My computer keeps freezing randomly
Sometimes my computer randomly starts to freeze, it often happens when I have a video playing, or I think something similar, it also freezes when I open some websites that don’t have a video, or some software, like when I open Discord.
From what I see in journalcli, it probably has something to do with the main thread hanging for KWin, but I’m not sure what’s causing it.
This is the journalcli of a session that started freezing randomly.
Apr 27 12:32:49 systemd[1]: Starting Pamac Daemon...
Apr 27 12:32:49 systemd[1]: Started Pamac Daemon.
Apr 27 12:32:49 pamac-manager[58967]: gdk_window_set_cursor: assertion 'GDK_IS_WINDOW (window)' failed
Apr 27 12:32:49 pamac-manager[58967]: manager_window.vala:2436: /var/lib/flatpak/appstream/flathub/x86_64/active/icons/64x64/com.skype.Client.desktop.png: Failed to open file “/var/lib/flatpak/appstream/flathub/x86_64/active/icons/64x64/com.skype.Client.desktop.png”: No such file>
Apr 27 12:33:03 polkit-kde-authentication-agent-1[1336]: Listener adapter polkit_qt_listener_initiate_authentication
Apr 27 12:33:03 polkit-kde-authentication-agent-1[1336]: GSimpleAsyncResult: 0x73ff00001480
Apr 27 12:33:03 polkit-kde-authentication-agent-1[1336]: polkit_qt_listener_initiate_authentication callback for  0x5fbcd18f5330
Apr 27 12:33:03 polkit-kde-authentication-agent-1[1336]: Initiating authentication
Apr 27 12:33:03 polkit-kde-authentication-agent-1[1336]: Action description has been found
Apr 27 12:33:03 polkit-kde-authentication-agent-1[1336]: User:  "unix-user:sp33d"
Apr 27 12:33:03 polkit-kde-authentication-agent-1[1336]: Trying again
Apr 27 12:33:03 kwin_wayland[1018]: kwin_core: Cannot grant a token to KWin::ClientConnection(0x6081af212c80)
Apr 27 12:33:03 polkit-kde-authentication-agent-1[1336]: REQUEST
Apr 27 12:33:03 polkit-kde-authentication-agent-1[1336]: Request:  "Password: "  echo:  false
Apr 27 12:33:05 polkit-kde-authentication-agent-1[1336]: Dialog accepted
Apr 27 12:33:06 polkit-kde-authentication-agent-1[1336]: COMPLETED
Apr 27 12:33:06 polkit-kde-authentication-agent-1[1336]: Completed:  true
Apr 27 12:33:06 polkit-kde-authentication-agent-1[1336]: Finishing obtaining privileges
Apr 27 12:33:06 polkit-kde-authentication-agent-1[1336]: Listener adapter polkit_qt_listener_initiate_authentication_finish
Apr 27 12:33:06 polkit-kde-authentication-agent-1[1336]: polkit_qt_listener_initiate_authentication_finish callback for  0x5fbcd18f5330
Apr 27 12:33:06 polkit-kde-authentication-agent-1[1336]: Finish obtain authorization: true
Apr 27 12:33:06 polkit-kde-authentication-agent-1[1336]: Dialog cancelled
Apr 27 12:33:06 polkitd[681]: Operator of unix-session:2 successfully authenticated as unix-user:sp33d to gain TEMPORARY authorization for action org.manjaro.pamac.commit for system-bus-name::1.252 [/usr/bin/pamac-manager --gapplication-service] (owned by unix-user:sp33d)
Apr 27 12:33:07 pamac-manager[59035]: cp: cannot access '/var/lib/pacman/sync/download-PWDx98': Permission denied
Apr 27 12:33:14 systemd[1]: Reload requested from client PID 59069 ('systemctl') (unit pamac-daemon.service)...
Apr 27 12:33:14 systemd[1]: Reloading...
Apr 27 12:33:14 systemd[1]: Reloading finished in 182 ms.
Apr 27 12:33:14 pamac-tray-plas[1655]: Source ID 20 was not found when attempting to remove it
Apr 27 12:33:16 systemd[968]: Starting Virtual filesystem metadata service...
