Kernel: 6.1.19-1-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 12.2.1
root=UUID=84186a04-1661-4f71-8801-c5f0e5e14f18 rw quiet apparmor=1
Desktop: i3 v: 4.22 info: i3bar vt: 7 dm: LightDM v: 1.32.0
Type: Laptop System: HUAWEI product: BOHB-WAX9 v: M1060
serial: <superuser required>
Mobo: HUAWEI model: BOHB-WAX9-PCB-B2 v: M1060 serial: <superuser required>
UEFI: HUAWEI v: 1.42 date: 03/25/2022
ID-1: BAT1 charge: 6.5 Wh (17.2%) condition: 37.7/41.6 Wh (90.7%)
volts: 12.3 min: 11.5 model: Desay HB4692J5ECW-31 type: Li-ion
serial: <filter> status: charging cycles: 111
Info: model: Intel Core i3-10110U bits: 64 type: MT MCP
arch: Comet/Whiskey Lake note: check gen: core 10 level: v3 note: check
built: 2018 process: Intel 14nm family: 6 model-id: 0x8E (142)
stepping: 0xC (12) microcode: 0xF4
L3: 4 MiB desc: 1x4 MiB
Speed (MHz): avg: 2600 min/max: 400/4100 scaling: driver: intel_pstate
governor: powersave cores: 1: 2600 2: 2600 3: 2600 4: 2600 bogomips: 20810
Type: retbleed mitigation: Enhanced IBRS
Type: spectre_v2 mitigation: Enhanced IBRS, IBPB: conditional, RSB
filling, PBRSB-eIBRS: SW sequence
Device-1: Intel CometLake-U GT2 [UHD Graphics] vendor: QUANTA driver: i915
v: kernel arch: Gen-9.5 process: Intel 14nm built: 2016-20 ports:
active: eDP-1 empty: DP-1,HDMI-A-1 bus-ID: 00:02.0 chip-ID: 8086:9b41
class-ID: 0300
Device-2: IMC Networks HD Camera type: USB driver: uvcvideo bus-ID: 1-6:4
chip-ID: 13d3:5480 class-ID: fe01 serial: <filter>
Display: x11 server: X.Org v: 21.1.7 compositor: Picom v: git-b700a
driver: X: loaded: modesetting alternate: fbdev,vesa dri: iris gpu: i915
display-ID: :0 screens: 1
s-diag: 582mm (22.93")
Monitor-1: eDP-1 model: BOE Display 0x0872 built: 2019 res: 1920x1080
hz: 60 dpi: 142 gamma: 1.2 size: 344x194mm (13.54x7.64") diag: 395mm (15.5")
ratio: 16:9 modes: 1920x1080
API: OpenGL Message: Unable to show GL data. Required tool glxinfo
missing.
Device-1: Intel Comet Lake PCH-LP cAVS vendor: QUANTA
driver: sof-audio-pci-intel-cnl
alternate: snd_hda_intel,snd_soc_skl,snd_sof_pci_intel_cnl bus-ID: 00:1f.3
chip-ID: 8086:02c8 class-ID: 0401
Sound API: ALSA v: k6.1.19-1-MANJARO running: yes
Sound Server-1: JACK v: 1.9.22 running: no
Sound Server-3: PipeWire v: 0.3.65 running: no
Device-1: Intel Comet Lake PCH-LP CNVi WiFi driver: iwlwifi v: kernel
bus-ID: 00:14.3 chip-ID: 8086:02f0 class-ID: 0280
Device-1: Intel Bluetooth 9460/9560 Jefferson Peak (JfP) type: USB
driver: btusb v: 0.8 bus-ID: 1-10:5 chip-ID: 8087:0aaa class-ID: e001
Local Storage: total: 238.47 GiB used: 10.91 GiB (4.6%)
model: MZVLB256HBHQ-00000 size: 238.47 GiB block-size: physical: 512 B
rev: EXH7201Q temp: 35.9 C scheme: GPT
ID-1: / raw-size: 117.53 GiB size: 115.13 GiB (97.95%)
used: 10.88 GiB (9.4%) fs: ext4 dev: /dev/nvme0n1p8 maj-min: 259:8
used: 37.8 MiB (39.4%) fs: vfat dev: /dev/nvme0n1p1 maj-min: 259:1
ID-1: swap-1 type: partition size: 977 MiB used: 0 KiB (0.0%) priority: -2
dev: /dev/nvme0n1p4 maj-min: 259:4
System Temperatures: cpu: 43.0 C pch: 34.0 C mobo: N/A
Processes: 189 Uptime: 3m wakeups: 1 Memory: 7.51 GiB used: 1.6 GiB (21.3%)
Init: systemd v: 252 default: graphical tool: systemctl Compilers:
gcc: 12.2.1 clang: 15.0.7 Packages: pm: pacman pkgs: 1065 libs: 304
tools: pamac,yay Shell: Bash v: 5.1.16 running-in: urxvtd inxi: 3.3.25
Moderator edit: In the future, please use proper formatting: [HowTo] Post command output and file content as formatted text
