I already have this problem, and “resolve it” using the timeshift backup on another directory different than the root directory. But now the PC doesn’t shutdown or reboot from the menu. I know the PC is on because all my fans are still operating and other parts of MOBO are still on. The only way to shutdown is to hold the power button, but even that doesn’t shutdown at all. This only occurs using Manjaro KDE.
More info:
inxi --full --verbosity=7 --filter --no-host
Kernel: 5.15.59-1-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 12.1.1
Desktop: KDE Plasma v: 5.24.6 tk: Qt v: 5.15.5 wm: kwin_x11 vt: 1 dm: SDDM
Type: Desktop System: Gigabyte product: B450 AORUS PRO v: N/A
serial: <superuser required>
Mobo: Gigabyte model: B450 AORUS PRO-CF serial: <superuser required>
UEFI: American Megatrends LLC. v: F62 date: 01/24/2022
Device-1: hidpp_battery_0 model: Logitech Wireless Keyboard
status: discharging
RAM: total: 15.54 GiB used: 6.5 GiB (41.8%)
RAM Report: permissions: Unable to run dmidecode. Root privileges
required.
Info: 8-core model: AMD Ryzen 7 5800X bits: 64 type: MT MCP smt: enabled
arch: Zen 3 rev: 0 cache: L1: 512 KiB L2: 4 MiB L3: 32 MiB
Speed (MHz): avg: 3273 high: 3820 min/max: 2200/4850 boost: enabled
cores: 1: 3598 2: 3094 3: 2872 4: 3598 5: 2871 6: 3598 7: 2879 8: 3600
9: 3596 10: 2880 11: 3033 12: 3820 13: 2869 14: 3598 15: 2877 16: 3598
bogomips: 121659
cqm_occup_llc cr8_legacy cx16 cx8 de decodeassists erms extapic
extd_apicid f16c flushbyasid fma fpu fsgsbase fsrm fxsr fxsr_opt ht
hw_pstate ibpb ibrs ibs invpcid irperf lahf_lm lbrv lm mba mca mce
v_spec_ctrl v_vmsave_vmload vaes vgif vmcb_clean vme vmmcall vpclmulqdq
wbnoinvd wdt x2apic xgetbv1 xsave xsavec xsaveerptr xsaveopt xsaves
Device-1: AMD Navi 23 [Radeon RX 6600/6600 XT/6600M] vendor: Sapphire
driver: amdgpu v: kernel arch: RDNA-2 pcie: speed: 16 GT/s lanes: 16 ports:
active: DP-3 empty: DP-1,DP-2,HDMI-A-1 bus-ID: 08:00.0 chip-ID: 1002:73ff
class-ID: 0300
Display: x11 server: X.Org v: 21.1.4 compositor: kwin_x11 driver: X:
loaded: amdgpu unloaded: modesetting,radeon alternate: fbdev,vesa
gpu: amdgpu display-ID: :0 screens: 1
s-diag: 582mm (22.93")
Monitor-1: DP-3 mapped: DisplayPort-2 model: OZDSP25FHD serial: <filter>
res: 1920x1080 dpi: 82 size: 597x336mm (23.5x13.23") diag: 685mm (27")
modes: max: 1920x1080 min: 720x400
OpenGL: renderer: AMD Radeon RX 6600 XT (dimgrey_cavefish LLVM 14.0.6 DRM
3.42 5.15.59-1-MANJARO) v: 4.6 Mesa 22.1.4 direct render: Yes
Device-1: AMD Navi 21/23 HDMI/DP Audio driver: snd_hda_intel v: kernel
pcie: speed: 16 GT/s lanes: 16 bus-ID: 08:00.1 chip-ID: 1002:ab28
class-ID: 0403
Device-2: AMD Starship/Matisse HD Audio vendor: Gigabyte
driver: snd_hda_intel v: kernel pcie: speed: 16 GT/s lanes: 16
bus-ID: 0a:00.4 chip-ID: 1022:1487 class-ID: 0403
Sound Server-1: ALSA v: k5.15.59-1-MANJARO running: yes
Sound Server-3: JACK v: 1.9.21 running: no
