My Intel Wireless AC 9260 gets detected, but does not scan any wifi networks
#1
I recently installed Manjaro KDE edition, but I cannot get the wifi to work. I have tried installing the drivers manually with no success. The card does work flawlessly on windows, but cannot detect any wifi networks on Manjaro. Running inxi -F gives this:
Device-1: Intel Wireless AC 9260 driver:N/A
Device-2: Realtek RT8111/8168/8411 PCI Express Gigabit Ethernet driver: r8169
IF: enp4s0 state: down mac:d8:cb:8a:2e:db:69
I believe that it is a driver problem due to the N/A drivers. But, after looking at lib/firmware, the drivers seem present.
Thanks for any help! :smiley:
#2
try this
ifconfig wlan0 up
and post the result.
#3
Run the set of commands below to see if your connection can be properly initiated.
Please do not cut and paste all the commands together at once.
Enter and run each command separately with a few seconds between each command.
Please post all inputs, and all outputs of the sequence of commands once they are finished being run.
Please do not give me a summary, such as “there were no outputs”.
It is very important that you post each input and output for troubleshooting purposes.
nmcli networking off
sudo systemctl stop NetworkManager
sudo ip link set wlan0 down
sudo lsmod | grep -o -e ^iwlmvm -e ^iwldvm -e ^iwlwifi | xargs sudo rmmod
sudo modprobe iwlwifi
sudo ip link set wlan0 up
sudo systemctl start NetworkManager
nmcli networking on
Also, please post:
inxi -Fxxxz
hwinfo --netcard --wlan --bluetooth | grep -Ei "model\:|driver\:|status\:|cmd\:|file\:|detected\:" | grep -v "Config Status"
Please post the input/outputs of all requested commands via the terminal as text, (not as pics).
Information on how to properly post hardware specs and logs:
Please format any terminal output with three backticks before and after, as shown in this picture:
I would also suggest installing and testing both older and newer kernels. Try at least these kernels 4.14, 4.19, and 4.20. Install kernels through Manjaro Settings Manager, and always have at least two kernels installed at all times for safety.
Internet connection doesn't work after suspend
#4
Here is the console output. Thanks for helping!
[yash@MyAmazingPC ~]$ sudo nmcli networking off
[yash@MyAmazingPC ~]$ sudo systemctl stop NetworkManager
[yash@MyAmazingPC ~]$ sudo ip link set wlan0 down
Cannot find device "wlan0"
[yash@MyAmazingPC ~]$ sudo lsmod | grep -o -e ^iwlmvm -e ^iwldvm -e ^iwlwifi | xargs sudo rmmod
[yash@MyAmazingPC ~]$ sudo modprobe iwlwifi
[yash@MyAmazingPC ~]$ sudo ip link set wlan0 up
[yash@MyAmazingPC ~]$ sudo systemctl start NetworkManager
[yash@MyAmazingPC ~]$ nmcli networking on
[yash@MyAmazingPC ~]$ inxi -Fxxxz
System:    Host: MyAmazingPC Kernel: 4.19.13-1-MANJARO x86_64 bits: 64 compiler: gcc v: 8.2.1 Desktop: KDE Plasma 5.14.4
           tk: Qt 5.12.0 wm: kwin_x11 dm: SDDM Distro: Manjaro Linux
Machine:   Type: Desktop System: LENOVO product: 90AV001LUK v: Erazer X310 serial: <filter>
           Mobo: LENOVO model: N/A v: 31900058 STD serial: <filter> UEFI: LENOVO v: I1KT44AUS date: 11/14/2014
CPU:       Topology: Quad Core model: Intel Core i7-4790 bits: 64 type: MT MCP arch: Haswell rev: 3 L2 cache: 8192 KiB
           flags: lm nx pae sse sse2 sse3 sse4_1 sse4_2 ssse3 vmx bogomips: 57481
           Speed: 2367 MHz min/max: 800/4000 MHz Core speeds (MHz): 1: 2367 2: 3851 3: 1921 4: 2108 5: 3752 6: 2148 7: 2184
           8: 2914
Graphics:  Device-1: Advanced Micro Devices [AMD/ATI] Ellesmere [Radeon RX 470/480/570/570X/580/580X] vendor: Micro-Star MSI
           driver: amdgpu v: kernel bus ID: 01:00.0 chip ID: 1002:67df
           Display: x11 server: X.Org 1.20.3 driver: amdgpu,ati unloaded: modesetting alternate: fbdev,vesa
           compositor: kwin_x11 resolution: 1920x1080~60Hz
           OpenGL: renderer: AMD Radeon RX 480 Graphics (POLARIS10 DRM 3.27.0 4.19.13-1-MANJARO LLVM 7.0.0) v: 4.5 Mesa 18.3.1
           direct render: Yes
Audio:     Device-1: Intel 8 Series/C220 Series High Definition Audio vendor: Lenovo driver: snd_hda_intel v: kernel
           bus ID: 00:1b.0 chip ID: 8086:8c20
           Device-2: Advanced Micro Devices [AMD/ATI] Ellesmere [Radeon RX 580] vendor: Micro-Star MSI driver: snd_hda_intel
           v: kernel bus ID: 01:00.1 chip ID: 1002:aaf0
           Device-3: Logitech HD Pro Webcam C920 type: USB driver: snd-usb-audio,uvcvideo bus ID: 2-1:2 chip ID: 046d:082d
           serial: <filter>
           Sound Server: ALSA v: k4.19.13-1-MANJARO
Network:   Device-1: Intel Wireless-AC 9260 driver: N/A port: e000 bus ID: 03:00.0 chip ID: 8086:2526
           Device-2: Realtek RTL8111/8168/8411 PCI Express Gigabit Ethernet vendor: Lenovo driver: r8169 v: kernel port: d000
           bus ID: 04:00.0 chip ID: 10ec:8168
           IF: enp4s0 state: down mac: <filter>
Drives:    Local Storage: total: 3.18 TiB used: 8.35 GiB (0.3%)
           ID-1: /dev/sda vendor: Samsung model: SSD 860 EVO 500GB size: 465.76 GiB speed: 6.0 Gb/s serial: <filter> rev: 1B6Q
           scheme: GPT
           ID-2: /dev/sdb vendor: Toshiba model: HDWD130 size: 2.73 TiB speed: 6.0 Gb/s rotation: 7200 rpm serial: <filter>
           rev: ACF0 scheme: GPT
Partition: ID-1: / size: 98.10 GiB used: 8.33 GiB (8.5%) fs: ext4 dev: /dev/sdb3
Sensors:   System Temperatures: cpu: 33.0 C mobo: N/A gpu: amdgpu temp: 29 C
           Fan Speeds (RPM): N/A gpu: amdgpu fan: 1349
Info:      Processes: 206 Uptime: 5m Memory: 15.60 GiB used: 595.1 MiB (3.7%) Init: systemd v: 239 Compilers: gcc: 8.2.1
           Shell: bash v: 4.4.23 running in: yakuake inxi: 3.0.28
[yash@MyAmazingPC ~]$ hwinfo --netcard --wlan --bluetooth | grep -Ei “model:|driver:|status:|cmd:|file:|detected:” | grep -v “Config Status”
  Model: "Intel Network controller"
    Driver Status: iwlwifi is active
    Driver Activation Cmd: "modprobe iwlwifi"
  Model: "Realtek RTL8111/8168/8411 PCI Express Gigabit Ethernet Controller"
  Driver: "r8169"
  Device File: enp4s0
  Link detected: no
    Driver Status: r8169 is active
    Driver Activation Cmd: "modprobe r8169"
#5
#7
Just to do a check list, is it a notebook or a pc?
If it’s a notebook did you check that the wifi button is on?
Did you tried with another kernel? Like 4.14?
#8
A network adapter not being detected properly (or a hard block) can sometimes be hard to correct. Changing the BIOS settings may help in this situation (as well as power cycling). If available, a BIOS update may also help correct these problems. Below are several methods that may help with raising your adapter.
Resetting the BIOS back to the factory default settings may help with adapter detection. This also sometimes helps to remove a hard block. Boot into the BIOS settings utility and reset the BIOS back to the factory default. Save the default settings, and power down the laptop.
Remove the battery and power plug, and let the laptop sit without power for a few minutes. Then, hold down the power button for approximately 30 seconds. Pressing the power button will help drain all left over power from the unit’s motherboard.
Then restart the laptop, and see if it will boot with the factory default settings. If not, you may have to change some settings in the BIOS (such as secure boot) to get Linux to boot up.
Hopefully, after rebooting your adapter is properly detected.
#9
It is a pc. I tried kernel 4.20 and 4.14. It sometimes works, but sometimes doesn’t. I’m not sure what is happening?
#10
I reset the BIOS settings, but still no luck.
#11
I’m having exactly the same problem as:
The iwlwifi driver keeps failing, however by booting into windows and then back into Manjaro, this isn’t a problem.
#12
The Intel 9260 should work with kernel 4.14 and up. Do you have the firmware for it installed?
Link to Intel page: https://www.intel.com/content/www/us/en/support/articles/000005511/network-and-i-o/wireless-networking.html
Not saying you need to install it from the Intel page, only providing it as a reference. I would imagine if the package is in the repos its something like “iwl…” or “iwlwifi…”.
Not sure if this Majaro site for searching packages is maintained: https://repology.org/metapackages/?inrepo=manjaro_stable but I could not find the drivers/firmware for Intel wifi in it.
According to this post https://unix.stackexchange.com/questions/441945/how-do-i-install-wifi-driver-in-arch-linux the Intel wifi firmwares may be part of linux-firmware. This link seems to confirm that the 9260.ucode is part of it: https://git.kernel.org/pub/scm/linux/kernel/git/firmware/linux-firmware.git/tree/. They mention trying a similar command to verify:
ls /lib/firmware/ | grep 'iwlwifi'
or
ls /lib/firmware/ | grep '9260'
This should list either all iwl .ucode entries or the 9260 specific one. If you have the ucode, then its unlikely a firmware/driver issue.
#13
I typed in the command ls /lib/firmware/ | grep ‘9260’ and got this:
iwlwifi-9260-th-b0-jf-b0-33.ucode
iwlwifi-9260-th-b0-jf-b0-34.ucode
iwlwifi-9260-th-b0-jf-b0-38.ucode
iwlwifi-9260-th-b0-jf-b0-41.ucode
iwlwifi-9260-th-b0-jf-b0-43.ucode
As you say, since it is listing the drivers, it probably is not a problem with the drivers. But do you know why it starts working after booting into windows and then into Manjaro? Is this related to dual booting?
#14
Yes, that is usually from Windows interfering with the driver. It could however be a wmi issue that requires blacklisting.
lsmod
#15
Thanks for the reply. Is it possible for you to guide me through how to do this?
#16
Simply input lsmod in the terminal, and post the output.
#17
lsmod
Module                  Size  Used by
ccm                    20480  6
mousedev               24576  0
joydev                 24576  0
input_leds             16384  0
uvcvideo              118784  0
videobuf2_vmalloc      16384  1 uvcvideo
videobuf2_memops       16384  1 videobuf2_vmalloc
videobuf2_v4l2         28672  1 uvcvideo
videobuf2_common       53248  2 videobuf2_v4l2,uvcvideo
snd_usb_audio         258048  1
videodev              217088  3 videobuf2_v4l2,uvcvideo,videobuf2_common
snd_usbmidi_lib        32768  1 snd_usb_audio
snd_rawmidi            36864  1 snd_usbmidi_lib
snd_seq_device         16384  1 snd_rawmidi
media                  45056  2 videodev,uvcvideo
hid_generic            16384  0
usbhid                 57344  0
hid                   139264  2 usbhid,hid_generic
nls_iso8859_1          16384  1
nls_cp437              20480  1
vfat                   24576  1
fat                    81920  1 vfat
amdkfd                229376  1
amd_iommu_v2           20480  1 amdkfd
amdgpu               3424256  17
arc4                   16384  2
intel_rapl             24576  0
x86_pkg_temp_thermal    16384  0
intel_powerclamp       16384  0
coretemp               16384  0
chash                  16384  1 amdgpu
iwlmvm                442368  0
snd_hda_codec_realtek   118784  1
mac80211              929792  1 iwlmvm
kvm_intel             245760  0
gpu_sched              28672  1 amdgpu
i2c_algo_bit           16384  1 amdgpu
kvm                   737280  1 kvm_intel
ttm                   126976  1 amdgpu
snd_hda_codec_generic    86016  1 snd_hda_codec_realtek
snd_hda_codec_hdmi     57344  1
drm_kms_helper        208896  1 amdgpu
snd_hda_intel          45056  5
drm                   495616  11 gpu_sched,drm_kms_helper,amdgpu,ttm
snd_hda_codec         151552  4 snd_hda_codec_generic,snd_hda_codec_hdmi,snd_hda_intel,snd_hda_codec_realtek
irqbypass              16384  1 kvm
snd_hda_core           94208  5 snd_hda_codec_generic,snd_hda_codec_hdmi,snd_hda_intel,snd_hda_codec,snd_hda_codec_realtek
crct10dif_pclmul       16384  0
crc32_pclmul           16384  0
snd_hwdep              16384  2 snd_usb_audio,snd_hda_codec
ghash_clmulni_intel    16384  0
snd_pcm               131072  5 snd_hda_codec_hdmi,snd_hda_intel,snd_usb_audio,snd_hda_codec,snd_hda_core
agpgart                49152  2 ttm,drm
snd_timer              36864  1 snd_pcm
pcbc                   16384  0
iwlwifi               344064  1 iwlmvm
snd                    98304  24 snd_hda_codec_generic,snd_seq_device,snd_hda_codec_hdmi,snd_hwdep,snd_hda_intel,snd_usb_audio,snd_usbmidi_lib,snd_hda_codec,snd_hda_codec_realtek,snd_timer,snd_pcm,snd_rawmidi
syscopyarea            16384  1 drm_kms_helper
sysfillrect            16384  1 drm_kms_helper
sysimgblt              16384  1 drm_kms_helper
fb_sys_fops            16384  1 drm_kms_helper
realtek                20480  1
aesni_intel           200704  4
r8169                  90112  0
aes_x86_64             20480  1 aesni_intel
ofpart                 16384  0
iTCO_wdt               16384  0
iTCO_vendor_support    16384  1 iTCO_wdt
cmdlinepart            16384  0
libphy                 77824  2 r8169,realtek
intel_spi_platform     16384  0
intel_spi              20480  1 intel_spi_platform
spi_nor                36864  1 intel_spi
mei_wdt                16384  0
cfg80211              778240  3 iwlmvm,iwlwifi,mac80211
mtd                    69632  5 cmdlinepart,intel_spi,ofpart
soundcore              16384  1 snd
crypto_simd            16384  1 aesni_intel
rfkill                 28672  6 cfg80211
cryptd                 28672  3 crypto_simd,ghash_clmulni_intel,aesni_intel
i2c_i801               32768  0
glue_helper            16384  1 aesni_intel
evdev                  24576  19
mei_me                 45056  1
mei                   114688  3 mei_wdt,mei_me
mac_hid                16384  0
intel_cstate           16384  0
intel_uncore          135168  0
lpc_ich                28672  0
intel_rapl_perf        16384  0
pcc_cpufreq            16384  0
pcspkr                 16384  0
uinput                 20480  0
crypto_user            16384  0
ip_tables              28672  0
x_tables               45056  1 ip_tables
ext4                  733184  1
crc32c_generic         16384  0
crc16                  16384  1 ext4
mbcache                16384  1 ext4
jbd2                  126976  1 ext4
fscrypto               32768  1 ext4
sd_mod                 61440  4
ahci                   40960  2
libahci                40960  1 ahci
libata                278528  2 libahci,ahci
xhci_pci               16384  0
scsi_mod              253952  2 sd_mod,libata
xhci_hcd              266240  1 xhci_pci
crc32c_intel           24576  2
ehci_pci               16384  0
ehci_hcd               94208  1 ehci_pci
#18
I would look for a bios update and install kernel 4.14.
