Hello,
I have a problem with the sound channels in alsa: After every restart of the computer, the headphone control is muted and its volume is at zero. Sound can only be output through the built-in speakers when I unmute it. alsactl store as root does not work. Is there a solution to the problem? I am grateful for any help.
Best regards
upload=true&script=true&cardinfo=
!!ALSA Information Script v 0.5.3
!!Script ran on: Sun Jul 30 18:31:47 UTC 2023
!!Linux Distribution
ID_LIKE=arch
!!DMI Information
Manufacturer: SchenkerTechnologiesGmbH
Product Name: XMG PRO (E23)
Product Version: Not Applicable
Firmware Version: 1.07.11RTR2
System SKU: XPR15E23 / XPR17E23
Board Vendor: NB01
Board Name: PD5x_7xSNC_SND_SNE
!!ACPI Device Status Information
/sys/bus/acpi/devices/ACPI0003:00/status 15
/sys/bus/acpi/devices/ACPI000C:00/status 15
/sys/bus/acpi/devices/CLV0001:00/status 15
/sys/bus/acpi/devices/CLV0002:00/status 15
/sys/bus/acpi/devices/FTCS1000:01/status 15
/sys/bus/acpi/devices/IFX1521:00/status 15
/sys/bus/acpi/devices/INT33A1:00/status 15
/sys/bus/acpi/devices/INT340E:00/status 15
/sys/bus/acpi/devices/INTC1051:00/status 15
/sys/bus/acpi/devices/INTC1085:00/status 15
/sys/bus/acpi/devices/INTC109C:00/status 15
/sys/bus/acpi/devices/INTC10A0:00/status 15
/sys/bus/acpi/devices/INTC10A1:00/status 15
/sys/bus/acpi/devices/INTC10A1:01/status 15
/sys/bus/acpi/devices/LNXPOWER:01/status 1
/sys/bus/acpi/devices/LNXPOWER:02/status 1
/sys/bus/acpi/devices/LNXPOWER:03/status 1
/sys/bus/acpi/devices/NVDA0820:00/status 15
/sys/bus/acpi/devices/PNP0103:00/status 15
/sys/bus/acpi/devices/PNP0B00:00/status 15
/sys/bus/acpi/devices/PNP0C02:02/status 8
/sys/bus/acpi/devices/PNP0C02:04/status 3
/sys/bus/acpi/devices/PNP0C02:05/status 3
/sys/bus/acpi/devices/PNP0C0A:00/status 31
/sys/bus/acpi/devices/PRP00001:00/status 15
/sys/bus/acpi/devices/PRP00001:01/status 11
/sys/bus/acpi/devices/USBC000:00/status 15
/sys/bus/acpi/devices/device:01/status 15
/sys/bus/acpi/devices/device:03/status 15
/sys/bus/acpi/devices/device:20/status 15
/sys/bus/acpi/devices/device:aa/status 15
/sys/bus/acpi/devices/device:ab/status 15
/sys/bus/acpi/devices/device:ac/status 15
/sys/bus/acpi/devices/device:ae/status 15
/sys/bus/acpi/devices/device:af/status 15
/sys/bus/acpi/devices/device:b0/status 15
!!Kernel Information
Kernel release: #1 SMP PREEMPT_DYNAMIC Tue Jul 25 09:17:30 UTC 2023
Operating System: GNU/Linux
Architecture: x86_64
Processor: unknown
SMP Enabled: Yes
!!ALSA Version
Driver version: k6.1.41-1-MANJARO
Library version: 1.2.9
Utilities version: 1.2.9
!!Loaded ALSA modules
snd_hda_intel (card 0)
snd_hda_intel (card 1)
!!Sound Servers on this system
PipeWire:
Installed - Yes (/usr/bin/pipewire)
Running - Yes
No sound servers found.
!!Soundcards recognised by ALSA
0 [PCH ]: HDA-Intel - HDA Intel PCH
HDA Intel PCH at 0x6203130000 irq 236
1 [NVidia ]: HDA-Intel - HDA NVidia
HDA NVidia at 0x74000000 irq 17
!!PCI Soundcards installed in the system
00:1f.3 Audio device [0403]: Intel Corporation Device [8086:7a50] (rev 11)
Subsystem: CLEVO/KAPOK Computer Device [1558:d702]
01:00.1 Audio device [0403]: NVIDIA Corporation Device [10de:22bd] (rev a1)
Subsystem: NVIDIA Corporation Device [10de:0000]
!!Modprobe options (Sound related)
snd_hda_intel: model=dual-codecs
snd_hda_intel: model=no-primary-hp
!!Loaded sound module options
!!Module: snd_hda_intel
align_buffer_size : -1
bdl_pos_adj : -1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1
beep_mode : N,N,N,N,N,N,N,N,N,N,N,N,N,N,N,N,N,N,N,N,N,N,N,N,N,N,N,N,N,N,N,N
ctl_dev_id : N
dmic_detect : Y
enable : Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y
enable_msi : -1
id : (null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null)
index : -1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1
jackpoll_ms : 0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0
model : no-primary-hp,(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null)
patch : (null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null)
pm_blacklist : Y
position_fix : -1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1
power_save : 1
power_save_controller : Y
probe_mask : -1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1
