Months of tinkering and trying to fix bootloader have took it’s toll. I am not sure I can fix bootloader alone. Please help!
Requirement:
To be able to get two bootloader options: 1). Manjaro 2). Windows
Currently have Manjaro and Windows installed in two different partitions on my SSD.
Disks are in uefi + gpt.
Manjaro is installed in sda5 and Windows is installed in sda4.
Tried following this wiki, but somehow made it worse (previously I was able to boot in Manjaro, but not even that is gone, and it reaches grub emergency mode).
lsblk output:
$ lsblk -o PATH,PTTYPE,PARTTYPE,FSTYPE,PARTTYPENAME
PATH PTTYPE PARTTYPE FSTYPE PARTTYPENAME
/dev/loop0 squashfs
/dev/loop1 squashfs
/dev/loop2 squashfs
/dev/loop3 squashfs
/dev/sda gpt
/dev/sda1 gpt de94bba4-06d1-4d40-a16a-bfd50179d6ac ntfs Windows recovery environment
/dev/sda2 gpt 21686148-6449-6e6f-744e-656564454649 vfat BIOS boot
/dev/sda3 gpt e3c9e316-0b5c-4db8-817d-f92df00215ae Microsoft reserved
/dev/sda4 gpt ebd0a0a2-b9e5-4433-87c0-68b6b72699c7 ntfs Microsoft basic data
/dev/sda5 gpt 0fc63daf-8483-4772-8e79-3d69d8477de4 ext4 Linux filesystem
/dev/sdb dos
/dev/sdb1 dos 0x7 exfat HPFS/NTFS/exFAT
/dev/sdb2 dos iso9660
/dev/sr0
fdisk output:
$ sudo fdisk -l /dev/sda
Disk /dev/sda: 232.89 GiB, 250059350016 bytes, 488397168 sectors
Disk model: Samsung SSD 850
Disklabel type: gpt
Disk identifier: A2987B43-DFE4-4FC7-BBEA-376E14C5015E
Device Start End Sectors Size Type
/dev/sda1 2048 923647 921600 450M Windows recovery environment
/dev/sda2 923648 1128447 204800 100M BIOS boot
/dev/sda3 1128448 1161215 32768 16M Microsoft reserved
/dev/sda4 1900544 288894975 286994432 136.8G Microsoft basic data
/dev/sda5 288894976 488396799 199501824 95.1G Linux filesystem
Currently in live usb mode from latest Manjaro ISO.
