I have a Munbyn label printer. Munbyn support told me to install this printer on Arch systems, using the ubuntu driver, this way:
$ chmod 755 Munbyn_Driver_Ubuntu.run
$ sudo ./Munbyn_Driver_Ubuntu.run
In CUPS, the printer shows up correctly. However, when I try printing, I get the error message:
stopped “No Available Printer.”
Does anyone know what might be the problem here?
UPDATE:
Found this page, and checked the error_log:
[mzuniga@greew ~]$ less /var/log/cups/error_log.1 | grep 'Job 307'
E [18/Jun/2022:21:35:32 +0000] [Job 307] No Available Printer.
E [18/Jun/2022:21:35:32 +0000] [Job 307] Job stopped due to filter errors; please consult the /var/log/cups/error_log file for details.
D [18/Jun/2022:21:35:32 +0000] [Job 307] The following messages were recorded from 21:35:32 to 21:35:32
D [18/Jun/2022:21:35:32 +0000] [Job 307] Applying default options...
D [18/Jun/2022:21:35:32 +0000] [Job 307] Adding start banner page "none".
D [18/Jun/2022:21:35:32 +0000] [Job 307] Adding end banner page "none".
D [18/Jun/2022:21:35:32 +0000] [Job 307] File of type application/pdf queued by "mzuniga".
D [18/Jun/2022:21:35:32 +0000] [Job 307] hold_until=0
D [18/Jun/2022:21:35:32 +0000] [Job 307] Queued on "Munbyn_Munbyn_ITPP941P" by "mzuniga".
D [18/Jun/2022:21:35:32 +0000] [Job 307] time-at-processing=1655588132
D [18/Jun/2022:21:35:32 +0000] [Job 307] 3 filters for job:
D [18/Jun/2022:21:35:32 +0000] [Job 307] pdftopdf (application/pdf to application/vnd.cups-pdf, cost 66)
D [18/Jun/2022:21:35:32 +0000] [Job 307] gstoraster (application/vnd.cups-pdf to application/vnd.cups-raster, cost 99)
D [18/Jun/2022:21:35:32 +0000] [Job 307] Munbyn/Filter/rastertolabel (application/vnd.cups-raster to printer/Munbyn_Munbyn_ITPP941P, cost 0)
D [18/Jun/2022:21:35:32 +0000] [Job 307] job-sheets=none,none
D [18/Jun/2022:21:35:32 +0000] [Job 307] argv[0]="Munbyn_Munbyn_ITPP941P"
D [18/Jun/2022:21:35:32 +0000] [Job 307] argv[1]="307"
D [18/Jun/2022:21:35:32 +0000] [Job 307] argv[2]="mzuniga"
D [18/Jun/2022:21:35:32 +0000] [Job 307] argv[3]="cn23_4x6inch.xcf"
D [18/Jun/2022:21:35:32 +0000] [Job 307] argv[4]="1"
D [18/Jun/2022:21:35:32 +0000] [Job 307] argv[5]="zePrintRate=4 AdjustVertical=0 Rotate=0 zeMediaTracking=Gap AutoDotted=0 GapOrMarkHeight=3 number-up=1 AdjustHoriaontal=0 MediaMethod=Normal Darkness=8 GapOrMarkOffset=0 PageSize=w288h432 job-uuid=urn:uuid:ca8c0968-d7aa-3271-67d6-e5f274e3e7ab job-originating-host-name=localhost date-time-at-creation= date-time-at-processing= time-at-creation=1655588132 time-at-processing=1655588132"
D [18/Jun/2022:21:35:32 +0000] [Job 307] argv[6]="/var/spool/cups/d00307-001"
D [18/Jun/2022:21:35:32 +0000] [Job 307] envp[0]="CUPS_CACHEDIR=/var/cache/cups"
D [18/Jun/2022:21:35:32 +0000] [Job 307] envp[1]="CUPS_DATADIR=/usr/share/cups"
D [18/Jun/2022:21:35:32 +0000] [Job 307] envp[2]="CUPS_DOCROOT=/usr/share/cups/doc"
D [18/Jun/2022:21:35:32 +0000] [Job 307] envp[3]="CUPS_REQUESTROOT=/var/spool/cups"
D [18/Jun/2022:21:35:32 +0000] [Job 307] envp[4]="CUPS_SERVERBIN=/usr/lib/cups"
D [18/Jun/2022:21:35:32 +0000] [Job 307] envp[5]="CUPS_SERVERROOT=/etc/cups"
D [18/Jun/2022:21:35:32 +0000] [Job 307] envp[6]="CUPS_STATEDIR=/run/cups"
D [18/Jun/2022:21:35:32 +0000] [Job 307] envp[7]="HOME=/var/spool/cups/tmp"