Sound Server-4: PulseAudio v: 16.1 running: yes
Sound Server-5: PipeWire v: 0.3.56 running: yes
Device-1: Intel I211 Gigabit Network vendor: Gigabyte driver: igb v: kernel
pcie: speed: 2.5 GT/s lanes: 1 port: f000 bus-ID: 03:00.0
Local Storage: total: 2.71 TiB used: 440.72 GiB (15.9%)
ID-1: /dev/sda vendor: Western Digital model: WD20EZAZ-00GGJB0
size: 1.82 TiB speed: 6.0 Gb/s type: HDD rpm: 5400 serial: <filter>
rev: 0A80 scheme: GPT
ID-2: /dev/sdb vendor: Crucial model: CT480BX500SSD1 size: 447.13 GiB
speed: 6.0 Gb/s type: SSD serial: <filter> rev: 054 scheme: GPT
ID-3: /dev/sdc vendor: Crucial model: CT500MX500SSD4 size: 465.76 GiB
speed: 6.0 Gb/s type: SSD serial: <filter> rev: 023 scheme: GPT
ID-1: / size: 457.09 GiB used: 41.74 GiB (9.1%) fs: ext4 dev: /dev/sdc2
label: N/A uuid: c6d34794-1652-46f8-86db-36042f6189a3
ID-2: /boot/efi size: 299.4 MiB used: 312 KiB (0.1%) fs: vfat
dev: /dev/sdc1 label: NO_LABEL uuid: D3D3-B757
ID-3: /run/media/guilhermebc/Arquivos size: 1.82 TiB used: 248.59 GiB
(13.3%) fs: btrfs dev: /dev/sda1 label: Arquivos
uuid: 18f299b3-ebd7-490a-a835-6b678aed2635
ID-4: /run/media/guilhermebc/Jogos e aplicativos size: 447.13 GiB
used: 150.39 GiB (33.6%) fs: btrfs dev: /dev/sdb1 label: Jogos e
aplicativos uuid: a0e4d1fe-c61c-4aa7-98af-67ef59f17d08
Hub-1: 1-0:1 info: Hi-speed hub with single TT ports: 10 rev: 2.0
Device-1: 1-4:2 info: Logitech Unifying Receiver type: Keyboard,Mouse
driver: logitech-djreceiver,usbhid interfaces: 2 rev: 2.0 speed: 12 Mb/s
power: 98mA chip-ID: 046d:c534 class-ID: 0301
Device-2: 1-9:3 info: Sunplus Innovation HID Gaming Mouse
type: Mouse,Keyboard driver: hid-generic,usbhid interfaces: 2 rev: 2.0
speed: 12 Mb/s power: 500mA chip-ID: 1bcf:08b8 class-ID: 0300
Device-3: 1-10:4 info: Logitech F310 Gamepad [XInput Mode]
type: <vendor specific> driver: xpad interfaces: 1 rev: 2.0 speed: 12 Mb/s
power: 500mA chip-ID: 046d:c21d class-ID: ff00 serial: <filter>
Hub-2: 2-0:1 info: Super-speed hub ports: 4 rev: 3.1 speed: 10 Gb/s
Hub-3: 3-0:1 info: Hi-speed hub with single TT ports: 4 rev: 2.0
Hub-4: 4-0:1 info: Super-speed hub ports: 4 rev: 3.1 speed: 10 Gb/s
System Temperatures: cpu: 44.9 C mobo: N/A gpu: amdgpu temp: 57.0 C
mem: 60.0 C
Fan Speeds (RPM): N/A gpu: amdgpu fan: 0
Processes: 430 Uptime: 8h 37m wakeups: 22 Init: systemd v: 251
default: graphical Compilers: gcc: 12.1.1 clang: 14.0.6 Packages: 1688
pacman: 1678 flatpak: 10 Shell: Zsh v: 5.9 default: Bash v: 5.1.16
running-in: konsole inxi: 3.3.20
journalctl -p3 -b -1
1 ✘
ago 10 23:23:27 guilherme-b450aoruspro systemd[741]: Failed to start Update XDG user dir configuration.
ago 10 23:23:30 guilherme-b450aoruspro kernel: [drm:dc_dmub_srv_wait_idle [amdgpu]] *ERROR* Error waiting for DMUB idle: status=3
journalctl -p2 -b -0 ✔
ago 11 10:14:47 guilherme-b450aoruspro systemd-coredump[7502]: [🡕] Process 3576 (chrome) of user 1000 dumped core.