Also please post:
dmesg
Of the alternatives I’d say this is a firmware issue.
#19
dmesg
[    0.000000] microcode: microcode updated early to revision 0x25, date = 2018-04-02
[    0.000000] Linux version 4.19.13-1-MANJARO (builduser@development) (gcc version 8.2.1 20181127 (GCC)) #1 SMP PREEMPT Sat Dec 29 15:43:56 UTC 2018
[    0.000000] Command line: BOOT_IMAGE=/boot/vmlinuz-4.19-x86_64 root=UUID=4872a587-cad4-49da-b88f-c81b61107061 rw quiet
[    0.000000] KERNEL supported cpus:
[    0.000000]   Intel GenuineIntel
[    0.000000]   AMD AuthenticAMD
[    0.000000]   Centaur CentaurHauls
[    0.000000] x86/fpu: Supporting XSAVE feature 0x001: 'x87 floating point registers'
[    0.000000] x86/fpu: Supporting XSAVE feature 0x002: 'SSE registers'
[    0.000000] x86/fpu: Supporting XSAVE feature 0x004: 'AVX registers'
[    0.000000] x86/fpu: xstate_offset[2]:  576, xstate_sizes[2]:  256
[    0.000000] x86/fpu: Enabled xstate features 0x7, context size is 832 bytes, using 'standard' format.
[    0.000000] BIOS-provided physical RAM map:
[    0.000000] BIOS-e820: [mem 0x0000000000000000-0x0000000000057fff] usable
[    0.000000] BIOS-e820: [mem 0x0000000000058000-0x0000000000058fff] reserved
[    0.000000] BIOS-e820: [mem 0x0000000000059000-0x000000000009dfff] usable
[    0.000000] BIOS-e820: [mem 0x000000000009e000-0x000000000009ffff] reserved
[    0.000000] BIOS-e820: [mem 0x0000000000100000-0x00000000cd327fff] usable
[    0.000000] BIOS-e820: [mem 0x00000000cd328000-0x00000000cd32efff] ACPI NVS
[    0.000000] BIOS-e820: [mem 0x00000000cd32f000-0x00000000cdbccfff] usable
[    0.000000] BIOS-e820: [mem 0x00000000cdbcd000-0x00000000cde40fff] reserved
[    0.000000] BIOS-e820: [mem 0x00000000cde41000-0x00000000ddecdfff] usable
[    0.000000] BIOS-e820: [mem 0x00000000ddece000-0x00000000ddf68fff] reserved
[    0.000000] BIOS-e820: [mem 0x00000000ddf69000-0x00000000ddfbdfff] ACPI data
[    0.000000] BIOS-e820: [mem 0x00000000ddfbe000-0x00000000de9dcfff] ACPI NVS
[    0.000000] BIOS-e820: [mem 0x00000000de9dd000-0x00000000def7afff] reserved
[    0.000000] BIOS-e820: [mem 0x00000000def7b000-0x00000000deffefff] type 20
[    0.000000] BIOS-e820: [mem 0x00000000defff000-0x00000000deffffff] usable
[    0.000000] BIOS-e820: [mem 0x00000000f8000000-0x00000000fbffffff] reserved
[    0.000000] BIOS-e820: [mem 0x00000000fec00000-0x00000000fec00fff] reserved
[    0.000000] BIOS-e820: [mem 0x00000000fed00000-0x00000000fed03fff] reserved
[    0.000000] BIOS-e820: [mem 0x00000000fed1c000-0x00000000fed1ffff] reserved
[    0.000000] BIOS-e820: [mem 0x00000000fee00000-0x00000000fee00fff] reserved
[    0.000000] BIOS-e820: [mem 0x00000000ff000000-0x00000000ffffffff] reserved
[    0.000000] BIOS-e820: [mem 0x0000000100000000-0x000000041dffffff] usable
[    0.000000] NX (Execute Disable) protection: active
[    0.000000] efi: EFI v2.31 by American Megatrends
[    0.000000] efi:  ESRT=0xdef79918  ACPI=0xddf9e000  ACPI 2.0=0xddf9e000  SMBIOS=0xdef79518
[    0.000000] SMBIOS 2.8 present.
[    0.000000] DMI: LENOVO 90AV001LUK/, BIOS I1KT44AUS 11/14/2014
[    0.000000] tsc: Fast TSC calibration using PIT
[    0.000000] tsc: Detected 3591.619 MHz processor
[    0.000065] e820: update [mem 0x00000000-0x00000fff] usable ==> reserved
[    0.000067] e820: remove [mem 0x000a0000-0x000fffff] usable
[    0.000072] last_pfn = 0x41e000 max_arch_pfn = 0x400000000
[    0.000075] MTRR default type: uncachable
[    0.000075] MTRR fixed ranges enabled:
[    0.000076]   00000-9FFFF write-back
[    0.000077]   A0000-DFFFF uncachable
[    0.000077]   E0000-FFFFF write-protect
[    0.000078] MTRR variable ranges enabled:
[    0.000079]   0 base 0000000000 mask 7C00000000 write-back
[    0.000079]   1 base 0400000000 mask 7FF0000000 write-back
[    0.000080]   2 base 0410000000 mask 7FF8000000 write-back
[    0.000080]   3 base 0418000000 mask 7FFC000000 write-back
[    0.000081]   4 base 041C000000 mask 7FFE000000 write-back
[    0.000081]   5 base 00E0000000 mask 7FE0000000 uncachable
[    0.000082]   6 disabled
[    0.000082]   7 disabled
[    0.000082]   8 disabled
[    0.000083]   9 disabled
[    0.000808] x86/PAT: Configuration [0-7]: WB  WC  UC- UC  WB  WP  UC- WT
[    0.000960] total RAM covered: 16352M
[    0.001214] Found optimal setting for mtrr clean up
[    0.001215]  gran_size: 64K  chunk_size: 64M         num_reg: 7      lose cover RAM: 0G
[    0.001916] e820: update [mem 0xe0000000-0xffffffff] usable ==> reserved
[    0.001920] last_pfn = 0xdf000 max_arch_pfn = 0x400000000
[    0.007320] esrt: Reserving ESRT space from 0x00000000def79918 to 0x00000000def79950.
[    0.007326] Scanning 1 areas for low memory corruption
[    0.007328] Base memory trampoline at [(____ptrval____)] 98000 size 24576
[    0.007331] Using GB pages for direct mapping
[    0.007332] BRK [0x1cda01000, 0x1cda01fff] PGTABLE
[    0.007334] BRK [0x1cda02000, 0x1cda02fff] PGTABLE
[    0.007334] BRK [0x1cda03000, 0x1cda03fff] PGTABLE
[    0.007349] BRK [0x1cda04000, 0x1cda04fff] PGTABLE
[    0.007350] BRK [0x1cda05000, 0x1cda05fff] PGTABLE
[    0.007412] BRK [0x1cda06000, 0x1cda06fff] PGTABLE
[    0.007431] BRK [0x1cda07000, 0x1cda07fff] PGTABLE
[    0.007485] BRK [0x1cda08000, 0x1cda08fff] PGTABLE
[    0.007506] BRK [0x1cda09000, 0x1cda09fff] PGTABLE
[    0.007541] BRK [0x1cda0a000, 0x1cda0afff] PGTABLE
[    0.007569] BRK [0x1cda0b000, 0x1cda0bfff] PGTABLE
[    0.007588] Secure boot could not be determined
[    0.007589] RAMDISK: [mem 0x36e85000-0x37739fff]
[    0.007594] ACPI: Early table checksum verification disabled
[    0.007596] ACPI: RSDP 0x00000000DDF9E000 000024 (v02 LENOVO)
[    0.007598] ACPI: XSDT 0x00000000DDF9E090 0000A4 (v01 LENOVO TC-03    000012C0 AMI  00010013)
[    0.007602] ACPI: FACP 0x00000000DDFAA7E8 00010C (v05 LENOVO TC-03    000012C0 AMI  00010013)
[    0.007606] ACPI: DSDT 0x00000000DDF9E1C8 00C61D (v02 LENOVO TC-03    000012C0 INTL 20120711)
[    0.007608] ACPI: FACS 0x00000000DE9DCF80 000040
[    0.007610] ACPI: APIC 0x00000000DDFAA8F8 000092 (v03 LENOVO TC-03    000012C0 AMI  00010013)
[    0.007611] ACPI: FPDT 0x00000000DDFAA990 000044 (v01 LENOVO TC-03    000012C0 AMI  00010013)
[    0.007613] ACPI: FIDT 0x00000000DDFAA9D8 00009C (v01 LENOVO TC-03    000012C0 AMI  00010013)
[    0.007615] ACPI: MSDM 0x00000000DDFAAA78 000055 (v03 LENOVO TC-03    000012C0 AMI  00010013)
[    0.007617] ACPI: SSDT 0x00000000DDFAAAD0 000539 (v01 LENOVO TC-03    000012C0 INTL 20120711)
[    0.007619] ACPI: SSDT 0x00000000DDFAB010 000AD8 (v01 LENOVO TC-03    000012C0 INTL 20120711)
[    0.007620] ACPI: MCFG 0x00000000DDFABAE8 00003C (v01 LENOVO TC-03    000012C0 MSFT 00000097)
[    0.007622] ACPI: HPET 0x00000000DDFABB28 000038 (v01 LENOVO TC-03    000012C0 AMI. 00000005)
[    0.007624] ACPI: SSDT 0x00000000DDFABB60 00036D (v01 LENOVO TC-03    000012C0 INTL 20120711)
[    0.007626] ACPI: SSDT 0x00000000DDFABED0 003528 (v01 LENOVO TC-03    000012C0 INTL 20091112)
[    0.007628] ACPI: ASF! 0x00000000DDFAF3F8 0000A5 (v32 LENOVO TC-03    000012C0 TFSM 000F4240)
[    0.007630] ACPI: VFCT 0x00000000DDFAF4A0 00E884 (v01 LENOVO TC-03    000012C0 AMD  31504F47)
[    0.007632] ACPI: DMAR 0x00000000DDFBDD28 000080 (v01 LENOVO TC-03    000012C0 INTL 00000001)
[    0.007634] ACPI: WPBT 0x00000000DDFBDDA8 000036 (v01 LENOVO TC-03    00000001 ACPI 00000001)
[    0.007636] ACPI: BGRT 0x00000000DDFBDDE0 000038 (v00 LENOVO TC-03    000012C0 AMI  00010013)
[    0.007641] ACPI: Local APIC address 0xfee00000
[    0.007699] No NUMA configuration found
[    0.007700] Faking a node at [mem 0x0000000000000000-0x000000041dffffff]
[    0.007702] NODE_DATA(0) allocated [mem 0x41dffc000-0x41dffffff]
[    0.007719] Zone ranges:
[    0.007720]   DMA      [mem 0x0000000000001000-0x0000000000ffffff]
[    0.007721]   DMA32    [mem 0x0000000001000000-0x00000000ffffffff]
[    0.007722]   Normal   [mem 0x0000000100000000-0x000000041dffffff]
[    0.007723]   Device   empty
[    0.007723] Movable zone start for each node
[    0.007724] Early memory node ranges
[    0.007724]   node   0: [mem 0x0000000000001000-0x0000000000057fff]
[    0.007725]   node   0: [mem 0x0000000000059000-0x000000000009dfff]
[    0.007725]   node   0: [mem 0x0000000000100000-0x00000000cd327fff]
[    0.007725]   node   0: [mem 0x00000000cd32f000-0x00000000cdbccfff]
[    0.007726]   node   0: [mem 0x00000000cde41000-0x00000000ddecdfff]
[    0.007726]   node   0: [mem 0x00000000defff000-0x00000000deffffff]
[    0.007727]   node   0: [mem 0x0000000100000000-0x000000041dffffff]
[    0.007729] Reserved but unavailable: 98 pages
[    0.007729] Initmem setup node 0 [mem 0x0000000000001000-0x000000041dffffff]
[    0.007730] On node 0 totalpages: 4176880
[    0.007731]   DMA zone: 64 pages used for memmap
[    0.007731]   DMA zone: 278 pages reserved
[    0.007732]   DMA zone: 3996 pages, LIFO batch:0
[    0.008048]   DMA32 zone: 14130 pages used for memmap
[    0.008048]   DMA32 zone: 904276 pages, LIFO batch:63
[    0.021310]   Normal zone: 51072 pages used for memmap
[    0.021312]   Normal zone: 3268608 pages, LIFO batch:63
[    0.068182] ACPI: PM-Timer IO Port: 0x1808
[    0.068185] ACPI: Local APIC address 0xfee00000
[    0.068190] ACPI: LAPIC_NMI (acpi_id[0xff] high edge lint[0x1])
[    0.068199] IOAPIC[0]: apic_id 8, version 32, address 0xfec00000, GSI 0-23
[    0.068200] ACPI: INT_SRC_OVR (bus 0 bus_irq 0 global_irq 2 dfl dfl)
[    0.068201] ACPI: INT_SRC_OVR (bus 0 bus_irq 9 global_irq 9 high level)
[    0.068202] ACPI: IRQ0 used by override.
