Hello, I’m running into some weird issues after updating the system 2 days ago after a very long time without using that computer, over a year.
Here are the issues I’m running into:
- The Backlight of the keyboard suddenly became really low no matter the setting, it stay the same, don’t get brighter, just turn off at 0, become low at minimum, stay the same until highest setting. I couldn’t find anything on that issue with gnome nor apple & the kde seems unrelated when I look in the terminal.
- My Speaker randomly stop working, quick work around I found out was to go into setting>sound, switch between the Built-in Audio & Digital Output to get back to the Built-in Audio then it work again, sometimes the Built-in Audio disappear, in those case I have to run “sudo pulseaudio -vvv” from terminal then reboot for it to come back but it randomly stop working & I have to go back to switching between Built-in & Digital to get sound again…
- Wifi suddenly stop working & won’t come back without restarting the computer. I have no clue what to do about it, drivers seems up to date, is it an apple issue? This issue unlike the first two isn’t new, it happened already before the last update.
- This one is really weird, not new either, happened before aswell, I looked into shortcut hoping it was it but it didn’t work. When I put my phone next to the touchpad, under the keyboard (below fn, ctrl, alt, cmd) or even just sometime with the palm on my hand going to the space on the keyboard, the computer just suddenly lock itself, would anyone have a clue what could be leading to this?
Issue 1 & 2 are new, since the update 2 days ago, issue 3 & 4 happened already before.
I’ve read that pipewire & pulse didn’t work well together but I didn’t install either of them, it came with the install, did one got added by the update? In any case I can’t remove either of them because of dependencies it says, so I don’t know…
I’ve been thinking of going with a fresh install of manjaro but honestly, it’s a triple boot, Mac > Windows > Linux, so Linux is always the autoboot, it runs with the Mac boot, if I re-install it’ll break Mac, which lead to a break of Windows & reinstalling Mac then Windows is a real hassle on this… (yes I’ve already gone throught it
Here’s the inxi, what else would be needed to help me resolve that issue? I’m looking into the wiki & in topic in the forum but maybe I’m dumb because I can’t find a way to resolve those issue, the workaround I use can only work for so long… Thanks in advance…
inxi -zv8 ✔
Kernel: 6.1.131-1-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 14.2.1
root=UUID=83f788f2-2b6f-40d3-9257-93c2398082aa rw quiet splash apparmor=1
Desktop: GNOME v: 47.5 tk: GTK v: 3.24.49 wm: gnome-shell
tools: gsd-screensaver-proxy dm: GDM v: 47.0 Distro: Manjaro
base: Arch Linux
Type: Laptop System: Apple product: MacBookPro9,2 v: 1.0
serial: <superuser required> Chassis: type: 10 v: Mac-6F01561E16C75D06
Mobo: Apple model: Mac-6F01561E16C75D06 v: MacBookPro9,2
serial: <superuser required> uuid: <superuser required> UEFI: Apple
v: 421.0.0.0.0 date: 12/17/2020