Module linux-vdso.so.1 with build-id 88563aa79dfc408a2e7f0b40fd711c0b4785d93b
Module librt.so.1 with build-id 6c2560cb8cee7be4d9571d9ba46e875b1c9070cd
Module libwidevinecdm.so with build-id e8b384278b62d82722bb2599c02fca53af063083
Module libgpg-error.so.0 with build-id 4738b8a9478177c202cccd64e0eb65d3dea2bfae
Module libbrotlicommon.so.1 with build-id acfd597a977c8087bb6184383daae2e828a9ce42
Module libbz2.so.1.0 with build-id 919597c477c9b2cb9cdbb7745ed6494ac0e6da60
Module libgraphite2.so.3 with build-id ce58945ebb55b86d3a4e717b6eae29efc4720d8e
Module libdatrie.so.1 with build-id 6fe3b6ece2c8e7d11869fa051375128d8f808f58
Module liblz4.so.1 with build-id e63600ab23b2f6997f42fac2fa56e1f02ce159a1
Module liblzma.so.5 with build-id 28b40c7af8098a66af6ee093b6986b91cad7694d
Module libgcrypt.so.20 with build-id 8bf3cb884124273640de797a3e77d86c98434ea4
Module libcap.so.2 with build-id 1f87347b85b55db2f75a2ecea5cb45d846dc7093
Module libblkid.so.1 with build-id 140694a62d8d4d07c6c320a501f948dd1b389d73
Module libgmp.so.10 with build-id 26cec2ebe94cc5c4cb99e6988717347222b324fd
Module libhogweed.so.6 with build-id 9577a5fe1921756af97b2af318ff1c9a03f10a84
Module libnettle.so.8 with build-id a2cc6a257b0729585e870b345b83497c478ee28b
Module libtasn1.so.6 with build-id ee3429ca5e94718aea4fe5249fc859e0cd88e4e9
Module libunistring.so.2 with build-id 617dbf3d3d6f85d6556a7a036e23845e95490158
Module libidn2.so.0 with build-id b16e7570b102789b13ff77289762dbfe3f8f46bc
Module libzstd.so.1 with build-id ab54c2881f53ab314e134f3e08c76d504376dd5d
Module libbrotlidec.so.1 with build-id 66c54e9301f7e102ecc1d88547e5f0e8a056fe22
Module libbrotlienc.so.1 with build-id 74adbc62e4fbb5da9d37b5aa458471f4130862ff
Module libp11-kit.so.0 with build-id cc372ea3c28c4d3dfc633b4d2e933c8584d2af16
Module libXi.so.6 with build-id 16603be937a02a7e61b0b0395d064be7efd86f49
Module libpixman-1.so.0 with build-id d2170a3ac106c2a68597bf7910ab04b1cdd69c14
Module libxcb-shm.so.0 with build-id 828fec4d856e2710e732ea8d92c3f250c807b1c2
Module libxcb-render.so.0 with build-id b1ca498d665807ab0ccdafbe8070853efd058173
Module libfreetype.so.6 with build-id f89dd5502e75aca28fb5c3ccd0dbd26fe822bfef
Module libfontconfig.so.1 with build-id 36be6951b8c1e42a7dd05684a37400fc8ef9147c
Module libpng16.so.16 with build-id 2dc0bce07f199bf983c07a05fb95a6f4af83a9b3
Module libharfbuzz.so.0 with build-id 236ab65053439e673a39fcb7aadedb28b17a338a
Module libthai.so.0 with build-id a7ac5010b4275c49308021200d23690533952702
Module libfribidi.so.0 with build-id fe9f35ac2a0074108c8306c517793f7279bd9b37
Module libXdmcp.so.6 with build-id d864159ab0008415667db8d5f251696d75c90df2
