Unless you post in the Chinese sub forum, you shouldn’t post your UI screenshot in Chinese, start application from terminal, probably like this should work for System Settings LANG=C systemsettings5, this way people can read the image.
If you want to keep the automatic screen shut, just check the box of “屏幕节能” and set it to 60 min. Before that, remember Energy Saving settings actually have 3 tabs, make sure that you edit the right tab according to your power source (AC or battery).
If settings, or the plasma desktop in general, is acting funny … this could be corrupted config files.
You can ‘refresh’ using the steps below - but be warned, you will lose most of your desktop changes.
(you will have to apply widgets the way you like it again, etc)
