I just switched to Linux, I don’t know much.
Here is the error:
cool-retro-term ✔
Using a variable-width font in the terminal. This may cause performance degradation and display/alignment errors.
Both point size and pixel size set. Using pixel size.
The terminal starts for a second and then collapses.
At first it worked fine, I launched it, configured it and it worked. Then I added that when the terminal starts, an neofetch should be displayed (I launched it manually, everything also worked). I restarted it to check and it broke.
I understand that it is not very important, I can just install another terminal or stay on the stock one, but I just like it. If I can give you more information, write. (I use a translator)
Is there any way I can change the variable font to monospace via console for this terminal?