[    0.068203] ACPI: IRQ9 used by override.
[    0.068204] Using ACPI (MADT) for SMP configuration information
[    0.068205] ACPI: HPET id: 0x8086a701 base: 0xfed00000
[    0.068213] smpboot: Allowing 8 CPUs, 0 hotplug CPUs
[    0.068226] PM: Registered nosave memory: [mem 0x00000000-0x00000fff]
[    0.068227] PM: Registered nosave memory: [mem 0x00058000-0x00058fff]
[    0.068228] PM: Registered nosave memory: [mem 0x0009e000-0x0009ffff]
[    0.068229] PM: Registered nosave memory: [mem 0x000a0000-0x000fffff]
[    0.068230] PM: Registered nosave memory: [mem 0xcd328000-0xcd32efff]
[    0.068231] PM: Registered nosave memory: [mem 0xcdbcd000-0xcde40fff]
[    0.068232] PM: Registered nosave memory: [mem 0xddece000-0xddf68fff]
[    0.068232] PM: Registered nosave memory: [mem 0xddf69000-0xddfbdfff]
[    0.068232] PM: Registered nosave memory: [mem 0xddfbe000-0xde9dcfff]
[    0.068233] PM: Registered nosave memory: [mem 0xde9dd000-0xdef7afff]
[    0.068233] PM: Registered nosave memory: [mem 0xdef7b000-0xdeffefff]
[    0.068234] PM: Registered nosave memory: [mem 0xdf000000-0xf7ffffff]
[    0.068234] PM: Registered nosave memory: [mem 0xf8000000-0xfbffffff]
[    0.068235] PM: Registered nosave memory: [mem 0xfc000000-0xfebfffff]
[    0.068235] PM: Registered nosave memory: [mem 0xfec00000-0xfec00fff]
[    0.068235] PM: Registered nosave memory: [mem 0xfec01000-0xfecfffff]
[    0.068236] PM: Registered nosave memory: [mem 0xfed00000-0xfed03fff]
[    0.068236] PM: Registered nosave memory: [mem 0xfed04000-0xfed1bfff]
[    0.068236] PM: Registered nosave memory: [mem 0xfed1c000-0xfed1ffff]
[    0.068237] PM: Registered nosave memory: [mem 0xfed20000-0xfedfffff]
[    0.068237] PM: Registered nosave memory: [mem 0xfee00000-0xfee00fff]
[    0.068238] PM: Registered nosave memory: [mem 0xfee01000-0xfeffffff]
[    0.068238] PM: Registered nosave memory: [mem 0xff000000-0xffffffff]
[    0.068239] [mem 0xdf000000-0xf7ffffff] available for PCI devices
[    0.068240] Booting paravirtualized kernel on bare hardware
[    0.068242] clocksource: refined-jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 6370452778343963 ns
[    0.143221] random: get_random_bytes called from start_kernel+0x95/0x545 with crng_init=0
[    0.143225] setup_percpu: NR_CPUS:320 nr_cpumask_bits:320 nr_cpu_ids:8 nr_node_ids:1
[    0.143371] percpu: Embedded 46 pages/cpu @(____ptrval____) s151552 r8192 d28672 u262144
[    0.143375] pcpu-alloc: s151552 r8192 d28672 u262144 alloc=1*2097152
[    0.143376] pcpu-alloc: [0] 0 1 2 3 4 5 6 7
[    0.143390] Built 1 zonelists, mobility grouping on.  Total pages: 4111336
[    0.143391] Policy zone: Normal
[    0.143392] Kernel command line: BOOT_IMAGE=/boot/vmlinuz-4.19-x86_64 root=UUID=4872a587-cad4-49da-b88f-c81b61107061 rw quiet
[    0.146175] Calgary: detecting Calgary via BIOS EBDA area
[    0.146176] Calgary: Unable to locate Rio Grande table in EBDA - bailing!
[    0.182764] Memory: 16292508K/16707520K available (12300K kernel code, 1383K rwdata, 3692K rodata, 1540K init, 3796K bss, 415012K reserved, 0K cma-reserved)
[    0.182838] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=8, Nodes=1
[    0.182841] Kernel/User page tables isolation: enabled
[    0.188046] ftrace: allocating 36082 entries in 141 pages
[    0.197693] rcu: Preemptible hierarchical RCU implementation.
[    0.197694] rcu:     CONFIG_RCU_FANOUT set to non-default value of 32.
[    0.197694] rcu:     RCU dyntick-idle grace-period acceleration is enabled.
[    0.197694] rcu:     RCU restricting CPUs from NR_CPUS=320 to nr_cpu_ids=8.
[    0.197695] rcu:     RCU priority boosting: priority 1 delay 500 ms.
[    0.197695]  Tasks RCU enabled.
[    0.197696] rcu: Adjusting geometry for rcu_fanout_leaf=16, nr_cpu_ids=8
[    0.198772] NR_IRQS: 20736, nr_irqs: 488, preallocated irqs: 16
[    0.198915] rcu:     Offload RCU callbacks from CPUs: (none).
[    0.198950] Console: colour dummy device 80x25
[    0.198955] console [tty0] enabled
[    0.198965] ACPI: Core revision 20180810
[    0.199126] clocksource: hpet: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 133484882848 ns
[    0.199133] hpet clockevent registered
[    0.199137] APIC: Switch to symmetric I/O mode setup
[    0.199138] DMAR: Host address width 39
[    0.199138] DMAR: DRHD base: 0x000000fed90000 flags: 0x1
[    0.199142] DMAR: dmar0: reg_base_addr fed90000 ver 1:0 cap d2008c20660462 ecap f010da
[    0.199142] DMAR: RMRR base: 0x000000dee9a000 end: 0x000000deea8fff
[    0.199144] DMAR-IR: IOAPIC id 8 under DRHD base  0xfed90000 IOMMU 0
[    0.199144] DMAR-IR: HPET id 0 under DRHD base 0xfed90000
[    0.199145] DMAR-IR: Queued invalidation will be enabled to support x2apic and Intr-remapping.
[    0.199360] DMAR-IR: Enabled IRQ remapping in x2apic mode
[    0.199360] x2apic enabled
[    0.199365] Switched APIC routing to cluster x2apic.
[    0.199757] ..TIMER: vector=0x30 apic1=0 pin1=2 apic2=-1 pin2=-1
[    0.215805] clocksource: tsc-early: mask: 0xffffffffffffffff max_cycles: 0x33c565cfbba, max_idle_ns: 440795284273 ns
[    0.215813] Calibrating delay loop (skipped), value calculated using timer frequency.. 7186.53 BogoMIPS (lpj=11972063)
[    0.215815] pid_max: default: 32768 minimum: 301
[    0.216270] Security Framework initialized
[    0.216271] Yama: becoming mindful.
[    0.216274] AppArmor: AppArmor disabled by boot time parameter
[    0.218135] Dentry cache hash table entries: 2097152 (order: 12, 16777216 bytes)
[    0.219071] Inode-cache hash table entries: 1048576 (order: 11, 8388608 bytes)
[    0.219112] Mount-cache hash table entries: 32768 (order: 6, 262144 bytes)
[    0.219148] Mountpoint-cache hash table entries: 32768 (order: 6, 262144 bytes)
[    0.219306] ENERGY_PERF_BIAS: Set to 'normal', was 'performance'
[    0.219307] ENERGY_PERF_BIAS: View and update with x86_energy_perf_policy(8)
[    0.219310] mce: CPU supports 9 MCE banks
[    0.219316] CPU0: Thermal monitoring enabled (TM1)
[    0.219325] process: using mwait in idle threads
[    0.219328] Last level iTLB entries: 4KB 1024, 2MB 1024, 4MB 1024
[    0.219328] Last level dTLB entries: 4KB 1024, 2MB 1024, 4MB 1024, 1GB 4
[    0.219329] Spectre V2 : Mitigation: Full generic retpoline
[    0.219330] Spectre V2 : Spectre v2 / SpectreRSB mitigation: Filling RSB on context switch
[    0.219330] Spectre V2 : Enabling Restricted Speculation for firmware calls
[    0.219336] Spectre V2 : mitigation: Enabling conditional Indirect Branch Prediction Barrier
[    0.219336] Spectre V2 : User space: Mitigation: STIBP via seccomp and prctl
[    0.219337] Speculative Store Bypass: Mitigation: Speculative Store Bypass disabled via prctl and seccomp
[    0.222372] Freeing SMP alternatives memory: 28K
[    0.224012] TSC deadline timer enabled
[    0.224015] smpboot: CPU0: Intel(R) Core(TM) i7-4790 CPU @ 3.60GHz (family: 0x6, model: 0x3c, stepping: 0x3)
[    0.242490] Performance Events: PEBS fmt2+, Haswell events, 16-deep LBR, full-width counters, Intel PMU driver.
[    0.242520] ... version:                3
[    0.242520] ... bit width:              48
[    0.242521] ... generic registers:      4
[    0.242521] ... value mask:             0000ffffffffffff
[    0.242522] ... max period:             00007fffffffffff
[    0.242522] ... fixed-purpose events:   3
[    0.242523] ... event mask:             000000070000000f
[    0.249153] rcu: Hierarchical SRCU implementation.
[    0.272590] NMI watchdog: Enabled. Permanently consumes one hw-PMU counter.
[    0.279157] smp: Bringing up secondary CPUs ...
