Hi,
I never had any sound on my laptop since I am on Manjaro. May someone explain help and explain meplease, I am a beginner with Linux. Thanks a lot
$mhwd -lh -d:
16: PCI 1f.3: 0403 Audio device
SysFS ID: /devices/pci0000:00/0000:00:1f.3
SysFS BusID: 0000:00:1f.3
Hardware Class: sound
Model: "Intel Audio device"
Vendor: pci 0x8086 "Intel Corporation"
Device: pci 0x51c8
SubVendor: pci 0x1028 "Dell"
SubDevice: pci 0x0ba8
Revision: 0x01
Driver: "snd_hda_intel"
Driver Modules: "snd_hda_intel"
Memory Range: 0x601f290000-0x601f293fff (rw,non-prefetchable)
Memory Range: 0x601f000000-0x601f0fffff (rw,non-prefetchable)
IRQ: 192 (707 events)
Module Alias: "pci:v00008086d000051C8sv00001028sd00000BA8bc04sc03i80"
Driver Info #0:
Driver Status: snd_hda_intel is active
Driver Activation Cmd: "modprobe snd_hda_intel"
Driver Info #1:
Driver Status: snd_sof_pci_intel_tgl is active
Driver Activation Cmd: "modprobe snd_sof_pci_intel_tgl"
$inxi -A:
Device-1: Intel Alder Lake PCH-P High Definition Audio driver: snd_hda_intel
Sound API: ALSA v: k5.15.84-1-MANJARO running: yes
$systemctl --user status pulseaudio
pulseaudio.service - Sound Service
Loaded: loaded (/usr/lib/systemd/user/pulseaudio.service; disabled; preset: enabled)
Active: failed (Result: start-limit-hit) since Tue 2023-01-24 15:22:27 CET; 29min ago
Duration: 213us
TriggeredBy: × pulseaudio.socket
Process: 24848 ExecStart=/usr/bin/pulseaudio --daemonize=no --log-target=journal (code=exited, status=0/SUCCESS)
Main PID: 24848 (code=exited, status=0/SUCCESS)
CPU: 115ms
janv. 24 15:22:27 adanamalatcha systemd[664]: Starting Sound Service...
janv. 24 15:22:27 adanamalatcha pulseaudio[24848]: module-combine is deprecated: Please use module-combine-sink ins>
janv. 24 15:22:27 adanamalatcha pulseaudio[24848]: We will now load module-combine-sink. Please make sure to remove>
janv. 24 15:22:27 adanamalatcha pulseaudio[24848]: stat('/etc/pulse/default.pa.d'): Aucun fichier ou dossier de ce >
janv. 24 15:22:27 adanamalatcha systemd[664]: Started Sound Service.
janv. 24 15:22:27 adanamalatcha systemd[664]: pulseaudio.service: Start request repeated too quickly.
janv. 24 15:22:27 adanamalatcha systemd[664]: pulseaudio.service: Failed with result 'start-limit-hit'.
janv. 24 15:22:27 adanamalatcha systemd[664]: Failed to start Sound Service.
$journalctl --user -xeu pulseaudio.service
janv. 24 15:22:24 adanamalatcha pulseaudio[24814]: Could not find org.bluez.BatteryProviderManager1.RegisterBatteryProvider(), is bluetoothd started with experimenta>
janv. 24 15:22:26 adanamalatcha systemd[664]: Starting Sound Service...
░░ Subject: L'unité (unit) UNIT a commencé à démarrer
░░ Defined-By: systemd
░░ L'unité (unit) UNIT a commencé à démarrer.
janv. 24 15:22:26 adanamalatcha pulseaudio[24826]: module-combine is deprecated: Please use module-combine-sink instead of module-combine!
janv. 24 15:22:26 adanamalatcha pulseaudio[24826]: We will now load module-combine-sink. Please make sure to remove module-combine from your configuration.
janv. 24 15:22:26 adanamalatcha pulseaudio[24826]: stat('/etc/pulse/default.pa.d'): Aucun fichier ou dossier de ce type
janv. 24 15:22:26 adanamalatcha systemd[664]: Started Sound Service.
░░ Subject: L'unité (unit) UNIT a terminé son démarrage
░░ L'unité (unit) UNIT a terminé son démarrage, avec le résultat done.
janv. 24 15:22:27 adanamalatcha pulseaudio[24837]: module-combine is deprecated: Please use module-combine-sink instead of module-combine!
janv. 24 15:22:27 adanamalatcha pulseaudio[24837]: We will now load module-combine-sink. Please make sure to remove module-combine from your configuration.
janv. 24 15:22:27 adanamalatcha pulseaudio[24837]: stat('/etc/pulse/default.pa.d'): Aucun fichier ou dossier de ce type
janv. 24 15:22:27 adanamalatcha pulseaudio[24848]: module-combine is deprecated: Please use module-combine-sink instead of module-combine!
janv. 24 15:22:27 adanamalatcha pulseaudio[24848]: We will now load module-combine-sink. Please make sure to remove module-combine from your configuration.
janv. 24 15:22:27 adanamalatcha pulseaudio[24848]: stat('/etc/pulse/default.pa.d'): Aucun fichier ou dossier de ce type
░░ Subject: Unit failed
░░ The unit UNIT has entered the 'failed' state with result 'start-limit-hit'.
░░ Subject: L'unité (unit) UNIT a échoué
░░ L'unité (unit) UNIT a échoué, avec le résultat failed.