ID-1: BAT0 charge: 10.4 Wh (33.0%) condition: 31.5/62.9 Wh (50.2%)
volts: 11.8 min: 10.9 model: DP bq20z451 type: Li-ion serial: N/A
status: charging cycles: 3348
System RAM: total: 16 GiB available: 15.53 GiB used: 2.53 GiB (16.3%)
Array-1: capacity: 16 GiB note: est. slots: 2 modules: 2 EC: None
Device-1: DIMM0 type: DDR3 detail: synchronous size: 8 GiB
speed: 1600 MT/s volts: N/A width: N/A manufacturer: 0x0198
part-no: 0x393930353432382D3435322E4130304C4620 serial: <filter>
Device-2: DIMM0 type: DDR3 detail: synchronous size: 8 GiB
part-no: 0x393930353432382D3133382E4130304C4620 serial: <filter>
Info: model: Intel Core i5-3210M bits: 64 type: MT MCP arch: Ivy Bridge
gen: core 3 level: v2 built: 2012-15 process: Intel 22nm family: 6
model-id: 0x3A (58) stepping: 9 microcode: 0x21
Topology: cpus: 1x dies: 1 clusters: 2 cores: 2 threads: 4 tpc: 2
smt: enabled cache: L1: 128 KiB desc: d-2x32 KiB; i-2x32 KiB L2: 512 KiB
desc: 2x256 KiB L3: 3 MiB desc: 1x3 MiB
Speed (MHz): avg: 2894 min/max: 1200/3100 scaling: driver: intel_cpufreq
governor: schedutil cores: 1: 2894 2: 2894 3: 2894 4: 2894 bogomips: 19961
Flags: acpi aes aperfmperf apic arat arch_perfmon avx bts clflush cmov
constant_tsc cpuid cpuid_fault cx16 cx8 de ds_cpl dtes64 dtherm dts ept
erms est f16c flexpriority flush_l1d fpu fsgsbase fxsr ht ibpb ibrs ida
lahf_lm lm mca mce md_clear mmx monitor msr mtrr nonstop_tsc nopl nx pae
pat pbe pcid pclmulqdq pdcm pebs pge pln pni popcnt pse pse36 pti pts
rdrand rdtscp rep_good sep smep ss ssbd sse sse2 sse4_1 sse4_2 ssse3
stibp syscall tm tm2 tpr_shadow tsc tsc_deadline_timer vme vmx vnmi vpid
x2apic xsave xsaveopt xtopology xtpr
vulnerable
STIBP: conditional; RSB filling; PBRSB-eIBRS: Not affected; BHI: Not
affected
Type: srbds status: Vulnerable: No microcode
Device-1: Intel 3rd Gen Core processor Graphics vendor: Apple driver: i915
v: kernel arch: Gen-7 process: Intel 22nm built: 2012-13 ports:
active: LVDS-1 empty: DP-1, DP-2, DP-3, HDMI-A-1, HDMI-A-2, HDMI-A-3,
VGA-1 bus-ID: 00:02.0 chip-ID: 8086:0166 class-ID: 0300
Device-2: Apple FaceTime HD Camera driver: uvcvideo type: USB rev: 2.0
speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 1-1.1:3 chip-ID: 05ac:8509
compositor: gnome-shell driver: gpu: i915 display-ID: 0
Monitor-1: LVDS-1 model: Apple 0x9cc5 built: 2009 res: 1280x800 dpi: 114
gamma: 1.2 chroma: red: x: 0 y: 0 green: x: 0 y: 0 blue: x: 0 y: 0 white:
x: 0.314 y: 0.329 size: 286x179mm (11.26x7.05") diag: 337mm (13.3")
ratio: 16:10 modes: 1280x800
EDID-Warnings: 1: parse_edid: unknown flag 1
API: EGL v: 1.5 hw: drv: intel crocus platforms: device: 0 drv: crocus
device: 1 drv: swrast gbm: drv: crocus surfaceless: drv: crocus wayland:
drv: crocus x11: drv: crocus
API: OpenGL v: 4.5 compat-v: 4.2 vendor: intel mesa v: 25.0.1-arch1.2
glx-v: 1.4 direct-render: yes renderer: Mesa Intel HD Graphics 4000 (IVB
GT2) device-ID: 8086:0166 memory: 1.46 GiB unified: yes display-ID: :0.0
Info: Tools: api: eglinfo,glxinfo x11: xprop,xrandr
Device-1: Intel 7 Series/C216 Family High Definition Audio
driver: snd_hda_intel v: kernel bus-ID: 00:1b.0 chip-ID: 8086:1e20
