) used: 4.52 GiB (2.1%)
    fs: btrfs dev: /dev/sda2 maj-min: 8:2 label: N/A uuid: fb771b47-3901-4457-a974-2c2625519d54
  ID-5: /var/log raw-size: 214.48 GiB size: 214.48 GiB (100.00%) used: 4.52 GiB (2.1%) fs: btrfs
  ID-1: swap-1 type: partition size: 8.8 GiB used: 0 KiB (0.0%) priority: -2 dev: /dev/sda3
    maj-min: 8:3 label: swap uuid: 4b85da62-c480-4ab3-ac61-7524621bd842
  Hub-1: 1-0:1 info: hi-speed hub with single TT ports: 11 rev: 2.0 speed: 480 Mb/s (57.2 MiB/s)
    lanes: 1 mode: 2.0 chip-ID: 1d6b:0002 class-ID: 0900
  Device-1: 1-1:5 info: A4Tech USB Mouse type: mouse driver: hid-generic,usbhid interfaces: 1
    rev: 1.1 speed: 1.5 Mb/s (183 KiB/s) lanes: 1 mode: 1.0 power: 98mA chip-ID: 09da:8736
    class-ID: 0301
  Hub-2: 2-0:1 info: super-speed hub ports: 4 rev: 3.0 speed: 5 Gb/s (596.0 MiB/s) lanes: 1
    mode: 3.2 gen-1x1 chip-ID: 1d6b:0003 class-ID: 0900
  Hub-3: 3-0:1 info: full speed or root hub ports: 2 rev: 2.0 speed: 480 Mb/s (57.2 MiB/s)
  Hub-4: 3-1:2 info: Intel Integrated Hub ports: 8 rev: 2.0 speed: 480 Mb/s (57.2 MiB/s)
    lanes: 1 mode: 2.0 chip-ID: 8087:8001 class-ID: 0900
  Device-1: 3-1.5:3 info: Sunplus Innovation Integrated_Webcam_HD type: video driver: uvcvideo
    interfaces: 2 rev: 2.0 speed: 480 Mb/s (57.2 MiB/s) lanes: 1 mode: 2.0 power: 500mA
  Device-2: 3-1.6:6 info: Qualcomm Atheros AR9462 Bluetooth type: bluetooth driver: btusb
    interfaces: 2 rev: 1.1 speed: 12 Mb/s (1.4 MiB/s) lanes: 1 mode: 1.1 power: 100mA
  Device-3: 3-1.8:5 info: Realtek RTS5129 Card Reader Controller type: <vendor specific>
    driver: rtsx_usb,rtsx_usb_ms,rtsx_usb_sdmmc interfaces: 1 rev: 2.0 speed: 480 Mb/s (57.2 MiB/s)
    lanes: 1 mode: 2.0 power: 500mA chip-ID: 0bda:0129 class-ID: ff00 serial: <filter>
  System Temperatures: cpu: 40.0 C mobo: 39.0 C
  Fan Speeds (rpm): cpu: 0
  Packages: pm: pacman pkgs: 1077 libs: 303 tools: pamac
    1: https://mirror.nju.edu.cn/manjaro/stable/$repo/$arch
    2: https://mirrors.ustc.edu.cn/manjaro/stable/$repo/$arch
    3: https://mirror.nyist.edu.cn/manjaro/stable/$repo/$arch
    4: https://mirrors.jlu.edu.cn/manjaro/stable/$repo/$arch
    5: https://mirrors.sjtug.sjtu.edu.cn/manjaro/stable/$repo/$arch
    6: https://mirrors.tuna.tsinghua.edu.cn/manjaro/stable/$repo/$arch
Processes:
  CPU top: 5 of 161
  1: cpu: 4.5% command: init pid: 1 mem: 13.3 MiB (0.1%)
  2: cpu: 1.7% command: [kworker/u16:1-btrfs-endio] pid: 13 mem: 0.00 MiB (0.0%)
  3: cpu: 1.5% command: [kworker/1:2-pm] pid: 92 mem: 0.00 MiB (0.0%)
  4: cpu: 1.4% command: systemd-journald pid: 294 mem: 22.6 MiB (0.2%)
  5: cpu: 1.4% command: NetworkManager pid: 478 mem: 23.3 MiB (0.2%)
  Memory top: 5 of 161
  1: mem: 23.3 MiB (0.2%) command: NetworkManager pid: 478 cpu: 1.4%
  2: mem: 22.6 MiB (0.2%) command: systemd-journald pid: 294 cpu: 1.4%
  3: mem: 22.1 MiB (0.2%) command: sddm pid: 549 cpu: 0.2%
  4: mem: 17.4 MiB (0.2%) command: (udev-worker) pid: 626 cpu: 0.8%
  5: mem: 17.2 MiB (0.2%) command: (udev-worker) pid: 622 cpu: 0.2%
  Processes: 161 Power: uptime: 0m states: freeze,mem,disk suspend: deep avail: s2idle wakeups: 0
    hibernate: platform avail: shutdown, reboot, suspend, test_resume image: 3.04 GiB Init: systemd
    v: 256 default: graphical tool: systemctl
  Compilers: N/A Shell: Bash v: 5.2.37 running-in: pty pts/0 (SSH) inxi: 3.3.36
