before it was working not it is not i also connected to my usb and the usb was recognised but phone is not
Did you enable file transfer mode on your phone after connecting it? It’s usually not default.
Also you could install CX File explorer or similar on Android and easily connect via Network (smb)if you are open to that idea.
Who? Why would anyone use that when there’s much better applications like Solid Explorer and MiXplorer?
That is a viable alternative, however that’s not what the OP was asking about.
actually what happend is i deleted some unwanted stuff with sudo pacman -R $(pacman -Qtdq)
it broke too many packages the trash icon was gone missing in thunar so i installed nautlasis the trash icon camed but the android phone it getting connected but not showing help me please
thunar
thunar-volman: There is no device with the sysfs path “/sys/devices/pci0000:00/0000:00:14.0/usb1/1-2”.
thunar-volman: Unsupported USB device type “usb”.
thunar-volman: Unsupported USB device type “(null)”.
any ways i am reinstalling whole os again