Apr 27 12:33:16 systemd[968]: Started Virtual filesystem metadata service.
Apr 27 12:33:16 systemd[968]: dbus-:1.2-org.manjaro.pamac.manager@0.service: Consumed 11.667s CPU time, 1.5G memory peak.
Apr 27 12:33:19 pamac-tray-plas[1655]: updates_checker.vala:59: check updates
Apr 27 12:33:20 systemd[1]: Starting Locale Service...
Apr 27 12:33:20 systemd[1]: Started Locale Service.
Apr 27 12:33:20 systemd[1]: pamac-daemon.service: Deactivated successfully.
Apr 27 12:33:20 systemd[1]: pamac-daemon.service: Consumed 3.645s CPU time, 730.1M memory peak.
Apr 27 12:33:50 systemd[1]: systemd-localed.service: Deactivated successfully.
Apr 27 12:34:03 vivaldi-stable[5141]: [5137:5163:0427/123403.444122:ERROR:object_proxy.cc(576)] Failed to call method: org.freedesktop.ScreenSaver.Inhibit: object_path= /org/freedesktop/ScreenSaver: org.freedesktop.DBus.Error.NoReply: Did not receive a reply. Possible causes incl>
Apr 27 12:34:03 vivaldi-stable[5141]: [5137:5163:0427/123403.444137:ERROR:power_save_blocker_linux.cc(342)] No response to Inhibit() request!
Apr 27 12:34:03 kwin_wayland[1018]: kwin_wayland_drm: The main thread was hanging temporarily!
Apr 27 12:34:09 wireplumber[2377]: wp-event-dispatcher: <WpAsyncEventHook:0x5a427bc9f950> failed: <WpSiStandardLink:0x5a427c0d96f0> link failed: 1 of 1 PipeWire links failed to activate
Apr 27 12:34:09 wireplumber[2377]: wp-event-dispatcher: <WpAsyncEventHook:0x5a427bc9f950> failed: <WpSiStandardLink:0x5a427c0fb7a0> link failed: 1 of 1 PipeWire links failed to activate
Apr 27 12:34:13 wireplumber[2377]: wp-event-dispatcher: <WpAsyncEventHook:0x5a427bcb2f30> failed: failed to activate item: Object activation aborted: proxy destroyed
Apr 27 12:34:20 vivaldi-stable[5141]: [5198:5198:0427/123420.120210:ERROR:shared_image_manager.cc(401)] SharedImageManager::ProduceSkia: Trying to Produce a Skia representation from a non-existent mailbox.
Apr 27 12:34:21 vivaldi-stable[5141]: [5198:5198:0427/123421.273208:ERROR:shared_image_manager.cc(401)] SharedImageManager::ProduceSkia: Trying to Produce a Skia representation from a non-existent mailbox.
Apr 27 12:34:21 vivaldi-stable[5141]: [5198:5198:0427/123421.273502:ERROR:shared_image_manager.cc(401)] SharedImageManager::ProduceSkia: Trying to Produce a Skia representation from a non-existent mailbox.
Apr 27 12:34:21 vivaldi-stable[5141]: [5198:5198:0427/123421.889686:ERROR:shared_image_manager.cc(401)] SharedImageManager::ProduceSkia: Trying to Produce a Skia representation from a non-existent mailbox.
Apr 27 12:34:21 vivaldi-stable[5141]: [5198:5198:0427/123421.889965:ERROR:shared_image_manager.cc(401)] SharedImageManager::ProduceSkia: Trying to Produce a Skia representation from a non-existent mailbox.
Apr 27 12:34:22 vivaldi-stable[5141]: [5198:5198:0427/123422.488652:ERROR:shared_image_manager.cc(401)] SharedImageManager::ProduceSkia: Trying to Produce a Skia representation from a non-existent mailbox.
Apr 27 12:34:22 vivaldi-stable[5141]: [5198:5198:0427/123422.488756:ERROR:shared_image_manager.cc(401)] SharedImageManager::ProduceSkia: Trying to Produce a Skia representation from a non-existent mailbox.