class-ID: 0403
API: ALSA v: k6.1.131-1-MANJARO status: kernel-api with: aoss
Server-2: PipeWire v: 1.4.1 status: active with: wireplumber
status: active tools: pw-cat,pw-cli,wpctl
Server-3: PulseAudio v: 17.0-43-g3e2bb status: active
with: pulseaudio-alsa type: plugin tools: pacat,pactl,pavucontrol
Device-1: Broadcom NetXtreme BCM57765 Gigabit Ethernet PCIe driver: tg3
v: kernel pcie: gen: 1 speed: 2.5 GT/s lanes: 1 port: N/A bus-ID: 01:00.0
chip-ID: 14e4:16b4 class-ID: 0200
IF: enp1s0f0 state: down mac: <filter>
Device-2: Broadcom BCM4331 802.11a/b/g/n vendor: Apple AirPort Extreme
driver: wl v: kernel modules: bcma pcie: gen: 1 speed: 2.5 GT/s lanes: 1
bus-ID: 02:00.0 chip-ID: 14e4:4331 class-ID: 0280
Info: services: mld, NetworkManager, systemd-timesyncd, wpa_supplicant
Local Storage: total: 447.13 GiB used: 22.53 GiB (5.0%)
ID-1: /dev/sda maj-min: 8:0 vendor: Kingston model: SA400S37480G
size: 447.13 GiB block-size: physical: 512 B logical: 512 B speed: 6.0 Gb/s
tech: SSD serial: <filter> fw-rev: K1B3 scheme: GPT
ID-1: / raw-size: 50.1 GiB size: 49.01 GiB (97.83%) used: 22.52 GiB (45.9%)
fs: ext4 dev: /dev/sda4 maj-min: 8:4 label: N/A
uuid: 83f788f2-2b6f-40d3-9257-93c2398082aa
ID-2: /boot/efi raw-size: 477 MiB size: 476.7 MiB (99.94%)
used: 8.4 MiB (1.8%) fs: vfat dev: /dev/sda1 maj-min: 8:1 label: EFI
uuid: F3BF-1729
ID-1: /dev/sda2 maj-min: 8:2 size: 44.7 GiB fs: apfs label: N/A
uuid: f1b93964-bad1-45e5-8e4f-fe991d6e2b6f
ID-2: /dev/sda3 maj-min: 8:3 size: 150.9 GiB fs: ntfs label: BOOTCAMP
uuid: 34F5EE1202469FF7
ID-3: /dev/sda5 maj-min: 8:5 size: 200.96 GiB fs: exfat label: Data
uuid: 64D4-8FAC
Hub-1: 1-0:1 info: full speed or root hub ports: 2 rev: 2.0
speed: 480 Mb/s (57.2 MiB/s) lanes: 1 mode: 2.0 chip-ID: 8087:0024
Device-1: 1-1.1:3 info: Apple FaceTime HD Camera type: video
driver: uvcvideo interfaces: 3 rev: 2.0 speed: 480 Mb/s (57.2 MiB/s)
lanes: 1 mode: 2.0 power: 500mA chip-ID: 05ac:8509 class-ID: 0e02
serial: <filter>
Hub-3: 2-0:1 info: full speed or root hub ports: 2 rev: 2.0
Hub-4: 2-1:2 info: Intel Integrated Rate Matching Hub ports: 8 rev: 2.0
Hub-5: 2-1.8:3 info: Microchip (formerly SMSC) 2.0 Hub ports: 3 rev: 2.0
speed: 480 Mb/s (57.2 MiB/s) lanes: 1 mode: 2.0 power: 2mA
chip-ID: 0424:2513 class-ID: 0900
Device-1: 2-1.8.2:4 info: Apple Built-in IR Receiver type: HID
driver: appleir,usbhid interfaces: 1 rev: 2.0 speed: 1.5 Mb/s (183 KiB/s)
lanes: 1 mode: 1.0 power: 100mA chip-ID: 05ac:8242 class-ID: 0300
Device-2: 2-1.8.3:5 info: Apple Internal Keyboard/Trackpad (ISO)
type: keyboard,HID,mouse driver: apple,bcm5974,usbhid interfaces: 3 rev: 2.0
speed: 12 Mb/s (1.4 MiB/s) lanes: 1 mode: 1.1 power: 40mA
chip-ID: 05ac:0253 class-ID: 0301
Hub-6: 3-0:1 info: hi-speed hub with single TT ports: 4 rev: 2.0
Device-1: 3-1:2 info: Yubicom Yubikey 4/5 OTP+U2F+CCID
type: keyboard,HID,smart card driver: hid-generic,usbhid interfaces: 3
rev: 2.0 speed: 12 Mb/s (1.4 MiB/s) lanes: 1 mode: 1.1 power: 30mA
chip-ID: 1050:0407 class-ID: 0b00
Hub-7: 4-0:1 info: super-speed hub ports: 4 rev: 3.0
System Temperatures: cpu: 88.0 C mobo: N/A
Fan Speeds (rpm): N/A