Module libXau.so.6 with build-id 60db1eac70f819bea9d4c366603c1583067510b4
Module libwayland-server.so.0 with build-id 4c54fc8a7c0d4eb8adf2a69e44ebf12d16969c74
Module libXrender.so.1 with build-id 42e386d2acf3cde61081959d9671ca74acfb3edc
Module libsystemd.so.0 with build-id 761a39da56f185d6f1ef6f7bb95a3299789eb3e2
Module libmount.so.1 with build-id 4436aeea0cd8c01b5a77969e0531184f8b3513ce
Module libgmodule-2.0.so.0 with build-id abd986222e2cf12fc7324cb0182dfc2c8f2269c0
Module libz.so.1 with build-id fefe3219a96d682ec98fcfb78866b8594298b5a2
Module libgnutls.so.30 with build-id a4f42d33fc809cb6f596998001cedc0bce06c751
Module libavahi-client.so.3 with build-id 1858551543958190c653b565cf0eb64609ad908a
Module libavahi-common.so.3 with build-id 80fda945459a3476ccd1050783dfd5f5c17c479a
Module libplc4.so with build-id 2f3f90e73b1f4fc3424689615d6d32f7427bb783
Module libplds4.so with build-id 2b49ec2f43d2e5fc2e56f35bcd094968f9bf36e6
Module libpcre.so.1 with build-id 845483dd0acba86de9f0313102bebbaf3ce52767
Module libffi.so.8 with build-id f0a9586cf0f42d2b9971bd1065ca3a6b19f4a2c2
Module ld-linux-x86-64.so.2 with build-id 8dac9e5903543a5f8a5f7339139c14444b9b4e0e
Module libc.so.6 with build-id e637217a46491314667a7a37b2155cb07afc1a40
Module libgcc_s.so.1 with build-id 308aed8b7d7e38f5efa23f75c25601668c1fc009
Module libatspi.so.0 with build-id 87bca381f073faea3b0ffd1ab06f5f8f204e24cf
Module libasound.so.2 with build-id aefb908044b1b408df406f1a9bab9bba486c0e94
Module libcairo.so.2 with build-id a222d042e56108d2786ece7bf291b56ba2069591
Module libpango-1.0.so.0 with build-id b358a862a5ca8b1e4e69235edce1780e9f860a0a
Module libxkbcommon.so.0 with build-id 6cf66eead3fcc20fe5df10162bfbcdcdc8b2a183
Module libxcb.so.1 with build-id 13d677412a71468381b11092915d231f664d18d3
Module libgbm.so.1 with build-id 589489ebc39c7c4de46d25028fd54896e0da464d
Module libXrandr.so.2 with build-id 154e55f082ee9e685d0794c98c5b76ffe9c8868e
Module libXfixes.so.3 with build-id 0a05c7e8714522bfbdd7c0027c3e2a94965664b0
Module libXext.so.6 with build-id 17beadf1cb40d41ab36629db3b4eed74110678a7
Module libXdamage.so.1 with build-id a99dbe3fc2b01da9fbdd90d5ad00621f9022379f
Module libXcomposite.so.1 with build-id 13228d108b290268d88510db494daefd5521cda0
Module libX11.so.6 with build-id 21e886e968772b7964d646f54c1faecc56734de9
Module libm.so.6 with build-id 598f2cb2b61d6ba52686c3d0d380daea7e55e97c
Module libexpat.so.1 with build-id 113bb5a3e9ad856801bfcfc029102c9bdc13d67e
Module libdbus-1.so.3 with build-id 7f4b16b4b407cbae2d7118d6f99610e29a18a56a
Module libdrm.so.2 with build-id 39847bc84bc769f632f8f599a62fdcc98c9270cd
Module libgio-2.0.so.0 with build-id 7a769ec24a9a705d04ee0297730032f70ed0835b