probe_only : 0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0
single_cmd : -1
snoop : -1
ctl_dev_id : N
dmic_detect : Y
enable_msi : -1
pm_blacklist : Y
power_save : 1
single_cmd : -1
snoop : -1
!!Sysfs card info
!!Card: /sys/class/sound/card0
Driver: /sys/bus/pci/drivers/snd_hda_intel
Tree:
!!Card: /sys/class/sound/card1
Tree:
!!HDA-Intel Codec information
--startcollapse--
Codec: Realtek ALC1220
Address: 0
AFG Function Id: 0x1 (unsol 1)
Vendor Id: 0x10ec1220
Subsystem Id: 0x1558d702
Revision Id: 0x100101
No Modem Function Group found
Default PCM:
rates [0x5f0]: 32000 44100 48000 88200 96000 192000
bits [0xe]: 16 20 24
formats [0x1]: PCM
Default Amp-In caps: N/A
Default Amp-Out caps: N/A
State of AFG node 0x01:
Power states: D0 D1 D2 D3 D3cold CLKSTOP EPSS
Power: setting=D0, actual=D0
GPIO: io=8, o=0, i=0, unsolicited=1, wake=0
IO[0]: enable=0, dir=0, wake=0, sticky=0, data=0, unsol=0
IO[1]: enable=0, dir=0, wake=0, sticky=0, data=0, unsol=0
IO[2]: enable=0, dir=0, wake=0, sticky=0, data=0, unsol=0
IO[3]: enable=0, dir=0, wake=0, sticky=0, data=0, unsol=0
IO[4]: enable=0, dir=0, wake=0, sticky=0, data=0, unsol=0
IO[5]: enable=0, dir=0, wake=0, sticky=0, data=0, unsol=0
IO[6]: enable=0, dir=0, wake=0, sticky=0, data=0, unsol=0
IO[7]: enable=0, dir=0, wake=0, sticky=0, data=0, unsol=0
Node 0x02 [Audio Output] wcaps 0x41d: Stereo Amp-Out
Control: name="Headphone Playback Volume", index=0, device=0
ControlAmp: chs=3, dir=Out, idx=0, ofs=0
Amp-Out caps: ofs=0x57, nsteps=0x57, stepsize=0x02, mute=0
Amp-Out vals: [0x47 0x47]
Converter: stream=1, channel=0
PCM:
rates [0x60]: 44100 48000
bits [0x1e]: 16 20 24 32
formats [0x1]: PCM
Power states: D0 D1 D2 D3 EPSS
Node 0x03 [Audio Output] wcaps 0x41d: Stereo Amp-Out
Control: name="Speaker Playback Volume", index=0, device=0
Device: name="ALC1220 Analog", type="Audio", device=0
PCM:
rates [0x7e0]: 44100 48000 88200 96000 176400 192000
formats [0x1]: PCM
Node 0x04 [Audio Output] wcaps 0x41d: Stereo Amp-Out
Amp-Out vals: [0x57 0x57]
Converter: stream=0, channel=0
PCM:
formats [0x1]: PCM
Node 0x05 [Audio Output] wcaps 0x41d: Stereo Amp-Out
PCM:
formats [0x1]: PCM
Node 0x06 [Audio Output] wcaps 0x611: Stereo Digital
Control: name="IEC958 Playback Con Mask", index=16, device=0
Control: name="IEC958 Playback Pro Mask", index=16, device=0
Control: name="IEC958 Playback Default", index=16, device=0
Control: name="IEC958 Playback Switch", index=16, device=0
Control: name="IEC958 Default PCM Playback Switch", index=0, device=0
Device: name="ALC1220 Digital", type="SPDIF", device=1
Digital: Enabled
Digital category: 0x0
IEC Coding Type: 0x0
PCM:
formats [0x1]: PCM
Node 0x07 [Vendor Defined Widget] wcaps 0xf00000: Mono
Node 0x08 [Audio Input] wcaps 0x10051b: Stereo Amp-In
Control: name="Capture Volume", index=0, device=0
ControlAmp: chs=3, dir=In, idx=0, ofs=0
Control: name="Capture Switch", index=0, device=0
Amp-In caps: ofs=0x17, nsteps=0x3f, stepsize=0x02, mute=1
Amp-In vals: [0x3f 0x3f]
SDI-Select: 0
PCM:
formats [0x1]: PCM
Connection: 1
0x23
Node 0x09 [Audio Input] wcaps 0x10051b: Stereo Amp-In
Amp-In vals: [0x97 0x97]
SDI-Select: 0
PCM:
formats [0x1]: PCM
Connection: 1
0x22
Node 0x0a [Vendor Defined Widget] wcaps 0xf00000: Mono
Node 0x0b [Audio Mixer] wcaps 0x20010b: Stereo Amp-In
Control: name="Mic Playback Volume", index=0, device=0
Control: name="Mic Playback Switch", index=0, device=0
Control: name="Beep Playback Volume", index=0, device=0
ControlAmp: chs=3, dir=In, idx=5, ofs=0
Control: name="Beep Playback Switch", index=0, device=0
Amp-In caps: ofs=0x17, nsteps=0x1f, stepsize=0x05, mute=1
Amp-In vals: [0x1f 0x1f] [0x80 0x80] [0x80 0x80] [0x80 0x80] [0x80 0x80] [0x1f 0x1f] [0x80 0x80] [0x80 0x80]
Connection: 8
0x18 0x19 0x1a 0x1b 0x1d 0x15 0x16 0x17
Node 0x0c [Audio Mixer] wcaps 0x20010b: Stereo Amp-In
Amp-In caps: ofs=0x00, nsteps=0x00, stepsize=0x00, mute=1
Amp-In vals: [0x00 0x00] [0x80 0x80]
Connection: 2
0x02 0x0b
Node 0x0d [Audio Mixer] wcaps 0x20010b: Stereo Amp-In
Connection: 2
0x03 0x0b
Node 0x0e [Audio Mixer] wcaps 0x20010b: Stereo Amp-In
Connection: 2
0x04 0x0b
Node 0x0f [Audio Mixer] wcaps 0x20010b: Stereo Amp-In
Connection: 2
0x05 0x0b
Node 0x10 [Vendor Defined Widget] wcaps 0xf00000: Mono