[    0.319162] x86: Booting SMP configuration:
[    0.319163] .... node  #0, CPUs:      #1 #2 #3 #4 #5 #6 #7
[    0.559449] smp: Brought up 1 node, 8 CPUs
[    0.559449] smpboot: Max logical packages: 1
[    0.559449] smpboot: Total of 8 processors activated (57488.31 BogoMIPS)
[    0.562799] devtmpfs: initialized
[    0.562799] x86/mm: Memory block size: 128MB
[    0.563243] PM: Registering ACPI NVS region [mem 0xcd328000-0xcd32efff] (28672 bytes)
[    0.563243] PM: Registering ACPI NVS region [mem 0xddfbe000-0xde9dcfff] (10612736 bytes)
[    0.563243] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 6370867519511994 ns
[    0.563243] futex hash table entries: 2048 (order: 5, 131072 bytes)
[    0.563243] pinctrl core: initialized pinctrl subsystem
[    0.563243] RTC time: 18:52:57, date: 02/07/19
[    0.563243] NET: Registered protocol family 16
[    0.563243] audit: initializing netlink subsys (disabled)
[    0.563243] audit: type=2000 audit(1549565576.363:1): state=initialized audit_enabled=0 res=1
[    0.565813] cpuidle: using governor ladder
[    0.565814] cpuidle: using governor menu
[    0.565833] ACPI: bus type PCI registered
[    0.565834] acpiphp: ACPI Hot Plug PCI Controller Driver version: 0.5
[    0.565883] PCI: MMCONFIG for domain 0000 [bus 00-3f] at [mem 0xf8000000-0xfbffffff] (base 0xf8000000)
[    0.565885] PCI: MMCONFIG at [mem 0xf8000000-0xfbffffff] reserved in E820
[    0.565891] PCI: Using configuration type 1 for base access
[    0.565904] core: PMU erratum BJ122, BV98, HSD29 worked around, HT is on
[    0.566586] HugeTLB registered 1.00 GiB page size, pre-allocated 0 pages
[    0.566586] HugeTLB registered 2.00 MiB page size, pre-allocated 0 pages
[    0.566586] ACPI: Added _OSI(Module Device)
[    0.566586] ACPI: Added _OSI(Processor Device)
[    0.566586] ACPI: Added _OSI(3.0 _SCP Extensions)
[    0.566586] ACPI: Added _OSI(Processor Aggregator Device)
[    0.566586] ACPI: Added _OSI(Linux-Dell-Video)
[    0.566586] ACPI: Added _OSI(Linux-Lenovo-NV-HDMI-Audio)
[    0.573756] ACPI: 5 ACPI AML tables successfully acquired and loaded
[    0.575805] ACPI: [Firmware Bug]: BIOS _OSI(Linux) query ignored
[    0.575920] ACPI: Dynamic OEM Table Load:
[    0.575925] ACPI: SSDT 0xFFFF9CEC4B2BE000 0003D3 (v01 PmRef  Cpu0Cst  00003001 INTL 20120711)
[    0.576071] ACPI: Dynamic OEM Table Load:
[    0.576071] ACPI: SSDT 0xFFFF9CEC4B0E7000 0005AA (v01 PmRef  ApIst    00003000 INTL 20120711)
[    0.576411] ACPI: Dynamic OEM Table Load:
[    0.576411] ACPI: SSDT 0xFFFF9CEC4B2B1E00 000119 (v01 PmRef  ApCst    00003000 INTL 20120711)
[    0.576981] ACPI: Interpreter enabled
[    0.577000] ACPI: (supports S0 S3 S4 S5)
[    0.577001] ACPI: Using IOAPIC for interrupt routing
[    0.577022] PCI: Using host bridge windows from ACPI; if necessary, use "pci=nocrs" and report a bug
[    0.577218] ACPI: Enabled 8 GPEs in block 00 to 3F
[    0.587804] ACPI: Power Resource [FN00] (off)
[    0.587861] ACPI: Power Resource [FN01] (off)
[    0.587914] ACPI: Power Resource [FN02] (off)
[    0.587968] ACPI: Power Resource [FN03] (off)
[    0.588021] ACPI: Power Resource [FN04] (off)
[    0.588627] ACPI: PCI Root Bridge [PCI0] (domain 0000 [bus 00-3e])
[    0.588631] acpi PNP0A08:00: _OSC: OS supports [ExtendedConfig ASPM ClockPM Segments MSI]
[    0.589183] acpi PNP0A08:00: _OSC: OS now controls [PCIeHotplug SHPCHotplug PME AER PCIeCapability LTR]
[    0.589537] PCI host bridge to bus 0000:00
[    0.589539] pci_bus 0000:00: root bus resource [io  0x0000-0x0cf7 window]
[    0.589539] pci_bus 0000:00: root bus resource [io  0x0d00-0xffff window]
[    0.589540] pci_bus 0000:00: root bus resource [mem 0x000a0000-0x000bffff window]
[    0.589541] pci_bus 0000:00: root bus resource [mem 0x000c0000-0x000c3fff window]
[    0.589542] pci_bus 0000:00: root bus resource [mem 0x000c4000-0x000c7fff window]
[    0.589543] pci_bus 0000:00: root bus resource [mem 0x000c8000-0x000cbfff window]
[    0.589544] pci_bus 0000:00: root bus resource [mem 0x000cc000-0x000cffff window]
[    0.589544] pci_bus 0000:00: root bus resource [mem 0x000d0000-0x000d3fff window]
[    0.589545] pci_bus 0000:00: root bus resource [mem 0x000d4000-0x000d7fff window]
[    0.589546] pci_bus 0000:00: root bus resource [mem 0x000d8000-0x000dbfff window]
[    0.589547] pci_bus 0000:00: root bus resource [mem 0x000dc000-0x000dffff window]
[    0.589548] pci_bus 0000:00: root bus resource [mem 0xe0000000-0xfeafffff window]
[    0.589549] pci_bus 0000:00: root bus resource [bus 00-3e]
[    0.589554] pci 0000:00:00.0: [8086:0c00] type 00 class 0x060000
[    0.589621] pci 0000:00:01.0: [8086:0c01] type 01 class 0x060400
[    0.589649] pci 0000:00:01.0: PME# supported from D0 D3hot D3cold
[    0.589762] pci 0000:00:14.0: [8086:8c31] type 00 class 0x0c0330
[    0.589792] pci 0000:00:14.0: reg 0x10: [mem 0xf7f00000-0xf7f0ffff 64bit]
[    0.589841] pci 0000:00:14.0: PME# supported from D3hot D3cold
[    0.589903] pci 0000:00:16.0: [8086:8c3a] type 00 class 0x078000
[    0.589922] pci 0000:00:16.0: reg 0x10: [mem 0xf7f1b000-0xf7f1b00f 64bit]
[    0.589974] pci 0000:00:16.0: PME# supported from D0 D3hot D3cold
[    0.590038] pci 0000:00:1a.0: [8086:8c2d] type 00 class 0x0c0320
[    0.590057] pci 0000:00:1a.0: reg 0x10: [mem 0xf7f18000-0xf7f183ff]
[    0.590126] pci 0000:00:1a.0: PME# supported from D0 D3hot D3cold
[    0.590190] pci 0000:00:1b.0: [8086:8c20] type 00 class 0x040300
[    0.590206] pci 0000:00:1b.0: reg 0x10: [mem 0xf7f10000-0xf7f13fff 64bit]
[    0.590255] pci 0000:00:1b.0: PME# supported from D0 D3hot D3cold
[    0.590316] pci 0000:00:1c.0: [8086:8c10] type 01 class 0x060400
[    0.590386] pci 0000:00:1c.0: PME# supported from D0 D3hot D3cold
[    0.590490] pci 0000:00:1c.3: [8086:8c16] type 01 class 0x060400
[    0.590559] pci 0000:00:1c.3: PME# supported from D0 D3hot D3cold
[    0.590659] pci 0000:00:1c.5: [8086:8c1a] type 01 class 0x060400
[    0.590720] pci 0000:00:1c.5: PME# supported from D0 D3hot D3cold
[    0.590827] pci 0000:00:1d.0: [8086:8c26] type 00 class 0x0c0320
[    0.590846] pci 0000:00:1d.0: reg 0x10: [mem 0xf7f17000-0xf7f173ff]
[    0.590915] pci 0000:00:1d.0: PME# supported from D0 D3hot D3cold
[    0.590977] pci 0000:00:1f.0: [8086:8c50] type 00 class 0x060100
[    0.591119] pci 0000:00:1f.2: [8086:8c02] type 00 class 0x010601
[    0.591132] pci 0000:00:1f.2: reg 0x10: [io  0xf070-0xf077]
[    0.591138] pci 0000:00:1f.2: reg 0x14: [io  0xf060-0xf063]
[    0.591144] pci 0000:00:1f.2: reg 0x18: [io  0xf050-0xf057]
[    0.591150] pci 0000:00:1f.2: reg 0x1c: [io  0xf040-0xf043]
[    0.591156] pci 0000:00:1f.2: reg 0x20: [io  0xf020-0xf03f]
[    0.591162] pci 0000:00:1f.2: reg 0x24: [mem 0xf7f16000-0xf7f167ff]
[    0.591190] pci 0000:00:1f.2: PME# supported from D3hot
[    0.591244] pci 0000:00:1f.3: [8086:8c22] type 00 class 0x0c0500
[    0.591258] pci 0000:00:1f.3: reg 0x10: [mem 0xf7f15000-0xf7f150ff 64bit]
[    0.591275] pci 0000:00:1f.3: reg 0x20: [io  0xf000-0xf01f]
[    0.591362] pci 0000:01:00.0: [1002:67df] type 00 class 0x030000
[    0.591379] pci 0000:01:00.0: reg 0x10: [mem 0xe0000000-0xefffffff 64bit pref]
[    0.591385] pci 0000:01:00.0: reg 0x18: [mem 0xf0000000-0xf01fffff 64bit pref]
[    0.591390] pci 0000:01:00.0: reg 0x20: [io  0xe000-0xe0ff]
[    0.591395] pci 0000:01:00.0: reg 0x24: [mem 0xf7e00000-0xf7e3ffff]
[    0.591399] pci 0000:01:00.0: reg 0x30: [mem 0xf7e40000-0xf7e5ffff pref]
[    0.591410] pci 0000:01:00.0: BAR 0: assigned to efifb
[    0.591440] pci 0000:01:00.0: supports D1 D2
[    0.591441] pci 0000:01:00.0: PME# supported from D1 D2 D3hot D3cold
[    0.591490] pci 0000:01:00.1: [1002:aaf0] type 00 class 0x040300
[    0.591503] pci 0000:01:00.1: reg 0x10: [mem 0xf7e60000-0xf7e63fff 64bit]
[    0.591547] pci 0000:01:00.1: supports D1 D2
[    0.591598] pci 0000:00:01.0: PCI bridge to [bus 01]
[    0.591599] pci 0000:00:01.0:   bridge window [io  0xe000-0xefff]
[    0.591601] pci 0000:00:01.0:   bridge window [mem 0xf7e00000-0xf7efffff]
[    0.591603] pci 0000:00:01.0:   bridge window [mem 0xe0000000-0xf01fffff 64bit pref]
[    0.591649] pci 0000:00:1c.0: PCI bridge to [bus 02]
[    0.591738] pci 0000:03:00.0: [8086:2526] type 00 class 0x028000
[    0.591777] pci 0000:03:00.0: reg 0x10: [mem 0xf7d00000-0xf7d03fff 64bit]
[    0.591910] pci 0000:03:00.0: PME# supported from D0 D3hot D3cold
[    0.592048] pci 0000:00:1c.3: PCI bridge to [bus 03]
[    0.592052] pci 0000:00:1c.3:   bridge window [mem 0xf7d00000-0xf7dfffff]
[    0.592111] pci 0000:04:00.0: [10ec:8168] type 00 class 0x020000
[    0.592137] pci 0000:04:00.0: reg 0x10: [io  0xd000-0xd0ff]
[    0.592163] pci 0000:04:00.0: reg 0x18: [mem 0xf0304000-0xf0304fff 64bit pref]
[    0.592179] pci 0000:04:00.0: reg 0x20: [mem 0xf0300000-0xf0303fff 64bit pref]
[    0.592265] pci 0000:04:00.0: supports D1 D2
[    0.592266] pci 0000:04:00.0: PME# supported from D0 D1 D2 D3hot D3cold
[    0.592361] pci 0000:00:1c.5: PCI bridge to [bus 04]
[    0.592364] pci 0000:00:1c.5:   bridge window [io  0xd000-0xdfff]
[    0.592369] pci 0000:00:1c.5:   bridge window [mem 0xf0300000-0xf03fffff 64bit pref]
[    0.593018] ACPI: PCI Interrupt Link [LNKA] (IRQs 3 4 5 6 10 11 12 14 15) *0, disabled.
[    0.593065] ACPI: PCI Interrupt Link [LNKB] (IRQs 3 4 5 6 10 11 12 14 15) *0, disabled.
[    0.593110] ACPI: PCI Interrupt Link [LNKC] (IRQs 3 4 5 6 10 11 12 14 15) *0, disabled.
[    0.593154] ACPI: PCI Interrupt Link [LNKD] (IRQs 3 4 5 6 10 11 12 14 15) *0, disabled.
[    0.593199] ACPI: PCI Interrupt Link [LNKE] (IRQs 3 4 5 6 10 11 12 14 15) *0, disabled.
[    0.593244] ACPI: PCI Interrupt Link [LNKF] (IRQs 3 4 5 6 10 11 12 14 15) *0, disabled.
[    0.593288] ACPI: PCI Interrupt Link [LNKG] (IRQs 3 4 5 6 10 11 12 14 15) *0, disabled.
[    0.593332] ACPI: PCI Interrupt Link [LNKH] (IRQs 3 4 5 6 10 11 12 14 15) *0, disabled.