Apr 27 12:34:28 vivaldi-stable[5141]: [5137:5163:0427/123428.467483:ERROR:object_proxy.cc(576)] Failed to call method: org.freedesktop.PowerManagement.Inhibit.Inhibit: object_path= /org/freedesktop/PowerManagement/Inhibit: org.freedesktop.DBus.Error.NoReply: Did not receive a rep>
Apr 27 12:34:28 vivaldi-stable[5141]: [5137:5163:0427/123428.467495:ERROR:power_save_blocker_linux.cc(342)] No response to Inhibit() request!
Apr 27 12:34:53 vivaldi-stable[5141]: [5137:5163:0427/123453.487060:ERROR:object_proxy.cc(576)] Failed to call method: org.freedesktop.ScreenSaver.Inhibit: object_path= /org/freedesktop/ScreenSaver: org.freedesktop.DBus.Error.NoReply: Did not receive a reply. Possible causes incl>
Apr 27 12:34:53 vivaldi-stable[5141]: [5137:5163:0427/123453.487072:ERROR:power_save_blocker_linux.cc(342)] No response to Inhibit() request!
Apr 27 12:34:53 kwin_wayland[1018]: kwin_wayland_drm: The main thread was hanging temporarily!
Apr 27 12:35:00 discord[13609]: blackbox: 4/27/2025, 12:35:00 PM GMT+3 12 window.close win2
Apr 27 12:35:07 plasmashell[1299]: file:///usr/share/plasma/plasmoids/org.kde.plasma.notifications/contents/ui/components/JobItem.qml:170: TypeError: Cannot read property 'effectiveDestUrl' of null
Apr 27 12:35:07 plasmashell[1299]: file:///usr/share/plasma/plasmoids/org.kde.plasma.notifications/contents/ui/components/JobItem.qml:143: TypeError: Cannot read property 'effectiveDestUrl' of null
Apr 27 12:35:18 vivaldi-stable[5141]: [5137:5163:0427/123518.510820:ERROR:object_proxy.cc(576)] Failed to call method: org.freedesktop.PowerManagement.Inhibit.Inhibit: object_path= /org/freedesktop/PowerManagement/Inhibit: org.freedesktop.DBus.Error.NoReply: Did not receive a rep>
Apr 27 12:35:18 vivaldi-stable[5141]: [5137:5163:0427/123518.510835:ERROR:power_save_blocker_linux.cc(342)] No response to Inhibit() request!
Apr 27 12:35:30 discord[13609]: 12:35:30.667 › [WindowVisibilityVideoManager] Incoming video enabled changed, incomingVideoEnabled = false
Apr 27 12:35:43 vivaldi-stable[5141]: [5137:5163:0427/123543.534110:ERROR:object_proxy.cc(576)] Failed to call method: org.freedesktop.ScreenSaver.Inhibit: object_path= /org/freedesktop/ScreenSaver: org.freedesktop.DBus.Error.NoReply: Did not receive a reply. Possible causes incl>
Apr 27 12:35:43 vivaldi-stable[5141]: [5137:5163:0427/123543.534130:ERROR:power_save_blocker_linux.cc(342)] No response to Inhibit() request!
Apr 27 12:35:43 kwin_wayland[1018]: kwin_wayland_drm: The main thread was hanging temporarily!
Apr 27 12:36:08 vivaldi-stable[5141]: [5137:5163:0427/123608.558684:ERROR:object_proxy.cc(576)] Failed to call method: org.freedesktop.PowerManagement.Inhibit.Inhibit: object_path= /org/freedesktop/PowerManagement/Inhibit: org.freedesktop.DBus.Error.NoReply: Did not receive a rep>
Apr 27 12:36:08 vivaldi-stable[5141]: [5137:5163:0427/123608.558696:ERROR:power_save_blocker_linux.cc(342)] No response to Inhibit() request!
Apr 27 12:36:33 vivaldi-stable[5141]: [5137:5163:0427/123633.584112:ERROR:object_proxy.cc(576)] Failed to call method: org.freedesktop.ScreenSaver.Inhibit: object_path= /org/freedesktop/ScreenSaver: org.freedesktop.DBus.Error.NoReply: Did not receive a reply. Possible causes incl>
Apr 27 12:36:33 vivaldi-stable[5141]: [5137:5163:0427/123633.584127:ERROR:power_save_blocker_linux.cc(342)] No response to Inhibit() request!