Node 0x11 [Vendor Defined Widget] wcaps 0xf00000: Mono
Node 0x12 [Pin Complex] wcaps 0x40040b: Stereo Amp-In
Control: name="Internal Mic Boost Volume", index=0, device=0
Amp-In caps: ofs=0x00, nsteps=0x03, stepsize=0x27, mute=0
Amp-In vals: [0x03 0x03]
Pincap 0x00000020: IN
Pin Default 0x90a60130: [Fixed] Mic at Int N/A
Conn = Digital, Color = Unknown
DefAssociation = 0x3, Sequence = 0x0
Misc = NO_PRESENCE
Pin-ctls: 0x20: IN
Node 0x13 [Vendor Defined Widget] wcaps 0xf00000: Mono
Node 0x14 [Pin Complex] wcaps 0x40058d: Stereo Amp-Out
Control: name="Headphone Playback Switch", index=0, device=0
Amp-Out caps: ofs=0x00, nsteps=0x00, stepsize=0x00, mute=1
Amp-Out vals: [0x00 0x00]
Pincap 0x0001001c: OUT HP EAPD Detect
EAPD 0x2: EAPD
Pin Default 0x0421101f: [Jack] HP Out at Ext Right
Conn = 1/8, Color = Black
DefAssociation = 0x1, Sequence = 0xf
Pin-ctls: 0xc0: OUT HP
Unsolicited: tag=01, enabled=1
Connection: 1
0x0c
Node 0x15 [Pin Complex] wcaps 0x40058d: Stereo Amp-Out
Amp-Out vals: [0x80 0x80]
Pincap 0x00000034: IN OUT Detect
Pin Default 0x40000000: [N/A] Line Out at Ext N/A
Conn = Unknown, Color = Unknown
DefAssociation = 0x0, Sequence = 0x0
Pin-ctls: 0x20: IN
Unsolicited: tag=00, enabled=0
Connection: 1
0x0d
Node 0x16 [Pin Complex] wcaps 0x40058d: Stereo Amp-Out
Pin Default 0x411111f0: [N/A] Speaker at Ext Rear
DefAssociation = 0xf, Sequence = 0x0
Misc = NO_PRESENCE
Pin-ctls: 0x20: IN
Connection: 1
0x0e
Node 0x17 [Pin Complex] wcaps 0x40058d: Stereo Amp-Out
Misc = NO_PRESENCE
Pin-ctls: 0x20: IN
Connection: 1
0x0f
Node 0x18 [Pin Complex] wcaps 0x40058f: Stereo Amp-In Amp-Out
Control: name="Mic Boost Volume", index=0, device=0
Pincap 0x00003734: IN OUT Detect
Vref caps: HIZ 50 GRD 80 100
Pin Default 0x04a11040: [Jack] Mic at Ext Right
DefAssociation = 0x4, Sequence = 0x0
Pin-ctls: 0x24: IN VREF_80
Unsolicited: tag=02, enabled=1
Connection: 5
0x0c* 0x0d 0x0e 0x0f 0x26
Node 0x19 [Pin Complex] wcaps 0x40058f: Stereo Amp-In Amp-Out
Pincap 0x0000373c: IN OUT HP Detect
Misc = NO_PRESENCE
Pin-ctls: 0x20: IN VREF_HIZ
Connection: 5
Node 0x1a [Pin Complex] wcaps 0x40058f: Stereo Amp-In Amp-Out
Misc = NO_PRESENCE
Connection: 5
Node 0x1b [Pin Complex] wcaps 0x40058f: Stereo Amp-In Amp-Out
Control: name="Speaker Playback Switch", index=0, device=0
Pincap 0x0001373c: IN OUT HP EAPD Detect
EAPD 0x2: EAPD
Pin Default 0x90170110: [Fixed] Speaker at Int N/A
Conn = Analog, Color = Unknown
DefAssociation = 0x1, Sequence = 0x0
Misc = NO_PRESENCE
Pin-ctls: 0x40: OUT VREF_HIZ
Connection: 5
0x0c 0x0d* 0x0e 0x0f 0x26
Node 0x1c [Vendor Defined Widget] wcaps 0xf00000: Mono
Node 0x1d [Pin Complex] wcaps 0x400400: Mono
Pin Default 0x40b7952d: [N/A] Telephony at Ext N/A
Conn = Analog, Color = Pink
DefAssociation = 0x2, Sequence = 0xd
Misc = NO_PRESENCE
Pin-ctls: 0x20: IN
Node 0x1e [Pin Complex] wcaps 0x400781: Stereo Digital
Pincap 0x00000010: OUT
Pin Default 0x04451150: [Jack] SPDIF Out at Ext Right
Conn = Optical, Color = Black
DefAssociation = 0x5, Sequence = 0x0
Misc = NO_PRESENCE
Pin-ctls: 0x40: OUT
Connection: 1
0x06
Node 0x1f [Vendor Defined Widget] wcaps 0xf00000: Mono
Node 0x20 [Vendor Defined Widget] wcaps 0xf00040: Mono
Processing caps: benign=0, ncoeff=127
Node 0x21 [Vendor Defined Widget] wcaps 0xf00000: Mono
Node 0x22 [Audio Mixer] wcaps 0x20010b: Stereo Amp-In
Amp-In vals: [0x80 0x80] [0x80 0x80] [0x80 0x80] [0x80 0x80] [0x80 0x80] [0x80 0x80] [0x80 0x80] [0x80 0x80] [0x80 0x80] [0x80 0x80]
Connection: 10
0x18 0x19 0x1a 0x1b 0x1d 0x15 0x16 0x17 0x12 0x0b
Node 0x23 [Audio Mixer] wcaps 0x20010b: Stereo Amp-In
Amp-In vals: [0x80 0x80] [0x80 0x80] [0x80 0x80] [0x80 0x80] [0x80 0x80] [0x80 0x80] [0x80 0x80] [0x80 0x80] [0x00 0x00] [0x80 0x80]
Connection: 10
Node 0x24 [Vendor Defined Widget] wcaps 0xf00000: Mono
Node 0x25 [Audio Output] wcaps 0x41d: Stereo Amp-Out
PCM:
formats [0x1]: PCM
Node 0x26 [Audio Mixer] wcaps 0x20010b: Stereo Amp-In
Connection: 2
0x25 0x0b
Codec: Intel Raptorlake HDMI
Address: 2
AFG Function Id: 0x1 (unsol 0)
Vendor Id: 0x80862818
Subsystem Id: 0x80860101
Revision Id: 0x100000
Default PCM:
rates [0x0]:
bits [0x0]:
formats [0x0]:
Power states: D0 D3 CLKSTOP EPSS
Power: setting=D0, actual=D0, Clock-stop-OK
GPIO: io=0, o=0, i=0, unsolicited=0, wake=0