Module libcups.so.2 with build-id 62620e2ba8de0b241ddcde466d8355ac8a37b41b
Module libatk-bridge-2.0.so.0 with build-id 1161ebbcc5aa791075dfa026671875e5417287bd
Module libatk-1.0.so.0 with build-id c2de8b4fcbd9681cef225fe3956a9608a2a664bb
Module libnspr4.so with build-id e54087b0e38cf8936f6c458e922589406343b05d
Module libsmime3.so with build-id e80b1eacbb0979a1355fd008847c6eef060e83e3
Module libnssutil3.so with build-id 36c34a5ab8de68047e7886fe56da7ccf6722f465
Module libnss3.so with build-id 87abb242025e6e243d6974b3a9da26166884533a
Module libglib-2.0.so.0 with build-id 1340f3a762b2293ebf6d725edf0eb14839f85317
Module libgobject-2.0.so.0 with build-id a7515bd8cd51064d187953c0f506a43958de31a6
Module libpthread.so.0 with build-id beb247374758b5c4cdc7a45b934fff02bfd90a71
Module libdl.so.2 with build-id 7a21bd4abe98057a730df3fcdea5099251e0d1e0
Module chrome with build-id a9188c3c983f51290f57c6415704f2957be4c934
Stack trace of thread 1:
#0 0x00005608df1c3488 n/a (chrome + 0x27ab488)
#1 0x00005608df1ddd6a n/a (chrome + 0x27c5d6a)
#2 0x00005608df1d955f n/a (chrome + 0x27c155f)
#3 0x00005608df1d11a9 n/a (chrome + 0x27b91a9)
#4 0x00005608df1c10d2 n/a (chrome + 0x27a90d2)
#5 0x00005608df1bfd5a n/a (chrome + 0x27a7d5a)
#6 0x00005608df584b43 n/a (chrome + 0x2b6cb43)
#7 0x00005608df583288 n/a (chrome + 0x2b6b288)
#8 0x00005608df582f29 n/a (chrome + 0x2b6af29)
#9 0x00005608e0382f5a n/a (chrome + 0x396af5a)
#10 0x00005608e3d43a42 n/a (chrome + 0x732ba42)
#11 0x00005608e3d43855 n/a (chrome + 0x732b855)
#12 0x00005608e3d3a294 n/a (chrome + 0x7322294)
#13 0x00005608e3d65fba n/a (chrome + 0x734dfba)
#14 0x00005608e3d65a8b n/a (chrome + 0x734da8b)
#15 0x00005608e3d6458d n/a (chrome + 0x734c58d)
#16 0x00005608e3d6442a n/a (chrome + 0x734c42a)
#17 0x00005608e1534752 n/a (chrome + 0x4b1c752)
#18 0x00005608e3d6b933 n/a (chrome + 0x7353933)
#19 0x00005608e3d63382 n/a (chrome + 0x734b382)
#20 0x00005608e3d4ed10 n/a (chrome + 0x7336d10)
#21 0x00005608e3d4e915 n/a (chrome + 0x7336915)
#22 0x00005608e7165b12 n/a (chrome + 0xa74db12)
#23 0x00005608e4496131 n/a (chrome + 0x7a7e131)
#24 0x00005608ded39bc0 n/a (chrome + 0x2321bc0)
#25 0x00005608ded386e5 n/a (chrome + 0x23206e5)
#26 0x00005608e155796e n/a (chrome + 0x4b3f96e)
#27 0x00005608e0573ea8 n/a (chrome + 0x3b5bea8)
#28 0x00005608e057354e n/a (chrome + 0x3b5b54e)
#29 0x00005608dee8e9ff n/a (chrome + 0x24769ff)
#30 0x00005608e0574e80 n/a (chrome + 0x3b5ce80)
#31 0x00005608e0322b92 n/a (chrome + 0x390ab92)
#32 0x00005608e0320238 ChromeMain (chrome + 0x3908238)
#33 0x00007f5c51c872d0 n/a (libc.so.6 + 0x232d0)
#34 0x00007f5c51c8738a __libc_start_main (libc.so.6 + 0x2338a)
#35 0x00005608e1706c6a _start (chrome + 0x4ceec6a)