D [18/Jun/2022:21:35:32 +0000] [Job 307] envp[8]="PATH=/usr/lib/cups/filter:/usr/bin:/usr/bin:/bin:/usr/bin"
D [18/Jun/2022:21:35:32 +0000] [Job 307] envp[9]="SERVER_ADMIN=root@greew"
D [18/Jun/2022:21:35:32 +0000] [Job 307] envp[10]="SOFTWARE=CUPS/2.4.2"
D [18/Jun/2022:21:35:32 +0000] [Job 307] envp[11]="TMPDIR=/var/spool/cups/tmp"
D [18/Jun/2022:21:35:32 +0000] [Job 307] envp[12]="USER=root"
D [18/Jun/2022:21:35:32 +0000] [Job 307] envp[13]="CUPS_MAX_MESSAGE=2047"
D [18/Jun/2022:21:35:32 +0000] [Job 307] envp[14]="CUPS_SERVER=/run/cups/cups.sock"
D [18/Jun/2022:21:35:32 +0000] [Job 307] envp[15]="CUPS_ENCRYPTION=IfRequested"
D [18/Jun/2022:21:35:32 +0000] [Job 307] envp[16]="IPP_PORT=631"
D [18/Jun/2022:21:35:32 +0000] [Job 307] envp[17]="CHARSET=utf-8"
D [18/Jun/2022:21:35:32 +0000] [Job 307] envp[18]="LANG=en_GB.UTF-8"
D [18/Jun/2022:21:35:32 +0000] [Job 307] envp[19]="PPD=/etc/cups/ppd/Munbyn_Munbyn_ITPP941P.ppd"
D [18/Jun/2022:21:35:32 +0000] [Job 307] envp[20]="CONTENT_TYPE=application/pdf"
D [18/Jun/2022:21:35:32 +0000] [Job 307] envp[21]="DEVICE_URI=dnssd://usbprinter1%20%40%20xylan._printer._tcp.local/"
D [18/Jun/2022:21:35:32 +0000] [Job 307] envp[22]="PRINTER_INFO=Munbyn Munbyn ITPP941P"
D [18/Jun/2022:21:35:32 +0000] [Job 307] envp[23]="PRINTER_LOCATION="
D [18/Jun/2022:21:35:32 +0000] [Job 307] envp[24]="PRINTER=Munbyn_Munbyn_ITPP941P"
D [18/Jun/2022:21:35:32 +0000] [Job 307] envp[25]="PRINTER_STATE_REASONS=none"
D [18/Jun/2022:21:35:32 +0000] [Job 307] envp[26]="CUPS_FILETYPE=document"
D [18/Jun/2022:21:35:32 +0000] [Job 307] envp[27]="FINAL_CONTENT_TYPE=application/vnd.cups-raster"
D [18/Jun/2022:21:35:32 +0000] [Job 307] envp[28]="AUTH_I****"
D [18/Jun/2022:21:35:32 +0000] [Job 307] Started filter /usr/lib/cups/filter/pdftopdf (PID 525752)
D [18/Jun/2022:21:35:32 +0000] [Job 307] Started filter /usr/lib/cups/filter/gstoraster (PID 525753)
D [18/Jun/2022:21:35:32 +0000] [Job 307] Started filter /usr/lib/cups/filter/Munbyn/Filter/rastertolabel (PID 525754)
D [18/Jun/2022:21:35:32 +0000] [Job 307] Started backend /usr/lib/cups/backend/dnssd (PID 525755)
D [18/Jun/2022:21:35:32 +0000] [Job 307] Resolving \"usbprinter1 @ xylan._printer._tcp.local\"...
D [18/Jun/2022:21:35:32 +0000] [Job 307] STATE: +connecting-to-device
D [18/Jun/2022:21:35:32 +0000] [Job 307] Resolving \"usbprinter1 @ xylan\", regtype=\"_printer._tcp\", domain=\"local.\"...
D [18/Jun/2022:21:35:32 +0000] [Job 307] OUTFORMAT=\"<none>\", so output format will be CUPS/PWG Raster
D [18/Jun/2022:21:35:32 +0000] [Job 307] pdftopdf: Last filter determined by the PPD: rastertolabel; FINAL_CONTENT_TYPE: application/vnd.cups-raster => pdftopdf will not log pages in page_log.
D [18/Jun/2022:21:35:32 +0000] [Job 307] PDF interactive form and annotation flattening done via QPDF
D [18/Jun/2022:21:35:32 +0000] [Job 307] pdftopdf: \"print-scaling\" IPP attribute: auto
D [18/Jun/2022:21:35:32 +0000] [Job 307] pdftopdf: Print scaling mode: Do not scale, center, crop if needed
D [18/Jun/2022:21:35:32 +0000] [Job 307] After Cropping: 288.000000 432.000000 288.000000 432.000000
D [18/Jun/2022:21:35:32 +0000] [Job 307] PID 525752 (/usr/lib/cups/filter/pdftopdf) exited with no errors.
D [18/Jun/2022:21:35:32 +0000] [Job 307] Color Manager: Calibration Mode/Off
D [18/Jun/2022:21:35:32 +0000] [Job 307] Calling FindDeviceById(cups-Munbyn_Munbyn_ITPP941P)
D [18/Jun/2022:21:35:32 +0000] [Job 307] Found device /org/freedesktop/ColorManager/devices/cups_Munbyn_Munbyn_ITPP941P
D [18/Jun/2022:21:35:32 +0000] [Job 307] Calling org.freedesktop.ColorManager.Device.Get(ProfilingInhibitors)
D [18/Jun/2022:21:35:32 +0000] [Job 307] Calling GetProfileForQualifiers(Gray..203dpi...)
D [18/Jun/2022:21:35:32 +0000] [Job 307] Failed to send: org.freedesktop.ColorManager.Device.NothingMatched:nothing matched expression \'Gray..203dpi,Gray..*,Gray.*.203dpi,Gray.*.*,*\'
D [18/Jun/2022:21:35:32 +0000] [Job 307] Failed to get profile filename for cups-Munbyn_Munbyn_ITPP941P
D [18/Jun/2022:21:35:32 +0000] [Job 307] Color Manager: no profiles specified in PPD
D [18/Jun/2022:21:35:32 +0000] [Job 307] Set job-printer-state-message to "Color Manager: no profiles specified in PPD", current level=INFO
D [18/Jun/2022:21:35:32 +0000] [Job 307] Color Manager: ICC Profile: None
D [18/Jun/2022:21:35:32 +0000] [Job 307] Ghostscript using Any-Part-of-Pixel method to fill paths.
D [18/Jun/2022:21:35:32 +0000] [Job 307] Ghostscript command line: gs -dQUIET -dSAFER -dNOPAUSE -dBATCH -dNOINTERPOLATE -dNOMEDIAATTRS -dShowAcroForm -sstdout=%stderr -sOutputFile=%stdout -sDEVICE=cups -r203x203 -dDEVICEWIDTHPOINTS=288 -dDEVICEHEIGHTPOINTS=432 -dcupsBitsPerColor=8 -dcupsColorOrder=0 -dcupsColorSpace=0 -dcupsRowCount=8 -scupsPageSizeName=w288h432 -I/usr/share/cups/fonts -c \'<</.HWMargins[0.000000 0.000000 0.000000 0.000000] /Margins[0 0]>>setpagedevice\' -f -_
D [18/Jun/2022:21:35:32 +0000] [Job 307] envp[0]=\"CUPS_CACHEDIR=/var/cache/cups\"
D [18/Jun/2022:21:35:32 +0000] [Job 307] envp[1]=\"CUPS_DATADIR=/usr/share/cups\"
D [18/Jun/2022:21:35:32 +0000] [Job 307] envp[2]=\"CUPS_DOCROOT=/usr/share/cups/doc\"
D [18/Jun/2022:21:35:32 +0000] [Job 307] envp[3]=\"CUPS_REQUESTROOT=/var/spool/cups\"
D [18/Jun/2022:21:35:32 +0000] [Job 307] envp[4]=\"CUPS_SERVERBIN=/usr/lib/cups\"
D [18/Jun/2022:21:35:32 +0000] [Job 307] envp[5]=\"CUPS_SERVERROOT=/etc/cups\"
D [18/Jun/2022:21:35:32 +0000] [Job 307] envp[6]=\"CUPS_STATEDIR=/run/cups\"
D [18/Jun/2022:21:35:32 +0000] [Job 307] envp[7]=\"HOME=/var/spool/cups/tmp\"
D [18/Jun/2022:21:35:32 +0000] [Job 307] envp[8]=\"PATH=/usr/lib/cups/filter:/usr/bin:/usr/bin:/bin:/usr/bin\"
D [18/Jun/2022:21:35:32 +0000] [Job 307] envp[9]=\"SERVER_ADMIN=root@greew\"
D [18/Jun/2022:21:35:32 +0000] [Job 307] envp[10]=\"SOFTWARE=CUPS/2.4.2\"
D [18/Jun/2022:21:35:32 +0000] [Job 307] envp[11]=\"TMPDIR=/var/spool/cups/tmp\"
D [18/Jun/2022:21:35:32 +0000] [Job 307] envp[12]=\"USER=root\"
D [18/Jun/2022:21:35:32 +0000] [Job 307] envp[13]=\"CUPS_MAX_MESSAGE=2047\"
D [18/Jun/2022:21:35:32 +0000] [Job 307] envp[14]=\"CUPS_SERVER=/run/cups/cups.sock\"
D [18/Jun/2022:21:35:32 +0000] [Job 307] envp[15]=\"CUPS_ENCRYPTION=IfRequested\"