Node 0x03 [Audio Output] wcaps 0x6611: 8-Channels Digital
Digital: Enabled KAE
PCM:
rates [0x7f0]: 32000 44100 48000 88200 96000 176400 192000
bits [0x1a]: 16 24 32
formats [0x5]: PCM AC3
Power states: D0 D3 EPSS
Node 0x04 [Pin Complex] wcaps 0x40778d: 8-Channels Digital Amp-Out CP
Pincap 0x0b000094: OUT Detect HBR HDMI DP
Pin Default 0x18560010: [Jack] Digital Out at Int HDMI
Pin-ctls: 0x00:
Devices: 0
Connection: 0
Node 0x05 [Audio Output] wcaps 0x6611: 8-Channels Digital
PCM:
Node 0x06 [Pin Complex] wcaps 0x40778d: 8-Channels Digital Amp-Out CP
Pin-ctls: 0x00:
Devices: 0
Connection: 0
Node 0x07 [Audio Output] wcaps 0x6611: 8-Channels Digital
PCM:
Node 0x08 [Pin Complex] wcaps 0x40778d: 8-Channels Digital Amp-Out CP
Pin-ctls: 0x00:
Devices: 0
Connection: 0
Node 0x09 [Audio Output] wcaps 0x6611: 8-Channels Digital
PCM:
Node 0x0a [Pin Complex] wcaps 0x40778d: 8-Channels Digital Amp-Out CP
Pin-ctls: 0x00:
Devices: 0
Connection: 0
Node 0x0b [Pin Complex] wcaps 0x40778d: 8-Channels Digital Amp-Out CP
Pin-ctls: 0x00:
Devices: 0
Connection: 0
Node 0x0c [Pin Complex] wcaps 0x40778d: 8-Channels Digital Amp-Out CP
Pin-ctls: 0x00:
Devices: 0
Connection: 0
Node 0x0d [Pin Complex] wcaps 0x40778d: 8-Channels Digital Amp-Out CP
Pin-ctls: 0x00:
Devices: 0
Connection: 0
Node 0x0e [Pin Complex] wcaps 0x40778d: 8-Channels Digital Amp-Out CP
Pin-ctls: 0x00:
Devices: 0
Connection: 0
Node 0x0f [Pin Complex] wcaps 0x40778d: 8-Channels Digital Amp-Out CP
Pin-ctls: 0x00:
Devices: 0
Connection: 0
Codec: Nvidia GPU a6 HDMI/DP
Address: 0
Vendor Id: 0x10de00a6
Subsystem Id: 0x10de0000
Revision Id: 0x100100
Default PCM:
rates [0x0]:
bits [0x0]:
formats [0x0]:
Power states: D0 D1 D2 D3 CLKSTOP EPSS
Node 0x04 [Pin Complex] wcaps 0x407381: 8-Channels Digital CP
Pincap 0x09000094: OUT Detect HBR HDMI DP
Pin Default 0x185600f0: [Jack] Digital Out at Int HDMI
Pin-ctls: 0x00:
Devices: 4
Dev 00: PD = 0, ELDV = 0, IA = 0, Connections [ 0x08* 0x09 0x0a 0x0b ]
Dev 01: PD = 0, ELDV = 0, IA = 0, Connections [ 0x08* 0x09 0x0a 0x0b ]
Dev 02: PD = 0, ELDV = 0, IA = 0, Connections [ 0x08* 0x09 0x0a 0x0b ]
*Dev 03: PD = 0, ELDV = 0, IA = 0, Connections [ 0x08* 0x09 0x0a 0x0b ]
Connection: 4
Node 0x05 [Pin Complex] wcaps 0x407381: 8-Channels Digital CP
Pin Default 0x585600f0: [N/A] Digital Out at Int HDMI
Pin-ctls: 0x00:
Devices: 4
*Dev 00: PD = 0, ELDV = 0, IA = 0, Connections [ 0x08* 0x09 0x0a 0x0b ]
Connection: 4
Node 0x06 [Pin Complex] wcaps 0x407381: 8-Channels Digital CP
Pin-ctls: 0x00:
Unsolicited: tag=05, enabled=1
Devices: 4
Connection: 4
Node 0x07 [Pin Complex] wcaps 0x407381: 8-Channels Digital CP
Pin-ctls: 0x00:
Unsolicited: tag=09, enabled=1
Devices: 4
Connection: 4
Node 0x08 [Audio Output] wcaps 0x62b1: 8-Channels Digital Stripe
Digital:
PCM:
Node 0x09 [Audio Output] wcaps 0x62b1: 8-Channels Digital Stripe
Digital:
PCM:
Node 0x0a [Audio Output] wcaps 0x62b1: 8-Channels Digital Stripe
Digital:
PCM:
Node 0x0b [Audio Output] wcaps 0x62b1: 8-Channels Digital Stripe
Digital:
PCM:
--endcollapse--
!!ALSA Device nodes
crw-rw----+ 1 root audio 116, 17 Jul 30 20:21 /dev/snd/controlC0
crw-rw----+ 1 root audio 116, 7 Jul 30 20:21 /dev/snd/controlC1
crw-rw----+ 1 root audio 116, 15 Jul 30 20:21 /dev/snd/hwC0D0
crw-rw----+ 1 root audio 116, 16 Jul 30 20:21 /dev/snd/hwC0D2
crw-rw----+ 1 root audio 116, 6 Jul 30 20:21 /dev/snd/hwC1D0
crw-rw----+ 1 root audio 116, 9 Jul 30 20:22 /dev/snd/pcmC0D0c
crw-rw----+ 1 root audio 116, 8 Jul 30 20:22 /dev/snd/pcmC0D0p
crw-rw----+ 1 root audio 116, 10 Jul 30 20:21 /dev/snd/pcmC0D1p
crw-rw----+ 1 root audio 116, 11 Jul 30 20:21 /dev/snd/pcmC0D3p
crw-rw----+ 1 root audio 116, 12 Jul 30 20:21 /dev/snd/pcmC0D7p
crw-rw----+ 1 root audio 116, 13 Jul 30 20:21 /dev/snd/pcmC0D8p
crw-rw----+ 1 root audio 116, 14 Jul 30 20:21 /dev/snd/pcmC0D9p
crw-rw----+ 1 root audio 116, 2 Jul 30 20:21 /dev/snd/pcmC1D3p
crw-rw----+ 1 root audio 116, 3 Jul 30 20:21 /dev/snd/pcmC1D7p
crw-rw----+ 1 root audio 116, 4 Jul 30 20:21 /dev/snd/pcmC1D8p
crw-rw----+ 1 root audio 116, 5 Jul 30 20:21 /dev/snd/pcmC1D9p
crw-rw----+ 1 root audio 116, 1 Jul 30 20:21 /dev/snd/seq
crw-rw----+ 1 root audio 116, 33 Jul 30 20:21 /dev/snd/timer
/dev/snd/by-path:
total 0
drwxr-xr-x 2 root root 80 Jul 30 20:21 .