Stack trace of thread 2:
#0 0x00007f5c51d6bd06 epoll_wait (libc.so.6 + 0x107d06)
#1 0x00005608ded5124a n/a (chrome + 0x233924a)
#2 0x00005608e02bbd1b n/a (chrome + 0x38a3d1b)
#3 0x00005608e02bb9e3 n/a (chrome + 0x38a39e3)
#4 0x00005608e0573ea8 n/a (chrome + 0x3b5bea8)
#5 0x00005608e057354e n/a (chrome + 0x3b5b54e)
#6 0x00005608e0573398 n/a (chrome + 0x3b5b398)
#7 0x00005608e057333d n/a (chrome + 0x3b5b33d)
#8 0x00005608e040e9d6 n/a (chrome + 0x39f69d6)
#9 0x00005608e028dea3 n/a (chrome + 0x3875ea3)
#10 0x00007f5c51cea78d n/a (libc.so.6 + 0x8678d)
#11 0x00007f5c51d6b8e4 __clone (libc.so.6 + 0x1078e4)
Stack trace of thread 10:
#0 0x00007f5c51ce7346 n/a (libc.so.6 + 0x83346)
#1 0x00007f5c51ce9b60 pthread_cond_wait (libc.so.6 + 0x85b60)
#2 0x00005608decf64d8 n/a (chrome + 0x22de4d8)
#3 0x00005608e028dea3 n/a (chrome + 0x3875ea3)
#4 0x00007f5c51cea78d n/a (libc.so.6 + 0x8678d)
#5 0x00007f5c51d6b8e4 __clone (libc.so.6 + 0x1078e4)
Stack trace of thread 4:
#7 0x00005608e164bf52 n/a (chrome + 0x4c33f52)
Stack trace of thread 9:
Stack trace of thread 6:
#2 0x00005608deefab47 n/a (chrome + 0x24e2b47)
#3 0x00005608df8c206e n/a (chrome + 0x2eaa06e)
#4 0x00005608e15579da n/a (chrome + 0x4b3f9da)
#5 0x00005608e0573ea8 n/a (chrome + 0x3b5bea8)
#6 0x00005608e057354e n/a (chrome + 0x3b5b54e)
#7 0x00005608e0573398 n/a (chrome + 0x3b5b398)
Stack trace of thread 11:
Stack trace of thread 13:
Stack trace of thread 7:
#7 0x00005608e0b20f26 n/a (chrome + 0x4108f26)
#8 0x00005608e028dea3 n/a (chrome + 0x3875ea3)
#9 0x00007f5c51cea78d n/a (libc.so.6 + 0x8678d)
#10 0x00007f5c51d6b8e4 __clone (libc.so.6 + 0x1078e4)
Stack trace of thread 8:
#3 0x00005608deef9c45 n/a (chrome + 0x24e1c45)
#4 0x00005608deef999d n/a (chrome + 0x24e199d)
#5 0x00005608e028dea3 n/a (chrome + 0x3875ea3)
#6 0x00007f5c51cea78d n/a (libc.so.6 + 0x8678d)
#7 0x00007f5c51d6b8e4 __clone (libc.so.6 + 0x1078e4)
Stack trace of thread 23:
#1 0x00007f5c51ce9e64 pthread_cond_timedwait (libc.so.6 + 0x85e64)
#2 0x00005608deefb160 n/a (chrome + 0x24e3160)
#3 0x00005608deefaad2 n/a (chrome + 0x24e2ad2)
#4 0x00005608deefa195 n/a (chrome + 0x24e2195)
#5 0x00005608deef996d n/a (chrome + 0x24e196d)
#6 0x00005608e028dea3 n/a (chrome + 0x3875ea3)
#7 0x00007f5c51cea78d n/a (libc.so.6 + 0x8678d)
#8 0x00007f5c51d6b8e4 __clone (libc.so.6 + 0x1078e4)
Stack trace of thread 12:
Stack trace of thread 17:
Stack trace of thread 24:
#4 0x00005608deefa137 n/a (chrome + 0x24e2137)
Stack trace of thread 26:
Stack trace of thread 33:
Stack trace of thread 28:
Stack trace of thread 22:
Stack trace of thread 25:
Stack trace of thread 30:
Stack trace of thread 31:
Stack trace of thread 27:
