My mouse (HP 240 Bluetooth) is connected and the power percentage is shown, but I cannot move the cursor.
You forgot to mention which DE you are using ![]()
Welcome to Manjaro!
- Please read the information behind this link. It will help you to post necessary information.
- Please press the three dots … below your post and then press the
- If you give us information about your system, we can see what we’re talking about and make better suggestions.
- You can do this by using
inxiin a terminal or in console.
- Personally identifiable information such as serial numbers and MAC addresses are filtered out by this command
- Presenting the information in this way allows everyone to be familiar with the format and quickly find the items they need without missing anything.
- Copy the output from inxi (including the command) and paste it into your post.
- To make it more readable, add 3 backticks ``` on an extra line before and after the pasted text.
Have you already
for your problem in the forum ? (Wisdom lies in asking → listening → reading
Kernel: 6.1.62-1-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 13.2.1
clocksource: tsc available: acpi_pm
root=UUID=fcd15d5d-4b60-402e-be78-6142cd443255 rw nouveau.modeset=0 quiet
resume=UUID=fc6c4c4b-6c61-4fa7-a334-ab1c856bfdf5 udev.log_priority=3
Desktop: KDE Plasma v: 5.27.9 tk: Qt v: 5.15.11 info: docker wm: kwin_x11
Type: Laptop System: Dell product: Precision 5570 v: N/A serial: <filter>
Chassis: type: 10 serial: <filter>
Mobo: Dell model: 02JH00 v: A00 serial: <filter> UEFI: Dell v: 1.16.0
date: 07/07/2023
ID-1: BAT0 charge: 23.3 Wh (37.7%) condition: 61.8/84.3 Wh (73.3%)
volts: 11.9 min: 11.4 model: BYD DELL M59JH25 type: Li-poly serial: <filter>
status: charging
System RAM: total: 16 GiB available: 15.3 GiB used: 5.87 GiB (38.4%)
igpu: 64 MiB
Device-1: DIMM A type: DDR5 detail: synchronous size: 8 GiB
speed: 4800 MT/s volts: curr: 1.1 width (bits): data: 64 total: 64
manufacturer: 80AD000080AD part-no: HMCG66MEBSA092N serial: <filter>
Device-2: DIMM B type: DDR5 detail: synchronous size: 8 GiB
Info: model: 12th Gen Intel Core i7-12700H socket: U3E1 bits: 64
type: MST AMCP arch: Alder Lake gen: core 12 level: v3 note: check
built: 2021+ process: Intel 7 (10nm ESF) family: 6 model-id: 0x9A (154)
stepping: 3 microcode: 0x42C
Topology: cpus: 1x cores: 14 mt: 6 tpc: 2 st: 8 threads: 20 smt: enabled
cache: L1: 1.2 MiB desc: d-8x32 KiB, 6x48 KiB; i-6x32 KiB, 8x64 KiB
L2: 11.5 MiB desc: 6x1.2 MiB, 2x2 MiB L3: 24 MiB desc: 1x24 MiB
Speed (MHz): avg: 690 high: 1800 min/max: 400/4600:4700:3500
base/boost: 1980/4700 scaling: driver: intel_pstate governor: performance
volts: 0.8 V ext-clock: 100 MHz cores: 1: 1004 2: 818 3: 1094 4: 401
5: 1800 6: 400 7: 1800 8: 400 9: 400 10: 400 11: 490 12: 400 13: 400
14: 427 15: 1574 16: 400 17: 400 18: 400 19: 400 20: 400 bogomips: 107560
de ds_cpl dtes64 dtherm dts epb ept ept_ad erms est f16c flexpriority
hwp_epp hwp_notify hwp_pkg_req ibpb ibrs ibrs_enhanced ibt ida intel_pt
msr mtrr nonstop_tsc nopl nx ospke pae pat pbe pclmulqdq pdcm pdpe1gb pebs
pge pku pln pni popcnt pse pse36 pts rdpid rdrand rdseed rdtscp rep_good
sdbg sep serialize sha_ni smap smep smx split_lock_detect ss ssbd sse sse2
tsc_deadline_timer tsc_known_freq umip vaes vme vmx vnmi vpclmulqdq vpid
waitpkg x2apic xgetbv1 xsave xsavec xsaveopt xsaves xtopology xtpr
Type: spectre_v2 mitigation: Enhanced IBRS, IBPB: conditional, RSB
filling, PBRSB-eIBRS: SW sequence
Device-1: Intel Alder Lake-P GT2 [Iris Xe Graphics] vendor: Dell driver: i915
v: kernel arch: Gen-12.2 process: Intel 10nm built: 2021-22+ ports:
active: eDP-1 empty: DP-1, DP-2, DP-3, DP-4, HDMI-A-1 bus-ID: 0000:00:02.0
chip-ID: 8086:46a6 class-ID: 0300
Device-2: NVIDIA GA107GLM [RTX A1000 Laptop GPU] vendor: Dell
driver: nvidia v: 535.54.03 alternate: nouveau,nvidia_drm non-free: 545.xx+
status: current (as of 2023-11; EOL~2026-12-xx) arch: Ampere code: GAxxx
process: TSMC n7 (7nm) built: 2020-2023 bus-ID: 0000:01:00.0