D [18/Jun/2022:21:35:32 +0000] [Job 307] envp[16]=\"IPP_PORT=631\"
D [18/Jun/2022:21:35:32 +0000] [Job 307] envp[17]=\"CHARSET=utf-8\"
D [18/Jun/2022:21:35:32 +0000] [Job 307] envp[18]=\"LANG=en_GB.UTF-8\"
D [18/Jun/2022:21:35:32 +0000] [Job 307] envp[19]=\"PPD=/etc/cups/ppd/Munbyn_Munbyn_ITPP941P.ppd\"
D [18/Jun/2022:21:35:32 +0000] [Job 307] envp[20]=\"CONTENT_TYPE=application/pdf\"
D [18/Jun/2022:21:35:32 +0000] [Job 307] envp[21]=\"DEVICE_URI=dnssd://usbprinter1%20%40%20xylan._printer._tcp.local/\"
D [18/Jun/2022:21:35:32 +0000] [Job 307] envp[22]=\"PRINTER_INFO=Munbyn Munbyn ITPP941P\"
D [18/Jun/2022:21:35:32 +0000] [Job 307] envp[23]=\"PRINTER_LOCATION=\"
D [18/Jun/2022:21:35:32 +0000] [Job 307] envp[24]=\"PRINTER=Munbyn_Munbyn_ITPP941P\"
D [18/Jun/2022:21:35:32 +0000] [Job 307] envp[25]=\"PRINTER_STATE_REASONS=none\"
D [18/Jun/2022:21:35:32 +0000] [Job 307] envp[26]=\"CUPS_FILETYPE=document\"
D [18/Jun/2022:21:35:32 +0000] [Job 307] envp[27]=\"FINAL_CONTENT_TYPE=application/vnd.cups-raster\"
D [18/Jun/2022:21:35:32 +0000] [Job 307] envp[28]=\"AUTH_INFO_REQUIRED=none\"
D [18/Jun/2022:21:35:32 +0000] [Job 307] Start rendering...
D [18/Jun/2022:21:35:32 +0000] [Job 307] Set job-printer-state-message to "Start rendering...", current level=INFO
D [18/Jun/2022:21:35:32 +0000] [Job 307] Processing page 1...
D [18/Jun/2022:21:35:32 +0000] [Job 307] Set job-printer-state-message to "Processing page 1...", current level=INFO
D [18/Jun/2022:21:35:32 +0000] [Job 307] Resolved as \"lpd://xylan.local:515/usbprinter1\"...
D [18/Jun/2022:21:35:32 +0000] [Job 307] STATE: -connecting-to-device,offline-report
D [18/Jun/2022:21:35:32 +0000] [Job 307] Executing backend \"/usr/lib/cups/backend/lpd\"...
D [18/Jun/2022:21:35:32 +0000] [Job 307] Looking up \"xylan.local\"...
D [18/Jun/2022:21:35:32 +0000] [Job 307] xylan.local=192.168.1.222
D [18/Jun/2022:21:35:32 +0000] [Job 307] backendWaitLoop(snmp_fd=6, addr=0x564f0b1116a8, side_cb=0x564f09ece6e0)
D [18/Jun/2022:21:35:32 +0000] [Job 307] Set job-printer-state-message to "No Available Printer.", current level=ERROR
D [18/Jun/2022:21:35:32 +0000] [Job 307] PID 525754 (/usr/lib/cups/filter/Munbyn/Filter/rastertolabel) stopped with status 1.
D [18/Jun/2022:21:35:32 +0000] [Job 307] Hint: Try setting the LogLevel to "debug" to find out more.
D [18/Jun/2022:21:35:32 +0000] [Job 307] PID 525755 (/usr/lib/cups/backend/dnssd) exited with no errors.
D [18/Jun/2022:21:35:32 +0000] [Job 307] Processing page 2...
D [18/Jun/2022:21:35:32 +0000] [Job 307] Rendering completed
D [18/Jun/2022:21:35:32 +0000] [Job 307] PID 525753 (/usr/lib/cups/filter/gstoraster) exited with no errors.
D [18/Jun/2022:21:35:32 +0000] [Job 307] End of messages
D [18/Jun/2022:21:35:32 +0000] [Job 307] printer-state=3(idle)
D [18/Jun/2022:21:35:32 +0000] [Job 307] printer-state-message="Rendering completed"
D [18/Jun/2022:21:35:32 +0000] [Job 307] printer-state-reasons=none
The following lines might be important:
Can this be due to a problem with the driver?