drwxr-xr-x 3 root root 420 Jul 30 20:21 ..
lrwxrwxrwx 1 root root 12 Jul 30 20:21 pci-0000:00:1f.3 -> ../controlC0
lrwxrwxrwx 1 root root 12 Jul 30 20:21 pci-0000:01:00.1 -> ../controlC1
!!ALSA configuration files
!!System wide config file (/etc/asound.conf)
defaults.pcm.card 0
defaults.ctl.card 0
!!Aplay/Arecord output
APLAY
**** List of PLAYBACK Hardware Devices ****
card 0: PCH [HDA Intel PCH], device 0: ALC1220 Analog [ALC1220 Analog]
Subdevices: 1/1
Subdevice #0: subdevice #0
card 0: PCH [HDA Intel PCH], device 1: ALC1220 Digital [ALC1220 Digital]
Subdevices: 1/1
card 0: PCH [HDA Intel PCH], device 3: HDMI 0 [HDMI 0]
Subdevices: 1/1
card 0: PCH [HDA Intel PCH], device 7: HDMI 1 [HDMI 1]
Subdevices: 1/1
card 0: PCH [HDA Intel PCH], device 8: HDMI 2 [HDMI 2]
Subdevices: 1/1
card 0: PCH [HDA Intel PCH], device 9: HDMI 3 [HDMI 3]
Subdevices: 1/1
card 1: NVidia [HDA NVidia], device 3: HDMI 0 [HDMI 0]
Subdevices: 1/1
card 1: NVidia [HDA NVidia], device 7: HDMI 1 [HDMI 1]
Subdevices: 1/1
card 1: NVidia [HDA NVidia], device 8: HDMI 2 [HDMI 2]
Subdevices: 1/1
card 1: NVidia [HDA NVidia], device 9: HDMI 3 [HDMI 3]
Subdevices: 1/1
ARECORD
**** List of CAPTURE Hardware Devices ****
Subdevices: 1/1
!!Amixer output
!!-------Mixer controls for card PCH
Card sysdefault:0 'PCH'/'HDA Intel PCH at 0x6203130000 irq 236'
Mixer name : 'Realtek ALC1220'
Components : 'HDA:10ec1220,1558d702,00100101 HDA:80862818,80860101,00100000'
Controls : 58
Simple ctrls : 17
Simple mixer control 'Master',0
Capabilities: pvolume pvolume-joined pswitch pswitch-joined
Playback channels: Mono
Limits: Playback 0 - 87
Mono: Playback 71 [82%] [-12.00dB] [on]
Simple mixer control 'Headphone',0
Capabilities: pvolume pswitch
Mono:
Front Left: Playback 87 [100%] [0.00dB] [on]
Front Right: Playback 87 [100%] [0.00dB] [on]
Simple mixer control 'Speaker',0
Mono:
Simple mixer control 'PCM',0
Limits: Playback 0 - 255
Mono:
Front Left: Playback 255 [100%] [0.00dB]
Front Right: Playback 255 [100%] [0.00dB]
Simple mixer control 'Mic',0
Limits: Playback 0 - 31
Mono:
Front Left: Playback 31 [100%] [12.00dB] [on]
Front Right: Playback 31 [100%] [12.00dB] [on]
Simple mixer control 'Mic Boost',0
Capabilities: volume
Limits: 0 - 3
Front Left: 0 [0%] [0.00dB]
Front Right: 0 [0%] [0.00dB]
Simple mixer control 'IEC958',0
Capabilities: pswitch pswitch-joined
Mono: Playback [off]
Simple mixer control 'IEC958 Default PCM',0
Mono: Playback [on]
Simple mixer control 'IEC958',1
Mono: Playback [on]
Simple mixer control 'IEC958',2
Mono: Playback [on]
Simple mixer control 'IEC958',3
Mono: Playback [on]
Simple mixer control 'IEC958',16
Mono: Playback [on]
Simple mixer control 'Beep',0
Mono:
Simple mixer control 'Capture',0
Capabilities: cvolume cswitch
Limits: Capture 0 - 63
Front Left: Capture 63 [100%] [30.00dB] [on]
Front Right: Capture 63 [100%] [30.00dB] [on]
Simple mixer control 'Auto-Mute Mode',0
Capabilities: enum
Items: 'Disabled' 'Enabled'
Item0: 'Disabled'
Simple mixer control 'Internal Mic Boost',0
Limits: 0 - 3
Front Left: 3 [100%] [30.00dB]
Front Right: 3 [100%] [30.00dB]
Simple mixer control 'Loopback Mixing',0
Capabilities: enum
Item0: 'Disabled'
!!-------Mixer controls for card NVidia
Card sysdefault:1 'NVidia'/'HDA NVidia at 0x74000000 irq 17'
Mixer name : 'Nvidia GPU a6 HDMI/DP'
Components : 'HDA:10de00a6,10de0000,00100100'
Controls : 28
Simple ctrls : 4
Mono: Playback [on]
Mono: Playback [on]
Mono: Playback [on]
Mono: Playback [on]
!!Alsactl output
--startcollapse--
state.PCH {
control.1 {
iface MIXER
name 'Speaker Playback Volume'
value.0 87
value.1 87
comment {
access 'read write'
type INTEGER
count 2
range '0 - 87'
dbmin -6525
dbmax 0
dbvalue.0 0
dbvalue.1 0
control.2 {
iface MIXER
name 'Speaker Playback Switch'
value.0 true
value.1 true
comment {
access 'read write'
type BOOLEAN
count 2
control.3 {
iface MIXER
name 'Headphone Playback Volume'
value.0 87
value.1 87
comment {
access 'read write'
type INTEGER
count 2
range '0 - 87'
dbmin -6525
dbmax 0
dbvalue.0 0
dbvalue.1 0
control.4 {
iface MIXER
name 'Headphone Playback Switch'
value.0 true
value.1 true
comment {
access 'read write'