[    0.593615] pci 0000:01:00.0: vgaarb: VGA device added: decodes=io+mem,owns=mem,locks=none
[    0.593615] pci 0000:01:00.0: vgaarb: bridge control possible
[    0.593615] pci 0000:01:00.0: vgaarb: setting as boot device
[    0.593615] vgaarb: loaded
[    0.593615] ACPI: bus type USB registered
[    0.593615] usbcore: registered new interface driver usbfs
[    0.593615] usbcore: registered new interface driver hub
[    0.593615] usbcore: registered new device driver usb
[    0.593615] pps_core: LinuxPPS API ver. 1 registered
[    0.593615] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it>
[    0.593615] PTP clock support registered
[    0.593615] EDAC MC: Ver: 3.0.0
[    0.593615] Registered efivars operations
[    0.599165] PCI: Using ACPI for IRQ routing
[    0.600305] PCI: pci_cache_line_size set to 64 bytes
[    0.600363] e820: reserve RAM buffer [mem 0x00058000-0x0005ffff]
[    0.600365] e820: reserve RAM buffer [mem 0x0009e000-0x0009ffff]
[    0.600365] e820: reserve RAM buffer [mem 0xcd328000-0xcfffffff]
[    0.600366] e820: reserve RAM buffer [mem 0xcdbcd000-0xcfffffff]
[    0.600367] e820: reserve RAM buffer [mem 0xddece000-0xdfffffff]
[    0.600368] e820: reserve RAM buffer [mem 0xdf000000-0xdfffffff]
[    0.600368] e820: reserve RAM buffer [mem 0x41e000000-0x41fffffff]
[    0.600435] NetLabel: Initializing
[    0.600436] NetLabel:  domain hash size = 128
[    0.600436] NetLabel:  protocols = UNLABELED CIPSOv4 CALIPSO
[    0.600445] NetLabel:  unlabeled traffic allowed by default
[    0.600447] hpet0: at MMIO 0xfed00000, IRQs 2, 8, 0, 0, 0, 0, 0, 0
[    0.600447] hpet0: 8 comparators, 64-bit 14.318180 MHz counter
[    0.602487] clocksource: Switched to clocksource tsc-early
[    0.609653] VFS: Disk quotas dquot_6.6.0
[    0.609663] VFS: Dquot-cache hash table entries: 512 (order 0, 4096 bytes)
[    0.609703] pnp: PnP ACPI init
[    0.609766] system 00:00: [mem 0xfed40000-0xfed44fff] has been reserved
[    0.609769] system 00:00: Plug and Play ACPI device, IDs PNP0c01 (active)
[    0.609908] system 00:01: [io  0x0680-0x069f] has been reserved
[    0.609910] system 00:01: [io  0xffff] has been reserved
[    0.609911] system 00:01: [io  0xffff] has been reserved
[    0.609912] system 00:01: [io  0x1c00-0x1cfe] has been reserved
[    0.609913] system 00:01: [io  0x1d00-0x1dfe] has been reserved
[    0.609914] system 00:01: [io  0x1e00-0x1efe] has been reserved
[    0.609915] system 00:01: [io  0x1f00-0x1ffe] has been reserved
[    0.609916] system 00:01: [io  0x1800-0x18fe] has been reserved
[    0.609917] system 00:01: [io  0x164e-0x164f] has been reserved
[    0.609919] system 00:01: Plug and Play ACPI device, IDs PNP0c02 (active)
[    0.609933] pnp 00:02: Plug and Play ACPI device, IDs PNP0b00 (active)
[    0.609966] system 00:03: [io  0x1854-0x1857] has been reserved
[    0.609968] system 00:03: Plug and Play ACPI device, IDs INT3f0d PNP0c02 (active)
[    0.610072] system 00:04: [io  0x0a00-0x0a1f] has been reserved
[    0.610073] system 00:04: [io  0x0a30-0x0a3f] has been reserved
[    0.610074] system 00:04: [io  0x0a20-0x0a2f] has been reserved
[    0.610076] system 00:04: Plug and Play ACPI device, IDs PNP0c02 (active)
[    0.610262] pnp 00:05: [dma 0 disabled]
[    0.610294] pnp 00:05: Plug and Play ACPI device, IDs PNP0501 (active)
[    0.610331] system 00:06: [io  0x04d0-0x04d1] has been reserved
[    0.610333] system 00:06: Plug and Play ACPI device, IDs PNP0c02 (active)
[    0.610673] system 00:07: [mem 0xfed1c000-0xfed1ffff] has been reserved
[    0.610674] system 00:07: [mem 0xfed10000-0xfed17fff] has been reserved
[    0.610675] system 00:07: [mem 0xfed18000-0xfed18fff] has been reserved
[    0.610676] system 00:07: [mem 0xfed19000-0xfed19fff] has been reserved
[    0.610677] system 00:07: [mem 0xf8000000-0xfbffffff] has been reserved
[    0.610678] system 00:07: [mem 0xfed20000-0xfed3ffff] has been reserved
[    0.610679] system 00:07: [mem 0xfed90000-0xfed93fff] could not be reserved
[    0.610680] system 00:07: [mem 0xfed45000-0xfed8ffff] has been reserved
[    0.610681] system 00:07: [mem 0xff000000-0xffffffff] has been reserved
[    0.610682] system 00:07: [mem 0xfee00000-0xfeefffff] could not be reserved
[    0.610683] system 00:07: [mem 0xf7fdf000-0xf7fdffff] has been reserved
[    0.610684] system 00:07: [mem 0xf7fe0000-0xf7feffff] has been reserved
[    0.610687] system 00:07: Plug and Play ACPI device, IDs PNP0c02 (active)
[    0.610868] pnp: PnP ACPI: found 8 devices
[    0.616152] clocksource: acpi_pm: mask: 0xffffff max_cycles: 0xffffff, max_idle_ns: 2085701024 ns
[    0.616165] pci 0000:00:1c.0: bridge window [io  0x1000-0x0fff] to [bus 02] add_size 1000
[    0.616167] pci 0000:00:1c.0: bridge window [mem 0x00100000-0x000fffff 64bit pref] to [bus 02] add_size 200000 add_align 100000
[    0.616168] pci 0000:00:1c.0: bridge window [mem 0x00100000-0x000fffff] to [bus 02] add_size 200000 add_align 100000
[    0.616183] pci 0000:00:1c.0: BAR 14: assigned [mem 0xf0400000-0xf05fffff]
[    0.616188] pci 0000:00:1c.0: BAR 15: assigned [mem 0xf0600000-0xf07fffff 64bit pref]
[    0.616190] pci 0000:00:1c.0: BAR 13: assigned [io  0x2000-0x2fff]
[    0.616191] pci 0000:00:01.0: PCI bridge to [bus 01]
[    0.616192] pci 0000:00:01.0:   bridge window [io  0xe000-0xefff]
[    0.616194] pci 0000:00:01.0:   bridge window [mem 0xf7e00000-0xf7efffff]
[    0.616196] pci 0000:00:01.0:   bridge window [mem 0xe0000000-0xf01fffff 64bit pref]
[    0.616198] pci 0000:00:1c.0: PCI bridge to [bus 02]
[    0.616200] pci 0000:00:1c.0:   bridge window [io  0x2000-0x2fff]
[    0.616204] pci 0000:00:1c.0:   bridge window [mem 0xf0400000-0xf05fffff]
[    0.616207] pci 0000:00:1c.0:   bridge window [mem 0xf0600000-0xf07fffff 64bit pref]
[    0.616212] pci 0000:00:1c.3: PCI bridge to [bus 03]
[    0.616216] pci 0000:00:1c.3:   bridge window [mem 0xf7d00000-0xf7dfffff]
[    0.616223] pci 0000:00:1c.5: PCI bridge to [bus 04]
[    0.616225] pci 0000:00:1c.5:   bridge window [io  0xd000-0xdfff]
[    0.616230] pci 0000:00:1c.5:   bridge window [mem 0xf0300000-0xf03fffff 64bit pref]
[    0.616235] pci_bus 0000:00: resource 4 [io  0x0000-0x0cf7 window]
[    0.616236] pci_bus 0000:00: resource 5 [io  0x0d00-0xffff window]
[    0.616237] pci_bus 0000:00: resource 6 [mem 0x000a0000-0x000bffff window]
[    0.616238] pci_bus 0000:00: resource 7 [mem 0x000c0000-0x000c3fff window]
[    0.616239] pci_bus 0000:00: resource 8 [mem 0x000c4000-0x000c7fff window]
[    0.616239] pci_bus 0000:00: resource 9 [mem 0x000c8000-0x000cbfff window]
[    0.616240] pci_bus 0000:00: resource 10 [mem 0x000cc000-0x000cffff window]
[    0.616241] pci_bus 0000:00: resource 11 [mem 0x000d0000-0x000d3fff window]
[    0.616242] pci_bus 0000:00: resource 12 [mem 0x000d4000-0x000d7fff window]
[    0.616243] pci_bus 0000:00: resource 13 [mem 0x000d8000-0x000dbfff window]
[    0.616244] pci_bus 0000:00: resource 14 [mem 0x000dc000-0x000dffff window]
[    0.616245] pci_bus 0000:00: resource 15 [mem 0xe0000000-0xfeafffff window]
[    0.616245] pci_bus 0000:01: resource 0 [io  0xe000-0xefff]
[    0.616246] pci_bus 0000:01: resource 1 [mem 0xf7e00000-0xf7efffff]
[    0.616247] pci_bus 0000:01: resource 2 [mem 0xe0000000-0xf01fffff 64bit pref]
[    0.616248] pci_bus 0000:02: resource 0 [io  0x2000-0x2fff]
[    0.616249] pci_bus 0000:02: resource 1 [mem 0xf0400000-0xf05fffff]
[    0.616250] pci_bus 0000:02: resource 2 [mem 0xf0600000-0xf07fffff 64bit pref]
[    0.616251] pci_bus 0000:03: resource 1 [mem 0xf7d00000-0xf7dfffff]
[    0.616252] pci_bus 0000:04: resource 0 [io  0xd000-0xdfff]
[    0.616252] pci_bus 0000:04: resource 2 [mem 0xf0300000-0xf03fffff 64bit pref]
[    0.616333] NET: Registered protocol family 2
[    0.616455] tcp_listen_portaddr_hash hash table entries: 8192 (order: 5, 131072 bytes)
[    0.616492] TCP established hash table entries: 131072 (order: 8, 1048576 bytes)
[    0.616617] TCP bind hash table entries: 65536 (order: 8, 1048576 bytes)
[    0.616719] TCP: Hash tables configured (established 131072 bind 65536)
[    0.616744] UDP hash table entries: 8192 (order: 6, 262144 bytes)
[    0.616777] UDP-Lite hash table entries: 8192 (order: 6, 262144 bytes)
[    0.616836] NET: Registered protocol family 1
[    0.616839] NET: Registered protocol family 44
[    0.617225] pci 0000:01:00.0: Video device with shadowed ROM at [mem 0x000c0000-0x000dffff]
[    0.617230] pci 0000:01:00.1: Linked as a consumer to 0000:01:00.0
[    0.617251] PCI: CLS 64 bytes, default 64
[    0.617305] Unpacking initramfs...
[    0.684060] Freeing initrd memory: 8916K
[    0.684095] PCI-DMA: Using software bounce buffering for IO (SWIOTLB)
[    0.684097] software IO TLB: mapped [mem 0xd6fbe000-0xdafbe000] (64MB)
[    0.684219] Scanning for low memory corruption every 60 seconds
[    0.684585] Initialise system trusted keyrings
[    0.684593] Key type blacklist registered
[    0.684630] workingset: timestamp_bits=41 max_order=22 bucket_order=0
[    0.685351] zbud: loaded
[    0.685523] pstore: using zstd compression
[    0.686190] Key type asymmetric registered
[    0.686191] Asymmetric key parser 'x509' registered
[    0.686196] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 244)
[    0.686221] io scheduler noop registered
[    0.686221] io scheduler deadline registered
[    0.686237] io scheduler cfq registered
[    0.686238] io scheduler mq-deadline registered
[    0.686238] io scheduler kyber registered
[    0.686251] io scheduler bfq registered
[    0.686263] io scheduler bfq-sq registered (default)
[    0.686264] BFQ I/O-scheduler: v9 (with cgroups support)
[    0.686264] blkcg_policy_register: BLKCG_MAX_POLS too small
[    0.686852] pcieport 0000:00:01.0: Signaling PME with IRQ 25
[    0.686868] pcieport 0000:00:1c.0: Signaling PME with IRQ 26
[    0.686880] pcieport 0000:00:1c.3: Signaling PME with IRQ 27
[    0.686891] pcieport 0000:00:1c.5: Signaling PME with IRQ 28
[    0.686904] pciehp 0000:00:1c.0:pcie004: Slot #0 AttnBtn- PwrCtrl- MRL- AttnInd- PwrInd- HotPlug+ Surprise+ Interlock- NoCompl+ LLActRep+
[    0.686941] shpchp: Standard Hot Plug PCI Controller Driver version: 0.4
[    0.686983] efifb: probing for efifb
[    0.686995] efifb: showing boot graphics
[    0.688454] efifb: framebuffer at 0xe0000000, using 8128k, total 8128k
[    0.688455] efifb: mode is 1920x1080x32, linelength=7680, pages=1
[    0.688455] efifb: scrolling: redraw
[    0.688457] efifb: Truecolor: size=8:8:8:8, shift=24:16:8:0
[    0.688483] fbcon: Deferring console take-over
[    0.688484] fb0: EFI VGA frame buffer device
[    0.688489] intel_idle: MWAIT substates: 0x42120
[    0.688489] intel_idle: v0.4.1 model 0x3C
[    0.688689] intel_idle: lapic_timer_reliable_states 0xffffffff
[    0.688739] input: Power Button as /devices/LNXSYSTM:00/LNXSYBUS:00/PNP0C0C:00/input/input0
[    0.688747] ACPI: Power Button [PWRB]
[    0.688774] input: Power Button as /devices/LNXSYSTM:00/LNXPWRBN:00/input/input1
[    0.688777] ACPI: Power Button [PWRF]
[    0.689519] thermal LNXTHERM:00: registered as thermal_zone0
[    0.689520] ACPI: Thermal Zone [TZ00] (28 C)
[    0.689718] thermal LNXTHERM:01: registered as thermal_zone1
[    0.689719] ACPI: Thermal Zone [TZ01] (30 C)
[    0.689828] Serial: 8250/16550 driver, 4 ports, IRQ sharing enabled
[    0.710432] 00:05: ttyS1 at I/O 0x2f8 (irq = 3, base_baud = 115200) is a 16550A
[    0.711498] usbcore: registered new interface driver usbserial_generic
[    0.711501] usbserial: USB Serial support registered for generic
[    0.711515] rtc_cmos 00:02: RTC can wake from S4
[    0.711648] rtc_cmos 00:02: registered as rtc0
[    0.711658] rtc_cmos 00:02: alarms up to one month, y3k, 242 bytes nvram, hpet irqs
[    0.711691] intel_pstate: Intel P-state driver initializing
[    0.712144] ledtrig-cpu: registered to indicate activity on CPUs
[    0.712798] NET: Registered protocol family 10
[    0.722209] Segment Routing with IPv6
[    0.722228] NET: Registered protocol family 17
[    0.722681] RAS: Correctable Errors collector initialized.
[    0.722713] microcode: sig=0x306c3, pf=0x2, revision=0x25
[    0.722840] microcode: Microcode Update Driver: v2.2.
[    0.722856] sched_clock: Marking stable (722629758, 203444)->(729561336, -6728134)
[    0.723101] registered taskstats version 1
[    0.723107] Loading compiled-in X.509 certificates
[    0.725099] Loaded X.509 cert 'Build time autogenerated kernel key: 527948c53ade48d6b6b6c73df839ceb5e9e33778'
[    0.725121] zswap: loaded using pool lzo/zbud
[    0.727657] Key type big_key registered
[    0.728202]   Magic number: 7:748:897
[    0.728291] rtc_cmos 00:02: setting system clock to 2019-02-07 18:52:57 UTC (1549565577)
[    0.903586] Freeing unused decrypted memory: 2040K
[    1.031458] Freeing unused kernel image memory: 1540K
[    1.031490] Write protecting the kernel read-only data: 18432k
[    1.032241] Freeing unused kernel image memory: 2008K
[    1.032310] Freeing unused kernel image memory: 404K
[    1.037588] x86/mm: Checked W+X mappings: passed, no W+X pages found.
[    1.037589] x86/mm: Checking user space page tables
[    1.042746] x86/mm: Checked W+X mappings: passed, no W+X pages found.
[    1.042747] Run /init as init process
[    1.106851] ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
[    1.107844] ehci-pci: EHCI PCI platform driver
[    1.108006] ehci-pci 0000:00:1a.0: EHCI Host Controller
[    1.108011] ehci-pci 0000:00:1a.0: new USB bus registered, assigned bus number 1
[    1.108033] ehci-pci 0000:00:1a.0: debug port 2
[    1.111929] ehci-pci 0000:00:1a.0: cache line size of 64 is not supported
[    1.111943] ehci-pci 0000:00:1a.0: irq 16, io mem 0xf7f18000
[    1.112191] SCSI subsystem initialized
[    1.117579] libata version 3.00 loaded.