Apr 27 12:36:58 vivaldi-stable[5141]: [5137:5163:0427/123658.607433:ERROR:object_proxy.cc(576)] Failed to call method: org.freedesktop.PowerManagement.Inhibit.Inhibit: object_path= /org/freedesktop/PowerManagement/Inhibit: org.freedesktop.DBus.Error.NoReply: Did not receive a rep>
Apr 27 12:36:58 vivaldi-stable[5141]: [5137:5163:0427/123658.607446:ERROR:power_save_blocker_linux.cc(342)] No response to Inhibit() request!
Apr 27 12:37:23 vivaldi-stable[5141]: [5137:5163:0427/123723.630788:ERROR:object_proxy.cc(576)] Failed to call method: org.freedesktop.ScreenSaver.Inhibit: object_path= /org/freedesktop/ScreenSaver: org.freedesktop.DBus.Error.NoReply: Did not receive a reply. Possible causes incl>
Apr 27 12:37:23 vivaldi-stable[5141]: [5137:5163:0427/123723.630800:ERROR:power_save_blocker_linux.cc(342)] No response to Inhibit() request!
Apr 27 12:37:48 vivaldi-stable[5141]: [5137:5163:0427/123748.654097:ERROR:object_proxy.cc(576)] Failed to call method: org.freedesktop.PowerManagement.Inhibit.Inhibit: object_path= /org/freedesktop/PowerManagement/Inhibit: org.freedesktop.DBus.Error.NoReply: Did not receive a rep>
Apr 27 12:37:48 vivaldi-stable[5141]: [5137:5163:0427/123748.654109:ERROR:power_save_blocker_linux.cc(342)] No response to Inhibit() request!
Apr 27 12:38:18 kioworker[59735]: kf.kio.core.connection: Socket not connected QLocalSocket::PeerClosedError
Apr 27 12:38:18 kioworker[59735]: kf.kio.core: An error occurred during write. The worker terminates now.
Apr 27 12:38:18 kioworker[59735]: QThreadStorage: entry 8 destroyed before end of thread 0x58de3b4e9360
Apr 27 12:38:18 kioworker[59735]: QThreadStorage: entry 2 destroyed before end of thread 0x58de3b4e9360
Apr 27 12:38:18 kioworker[59735]: QThreadStorage: entry 1 destroyed before end of thread 0x58de3b4e9360
Apr 27 12:38:38 vivaldi-stable[5141]: [5137:5163:0427/123838.674096:ERROR:object_proxy.cc(576)] Failed to call method: org.freedesktop.PowerManagement.Inhibit.Inhibit: object_path= /org/freedesktop/PowerManagement/Inhibit: org.freedesktop.DBus.Error.NoReply: Did not receive a rep>
Apr 27 12:38:38 vivaldi-stable[5141]: [5137:5163:0427/123838.674109:ERROR:power_save_blocker_linux.cc(342)] No response to Inhibit() request!
Apr 27 12:39:28 vivaldi-stable[5141]: [5137:5163:0427/123928.671340:ERROR:object_proxy.cc(576)] Failed to call method: org.freedesktop.PowerManagement.Inhibit.Inhibit: object_path= /org/freedesktop/PowerManagement/Inhibit: org.freedesktop.DBus.Error.NoReply: Did not receive a rep>
Apr 27 12:39:28 vivaldi-stable[5141]: [5137:5163:0427/123928.671351:ERROR:power_save_blocker_linux.cc(342)] No response to Inhibit() request!
Apr 27 12:40:18 vivaldi-stable[5141]: [5137:5163:0427/124018.670770:ERROR:object_proxy.cc(576)] Failed to call method: org.freedesktop.PowerManagement.Inhibit.Inhibit: object_path= /org/freedesktop/PowerManagement/Inhibit: org.freedesktop.DBus.Error.NoReply: Did not receive a rep>
Apr 27 12:40:18 vivaldi-stable[5141]: [5137:5163:0427/124018.670781:ERROR:power_save_blocker_linux.cc(342)] No response to Inhibit() request!
