Hello, I’m new to manjaro.
I had installed the operating system the other day. I noticed that my operating system boot time and the time for the DE to load after login is long . tried running nvtop and
i noticed that my Intel 630 graphics not being used at all.i would love to get help from the community.
Here is the image for it imgur(dot)com/a/hNSgPog
Welcome.
How did you reach the conclusion?
Don’t post images - we won’t respond to images as they are useless - and that is one of the reasons that new members cannot post images.
A sincere effort to describe your issue in words using proper spelling and grammar goes a long way.
Please provide textual description - perhaps terminal output as text
Example
Host: tiger Kernel: 5.15.84-1-MANJARO arch: x86_64 bits: 64
Desktop: KDE Plasma v: 5.26.4 Distro: Manjaro Linux
Please provide the output of command
inxi -Fxxxc0
Sorry about it.
I’ll make sure not to post images.
Here is the output:
Host: Khader-laptop Kernel: 5.15.81-1-MANJARO arch: x86_64 bits: 64
compiler: gcc v: 12.2.0 Desktop: KDE Plasma v: 5.26.4 tk: Qt v: 5.15.7
wm: kwin_x11 vt: 1 dm: SDDM Distro: Manjaro Linux base: Arch Linux
Type: Laptop System: Acer product: Predator PH315-52 v: V1.04
Mobo: CFL model: Covini_CFS v: V1.04 serial: <superuser required>
UEFI: Insyde v: 1.04 date: 06/19/2019
ID-1: BAT0 charge: 53.4 Wh (100.0%) condition: 53.4/53.4 Wh (100.0%)
volts: 16.4 min: 15.4 model: SMP KT00407009 AP18E7M type: Li-ion
serial: 26646 06/20/2019 status: full
Info: quad core model: Intel Core i5-9300H bits: 64 type: MT MCP
smt: enabled arch: Coffee Lake rev: A cache: L1: 256 KiB L2: 1024 KiB
L3: 8 MiB
Speed (MHz): avg: 800 min/max: 800/4100 cores: 1: 800 2: 800 3: 800 4: 800
5: 800 6: 800 7: 800 8: 800 bogomips: 38408
Device-1: Intel CoffeeLake-H GT2 [UHD Graphics 630]
vendor: Acer Incorporated ALI driver: i915 v: kernel arch: Gen-9.5 ports:
active: eDP-1 empty: DP-1, DP-2, DP-3, HDMI-A-1, HDMI-A-2 bus-ID: 00:02.0
chip-ID: 8086:3e9b class-ID: 0300
Device-2: NVIDIA TU116M [GeForce GTX 1660 Ti Mobile]
vendor: Acer Incorporated ALI driver: nvidia v: 525.60.11 arch: Turing pcie:
speed: 8 GT/s lanes: 16 bus-ID: 01:00.0 chip-ID: 10de:2191 class-ID: 0300
Display: x11 server: X.Org v: 21.1.4 compositor: kwin_x11 driver: X:
loaded: modesetting,nvidia alternate: fbdev,nouveau,nv,vesa dri: iris
gpu: i915 display-ID: :0 screens: 1
s-diag: 582mm (22.93")
Monitor-1: eDP-1 model: BOE Display 0x082a res: 1920x1080 hz: 144 dpi: 142
size: 344x193mm (13.54x7.6") diag: 398mm (15.7") modes: 1920x1080
API: OpenGL v: 4.6 Mesa 22.2.4 renderer: Mesa Intel UHD Graphics 630 (CFL
GT2) direct render: Yes
Device-1: Intel Cannon Lake PCH cAVS vendor: Acer Incorporated ALI
driver: snd_hda_intel v: kernel bus-ID: 00:1f.3 chip-ID: 8086:a348
class-ID: 0403
Device-2: NVIDIA TU116 High Definition Audio vendor: Acer Incorporated ALI
driver: snd_hda_intel v: kernel pcie: speed: 8 GT/s lanes: 16
bus-ID: 01:00.1 chip-ID: 10de:1aeb class-ID: 0403
Sound API: ALSA v: k5.15.81-1-MANJARO running: yes
Sound Server-3: PipeWire v: 0.3.61 running: yes
Device-1: Qualcomm Atheros Killer E2500 Gigabit Ethernet
vendor: Acer Incorporated ALI driver: alx v: kernel pcie: speed: 2.5 GT/s
lanes: 1 port: 3000 bus-ID: 06:00.0 chip-ID: 1969:e0b1 class-ID: 0200
IF: enp6s0 state: down mac: 7c:d3:0a:81:e9:0a
Device-2: Intel Wi-Fi 6 AX200 vendor: Rivet Networks Killer™
driver: iwlwifi v: kernel pcie: speed: 5 GT/s lanes: 1 bus-ID: 07:00.0
chip-ID: 8086:2723 class-ID: 0280
IF: wlp7s0 state: up mac: 38:00:25:94:d0:90
Hardware-1: Intel 82801 Mobile SATA Controller [RAID mode] driver: ahci
v: 3.0 port: 5060 bus-ID: 00:17.0 chip-ID: 8086:282a rev: N/A class-ID: 0104
Local Storage: total: 931.51 GiB used: 12.63 GiB (1.4%)
ID-1: /dev/sda vendor: Seagate model: ST1000LM049-2GH172 size: 931.51 GiB
speed: 6.0 Gb/s type: HDD rpm: 7200 serial: ZGS0R8AL rev: ACM1 scheme: MBR
ID-1: / size: 238.03 GiB used: 12.63 GiB (5.3%) fs: ext4 dev: /dev/sda2
ID-2: /boot/efi size: 1.09 GiB used: 332 KiB (0.0%) fs: vfat
dev: /dev/sda4
System Temperatures: cpu: 42.0 C pch: 51.0 C mobo: N/A
Processes: 257 Uptime: 3m wakeups: 1 Memory: 15.48 GiB
used: 1.93 GiB (12.5%) Init: systemd v: 251 default: graphical Compilers:
gcc: 12.2.0 clang: 14.0.6 Packages: pm: pacman pkgs: 1232 Shell: Zsh v: 5.9
default: Bash v: 5.1.16 running-in: konsole inxi: 3.3.24
Please have a look at the search function in upper right corner
Thank you.
My Apologies for posting the thread.
I’m new to Linux and with a recommendation from my friend got to know about Manjaro.
Thank you for spending your valuable time helping me.
I only have one system with dual graphics - an old ThinkPad T550 - so the best I could do was pointing you in the right direction ![]()