[    1.119691] ahci 0000:00:1f.2: version 3.0
[    1.119814] ahci 0000:00:1f.2: AHCI 0001.0300 32 slots 6 ports 6 Gbps 0x19 impl SATA mode
[    1.119816] ahci 0000:00:1f.2: flags: 64bit ncq pm led clo pio slum part ems apst
[    1.122492] ehci-pci 0000:00:1a.0: USB 2.0 started, EHCI 1.00
[    1.122533] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 4.19
[    1.122534] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[    1.122536] usb usb1: Product: EHCI Host Controller
[    1.122536] usb usb1: Manufacturer: Linux 4.19.13-1-MANJARO ehci_hcd
[    1.122537] usb usb1: SerialNumber: 0000:00:1a.0
[    1.122621] hub 1-0:1.0: USB hub found
[    1.122624] hub 1-0:1.0: 2 ports detected
[    1.122730] xhci_hcd 0000:00:14.0: xHCI Host Controller
[    1.122736] xhci_hcd 0000:00:14.0: new USB bus registered, assigned bus number 2
[    1.123790] xhci_hcd 0000:00:14.0: hcc params 0x200077c1 hci version 0x100 quirks 0x0000000000009810
[    1.123794] xhci_hcd 0000:00:14.0: cache line size of 64 is not supported
[    1.123912] usb usb2: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 4.19
[    1.123913] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[    1.123914] usb usb2: Product: xHCI Host Controller
[    1.123915] usb usb2: Manufacturer: Linux 4.19.13-1-MANJARO xhci-hcd
[    1.123916] usb usb2: SerialNumber: 0000:00:14.0
[    1.123989] hub 2-0:1.0: USB hub found
[    1.124005] hub 2-0:1.0: 12 ports detected
[    1.125790] ehci-pci 0000:00:1d.0: EHCI Host Controller
[    1.125793] ehci-pci 0000:00:1d.0: new USB bus registered, assigned bus number 3
[    1.125804] ehci-pci 0000:00:1d.0: debug port 2
[    1.125827] xhci_hcd 0000:00:14.0: xHCI Host Controller
[    1.125830] xhci_hcd 0000:00:14.0: new USB bus registered, assigned bus number 4
[    1.125833] xhci_hcd 0000:00:14.0: Host supports USB 3.0  SuperSpeed
[    1.125877] usb usb4: New USB device found, idVendor=1d6b, idProduct=0003, bcdDevice= 4.19
[    1.125878] usb usb4: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[    1.125879] usb usb4: Product: xHCI Host Controller
[    1.125880] usb usb4: Manufacturer: Linux 4.19.13-1-MANJARO xhci-hcd
[    1.125881] usb usb4: SerialNumber: 0000:00:14.0
[    1.125970] hub 4-0:1.0: USB hub found
[    1.125984] hub 4-0:1.0: 6 ports detected
[    1.129722] ehci-pci 0000:00:1d.0: cache line size of 64 is not supported
[    1.129732] ehci-pci 0000:00:1d.0: irq 23, io mem 0xf7f17000
[    1.139962] scsi host0: ahci
[    1.140112] scsi host1: ahci
[    1.140263] scsi host2: ahci
[    1.140424] scsi host3: ahci
[    1.140565] scsi host4: ahci
[    1.140725] scsi host5: ahci
[    1.140790] ata1: SATA max UDMA/133 abar m2048@0xf7f16000 port 0xf7f16100 irq 29
[    1.140791] ata2: DUMMY
[    1.140791] ata3: DUMMY
[    1.140794] ata4: SATA max UDMA/133 abar m2048@0xf7f16000 port 0xf7f16280 irq 29
[    1.140796] ata5: SATA max UDMA/133 abar m2048@0xf7f16000 port 0xf7f16300 irq 29
[    1.140797] ata6: DUMMY
[    1.142491] ehci-pci 0000:00:1d.0: USB 2.0 started, EHCI 1.00
[    1.142567] usb usb3: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 4.19
[    1.142569] usb usb3: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[    1.142570] usb usb3: Product: EHCI Host Controller
[    1.142572] usb usb3: Manufacturer: Linux 4.19.13-1-MANJARO ehci_hcd
[    1.142573] usb usb3: SerialNumber: 0000:00:1d.0
[    1.142691] hub 3-0:1.0: USB hub found
[    1.142704] hub 3-0:1.0: 2 ports detected
[    1.452598] usb 2-1: new high-speed USB device number 2 using xhci_hcd
[    1.452623] usb 1-1: new high-speed USB device number 2 using ehci-pci
[    1.457132] ata5: SATA link down (SStatus 0 SControl 300)
[    1.457170] ata4: SATA link up 6.0 Gbps (SStatus 133 SControl 300)
[    1.457208] ata1: SATA link up 6.0 Gbps (SStatus 133 SControl 300)
[    1.457974] ata1.00: supports DRM functions and may not be fully accessible
[    1.458896] ata4.00: ATA-8: TOSHIBA HDWD130, MX6OACF0, max UDMA/133
[    1.458903] ata4.00: 5860533168 sectors, multi 16: LBA48 NCQ (depth 32), AA
[    1.459076] ata1.00: ATA-11: Samsung SSD 860 EVO 500GB, RVT01B6Q, max UDMA/133
[    1.459082] ata1.00: 976773168 sectors, multi 1: LBA48 NCQ (depth 32), AA
[    1.460900] ata4.00: configured for UDMA/133
[    1.462395] ata1.00: supports DRM functions and may not be fully accessible
[    1.465863] ata1.00: configured for UDMA/133
[    1.466218] scsi 0:0:0:0: Direct-Access     ATA      Samsung SSD 860  1B6Q PQ: 0 ANSI: 5
[    1.467015] scsi 3:0:0:0: Direct-Access     ATA      TOSHIBA HDWD130  ACF0 PQ: 0 ANSI: 5
[    1.472528] usb 3-1: new high-speed USB device number 2 using ehci-pci
[    1.478714] ata1.00: Enabling discard_zeroes_data
[    1.478777] sd 0:0:0:0: [sda] 976773168 512-byte logical blocks: (500 GB/466 GiB)
[    1.478793] sd 0:0:0:0: [sda] Write Protect is off
[    1.478798] sd 0:0:0:0: [sda] Mode Sense: 00 3a 00 00
[    1.478826] sd 0:0:0:0: [sda] Write cache: enabled, read cache: enabled, doesn't support DPO or FUA
[    1.478863] sd 3:0:0:0: [sdb] 5860533168 512-byte logical blocks: (3.00 TB/2.73 TiB)
[    1.478869] sd 3:0:0:0: [sdb] 4096-byte physical blocks
[    1.478885] sd 3:0:0:0: [sdb] Write Protect is off
[    1.478890] sd 3:0:0:0: [sdb] Mode Sense: 00 3a 00 00
[    1.478911] sd 3:0:0:0: [sdb] Write cache: enabled, read cache: enabled, doesn't support DPO or FUA
[    1.479006] ata1.00: Enabling discard_zeroes_data
[    1.480472]  sda: sda1 sda2 sda3 sda4
[    1.480820] ata1.00: Enabling discard_zeroes_data
[    1.481798] sd 0:0:0:0: [sda] supports TCG Opal
[    1.481799] sd 0:0:0:0: [sda] Attached SCSI disk
[    1.524407]  sdb: sdb1 sdb2 sdb3
[    1.525018] sd 3:0:0:0: [sdb] Attached SCSI disk
[    1.599938] usb 1-1: New USB device found, idVendor=8087, idProduct=8008, bcdDevice= 0.05
[    1.599943] usb 1-1: New USB device strings: Mfr=0, Product=0, SerialNumber=0
[    1.600496] hub 1-1:1.0: USB hub found
[    1.600659] hub 1-1:1.0: 6 ports detected
[    1.620032] usb 3-1: New USB device found, idVendor=8087, idProduct=8000, bcdDevice= 0.05
[    1.620037] usb 3-1: New USB device strings: Mfr=0, Product=0, SerialNumber=0
[    1.620502] hub 3-1:1.0: USB hub found
[    1.620682] hub 3-1:1.0: 6 ports detected
[    1.692582] tsc: Refined TSC clocksource calibration: 3591.681 MHz
[    1.692599] clocksource: tsc: mask: 0xffffffffffffffff max_cycles: 0x33c5a0b45fc, max_idle_ns: 440795301468 ns
[    1.692649] clocksource: Switched to clocksource tsc
[    1.708606] random: fast init done
[    2.063888] EXT4-fs (sdb3): mounted filesystem with ordered data mode. Opts: (null)
[    2.889582] systemd[1]: systemd 239 running in system mode. (+PAM +AUDIT -SELINUX -IMA -APPARMOR +SMACK -SYSVINIT +UTMP +LIBCRYPTSETUP +GCRYPT +GNUTLS +ACL +XZ +LZ4 +SECCOMP +BLKID +ELFUTILS +KMOD +IDN2 -IDN +PCRE2 default-hierarchy=hybrid)
[    2.906419] systemd[1]: Detected architecture x86-64.
[    2.916239] systemd[1]: Set hostname to <MyAmazingPC>.
[    3.875493] usb 2-1: New USB device found, idVendor=046d, idProduct=082d, bcdDevice= 0.11
[    3.875495] usb 2-1: New USB device strings: Mfr=0, Product=2, SerialNumber=1
[    3.875497] usb 2-1: Product: HD Pro Webcam C920
[    3.875499] usb 2-1: SerialNumber: EAEC3A3F
[    3.999178] usb 2-2: new full-speed USB device number 3 using xhci_hcd
[    4.048659] random: crng init done
[    4.108569] systemd[1]: Reached target Login Prompts.
[    4.108795] systemd[1]: Set up automount Arbitrary Executable File Formats File System Automount Point.
[    4.108873] systemd[1]: Listening on udev Kernel Socket.
[    4.108921] systemd[1]: Listening on Device-mapper event daemon FIFOs.
[    4.109020] systemd[1]: Listening on Journal Audit Socket.
[    4.119664] systemd[1]: Listening on LVM2 poll daemon socket.
[    4.121440] systemd[1]: Created slice system-getty.slice.
[    4.140370] usb 2-2: New USB device found, idVendor=0951, idProduct=16be, bcdDevice= 1.04
[    4.140372] usb 2-2: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[    4.140374] usb 2-2: Product: HyperX Alloy Elite RGB
[    4.140376] usb 2-2: Manufacturer: HyperX Alloy Elite RGB
[    4.262563] usb 2-6: new full-speed USB device number 4 using xhci_hcd
[    4.313107] audit: type=1130 audit(1549565581.081:2): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=systemd-journald comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[    4.330676] EXT4-fs (sdb3): re-mounted. Opts: (null)
[    4.331584] audit: type=1130 audit(1549565581.097:3): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=systemd-remount-fs comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[    4.358956] audit: type=1130 audit(1549565581.124:4): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=lvm2-lvmetad comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[    4.383058] audit: type=1130 audit(1549565581.151:5): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=systemd-binfmt comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[    4.424393] audit: type=1130 audit(1549565581.191:6): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=systemd-udev-trigger comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[    4.439063] systemd-journald[286]: Received request to flush runtime journal from PID 1
[    4.500871] audit: type=1130 audit(1549565581.267:7): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=systemd-modules-load comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[    4.568926] audit: type=1130 audit(1549565581.334:8): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=systemd-sysctl comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[    4.580692] audit: type=1130 audit(1549565581.347:9): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=systemd-random-seed comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[    4.768766] audit: type=1130 audit(1549565581.537:10): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=systemd-sysusers comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[    5.581331] input: PC Speaker as /devices/platform/pcspkr/input/input2
[    5.626203] RAPL PMU: API unit is 2^-32 Joules, 4 fixed counters, 655360 ms ovfl timer
[    5.626205] RAPL PMU: hw unit of domain pp0-core 2^-14 Joules
[    5.626205] RAPL PMU: hw unit of domain package 2^-14 Joules
[    5.626206] RAPL PMU: hw unit of domain dram 2^-14 Joules
[    5.626206] RAPL PMU: hw unit of domain pp1-gpu 2^-14 Joules
[    5.626207] ACPI Warning: SystemIO range 0x0000000000001828-0x000000000000182F conflicts with OpRegion 0x0000000000001800-0x000000000000187F (\PMIO) (20180810/utaddress-213)
[    5.626213] ACPI: If an ACPI driver is available for this device, you should use it instead of the native driver
[    5.626216] ACPI Warning: SystemIO range 0x0000000000001C40-0x0000000000001C4F conflicts with OpRegion 0x0000000000001C00-0x0000000000001FFF (\GPR) (20180810/utaddress-213)
[    5.626220] ACPI: If an ACPI driver is available for this device, you should use it instead of the native driver
[    5.626222] ACPI Warning: SystemIO range 0x0000000000001C30-0x0000000000001C3F conflicts with OpRegion 0x0000000000001C00-0x0000000000001C3F (\GPRL) (20180810/utaddress-213)
[    5.626226] ACPI Warning: SystemIO range 0x0000000000001C30-0x0000000000001C3F conflicts with OpRegion 0x0000000000001C00-0x0000000000001FFF (\GPR) (20180810/utaddress-213)
[    5.626230] ACPI: If an ACPI driver is available for this device, you should use it instead of the native driver
[    5.626231] ACPI Warning: SystemIO range 0x0000000000001C00-0x0000000000001C2F conflicts with OpRegion 0x0000000000001C00-0x0000000000001C3F (\GPRL) (20180810/utaddress-213)
[    5.626234] ACPI Warning: SystemIO range 0x0000000000001C00-0x0000000000001C2F conflicts with OpRegion 0x0000000000001C00-0x0000000000001FFF (\GPR) (20180810/utaddress-213)
[    5.626236] ACPI: If an ACPI driver is available for this device, you should use it instead of the native driver
[    5.626237] lpc_ich: Resource conflict(s) found affecting gpio_ich
[    5.705495] i801_smbus 0000:00:1f.3: SPD Write Disable is set
[    5.705523] i801_smbus 0000:00:1f.3: SMBus using PCI interrupt
[    5.732421] cryptd: max_cpu_qlen set to 1000
[    5.903682] cfg80211: Loading compiled-in X.509 certificates for regulatory database
[    5.920780] cfg80211: Loaded X.509 cert 'sforshee: 00b28ddf47aef9cea7'
[    5.931458] intel-spi intel-spi: s25fl064k (8192 Kbytes)
[    5.939323] iTCO_vendor_support: vendor-support=0
[    5.942315] iTCO_wdt: Intel TCO WatchDog Timer Driver v1.11
[    5.942344] iTCO_wdt: Found a Lynx Point TCO device (Version=2, TCOBASE=0x1860)
[    5.942402] iTCO_wdt: initialized. heartbeat=30 sec (nowayout=0)
[    5.947420] Creating 1 MTD partitions on "intel-spi":
[    5.947422] 0x000000000000-0x000000a00000 : "BIOS"
[    5.947423] mtd: partition "BIOS" extends beyond the end of device "intel-spi" -- size truncated to 0x800000
[    6.026855] AVX2 version of gcm_enc/dec engaged.
