Hey there,
I used Lutris to install Hearthstone on my machine. Installation created a folder “Games” in /home/username/ with another folder called “hearthstone”.
This worked flawlessly for one year or so. A week ago I tried to launch Heartstone via Lutris and got an error message: “Invalid Wine prefix path /home/username/Games/hearthstone, make sure to create the prefix before saving to a registry”.
Looked into that and found that the “Games” folder no longer existed. I thought that maybe I deleted the folder by mistake and re-installed Hearthstone via Lutris. Worked for a week until today - same error message, “Games” folder gone again.
What could be wrong here?
Thanks a lot!
Edit: Forgot to mention that all my installed Steam games also disappeared. These weren’t even installed in the “Games” folder and (as far as I know) not integrated to Lutris. Installed them via Steam itself.
Kernel: 5.15.2-2-MANJARO x86_64 bits: 64 compiler: gcc v: 11.1.0
root=UUID=309797db-be17-466d-98be-174aa1629301 rw quiet apparmor=1
security=apparmor resume=UUID=0901642f-6782-43b8-bce1-ea689d504d5c
udev.log_priority=3
Desktop: KDE Plasma 5.23.3 tk: Qt 5.15.2 info: plank wm: kwin_x11 vt: 1
dm: LightDM 1.30.0, SDDM Distro: Manjaro Linux base: Arch Linux
Type: Laptop System: Dell product: XPS 15 7590 v: N/A serial: <filter>
Chassis: type: 10 serial: <filter>
Mobo: Dell model: 0VYV0G v: A00 serial: <filter> UEFI: Dell v: 1.12.0
date: 06/10/2021
ID-1: BAT0 charge: 81.6 Wh (100.0%) condition: 81.6/97.0 Wh (84.1%)
volts: 12.4 min: 11.4 model: SMP DELL GPM0365 type: Li-ion serial: <filter>
status: Full
Device-1: hidpp_battery_0 model: Logitech Wireless Keyboard K360
serial: <filter> charge: 100% (should be ignored) rechargeable: yes
status: Discharging
Device-2: hidpp_battery_1 model: Logitech Wireless Mouse serial: <filter>
charge: 55% (should be ignored) rechargeable: yes status: Discharging
RAM: total: 15.24 GiB used: 3.63 GiB (23.8%)
Info: 6-Core model: Intel Core i7-9750H bits: 64 type: MT MCP
arch: Kaby Lake note: check family: 6 model-id: 9E (158) stepping: A (10)
microcode: EA cache: L2: 12 MiB bogomips: 62431
Speed: 3650 MHz min/max: 800/4500 MHz Core speeds (MHz): 1: 3650 2: 3651
3: 3665 4: 3722 5: 3653 6: 3655 7: 3656 8: 3378 9: 3417 10: 4072 11: 4035
12: 4067
Flags: 3dnowprefetch abm acpi adx aes aperfmperf apic arat arch_perfmon art
avx avx2 bmi1 bmi2 bts clflush clflushopt cmov constant_tsc cpuid
hwp_epp hwp_notify ibpb ibrs ida intel_pt invpcid invpcid_single lahf_lm lm
mca mce md_clear mmx monitor movbe mpx msr mtrr nonstop_tsc nopl nx pae pat
rdrand rdseed rdtscp rep_good sdbg sep sgx sgx_lc smap smep ss ssbd sse sse2
xsaves xtopology xtpr
Type: l1tf
Device-1: Intel CoffeeLake-H GT2 [UHD Graphics 630] vendor: Dell
driver: i915 v: kernel bus-ID: 00:02.0 chip-ID: 8086:3e9b class-ID: 0300
Device-2: NVIDIA TU117M [GeForce GTX 1650 Mobile / Max-Q]
vendor: Hewlett-Packard driver: nvidia v: 495.44