Apr 27 12:41:08 vivaldi-stable[5141]: [5137:5163:0427/124108.670775:ERROR:object_proxy.cc(576)] Failed to call method: org.freedesktop.PowerManagement.Inhibit.Inhibit: object_path= /org/freedesktop/PowerManagement/Inhibit: org.freedesktop.DBus.Error.NoReply: Did not receive a rep>
Apr 27 12:41:08 vivaldi-stable[5141]: [5137:5163:0427/124108.670787:ERROR:power_save_blocker_linux.cc(342)] No response to Inhibit() request!
Apr 27 12:41:58 vivaldi-stable[5141]: [5137:5163:0427/124158.672534:ERROR:object_proxy.cc(576)] Failed to call method: org.freedesktop.PowerManagement.Inhibit.Inhibit: object_path= /org/freedesktop/PowerManagement/Inhibit: org.freedesktop.DBus.Error.NoReply: Did not receive a rep>
Apr 27 12:41:58 vivaldi-stable[5141]: [5137:5163:0427/124158.672549:ERROR:power_save_blocker_linux.cc(342)] No response to Inhibit() request!
This is inix
  Kernel: 6.12.21-4-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 14.2.1
    root=UUID=e25eb414-7401-4086-851c-0725906b306f rw quiet splash
    udev.log_priority=3
  Desktop: KDE Plasma v: 6.3.4 tk: Qt v: N/A info: frameworks v: 6.12.0
  Type: Desktop System: Gigabyte product: X570 AORUS ELITE v: -CF
    serial: <superuser required>
  Mobo: Gigabyte model: X570 AORUS ELITE serial: <superuser required>
    uuid: <superuser required> UEFI: American Megatrends LLC. v: F40d
    date: 09/02/2024
  Device-1: wacom_battery_0 model: Wacom Intuos Pro L serial: N/A charge: 100%
    status: discharging
  Info: model: AMD Ryzen 5 5600X bits: 64 type: MT MCP arch: Zen 3+ gen: 3
    model-id: 0x21 (33) stepping: 0 microcode: 0xA20102D
    desc: 6x512 KiB L3: 32 MiB desc: 1x32 MiB
  Speed (MHz): avg: 3606 min/max: 550/4651 boost: enabled scaling:
    driver: amd-pstate-epp governor: performance cores: 1: 3606 2: 3606 3: 3606
    4: 3606 5: 3606 6: 3606 7: 3606 8: 3606 9: 3606 10: 3606 11: 3606 12: 3606
    bogomips: 88844
    affected
  Device-1: Advanced Micro Devices [AMD/ATI] Navi 32 [Radeon RX 7700 XT / 7800
    XT] vendor: Sapphire driver: amdgpu v: kernel arch: RDNA-3 code: Navi-3x
    process: TSMC n5 (5nm) built: 2022+ pcie: gen: 4 speed: 16 GT/s lanes: 16
    ports: active: DP-2,HDMI-A-2 empty: DP-1,HDMI-A-1,Writeback-1
    bus-ID: 0c:00.0 chip-ID: 1002:747e class-ID: 0300
  Device-2: Logitech Brio 100 driver: snd-usb-audio,uvcvideo type: USB
    rev: 2.0 speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 1-1:2 chip-ID: 046d:094c
    class-ID: 0102 serial: <filter>
    compositor: kwin_wayland driver: X: loaded: amdgpu
    gpu: amdgpu d-rect: 4480x2520 display-ID: 0
  Monitor-1: DP-2 pos: top-right model: Gigabyte M27Q X serial: <filter>
    built: 2022 res: mode: 2560x1440 hz: 240 scale: 100% (1) dpi: 109 gamma: 1.2
    size: 596x335mm (23.46x13.19") diag: 684mm (26.9") ratio: 16:9 modes:
    max: 2560x1440 min: 640x480
  Monitor-2: HDMI-A-2 pos: bottom-l model: BenQ RL2455 serial: <filter>
    built: 2015 res: mode: 1920x1080 hz: 60 scale: 100% (1) dpi: 92 gamma: 1.2
    size: 531x298mm (20.91x11.73") diag: 609mm (24") ratio: 16:9 modes:
    max: 1920x1080 min: 720x400