[    6.026856] AES CTR mode by8 optimization enabled
[    6.034688] libphy: r8169: probed
[    6.035125] r8169 0000:04:00.0 eth0: RTL8168f/8111f, d8:cb:8a:2e:db:69, XID 48000800, IRQ 32
[    6.035128] r8169 0000:04:00.0 eth0: jumbo features [frames: 9200 bytes, tx checksumming: ko]
[    6.065854] r8169 0000:04:00.0 enp4s0: renamed from eth0
[    6.117806] Intel(R) Wireless WiFi driver for Linux
[    6.117807] Copyright(c) 2003- 2015 Intel Corporation
[    6.117872] iwlwifi 0000:03:00.0: enabling device (0000 -> 0002)
[    6.128302] Linux agpgart interface v0.103
[    6.246640] snd_hda_intel 0000:00:1b.0: enabling device (0000 -> 0002)
[    6.246888] snd_hda_intel 0000:01:00.1: enabling device (0000 -> 0002)
[    6.246931] snd_hda_intel 0000:01:00.1: Handle vga_switcheroo audio client
[    6.246932] snd_hda_intel 0000:01:00.1: Force to non-snoop mode
[    6.258421] iwlwifi 0000:03:00.0: loaded firmware version 38.755cfdd8.0 op_mode iwlmvm
[    6.302618] input: HDA ATI HDMI HDMI/DP,pcm=3 as /devices/pci0000:00/0000:00:01.0/0000:01:00.1/sound/card1/input3
[    6.302665] input: HDA ATI HDMI HDMI/DP,pcm=7 as /devices/pci0000:00/0000:00:01.0/0000:01:00.1/sound/card1/input4
[    6.302708] input: HDA ATI HDMI HDMI/DP,pcm=8 as /devices/pci0000:00/0000:00:01.0/0000:01:00.1/sound/card1/input5
[    6.302751] input: HDA ATI HDMI HDMI/DP,pcm=9 as /devices/pci0000:00/0000:00:01.0/0000:01:00.1/sound/card1/input6
[    6.370880] snd_hda_codec_realtek hdaudioC0D0: autoconfig for ALC892: line_outs=3 (0x14/0x15/0x16/0x0/0x0) type:line
[    6.370883] snd_hda_codec_realtek hdaudioC0D0:    speaker_outs=0 (0x0/0x0/0x0/0x0/0x0)
[    6.370885] snd_hda_codec_realtek hdaudioC0D0:    hp_outs=1 (0x1b/0x0/0x0/0x0/0x0)
[    6.370886] snd_hda_codec_realtek hdaudioC0D0:    mono: mono_out=0x0
[    6.370888] snd_hda_codec_realtek hdaudioC0D0:    dig-out=0x1e/0x0
[    6.370889] snd_hda_codec_realtek hdaudioC0D0:    inputs:
[    6.370890] snd_hda_codec_realtek hdaudioC0D0:      Front Mic=0x19
[    6.370892] snd_hda_codec_realtek hdaudioC0D0:      Rear Mic=0x18
[    6.370893] snd_hda_codec_realtek hdaudioC0D0:      Line=0x1a
[    6.383277] input: HDA Intel PCH Front Mic as /devices/pci0000:00/0000:00:1b.0/sound/card0/input7
[    6.383310] input: HDA Intel PCH Rear Mic as /devices/pci0000:00/0000:00:1b.0/sound/card0/input8
[    6.383336] input: HDA Intel PCH Line as /devices/pci0000:00/0000:00:1b.0/sound/card0/input9
[    6.383362] input: HDA Intel PCH Line Out Front as /devices/pci0000:00/0000:00:1b.0/sound/card0/input10
[    6.383388] input: HDA Intel PCH Line Out Surround as /devices/pci0000:00/0000:00:1b.0/sound/card0/input11
[    6.383412] input: HDA Intel PCH Line Out CLFE as /devices/pci0000:00/0000:00:1b.0/sound/card0/input12
[    6.383438] input: HDA Intel PCH Front Headphone as /devices/pci0000:00/0000:00:1b.0/sound/card0/input13
[    6.391705] iwlwifi 0000:03:00.0: Detected Intel(R) Dual Band Wireless AC 9260, REV=0x324
[    6.440791] iwlwifi 0000:03:00.0: base HW address: 14:4f:8a:24:70:fc
[    6.480459] intel_rapl: Found RAPL domain package
[    6.480461] intel_rapl: Found RAPL domain core
[    6.480462] intel_rapl: Found RAPL domain dram
[    6.480464] intel_rapl: RAPL package 0 domain package locked by BIOS
[    6.480468] intel_rapl: RAPL package 0 domain dram locked by BIOS
[    6.513409] ieee80211 phy0: Selected rate control algorithm 'iwl-mvm-rs'
[    6.513784] thermal thermal_zone3: failed to read out thermal zone (-61)
[    6.566988] iwlwifi 0000:03:00.0 wlp3s0: renamed from wlan0
[    6.645779] kauditd_printk_skb: 2 callbacks suppressed
[    6.645780] audit: type=1130 audit(1549565583.411:13): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=systemd-rfkill comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[    6.706587] [drm] amdgpu kernel modesetting enabled.
[    6.849814] AMD IOMMUv2 driver by Joerg Roedel <jroedel@suse.de>
[    6.849815] AMD IOMMUv2 functionality not available on this system
[    6.863987] CRAT table not found
[    6.863988] Virtual CRAT table created for CPU
[    6.863989] Parsing CRAT table with 1 nodes
[    6.863990] Creating topology SYSFS entries
[    6.863999] Topology: Add CPU node
[    6.864000] Finished initializing topology
[    6.864057] kfd kfd: Initialized module
[    6.864225] checking generic (e0000000 7f0000) vs hw (e0000000 10000000)
[    6.864226] fb: switching to amdgpudrmfb from EFI VGA
[    6.864298] amdgpu 0000:01:00.0: enabling device (0006 -> 0007)
[    6.864430] [drm] initializing kernel modesetting (POLARIS10 0x1002:0x67DF 0x1462:0x3415 0xC7).
[    6.864436] [drm] register mmio base: 0xF7E00000
[    6.864436] [drm] register mmio size: 262144
[    6.864444] [drm] add ip block number 0 <vi_common>
[    6.864445] [drm] add ip block number 1 <gmc_v8_0>
[    6.864446] [drm] add ip block number 2 <tonga_ih>
[    6.864446] [drm] add ip block number 3 <powerplay>
[    6.864447] [drm] add ip block number 4 <dm>
[    6.864448] [drm] add ip block number 5 <gfx_v8_0>
[    6.864448] [drm] add ip block number 6 <sdma_v3_0>
[    6.864449] [drm] add ip block number 7 <uvd_v6_0>
[    6.864450] [drm] add ip block number 8 <vce_v3_0>
[    6.864457] [drm] UVD is enabled in VM mode
[    6.864458] [drm] UVD ENC is enabled in VM mode
[    6.864459] [drm] VCE enabled in VM mode
[    6.864494] [drm] vm size is 64 GB, 2 levels, block size is 10-bit, fragment size is 9-bit
[    7.009701] amdgpu 0000:01:00.0: VRAM: 8192M 0x000000F400000000 - 0x000000F5FFFFFFFF (8192M used)
[    7.009704] amdgpu 0000:01:00.0: GART: 256M 0x0000000000000000 - 0x000000000FFFFFFF
[    7.009718] [drm] Detected VRAM RAM=8192M, BAR=256M
[    7.009719] [drm] RAM width 256bits GDDR5
[    7.009926] [TTM] Zone  kernel: Available graphics memory: 8177380 kiB
[    7.009927] [TTM] Zone   dma32: Available graphics memory: 2097152 kiB
[    7.009928] [TTM] Initializing pool allocator
[    7.009932] [TTM] Initializing DMA pool allocator
[    7.009968] [drm] amdgpu: 8192M of VRAM memory ready
[    7.009969] [drm] amdgpu: 8192M of GTT memory ready.
[    7.009989] [drm] GART: num cpu pages 65536, num gpu pages 65536
[    7.010691] [drm] PCIE GART of 256M enabled (table at 0x000000F4007E9000).
[    7.020851] [drm] Chained IB support enabled!
[    7.277634] [drm] Found UVD firmware Version: 1.130 Family ID: 16
[    7.412313] [drm] Found VCE firmware Version: 53.26 Binary ID: 3
[    7.476110] amdgpu: [powerplay] Failed to retrieve minimum clocks.
[    7.476111] amdgpu: [powerplay] Error in phm_get_clock_info
[    7.476144] [drm] DM_PPLIB: values for Engine clock
[    7.476145] [drm] DM_PPLIB:   300000
[    7.476145] [drm] DM_PPLIB:   608000
[    7.476146] [drm] DM_PPLIB:   928000
[    7.476146] [drm] DM_PPLIB:   1098000
[    7.476146] [drm] DM_PPLIB:   1167000
[    7.476147] [drm] DM_PPLIB:   1214000
[    7.476147] [drm] DM_PPLIB:   1260000
[    7.476147] [drm] DM_PPLIB:   1291000
[    7.476148] [drm] DM_PPLIB: Validation clocks:
[    7.476148] [drm] DM_PPLIB:    engine_max_clock: 129100
[    7.476148] [drm] DM_PPLIB:    memory_max_clock: 200000
[    7.476149] [drm] DM_PPLIB:    level           : 8
[    7.476150] [drm] DM_PPLIB: values for Memory clock
[    7.476150] [drm] DM_PPLIB:   300000
[    7.476150] [drm] DM_PPLIB:   2000000
[    7.476150] [drm] DM_PPLIB: Validation clocks:
[    7.476151] [drm] DM_PPLIB:    engine_max_clock: 129100
[    7.476151] [drm] DM_PPLIB:    memory_max_clock: 200000
[    7.476151] [drm] DM_PPLIB:    level           : 8
[    7.495919] [drm] Display Core initialized with v3.1.59!
[    7.521108] [drm] Supports vblank timestamp caching Rev 2 (21.10.2013).
[    7.521108] [drm] Driver supports precise vblank timestamp query.
[    7.569909] [drm] UVD and UVD ENC initialized successfully.
[    7.680856] [drm] VCE initialized successfully.
[    7.683360] kfd kfd: Allocated 3969056 bytes on gart
[    7.683381] Virtual CRAT table created for GPU
[    7.683382] Parsing CRAT table with 1 nodes
[    7.683387] Creating topology SYSFS entries
[    7.683438] Topology: Add dGPU node [0x67df:0x1002]
[    7.683498] kfd kfd: added device 1002:67df
[    7.685043] [drm] fb mappable at 0xE0D11000
[    7.685044] [drm] vram apper at 0xE0000000
[    7.685044] [drm] size 8294400
[    7.685045] [drm] fb depth is 24
[    7.685045] [drm]    pitch is 7680
[    7.685174] fbcon: amdgpudrmfb (fb0) is primary device
[    7.685175] fbcon: Deferring console take-over
[    7.685177] amdgpu 0000:01:00.0: fb0: amdgpudrmfb frame buffer device
[    7.709436] [drm] Initialized amdgpu 3.27.0 20150101 for 0000:01:00.0 on minor 0
[    7.881354] audit: type=1130 audit(1549565584.651:14): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=lvm2-monitor comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[    8.090066] audit: type=1130 audit(1549565584.857:15): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=systemd-fsck@dev-disk-by\x2duuid-EE31\x2d5E3F comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[    8.485954] audit: type=1130 audit(1549565585.254:16): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=systemd-journal-catalog-update comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[    8.671024] audit: type=1130 audit(1549565585.437:17): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=systemd-journal-flush comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[    9.216863] audit: type=1130 audit(1549565585.984:18): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=systemd-tmpfiles-setup comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[    9.235655] audit: type=1127 audit(1549565586.001:19): pid=451 uid=0 auid=4294967295 ses=4294967295 msg=' comm="systemd-update-utmp" exe="/usr/lib/systemd/systemd-update-utmp" hostname=? addr=? terminal=? res=success'
[    9.260360] audit: type=1130 audit(1549565586.027:20): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=systemd-update-utmp comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[    9.543888] audit: type=1130 audit(1549565586.311:21): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=ldconfig comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[    9.569302] audit: type=1130 audit(1549565586.337:22): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=systemd-update-done comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[   11.651413] kauditd_printk_skb: 11 callbacks suppressed
[   11.651414] audit: type=1131 audit(1549565588.421:34): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=systemd-rfkill comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[   11.849954] audit: type=1130 audit(1549565588.617:35): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=polkit comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[   12.048846] IPv6: ADDRCONF(NETDEV_UP): enp4s0: link is not ready
[   12.072263] RTL8211E Gigabit Ethernet r8169-400:00: attached PHY driver [RTL8211E Gigabit Ethernet] (mii_bus:phy_addr=r8169-400:00, irq=IGNORE)
[   12.188483] audit: type=1130 audit(1549565588.954:36): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=ModemManager comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[   12.251451] IPv6: ADDRCONF(NETDEV_UP): enp4s0: link is not ready
[   12.253253] IPv6: ADDRCONF(NETDEV_UP): wlp3s0: link is not ready
[   12.443809] IPv6: ADDRCONF(NETDEV_UP): wlp3s0: link is not ready
[   12.646606] IPv6: ADDRCONF(NETDEV_UP): wlp3s0: link is not ready
[   13.195913] audit: type=1130 audit(1549565589.964:37): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=tlp comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[   13.507790] audit: type=1130 audit(1549565590.274:38): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=wpa_supplicant comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[   13.746753] IPv6: ADDRCONF(NETDEV_UP): wlp3s0: link is not ready
[   16.496650] audit: type=1130 audit(1549565593.264:39): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=user-runtime-dir@973 comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[   16.528353] audit: type=1006 audit(1549565593.294:40): pid=652 uid=0 old-auid=4294967295 auid=973 tty=(none) old-ses=4294967295 ses=1 res=1
[   16.699632] audit: type=1130 audit(1549565593.467:41): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=user@973 comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[   21.109613] audit: type=1130 audit(1549565597.877:42): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=udisks2 comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[   22.008988] audit: type=1130 audit(1549565598.774:43): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=upower comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[   22.037053] audit: type=1131 audit(1549565598.804:44): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=NetworkManager-dispatcher comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[   24.786019] usb 2-6: New USB device found, idVendor=1b1c, idProduct=1b3c, bcdDevice= 1.01
[   24.786025] usb 2-6: New USB device strings: Mfr=1, Product=2, SerialNumber=3
[   24.786029] usb 2-6: Product: Corsair Gaming HARPOON RGB Mouse
[   29.906353] usb 2-6: can't set config #1, error -110
[   30.029257] usb 2-10: new full-speed USB device number 5 using xhci_hcd
[   30.170915] usb 2-10: New USB device found, idVendor=1e71, idProduct=1714, bcdDevice= 2.00
[   30.170921] usb 2-10: New USB device strings: Mfr=1, Product=2, SerialNumber=3
[   30.170924] usb 2-10: Product: NZXT USB Device
[   30.170927] usb 2-10: Manufacturer: NZXT.-Inc.
