Thanks for the responses everyone!
I should clarify that the “other issues” are related to increased latency and lower throughput - not routing.
@bedna I do have separate network cards for every connection. One integrated (Internet), one PCIe (very rarely used but this is actually static IP) and one USB device (which is forced to be DHCP basically, and it even changes its MAC accress every connection because who knows why). Only one interface (the integrated) will ever have access to the Internet, the other ones are not connectable to the Internet.
Then again, my WIFI and Ethernet go to the same Internet-connected local network, there’s no issue in networking if they are both connected. In that light, it makes no sense to limit to only one wired connection at a time.
This starts to sound like a bug on the KDE side. There was no such issue with Gnome (which I will not go back to).
@Mirdarthos Everything else needs to be DHCP, but the Internet connectivity card could actually have a static IP address. I’ll try that, thanks!
@linux-aarhus As I wrote above, I can have Ethernet and WIFI connection to the same Internet-connected LAN and there’s no issue. Also, routing issues would come after I manage to somehow have two Ethernet connections active at the same time. The GUI tools at least don’t allow that, that’s the issue.
Currently every device is using DHCP, no configuration has been made whatsoever. If I click the connect on the left picture, the right picture results, and vica versa. The “shorter” Ethernet device and the WIFI are connected to the same LAN with Internet access.
It’s not possible to have two Ethernet devices (or any two devices of the same type I think) connected at the same time (without extra configuration). To me this is a bug.
PS. I have also studied IPv4 and routing in depth and have several years of work experience on top of that, but thanks for the effort anyway
