i was a windows user internet was fine, i switched to linux started with ubuntu, but my wifi router was so slow, the thing is my hotspot data from my phone was fine, and the other thing i used usb tethring from my phone via the same wifi that is not working and it was completely fine.i switched to fedora and manjaro (witch i’m using now) and exactly the same proplem.
i hope someone help me.
output of: inxi --admin --verbosity=7 --filter --no-host --width.
Kernel: 5.15.50-1-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 12.1.0
root=UUID=09bc1d03-554e-43d0-815a-90f8e94118d0 rw quiet apparmor=1
security=apparmor resume=UUID=8bc2f63b-e1ea-4f31-8aa5-7915fe3e93de
udev.log_priority=3
Desktop: KDE Plasma v: 5.24.5 tk: Qt v: 5.15.5 wm: kwin_x11 vt: 1 dm: SDDM
Type: Laptop System: Dell product: Latitude E6540 v: 00
serial: Chassis: type: 9 serial:
Mobo: Dell model: 0HF9PT v: A00 serial: UEFI: Dell
v: A27 date: 06/13/2019
RAM: total: 7.67 GiB used: 1.99 GiB (25.9%)
RAM Report:
Info: model: Intel Core i7-4610M bits: 64 type: MT MCP arch: Haswell
gen: core 4 built: 2013-15 process: Intel 22nm family: 6 model-id: 0x3C (60)
stepping: 3 microcode: 0x28
L3: 4 MiB desc: 1x4 MiB
Speed (MHz): avg: 2993 high: 2995 min/max: 800/3700 scaling:
driver: intel_cpufreq governor: schedutil cores: 1: 2993 2: 2993 3: 2994
4: 2995 bogomips: 23954
Flags: abm acpi aes aperfmperf apic arat arch_perfmon avx avx2 bmi1 bmi2
bts clflush cmov constant_tsc cpuid cpuid_fault cx16 cx8 de ds_cpl dtes64
fsgsbase fxsr ht ibpb ibrs ida invpcid invpcid_single lahf_lm lm mca mce
md_clear mmx monitor movbe msr mtrr nonstop_tsc nopl nx pae pat pbe pcid
pclmulqdq pdcm pdpe1gb pebs pge pln pni popcnt pse pse36 pti pts rdrand
rdtscp rep_good sdbg sep smep smx ss ssbd sse sse2 sse4_1 sse4_2 ssse3
stibp syscall tm tm2 tpr_shadow tsc tsc_adjust tsc_deadline_timer vme vmx
vnmi vpid x2apic xsave xsaveopt xtopology xtpr
Type: l1tf
Device-1: Intel Ethernet I217-LM vendor: Dell driver: e1000e v: kernel
port: f080 bus-ID: 00:19.0 chip-ID: 8086:153a class-ID: 0200
IF: eno1 state: down mac:
Device-2: Intel Centrino Ultimate-N 6300 driver: iwlwifi v: kernel pcie:
gen: 1 speed: 2.5 GT/s lanes: 1 bus-ID: 03:00.0 chip-ID: 8086:422b
class-ID: 0280
IF: wlp3s0 state: up mac:
IP v4: type: dynamic noprefixroute scope: global
broadcast:
IP v6: type: noprefixroute scope: link
WAN IP:
Hardware-1: Intel 82801 Mobile SATA Controller [RAID mode] driver: ahci
v: 3.0 port: f060 bus-ID: 00:1f.2 chip-ID: 8086:282a rev: N/A class-ID: 0104
Local Storage: total: 238.47 GiB used: 120.01 GiB (50.3%)
ID-1: /dev/sda maj-min: 8:0 model: P3-256 size: 238.47 GiB block-size:
physical: 512 B logical: 512 B speed: 6.0 Gb/s type: SSD serial:
rev: 0326 scheme: GPT
Optical-1: /dev/sr0 vendor: HL-DT-ST model: DVD±RW GU90N rev: A1B0
dev-links: cdrom
ID-1: / raw-size: 100 GiB size: 97.87 GiB (97.87%) used: 35.96 GiB (36.7%)
fs: ext4 dev: /dev/sda4 maj-min: 8:4 label: N/A
uuid: 09bc1d03-554e-43d0-815a-90f8e94118d0
ID-2: /boot/efi raw-size: 512 MiB size: 96 MiB (18.75%)
used: 29.5 MiB (30.8%) fs: vfat dev: /dev/sda1 maj-min: 8:1 label: N/A
uuid: A08C-CD30
ID-3: /run/media/muhammad/da258fa8-1803-43b7-a047-67ab85d6770e
raw-size: 130.41 GiB size: 127.3 GiB (97.62%) used: 84.03 GiB (66.0%)
fs: ext4 dev: /dev/sda3 maj-min: 8:3 label: N/A
uuid: da258fa8-1803-43b7-a047-67ab85d6770e
Kernel: swappiness: 10 (default 60) cache-pressure: 100 (default)
ID-1: swap-1 type: partition size: 7.56 GiB used: 0 KiB (0.0%)
priority: -2 dev: /dev/sda2 maj-min: 8:2 label: N/A
uuid: 8bc2f63b-e1ea-4f31-8aa5-7915fe3e93de
Hub-1: 1-0:1 info: Full speed or root hub ports: 2 rev: 2.0 speed: 480 Mb/s
speed: 480 Mb/s chip-ID: 8087:8008 class-ID: 0900
Hub-3: 2-0:1 info: Full speed or root hub ports: 2 rev: 2.0
Hub-4: 2-1:2 info: Intel Integrated Rate Matching Hub ports: 8 rev: 2.0
speed: 480 Mb/s chip-ID: 8087:8000 class-ID: 0900
Device-1: 2-1.8:3 info: Broadcom BCM5880 Secure Applications Processor
type: Smart Card driver: N/A interfaces: 2 rev: 1.1 speed: 12 Mb/s
power: 100mA chip-ID: 0a5c:5800 class-ID: 0b00 serial:
Hub-5: 3-0:1 info: Hi-speed hub with single TT ports: 15 rev: 2.0
Device-1: 3-1:6 info: USB OPTICAL MOUSE type: Mouse,Keyboard
power: 100mA chip-ID: 4e53:5407 class-ID: 0301
Device-2: 3-6:4 info: Dell SK-3205 SmartCard Reader Keyboard
type: Keyboard,Smart Card driver: hid-generic,usbhid interfaces: 2 rev: 2.0
speed: 12 Mb/s power: 50mA chip-ID: 413c:2101 class-ID: 0b00
Hub-6: 4-0:1 info: Super-speed hub ports: 6 rev: 3.0 speed: 5 Gb/s
System Temperatures: cpu: 49.0 C mobo: 51.0 C sodimm: SODIMM C gpu: radeon
temp: 45.0 C
Fan Speeds (RPM): cpu: 3223
Processes: 228 Uptime: 1d 6m wakeups: 22 Init: systemd v: 251
default: graphical tool: systemctl Compilers: gcc: 12.1.0 clang: 13.0.1
Packages: pacman: 1252 lib: 339 flatpak: 0 Shell: Zsh v: 5.9 default: Bash
v: 5.1.16 running-in: konsole inxi: 3.3.19