type BOOLEAN
count 2
control.5 {
iface MIXER
name 'Loopback Mixing'
value Disabled
comment {
access 'read write'
type ENUMERATED
count 1
item.0 Disabled
item.1 Enabled
control.6 {
iface MIXER
name 'Mic Playback Volume'
value.0 31
value.1 31
comment {
access 'read write'
type INTEGER
count 2
range '0 - 31'
dbmin -3450
dbmax 1200
dbvalue.0 1200
dbvalue.1 1200
control.7 {
iface MIXER
name 'Mic Playback Switch'
value.0 true
value.1 true
comment {
access 'read write'
type BOOLEAN
count 2
control.8 {
iface MIXER
name 'Auto-Mute Mode'
value Disabled
comment {
access 'read write'
type ENUMERATED
count 1
item.0 Disabled
item.1 Enabled
control.9 {
iface MIXER
name 'Capture Volume'
value.0 63
value.1 63
comment {
access 'read write'
type INTEGER
count 2
range '0 - 63'
dbmin -1725
dbmax 3000
dbvalue.0 3000
dbvalue.1 3000
control.10 {
iface MIXER
name 'Capture Switch'
value.0 true
value.1 true
comment {
access 'read write'
type BOOLEAN
count 2
control.11 {
iface MIXER
name 'Mic Boost Volume'
value.0 0
value.1 0
comment {
access 'read write'
type INTEGER
count 2
range '0 - 3'
dbmin 0
dbmax 3000
dbvalue.0 0
dbvalue.1 0
control.12 {
iface MIXER
name 'Internal Mic Boost Volume'
value.0 3
value.1 3
comment {
access 'read write'
type INTEGER
count 2
range '0 - 3'
dbmin 0
dbmax 3000
dbvalue.0 3000
dbvalue.1 3000
control.13 {
iface MIXER
name 'Beep Playback Volume'
value.0 31
value.1 31
comment {
access 'read write'
type INTEGER
count 2
range '0 - 31'
dbmin -3450
dbmax 1200
dbvalue.0 1200
dbvalue.1 1200
control.14 {
iface MIXER
name 'Beep Playback Switch'
value.0 true
value.1 true
comment {
access 'read write'
type BOOLEAN
count 2
control.31 {
iface MIXER
name 'IEC958 Playback Con Mask'
index 16
value '0fff000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000'
comment {
access read
type IEC958
count 1
control.32 {
iface MIXER
name 'IEC958 Playback Pro Mask'
index 16
value '0f00000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000'
comment {
access read
type IEC958
count 1
control.33 {
iface MIXER
name 'IEC958 Playback Default'
index 16
value '0400000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000'
comment {
access 'read write'
type IEC958
count 1
control.34 {
iface MIXER
name 'IEC958 Playback Switch'
index 16
value true
comment {
access 'read write'
type BOOLEAN
count 1
control.19 {
iface MIXER
name 'IEC958 Default PCM Playback Switch'
value true
comment {
access 'read write'
type BOOLEAN
count 1
control.20 {
iface MIXER
name 'Master Playback Volume'
value 71
comment {
access 'read write'
type INTEGER
count 1
range '0 - 87'
dbmin -6525
dbmax 0
dbvalue.0 -1200
control.21 {
iface MIXER
name 'Master Playback Switch'
value true
comment {
access 'read write'
type BOOLEAN
count 1
control.22 {
iface CARD
name 'Mic Jack'
value false
comment {
access read
type BOOLEAN
count 1
control.23 {
iface CARD
name 'Internal Mic Phantom Jack'
value true
comment {
access read
type BOOLEAN
count 1
control.24 {
iface CARD
name 'Speaker Phantom Jack'
value true
comment {
access read
type BOOLEAN
count 1
control.25 {
iface CARD
name 'Headphone Jack'
value false
comment {
access read
type BOOLEAN
count 1
control.26 {
iface CARD
name 'SPDIF Phantom Jack'
value true
comment {
access read
type BOOLEAN
count 1
control.27 {
iface PCM
name 'Playback Channel Map'
value.0 0
value.1 0
comment {
access read
type INTEGER
count 2
range '0 - 36'
control.28 {
iface PCM
name 'Capture Channel Map'
value.0 0
value.1 0
comment {
access read
type INTEGER
count 2
range '0 - 36'
control.29 {
iface PCM
device 1
value.0 0
value.1 0
comment {
access read
type INTEGER
count 2
range '0 - 36'
control.30 {
iface CARD
name 'HDMI/DP,pcm=3 Jack'
value false
comment {
access read
type BOOLEAN
count 1
control.35 {
iface MIXER
comment {
access read
type IEC958
count 1
control.36 {
iface MIXER
comment {
access read
type IEC958
count 1
control.37 {
iface MIXER
comment {
access 'read write'
type IEC958
count 1
control.38 {
iface MIXER
value false
comment {
access 'read write'
type BOOLEAN
count 1
control.39 {
iface PCM
device 3
name ELD
value ''
comment {
access 'read volatile'
type BYTES
count 0
control.40 {