[   30.170929] usb 2-10: SerialNumber: 497318463436
[   30.286697] hidraw: raw HID events driver (C) Jiri Kosina
[   30.297795] usbcore: registered new interface driver usbhid
[   30.297795] usbhid: USB HID core driver
[   30.356975] input: HyperX Alloy Elite RGB HyperX Alloy Elite RGB as /devices/pci0000:00/0000:00:14.0/usb2/2-2/2-2:1.0/0003:0951:16BE.0001/input/input14
[   30.395886] media: Linux media interface: v0.10
[   30.412574] hid-generic 0003:0951:16BE.0001: input,hidraw0: USB HID v1.11 Keyboard [HyperX Alloy Elite RGB HyperX Alloy Elite RGB] on usb-0000:00:14.0-2/input0
[   30.412710] input: HyperX Alloy Elite RGB HyperX Alloy Elite RGB as /devices/pci0000:00/0000:00:14.0/usb2/2-2/2-2:1.1/0003:0951:16BE.0002/input/input15
[   30.425360] videodev: Linux video capture interface: v2.00
[   30.469370] hid-generic 0003:0951:16BE.0002: input,hidraw1: USB HID v1.11 Keyboard [HyperX Alloy Elite RGB HyperX Alloy Elite RGB] on usb-0000:00:14.0-2/input1
[   30.469692] input: HyperX Alloy Elite RGB HyperX Alloy Elite RGB Mouse as /devices/pci0000:00/0000:00:14.0/usb2/2-2/2-2:1.2/0003:0951:16BE.0003/input/input16
[   30.469787] input: HyperX Alloy Elite RGB HyperX Alloy Elite RGB System Control as /devices/pci0000:00/0000:00:14.0/usb2/2-2/2-2:1.2/0003:0951:16BE.0003/input/input17
[   30.526112] input: HyperX Alloy Elite RGB HyperX Alloy Elite RGB Consumer Control as /devices/pci0000:00/0000:00:14.0/usb2/2-2/2-2:1.2/0003:0951:16BE.0003/input/input18
[   30.526233] input: HyperX Alloy Elite RGB HyperX Alloy Elite RGB Keyboard as /devices/pci0000:00/0000:00:14.0/usb2/2-2/2-2:1.2/0003:0951:16BE.0003/input/input20
[   30.526409] hid-generic 0003:0951:16BE.0003: input,hiddev0,hidraw2: USB HID v1.11 Mouse [HyperX Alloy Elite RGB HyperX Alloy Elite RGB] on usb-0000:00:14.0-2/input2
[   30.526616] hid-generic 0003:1E71:1714.0004: hiddev1,hidraw3: USB HID v1.10 Device [NZXT.-Inc. NZXT USB Device] on usb-0000:00:14.0-10/input0
[   30.540087] mousedev: PS/2 mouse device common for all mice
[   30.609132] usbcore: registered new interface driver snd-usb-audio
[   30.609160] uvcvideo: Found UVC 1.00 device HD Pro Webcam C920 (046d:082d)
[   30.610901] uvcvideo 2-1:1.0: Entity type for entity Processing 3 was not initialized!
[   30.610903] uvcvideo 2-1:1.0: Entity type for entity Extension 6 was not initialized!
[   30.610905] uvcvideo 2-1:1.0: Entity type for entity Extension 12 was not initialized!
[   30.610906] uvcvideo 2-1:1.0: Entity type for entity Camera 1 was not initialized!
[   30.610908] uvcvideo 2-1:1.0: Entity type for entity Extension 8 was not initialized!
[   30.610909] uvcvideo 2-1:1.0: Entity type for entity Extension 9 was not initialized!
[   30.610910] uvcvideo 2-1:1.0: Entity type for entity Extension 10 was not initialized!
[   30.610912] uvcvideo 2-1:1.0: Entity type for entity Extension 11 was not initialized!
[   30.610982] input: HD Pro Webcam C920 as /devices/pci0000:00/0000:00:14.0/usb2/2-1/2-1:1.0/input/input22
[   30.611042] usbcore: registered new interface driver uvcvideo
[   30.611042] USB Video Class driver (1.1.1)
[   34.083987] audit: type=1006 audit(1549565610.851:45): pid=767 uid=0 old-auid=4294967295 auid=1000 tty=(none) old-ses=4294967295 ses=2 res=1
[   34.091478] audit: type=1130 audit(1549565610.857:46): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=user-runtime-dir@1000 comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[   34.091729] IPv6: ADDRCONF(NETDEV_UP): wlp3s0: link is not ready
[   34.097890] audit: type=1006 audit(1549565610.864:47): pid=771 uid=0 old-auid=4294967295 auid=1000 tty=(none) old-ses=4294967295 ses=3 res=1
[   34.125102] audit: type=1130 audit(1549565610.891:48): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=user@1000 comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[   34.801068] wlp3s0: authenticate with 4c:1b:86:5f:39:d3
[   34.805019] wlp3s0: send auth to 4c:1b:86:5f:39:d3 (try 1/3)
[   34.845911] wlp3s0: authenticated
[   34.849177] wlp3s0: associate with 4c:1b:86:5f:39:d3 (try 1/3)
[   34.853303] wlp3s0: RX AssocResp from 4c:1b:86:5f:39:d3 (capab=0x411 status=0 aid=1)
[   34.854983] wlp3s0: associated
[   34.898665] wlp3s0: Limiting TX power to 17 (20 - 3) dBm as advertised by 4c:1b:86:5f:39:d3
[   34.899008] IPv6: ADDRCONF(NETDEV_CHANGE): wlp3s0: link becomes ready
[   34.999316] audit: type=1131 audit(1549565611.767:49): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=user@973 comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[   35.026763] audit: type=1131 audit(1549565611.794:50): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=user-runtime-dir@973 comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[   40.192095] audit: type=1130 audit(1549565616.957:51): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=NetworkManager-dispatcher comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[   41.109920] audit: type=1131 audit(1549565617.877:52): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=systemd-hostnamed comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[   42.253548] audit: type=1130 audit(1549565619.021:53): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=rtkit-daemon comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[   44.835996] usb 2-1: reset high-speed USB device number 2 using xhci_hcd
[   50.011396] audit: type=1131 audit(1549565626.777:54): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=NetworkManager-dispatcher comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[   52.783229] audit: type=1130 audit(1549565629.551:55): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=org.cups.cupsd comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[   72.680486] usb 2-1: USB disconnect, device number 2
[   91.222714] usb 2-6: USB disconnect, device number 4
[  106.202554] usb 2-6: new full-speed USB device number 6 using xhci_hcd
[  106.344346] usb 2-6: New USB device found, idVendor=1b1c, idProduct=1b3c, bcdDevice= 1.01
[  106.344350] usb 2-6: New USB device strings: Mfr=1, Product=2, SerialNumber=3
[  106.344352] usb 2-6: Product: Corsair Gaming HARPOON RGB Mouse
[  106.344355] usb 2-6: Manufacturer: Corsair
[  106.344357] usb 2-6: SerialNumber: 0C03100DAF2608435A3D621DF5001BC7
[  106.347011] input: Corsair Corsair Gaming HARPOON RGB Mouse as /devices/pci0000:00/0000:00:14.0/usb2/2-6/2-6:1.0/0003:1B1C:1B3C.0005/input/input23
[  106.347441] hid-generic 0003:1B1C:1B3C.0005: input,hidraw4: USB HID v1.11 Mouse [Corsair Corsair Gaming HARPOON RGB Mouse] on usb-0000:00:14.0-6/input0
[  106.348885] input: Corsair Corsair Gaming HARPOON RGB Mouse Mouse as /devices/pci0000:00/0000:00:14.0/usb2/2-6/2-6:1.1/0003:1B1C:1B3C.0006/input/input24
[  106.349222] input: Corsair Corsair Gaming HARPOON RGB Mouse Consumer Control as /devices/pci0000:00/0000:00:14.0/usb2/2-6/2-6:1.1/0003:1B1C:1B3C.0006/input/input25
[  106.406242] input: Corsair Corsair Gaming HARPOON RGB Mouse as /devices/pci0000:00/0000:00:14.0/usb2/2-6/2-6:1.1/0003:1B1C:1B3C.0006/input/input26
[  106.406459] input: Corsair Corsair Gaming HARPOON RGB Mouse as /devices/pci0000:00/0000:00:14.0/usb2/2-6/2-6:1.1/0003:1B1C:1B3C.0006/input/input27
[  106.406880] hid-generic 0003:1B1C:1B3C.0006: input,hiddev2,hidraw5: USB HID v1.11 Mouse [Corsair Corsair Gaming HARPOON RGB Mouse] on usb-0000:00:14.0-6/input1
[  106.407007] usbhid 2-6:1.2: couldn't find an input interrupt endpoint
[  125.769252] usb 2-1: new high-speed USB device number 7 using xhci_hcd
[  128.248743] usb 2-1: New USB device found, idVendor=046d, idProduct=082d, bcdDevice= 0.11
[  128.248750] usb 2-1: New USB device strings: Mfr=0, Product=2, SerialNumber=1
[  128.248755] usb 2-1: Product: HD Pro Webcam C920
[  128.248759] usb 2-1: SerialNumber: EAEC3A3F
[  128.250810] uvcvideo: Found UVC 1.00 device HD Pro Webcam C920 (046d:082d)
[  128.251750] uvcvideo 2-1:1.0: Entity type for entity Processing 3 was not initialized!
[  128.251751] uvcvideo 2-1:1.0: Entity type for entity Extension 6 was not initialized!
[  128.251752] uvcvideo 2-1:1.0: Entity type for entity Extension 12 was not initialized!
[  128.251753] uvcvideo 2-1:1.0: Entity type for entity Camera 1 was not initialized!
[  128.251754] uvcvideo 2-1:1.0: Entity type for entity Extension 8 was not initialized!
[  128.251755] uvcvideo 2-1:1.0: Entity type for entity Extension 9 was not initialized!
[  128.251756] uvcvideo 2-1:1.0: Entity type for entity Extension 10 was not initialized!
[  128.251757] uvcvideo 2-1:1.0: Entity type for entity Extension 11 was not initialized!
[  128.251815] input: HD Pro Webcam C920 as /devices/pci0000:00/0000:00:14.0/usb2/2-1/2-1:1.0/input/input28
[  146.663962] fuse init (API version 7.27)
[  205.179270] usb 2-1: reset high-speed USB device number 7 using xhci_hcd
[  915.480592] audit: type=1130 audit(1549566492.247:56): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=systemd-tmpfiles-clean comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[  915.480601] audit: type=1131 audit(1549566492.247:57): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=systemd-tmpfiles-clean comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
#20
Try running the long list of commands I gave before one more time.
Replace wlan0 with wlp3s0 in both commands on the list.
#21
[yash@MyAmazingPC ~]$ nmcli networking off
[yash@MyAmazingPC ~]$ sudo systemctl stop NetworkManager
[sudo] password for yash:
[yash@MyAmazingPC ~]$ sudo ip link set wlp3s0 down
[yash@MyAmazingPC ~]$ sudo lsmod | grep -o -e ^iwlmvm -e ^iwldvm -e ^iwlwifi | xargs sudo rmmod
[yash@MyAmazingPC ~]$ sudo modprobe iwlwifi
[yash@MyAmazingPC ~]$ sudo ip link set wlp3s0 up
[yash@MyAmazingPC ~]$ sudo systemctl start NetworkManager
[yash@MyAmazingPC ~]$ nmcli networking on
I think that it worked