  API: OpenGL v: 4.6 compat-v: 4.5 vendor: amd mesa v: 25.0.3-arch1.1
    glx-v: 1.4 direct-render: yes renderer: AMD Radeon RX 7800 XT (radeonsi
    navi32 LLVM 19.1.7 DRM 3.61 6.12.21-4-MANJARO) device-ID: 1002:747e
    memory: 15.62 GiB unified: no display-ID: :1.0
  API: Vulkan v: 1.4.309 layers: 14 device: 0 type: discrete-gpu name: AMD
    Radeon RX 7800 XT (RADV NAVI32) driver: mesa radv v: 25.0.3-arch1.1
    device-ID: 1002:747e surfaces: xcb,xlib,wayland
    de: kscreen-console,kscreen-doctor gpu: amdgpu_top,radeontop
    wl: wayland-info,wlr-randr x11: xdpyinfo, xprop, xrandr
  Device-1: Advanced Micro Devices [AMD/ATI] Navi 31 HDMI/DP Audio
    bus-ID: 0c:00.1 chip-ID: 1002:ab30 class-ID: 0403
    vendor: Gigabyte driver: snd_hda_intel v: kernel pcie: gen: 4 speed: 16 GT/s
    lanes: 16 bus-ID: 0e:00.4 chip-ID: 1022:1487 class-ID: 0403
  Device-3: Logitech Brio 100 driver: snd-usb-audio,uvcvideo type: USB
  Device-4: Audio-Technica AT2020USB+
    driver: hid-generic,snd-usb-audio,usbhid type: USB rev: 1.1 speed: 12 Mb/s
    lanes: 1 mode: 1.1 bus-ID: 5-4:4 chip-ID: 0909:001c class-ID: 0300
  API: ALSA v: k6.12.21-4-MANJARO status: kernel-api with: aoss
  Server-3: PipeWire v: 1.4.1 status: active with: 1: pipewire-pulse
  Device-1: Intel Ethernet 10-Gigabit X540-AT2 driver: ixgbe v: kernel pcie:
    gen: 2 speed: 5 GT/s lanes: 4 link-max: lanes: 8 port: N/A bus-ID: 05:00.0
    chip-ID: 8086:1528 class-ID: 0200
  IF: enp5s0f0 state: down mac: <filter>
  Device-2: Intel Ethernet 10-Gigabit X540-AT2 driver: ixgbe v: kernel pcie:
    gen: 2 speed: 5 GT/s lanes: 4 link-max: lanes: 8 port: N/A bus-ID: 05:00.1
  IF: enp5s0f1 state: up speed: 10000 Mbps duplex: full mac: <filter>
  Device-3: Intel I211 Gigabit Network vendor: Gigabyte driver: igb v: kernel
    pcie: gen: 1 speed: 2.5 GT/s lanes: 1 port: f000 bus-ID: 06:00.0
  IF: enp6s0 state: down mac: <filter>
  IF-ID-1: mullvpn state: unknown speed: 10000 Mbps duplex: full mac: N/A
  Device-1: TP-Link UB500 Adapter driver: btusb v: 0.8 type: USB rev: 1.1
    speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 3-4:2 chip-ID: 2357:0604
  Report: btmgmt ID: hci0 rfk-id: 0 state: up address: <filter> bt-v: 5.1
    lmp-v: 10 status: discoverable: no pairing: no class-ID: 6c0104
  Local Storage: total: 6.37 TiB used: 1.71 TiB (26.9%)
  ID-1: /dev/nvme0n1 maj-min: 259:5 vendor: Samsung
    model: SSD 970 EVO Plus 2TB size: 1.82 TiB block-size: physical: 512 B
    fw-rev: 2B2QEXM7 temp: 48.9 C scheme: GPT
  ID-2: /dev/nvme1n1 maj-min: 259:0 vendor: Samsung model: SSD 980 PRO with
    Heatsink 2TB size: 1.82 TiB block-size: physical: 512 B logical: 512 B
    speed: 63.2 Gb/s lanes: 4 tech: SSD serial: <filter> fw-rev: 5B2QGXA7
    temp: 51.9 C scheme: GPT
  ID-3: /dev/sda maj-min: 8:0 vendor: Samsung model: SSD 860 EVO 1TB
    tech: SSD serial: <filter> fw-rev: 4B6Q scheme: GPT
  ID-4: /dev/sdb maj-min: 8:16 vendor: Seagate model: ST2000DM008-2FR102
    tech: HDD rpm: 7200 serial: <filter> fw-rev: 0001 scheme: GPT
  ID-1: / raw-size: 1.82 TiB size: 1.79 TiB (98.37%) used: 655.02 GiB (35.7%)