iface CARD
name 'HDMI/DP,pcm=7 Jack'
value false
comment {
access read
type BOOLEAN
count 1
control.41 {
iface MIXER
index 1
comment {
access read
type IEC958
count 1
control.42 {
iface MIXER
index 1
comment {
access read
type IEC958
count 1
control.43 {
iface MIXER
index 1
comment {
access 'read write'
type IEC958
count 1
control.44 {
iface MIXER
index 1
value true
comment {
access 'read write'
type BOOLEAN
count 1
control.45 {
iface PCM
device 7
name ELD
value ''
comment {
type BYTES
count 0
control.46 {
iface CARD
name 'HDMI/DP,pcm=8 Jack'
value false
comment {
access read
type BOOLEAN
count 1
control.47 {
iface MIXER
index 2
comment {
access read
type IEC958
count 1
control.48 {
iface MIXER
index 2
comment {
access read
type IEC958
count 1
control.49 {
iface MIXER
index 2
comment {
access 'read write'
type IEC958
count 1
control.50 {
iface MIXER
index 2
value true
comment {
access 'read write'
type BOOLEAN
count 1
control.51 {
iface PCM
device 8
name ELD
value ''
comment {
type BYTES
count 0
control.52 {
iface CARD
name 'HDMI/DP,pcm=9 Jack'
value false
comment {
access read
type BOOLEAN
count 1
control.53 {
iface MIXER
index 3
comment {
access read
type IEC958
count 1
control.54 {
iface MIXER
index 3
comment {
access read
type IEC958
count 1
control.55 {
iface MIXER
index 3
comment {
access 'read write'
type IEC958
count 1
control.56 {
iface MIXER
index 3
value true
comment {
access 'read write'
type BOOLEAN
count 1
control.57 {
iface PCM
device 9
name ELD
value ''
comment {
type BYTES
count 0
control.58 {
iface PCM
device 3
value.0 0
value.1 0
value.2 0
value.3 0
value.4 0
value.5 0
value.6 0
value.7 0
comment {
access 'read write'
type INTEGER
count 8
range '0 - 36'
control.59 {
iface PCM
device 7
value.0 0
value.1 0
value.2 0
value.3 0
value.4 0
value.5 0
value.6 0
value.7 0
comment {
access 'read write'
type INTEGER
count 8
range '0 - 36'
control.60 {
iface PCM
device 8
value.0 0
value.1 0
value.2 0
value.3 0
value.4 0
value.5 0
value.6 0
value.7 0
comment {
access 'read write'
type INTEGER
count 8
range '0 - 36'
control.61 {
iface PCM
device 9
value.0 0
value.1 0
value.2 0
value.3 0
value.4 0
value.5 0
value.6 0
value.7 0
comment {
access 'read write'
type INTEGER
count 8
range '0 - 36'
control.62 {
iface MIXER
name 'PCM Playback Volume'
value.0 255
value.1 255
comment {
access 'read write user'
type INTEGER
count 2
range '0 - 255'
tlv '0000000100000008ffffec1400000014'
dbmin -5100
dbmax 0
dbvalue.0 0
dbvalue.1 0
state.NVidia {
control.1 {
iface CARD
value false
comment {
access read
type BOOLEAN
count 1
control.2 {
iface MIXER
comment {
access read
type IEC958
count 1
control.3 {
iface MIXER
comment {
access read
type IEC958
count 1
control.4 {
iface MIXER
comment {
access 'read write'
type IEC958
count 1
control.5 {
iface MIXER
value true
comment {
access 'read write'
type BOOLEAN
count 1
control.6 {
iface PCM
device 3
name ELD
value ''
comment {
type BYTES
count 0
control.7 {
iface CARD
value false
comment {
access read
type BOOLEAN
count 1
control.8 {
iface MIXER
index 1
comment {
access read
type IEC958
count 1
control.9 {
iface MIXER
index 1
comment {
access read
type IEC958
count 1
control.10 {
iface MIXER
index 1
comment {
access 'read write'
type IEC958
count 1
control.11 {
iface MIXER
index 1
value true
comment {
access 'read write'
type BOOLEAN
count 1
control.12 {
iface PCM
device 7
name ELD
value ''
comment {
type BYTES
count 0
control.13 {
iface CARD
value false
comment {
access read
type BOOLEAN
count 1
control.14 {
iface MIXER
index 2
comment {
access read
type IEC958
count 1
control.15 {
iface MIXER
index 2
comment {
access read
type IEC958
count 1
control.16 {
iface MIXER
index 2
comment {
access 'read write'
type IEC958
count 1
control.17 {
iface MIXER
index 2
value true
comment {
access 'read write'
type BOOLEAN
count 1
control.18 {
iface PCM
device 8
name ELD
value ''
comment {
type BYTES
count 0
control.19 {
iface CARD
value false
comment {
access read
type BOOLEAN
count 1
control.20 {
iface MIXER
index 3
comment {
access read
type IEC958
count 1
control.21 {
iface MIXER
index 3
comment {
access read
type IEC958