Packages: pm: pacman pkgs: 1350 libs: 381 tools: gnome-software,pamac
pm: flatpak pkgs: 0
1: https://mirrors.manjaro.org/repo/stable/$repo/$arch
2: https://mirror.vinehost.net/manjaro/stable/$repo/$arch
3: https://mirror.zetup.net/manjaro/stable/$repo/$arch
4: https://coresite.mm.fcix.net/manjaro/stable/$repo/$arch
5: https://mirror.xenyth.net/manjaro/stable/$repo/$arch
6: https://muug.ca/mirror/manjaro/stable/$repo/$arch
7: https://mirror.ufam.edu.br/manjaro/stable/$repo/$arch
8: https://gsl-syd.mm.fcix.net/manjaro/stable/$repo/$arch
Processes:
CPU top: 5 of 231
1: cpu: 99.5% command: pipewire pid: 1912 mem: 10.7 MiB (0.0%)
2: cpu: 27.0% command: localsearch-extractor-3 pid: 3330
mem: 31.1 MiB (0.1%)
3: cpu: 5.1% command: firefox pid: 2198 mem: 433.6 MiB (2.7%)
4: cpu: 3.4% command: firefox pid: 2420 mem: 296.3 MiB (1.8%)
5: cpu: 3.2% command: gnome-shell pid: 1422 mem: 297.0 MiB (1.8%)
Memory top: 5 of 231
1: mem: 433.6 MiB (2.7%) command: firefox pid: 2198 cpu: 5.1%
2: mem: 297.0 MiB (1.8%) command: gnome-shell pid: 1422 cpu: 3.2%
3: mem: 296.3 MiB (1.8%) command: firefox pid: 2420 cpu: 3.4%
4: mem: 249.4 MiB (1.5%) command: firefox pid: 2441 cpu: 0.3%
5: mem: 208.1 MiB (1.3%) command: firefox pid: 2424 cpu: 0.2%
Processes: 231 Power: uptime: 28m states: freeze,mem,disk suspend: deep
suspend, test_resume image: 6.2 GiB services: gsd-power,
tool: systemctl
Compilers: clang: 19.1.7 gcc: 14.2.1 Shell: Zsh v: 5.9
running-in: gnome-terminal inxi: 3.3.37
aplay -L INT ✘
null
Discard all samples (playback) or generate zero samples (capture)
lavrate
Rate Converter Plugin Using Libav/FFmpeg Library
samplerate
Rate Converter Plugin Using Samplerate Library
speexrate
Rate Converter Plugin Using Speex Resampler
jack
JACK Audio Connection Kit
oss
Open Sound System
pipewire
PipeWire Sound Server
pulse
PulseAudio Sound Server
speex
Plugin using Speex DSP (resample, agc, denoise, echo, dereverb)
upmix
Plugin for channel upmix (4,6,8)
vdownmix
Plugin for channel downmix (stereo) with a simple spacialization
default
Default ALSA Output (currently PulseAudio Sound Server)
sysdefault:CARD=PCH
HDA Intel PCH, CS4206 Analog
Default Audio Device
front:CARD=PCH,DEV=0
Front output / input
surround21:CARD=PCH,DEV=0
2.1 Surround output to Front and Subwoofer speakers
surround40:CARD=PCH,DEV=0
4.0 Surround output to Front and Rear speakers
surround41:CARD=PCH,DEV=0
4.1 Surround output to Front, Rear and Subwoofer speakers
surround50:CARD=PCH,DEV=0
5.0 Surround output to Front, Center and Rear speakers
surround51:CARD=PCH,DEV=0
5.1 Surround output to Front, Center, Rear and Subwoofer speakers
surround71:CARD=PCH,DEV=0
7.1 Surround output to Front, Center, Side, Rear and Woofer speakers
iec958:CARD=PCH,DEV=0
HDA Intel PCH, CS4206 Digital
IEC958 (S/PDIF) Digital Audio Output
hdmi:CARD=PCH,DEV=0
HDA Intel PCH, HDMI 0
HDMI Audio Output
hdmi:CARD=PCH,DEV=1
HDA Intel PCH, HDMI 1
HDMI Audio Output
hdmi:CARD=PCH,DEV=2
HDA Intel PCH, HDMI 2
HDMI Audio Output
usbstream:CARD=PCH
HDA Intel PCH
USB Stream Output
mhwd-kernel -li ✔
Currently running: 6.1.131-1-MANJARO (linux61)
* linux61