chip-ID: 10de:25b9 class-ID: 0302
Device-3: Microdia Integrated_Webcam_HD driver: uvcvideo type: USB rev: 2.0
speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 3-6:2 chip-ID: 0c45:6a15
class-ID: 0e02
Display: server: X.Org v: 21.1.9 compositor: kwin_x11 driver: X:
loaded: modesetting,nvidia unloaded: nouveau alternate: fbdev,nv,vesa
dri: iris gpu: i915 display-ID: :0 screens: 1
Screen-1: 0 s-res: 1920x1200 s-dpi: 96 s-size: 508x317mm (20.00x12.48")
s-diag: 599mm (23.57")
Monitor-1: eDP-1 model: LG Display 0x06b3 built: 2021 res: 1920x1200 hz: 60
dpi: 145 gamma: 1.2 size: 336x210mm (13.23x8.27") diag: 396mm (15.6")
ratio: 16:10 modes: 1920x1200
drv: nvidia device: 1 drv: iris device: 3 drv: swrast gbm: drv: iris
surfaceless: drv: nvidia x11: drv: iris inactive: wayland,device-2
API: OpenGL v: 4.6.0 compat-v: 4.5 vendor: intel mesa v: 23.1.9-manjaro1.1
glx-v: 1.4 direct-render: yes renderer: Mesa Intel Graphics (ADL GT2)
device-ID: 8086:46a6 memory: 14.94 GiB unified: yes
API: Vulkan v: 1.3.269 layers: 1 device: 0 type: discrete-gpu name: NVIDIA
RTX A1000 Laptop GPU driver: nvidia v: 535.54.03 device-ID: 10de:25b9
surfaces: xcb,xlib device: 1 type: integrated-gpu name: Intel Graphics
(ADL GT2) driver: mesa intel v: 23.1.9-manjaro1.1 device-ID: 8086:46a6
surfaces: xcb,xlib
Device-1: Intel Alder Lake PCH-P High Definition Audio vendor: Dell
driver: snd_hda_intel v: kernel alternate: snd_sof_pci_intel_tgl
bus-ID: 0000:00:1f.3 chip-ID: 8086:51c8 class-ID: 0403
API: ALSA v: k6.1.62-1-MANJARO status: kernel-api with: aoss
Server-1: PipeWire v: 0.3.84 status: n/a (root, process) with:
3: pipewire-alsa type: plugin 4: pw-jack type: plugin
Device-1: Intel Alder Lake-P PCH CNVi WiFi driver: iwlwifi v: kernel
bus-ID: 0000:00:14.3 chip-ID: 8086:51f0 class-ID: 0280
IF-ID-1: docker0 state: up speed: 10000 Mbps duplex: unknown mac: <filter>
IP v6: <filter> virtual: proto kernel_ll scope: link
IF-ID-2: veth4f75dde state: up speed: 10000 Mbps duplex: full mac: <filter>
Hardware-1: Intel Volume Management Device NVMe RAID Controller driver: vmd
v: 0.6 port: N/A bus-ID: 0000:00:0e.0 chip-ID: 8086:467f rev: class-ID: 0104
Local Storage: total: 476.94 GiB used: 110.39 GiB (23.1%)
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Samsung model: PM9A1 NVMe 512GB
size: 476.94 GiB block-size: physical: 512 B logical: 512 B speed: 63.2 Gb/s
lanes: 4 tech: SSD serial: <filter> fw-rev: 36308229 temp: 41.9 C
scheme: GPT
SMART: yes health: PASSED on: 44d 9h cycles: 1,519
read-units: 21,416,607 [10.9 TB] written-units: 60,649,095 [31.0 TB]
ID-1: / raw-size: 200 GiB size: 195.8 GiB (97.90%) used: 109.07 GiB (55.7%)
fs: ext4 block-size: 4096 B dev: /dev/nvme0n1p3 maj-min: 259:3 label: N/A
uuid: fcd15d5d-4b60-402e-be78-6142cd443255
ID-2: /boot/efi raw-size: 815 MiB size: 811 MiB (99.51%)
used: 70.6 MiB (8.7%) fs: vfat block-size: 512 B dev: /dev/nvme0n1p1
maj-min: 259:1 label: ESP uuid: 4A33-B00C
ID-1: swap-1 type: partition size: 20 GiB used: 1.25 GiB (6.3%)
priority: -2 dev: /dev/nvme0n1p4 maj-min: 259:4 label: N/A
uuid: fc6c4c4b-6c61-4fa7-a334-ab1c856bfdf5
ID-1: /dev/nvme0n1p2 maj-min: 259:2 size: 256.14 GiB fs: ntfs label: N/A
uuid: 7A46F27246F22F0F
Hub-1: 1-0:1 info: hi-speed hub with single TT ports: 1 rev: 2.0
Hub-3: 3-0:1 info: hi-speed hub with single TT ports: 12 rev: 2.0
Device-1: 3-6:2 info: Microdia Integrated_Webcam_HD type: video
driver: uvcvideo interfaces: 4 rev: 2.0 speed: 480 Mb/s (57.2 MiB/s) lanes: 1
mode: 2.0 power: 500mA chip-ID: 0c45:6a15 class-ID: 0e02
Device-2: 3-9:7 info: Shenzhen Goodix USB2.0 MISC type: <vendor specific>
driver: N/A interfaces: 1 rev: 2.0 speed: 12 Mb/s (1.4 MiB/s) lanes: 1
mode: 1.1 power: 100mA chip-ID: 27c6:63ac class-ID: ef00 serial: <filter>
System Temperatures: cpu: 54.0 C mobo: N/A
Fan Speeds (rpm): N/A
Processes: 417 Uptime: 1d 9m wakeups: 0 Init: systemd v: 254
Packages: pm: pacman pkgs: 1657 libs: 431 tools: pamac,yay pm: flatpak
pkgs: 0 Shell: Sudo (sudo) v: 1.9.15p2 default: Zsh v: 5.9
running-in: konsole inxi: 3.3.31