    fs: ext4 dev: /dev/nvme0n1p2 maj-min: 259:7
    used: 316 KiB (0.1%) fs: vfat dev: /dev/nvme0n1p1 maj-min: 259:6
  System Temperatures: cpu: 50.0 C mobo: 36.0 C gpu: amdgpu temp: 64.0 C
    mem: 64.0 C
  Fan Speeds (rpm): N/A gpu: amdgpu fan: 512
  Memory: total: 32 GiB available: 31.26 GiB used: 8.31 GiB (26.6%)
  Processes: 374 Power: uptime: 10h 57m states: freeze,mem,disk suspend: deep
    suspend, test_resume image: 12.49 GiB services: org_kde_powerdevil,
    tool: systemctl
  Packages: 2358 pm: dpkg pkgs: 0 pm: pacman pkgs: 2323 libs: 554
    tools: pamac,yay pm: rpm pkgs: 0 pm: flatpak pkgs: 35 Compilers:
    clang: 19.1.7 gcc: 14.2.1 Shell: Zsh v: 5.9 default: Bash v: 5.2.37
    running-in: konsole inxi: 3.3.38
Well, I guess no one has a solution. I guess I will reinstall Manjaro, hopefully that will fix it
You can try that. but I notice you didn’t give anyone much time to respond to your initial post.
Both your posts are from the 27th of April.
It’s worth keeping a Terminal window open running
watch -n30 free -h
N.B. The number is in seconds, set it to something more suitable if you want.
You could use Yakuake for this (F12 to reveal or hide this handy drop-down terminal). I believe this is installed by default with a full Manjaro .ISO, but I could be wrong there.
This will let you keep an eye on RAM usage. :eyes:
You have no swap set up, so if your memory gets too full it will cause issues like this.
Maybe my case is different, but my Manjaro Sway edition has had random freezes since the 2025-04-12 stable update.
I suspect AMD CPU and maybe systemd…
As a workaround, I added processor.max_cstate=0 to the kernel parameter.
Now my system is relatively stable.
I will try to keep a terminal window, maybe that will give me more clues for the problem, and I will try adding this processor.max_cstate=0 to the kernel parameter as aki42 suggested
Thank you for the help
I might be wrong; it’s been a full day since I started this thread, and when I sent the reply. I guess I don’t know much about this forum, as I thought this thread had already been buried. I guess I was wrong. Next time, I will be more patient.
It used to be, but I believe it has no longer been included by default in the KDE Plasma ISOs for a while now.
Still, it’s a great little tool, and in my personal opinion, a must-have. And for good measure, one should have it auto-started upon login too. :wink:
You have to keep in mind that this is a worldwide community of unpaid volunteers. This means that we’re all in different time zones, and that we all tend to the forum depending on the time life avails us. :wink:
It’s installed in the latest Zetar ISO, but has to be manually activated or set-up to auto start.
Probably this seems to be bug with mesa and amd graphics.
I have same problems with my Ryzen 5 machine.
It has been fixed in arch linux, but bug seems to be in manjaro.
https://bbs.archlinux.org/viewtopic.php?id=301798&p=29
Maybe its this bug here?
https://bugs.kde.org/show_bug.cgi?id=500951
I have the same issue and im waiting for DDCUTIL to be updated in manjaro…