alternate: nouveau,nvidia_drm bus-ID: 01:00.0 chip-ID: 10de:1f91
class-ID: 0302
Device-3: Microdia Integrated_Webcam_HD type: USB driver: uvcvideo
bus-ID: 1-12:5 chip-ID: 0c45:6723 class-ID: 0e02
Display: x11 server: X.Org 1.21.1.1 compositor: kwin_x11 driver:
loaded: modesetting,nvidia unloaded: nouveau alternate: fbdev,nv,vesa
display-ID: :0 screens: 1
Screen-1: 0 s-res: 7040x1440 s-dpi: 96 s-size: 1862x381mm (73.3x15.0")
s-diag: 1901mm (74.8")
Monitor-1: eDP-1 res: 1920x1080 dpi: 142 size: 344x194mm (13.5x7.6")
diag: 395mm (15.5")
Monitor-2: DP-1 res: 2560x1440 dpi: 109 size: 597x336mm (23.5x13.2")
diag: 685mm (27")
Monitor-3: DP-3 res: 2560x1440 dpi: 109 size: 597x336mm (23.5x13.2")
diag: 685mm (27")
OpenGL: renderer: Mesa Intel UHD Graphics 630 (CFL GT2) v: 4.6 Mesa 21.2.5
direct render: Yes
Device-1: Intel Cannon Lake PCH cAVS vendor: Dell driver: snd_hda_intel
Sound Server-1: ALSA v: k5.15.2-2-MANJARO running: yes
Sound Server-4: PipeWire v: 0.3.40 running: yes
Device-1: Intel Wi-Fi 6 AX200 vendor: Rivet Networks Killer™
driver: iwlwifi v: kernel bus-ID: 3b:00.0 chip-ID: 8086:2723 class-ID: 0280
IF: wlp59s0 state: up mac: <filter>
Device-1: Intel AX200 Bluetooth type: USB driver: btusb v: 0.8 bus-ID: 1-4:3
Local Storage: total: 476.94 GiB used: 249.12 GiB (52.2%)
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Toshiba
model: KXG60ZNV512G NVMe 512GB size: 476.94 GiB block-size: physical: 512 B
rev: 10604107 temp: 32.9 C scheme: GPT
ID-1: / raw-size: 459.86 GiB size: 451.57 GiB (98.20%)
used: 249.08 GiB (55.2%) fs: ext4 dev: /dev/nvme0n1p2 maj-min: 259:2
label: N/A uuid: 309797db-be17-466d-98be-174aa1629301
used: 39.9 MiB (13.3%) fs: vfat dev: /dev/nvme0n1p1 maj-min: 259:1
label: NO_LABEL uuid: 9434-0220
ID-1: swap-1 type: partition size: 16.78 GiB used: 0 KiB (0.0%) priority: -2
dev: /dev/nvme0n1p3 maj-min: 259:3 label: N/A
uuid: 0901642f-6782-43b8-bce1-ea689d504d5c
Hub-1: 1-0:1 info: Full speed (or root) Hub ports: 16 rev: 2.0
Device-1: 1-2:2 info: Logitech Unifying Receiver type: Keyboard,Mouse,HID
power: 98mA chip-ID: 046d:c52b class-ID: 0300
Device-2: 1-4:3 info: Intel AX200 Bluetooth type: Bluetooth driver: btusb
class-ID: e001
Device-3: 1-7:4 info: Shenzhen Goodix Fingerprint Reader
type: Abstract (modem),CDC-Data driver: N/A interfaces: 2 rev: 2.0
speed: 12 Mb/s power: 100mA chip-ID: 27c6:5395 class-ID: 0a00
serial: <filter>
Device-4: 1-12:5 info: Microdia Integrated_Webcam_HD type: Video
Hub-2: 2-0:1 info: Full speed (or root) Hub ports: 10 rev: 3.1
speed: 10 Gb/s chip-ID: 1d6b:0003 class-ID: 0900
Hub-3: 3-0:1 info: Full speed (or root) Hub ports: 2 rev: 2.0
Hub-4: 4-0:1 info: Full speed (or root) Hub ports: 2 rev: 3.1 speed: 10 Gb/s
System Temperatures: cpu: 53.0 C mobo: N/A
Fan Speeds (RPM): cpu: 2424 fan-2: 2418
Processes: 311 Uptime: 2h 30m wakeups: 65 Init: systemd v: 249
tool: systemctl Compilers: gcc: 11.1.0 Packages: pacman: 1400 lib: 418
flatpak: 0 Shell: Bash v: 5.1.8 running-in: konsole inxi: 3.3.08
