I have Windows and Linux on my computer (256G) and Windows has C: System(65G) and D: Data(65G), my Linux has /(108G) and System, Data are also mounted on /.
df -h
Filesystem Size Used Avail Use% Mounted on
dev 3.9G 0 3.9G 0% /dev
run 3.9G 1.9M 3.9G 1% /run
/dev/nvme0n1p5 108G 39G 64G 38% /
tmpfs 3.9G 0 3.9G 0% /dev/shm
tmpfs 4.0M 0 4.0M 0% /sys/fs/cgroup
tmpfs 3.9G 68M 3.8G 2% /tmp
/dev/nvme0n1p4 65G 39G 26G 60% /Data
/dev/nvme0n1p3 65G 43G 22G 67% /System
/dev/nvme0n1p1 256M 26M 231M 11% /boot/efi
tmpfs 788M 100K 788M 1% /run/user/1000
I want to check the size of / without /System and /Data, and the Dolphin says it has 128TB:
It seems that it will show 128TB because it cannot know the size of /root and /lost+found?