count 1
control.22 {
iface MIXER
index 3
comment {
access 'read write'
type IEC958
count 1
control.23 {
iface MIXER
index 3
value true
comment {
access 'read write'
type BOOLEAN
count 1
control.24 {
iface PCM
device 9
name ELD
value ''
comment {
type BYTES
count 0
control.25 {
iface PCM
device 3
value.0 0
value.1 0
value.2 0
value.3 0
value.4 0
value.5 0
value.6 0
value.7 0
comment {
access 'read write'
type INTEGER
count 8
range '0 - 36'
control.26 {
iface PCM
device 7
value.0 0
value.1 0
value.2 0
value.3 0
value.4 0
value.5 0
value.6 0
value.7 0
comment {
access 'read write'
type INTEGER
count 8
range '0 - 36'
control.27 {
iface PCM
device 8
value.0 0
value.1 0
value.2 0
value.3 0
value.4 0
value.5 0
value.6 0
value.7 0
comment {
access 'read write'
type INTEGER
count 8
range '0 - 36'
control.28 {
iface PCM
device 9
value.0 0
value.1 0
value.2 0
value.3 0
value.4 0
value.5 0
value.6 0
value.7 0
comment {
access 'read write'
type INTEGER
count 8
range '0 - 36'
--endcollapse--
!!All Loaded Modules
ac97_bus
acpi_pad
acpi_thermal_rel
aesni_intel
af_alg
algif_hash
algif_skcipher
atkbd
bluetooth
bnep
bpf_preload
btbcm
btintel
btmtk
btrtl
btusb
ccm
cec
cfg80211
cmac
coretemp
cqhci
crc16
crc32_pclmul
crc32c_generic
crc32c_intel
crct10dif_pclmul
cryptd
crypto_simd
crypto_user
dm_mod
drm_buddy
drm_display_helper
ecdh_generic
ext4
fat
fuse
gf128mul
ghash_clmulni_intel
hid_multitouch
i2c_hid
i2c_hid_acpi
i2c_i801
i2c_smbus
i8042
i915
iTCO_vendor_support
iTCO_wdt
idma64
int3400_thermal
int3403_thermal
int340x_thermal_zone
intel_cstate
intel_gtt
intel_hid
intel_lpss
intel_lpss_pci
intel_pmc_bxt
intel_powerclamp
intel_rapl_common
intel_rapl_msr
intel_tcc_cooling
intel_uncore
intel_vsec
ip_tables
irqbypass
iwlmvm
iwlwifi
jbd2
joydev
kvm
kvm_intel
led_class_multicolor
ledtrig_audio
libarc4
libphy
libps2
loop
mac80211
mac_hid
mbcache
mc
mdio_devres
mei
mei_hdcp
mei_me
mei_pxp
mmc_core
mousedev
mtd
mxm_wmi
nvidia
nvidia_drm
nvidia_modeset
nvidia_uvm
nvidia_wmi_ec_backlight
nvme
nvme_common
nvme_core
pcspkr
pmt_class
pmt_telemetry
polyval_clmulni
polyval_generic
processor_thermal_device
processor_thermal_device_pci
processor_thermal_mbox
processor_thermal_rapl
processor_thermal_rfim
psmouse
qrtr
r8169
rapl
realtek
rfcomm
rfkill
roles
sdhci
sdhci_pci
serio
serio_raw
sha512_ssse3
snd
snd_compress
snd_hda_codec
snd_hda_codec_generic
snd_hda_codec_hdmi
snd_hda_codec_realtek
snd_hda_core
snd_hda_ext_core
snd_hda_intel
snd_hrtimer
snd_hwdep
snd_intel_dspcfg
snd_intel_sdw_acpi
snd_pcm
snd_pcm_dmaengine
snd_seq
snd_seq_device
snd_seq_dummy
snd_soc_acpi
snd_soc_acpi_intel_match
snd_soc_core
snd_soc_hdac_hda
snd_sof
snd_sof_intel_hda
snd_sof_intel_hda_common
snd_sof_pci
snd_sof_pci_intel_tgl
snd_sof_utils
snd_sof_xtensa_dsp
snd_timer
soundcore
soundwire_bus
soundwire_cadence
soundwire_generic_allocation
soundwire_intel
sparse_keymap
spi_intel
spi_intel_pci
spi_nor
thunderbolt
ttm
typec
typec_ucsi
ucsi_acpi
uinput
usbhid
uvcvideo
vfat
video
videobuf2_common
videobuf2_memops
videobuf2_v4l2
videobuf2_vmalloc
videodev
vivaldi_fmap
wmi
x86_pkg_temp_thermal
x_tables
xhci_pci
xhci_pci_renesas
!!Sysfs Files
/sys/class/sound/hwC0D0/init_pin_configs:
0x12 0x90a60130
0x14 0x0421101f
0x15 0x40000000
0x16 0x411111f0
0x17 0x411111f0
0x18 0x04a11040
0x19 0x411111f0
0x1a 0x411111f0
0x1b 0x90170110
0x1d 0x40b7952d
0x1e 0x04451150
/sys/class/sound/hwC0D0/driver_pin_configs:
/sys/class/sound/hwC0D0/user_pin_configs:
/sys/class/sound/hwC0D0/init_verbs:
/sys/class/sound/hwC0D0/hints:
/sys/class/sound/hwC0D2/init_pin_configs:
0x04 0x18560010
0x06 0x18560010
0x08 0x18560010
0x0a 0x18560010
0x0b 0x18560010
0x0c 0x18560010
0x0d 0x18560010
0x0e 0x18560010
0x0f 0x18560010
/sys/class/sound/hwC0D2/driver_pin_configs:
/sys/class/sound/hwC0D2/user_pin_configs:
/sys/class/sound/hwC0D2/init_verbs:
/sys/class/sound/hwC0D2/hints:
/sys/class/sound/hwC1D0/init_pin_configs:
0x04 0x185600f0
0x05 0x585600f0
0x06 0x185600f0
0x07 0x185600f0
/sys/class/sound/hwC1D0/driver_pin_configs:
/sys/class/sound/hwC1D0/user_pin_configs:
/sys/class/sound/hwC1D0/init_verbs:
/sys/class/sound/hwC1D0/hints:
!!ALSA/HDA dmesg
