I was rebooting my computer when it got stuck on lock screen even when I am putting right password it look like it going to unlock but then I am again on the same lock screen. I have rebooted many times but it’s the same problem. Can anyone help me with this.
Below is the image of me running journalctl to see the error logs.
Here some code errors logs
Sep 09 13:29:09 bibek-hplaptop systemd[1]: Started Getty on tty6.
Sep 09 13:29:16 bibek-hplaptop lightdm[1580]: pam_unix(lightdm:auth): authentication failure; logname= uid=0 euid=0 tty=:0 ruser= rhost= user=bibek
Sep 09 13:29:18 bibek-hplaptop dbus-daemon[718]: [system] Activating via systemd: service name='org.freedesktop.home1' unit='dbus-org.freedesktop.home1.service' requested by ':1.47' (uid=0 pid=2134 comm="lightdm --session-child 12 20")
Sep 09 13:29:18 bibek-hplaptop dbus-daemon[718]: [system] Activation via systemd failed for unit 'dbus-org.freedesktop.home1.service': Unit dbus-org.freedesktop.home1.service not found.
Sep 09 13:29:22 bibek-hplaptop lightdm[2134]: gkr-pam: unable to locate daemon control file
Sep 09 13:29:22 bibek-hplaptop lightdm[2134]: gkr-pam: stashed password to try later in open session
Sep 09 13:29:22 bibek-hplaptop systemd[1]: Stopping Session c2 of User lightdm...
Sep 09 13:29:22 bibek-hplaptop lightdm[1560]: pam_unix(lightdm-greeter:session): session closed for user lightdm
Sep 09 13:29:22 bibek-hplaptop systemd[1]: session-c2.scope: Deactivated successfully.
Sep 09 13:29:22 bibek-hplaptop systemd[1]: Stopped Session c2 of User lightdm.
Sep 09 13:29:22 bibek-hplaptop systemd[1]: session-c2.scope: Consumed 2.932s CPU time.
Sep 09 13:29:22 bibek-hplaptop lightdm[2134]: pam_unix(lightdm:session): session opened for user bibek(uid=1000) by bibek(uid=0)
Sep 09 13:29:22 bibek-hplaptop systemd-logind[722]: Removed session c2.
Sep 09 13:29:22 bibek-hplaptop systemd-logind[722]: New session 6 of user bibek.
Sep 09 13:29:22 bibek-hplaptop systemd[1]: Started Session 6 of User bibek.
Sep 09 13:29:22 bibek-hplaptop systemd[1587]: Started GNOME Keyring daemon.
Sep 09 13:29:22 bibek-hplaptop systemd[1587]: Created slice User Core Session Slice.
Sep 09 13:29:22 bibek-hplaptop lightdm[2134]: Error writing X authority: Failed to open X authority /home/bibek/.Xauthority: Permission denied
Sep 09 13:29:22 bibek-hplaptop gnome-keyring-daemon[2141]: keyring was in an invalid or unrecognized format: /home/bibek/.local/share/keyrings/default.keyring
Sep 09 13:29:22 bibek-hplaptop systemd[1587]: Starting D-Bus User Message Bus...
Sep 09 13:29:22 bibek-hplaptop gnome-keyring-daemon[2141]: GNOME_KEYRING_CONTROL=/run/user/1000/keyring
Sep 09 13:29:22 bibek-hplaptop lightdm[2134]: gkr-pam: unlocked login keyring
Sep 09 13:29:22 bibek-hplaptop systemd[1587]: Started D-Bus User Message Bus.
Sep 09 13:29:22 bibek-hplaptop gnome-keyring-d[2141]: keyring was in an invalid or unrecognized format: /home/bibek/.local/share/keyrings/default.keyring
Sep 09 13:29:22 bibek-hplaptop lightdm[2134]: Error reading existing Xauthority: Failed to open file “/home/bibek/.Xauthority”: Permission denied
Sep 09 13:29:22 bibek-hplaptop systemd[1]: session-6.scope: Deactivated successfully.
Sep 09 13:29:22 bibek-hplaptop systemd-logind[722]: Session 6 logged out. Waiting for processes to exit.
Sep 09 13:29:22 bibek-hplaptop systemd-logind[722]: Removed session 6.
Sep 09 13:29:24 bibek-hplaptop lightdm[2165]: pam_unix(lightdm-greeter:session): session opened for user lightdm(uid=966) by (uid=0)
Sep 09 13:29:24 bibek-hplaptop systemd-logind[722]: New session c3 of user lightdm.
Sep 09 13:29:24 bibek-hplaptop systemd[1]: Started Session c3 of User lightdm.
Sep 09 13:29:26 bibek-hplaptop dbus-daemon[718]: [system] Activating via systemd: service name='org.freedesktop.home1' unit='dbus-org.freedesktop.home1.service' requested by ':1.56' (uid=0 pid=2185 comm="lightdm --session-child 13 20")
Sep 09 13:29:26 bibek-hplaptop dbus-daemon[718]: [system] Activation via systemd failed for unit 'dbus-org.freedesktop.home1.service': Unit dbus-org.freedesktop.home1.service not found.
Sep 09 13:29:30 bibek-hplaptop systemd[1]: Started Getty on tty5.
Sep 09 13:29:36 bibek-hplaptop dbus-daemon[718]: [system] Activating via systemd: service name='org.freedesktop.home1' unit='dbus-org.freedesktop.home1.service' requested by ':1.57' (uid=0 pid=2188 comm="/bin/login -p -- ")
Sep 09 13:29:36 bibek-hplaptop dbus-daemon[718]: [system] Activation via systemd failed for unit 'dbus-org.freedesktop.home1.service': Unit dbus-org.freedesktop.home1.service not found.
Sep 09 13:29:38 bibek-hplaptop login[2188]: pam_unix(login:session): session opened for user bibek(uid=1000) by bibek(uid=0)
Sep 09 13:29:38 bibek-hplaptop systemd-logind[722]: New session 7 of user bibek.
Sep 09 13:29:38 bibek-hplaptop systemd[1]: Started Session 7 of User bibek.
Sep 09 13:29:38 bibek-hplaptop login[2188]: LOGIN ON tty5 BY bibek
