Multiple Electron versions installed (13, 15, 17, 20): Do I need them all?
As per the title: when I search ‘Electron’ on my GNOME machine, I see four versions of it installed: electron13, electron15, electron17 and electron (the last one being Electron 20, the latest version).
My question is, do I need all of these? Is there a way to find out if any pre-installed apps on my machine need any of these versions of Electron to run? I didn’t install Manjaro myself on my machine, so would like to clarify if I actually need specific versions of Electron, so I can remove any ones I can to free up some space.
Thanks a lot!
Only you know your system and requirements.
Check, if those are orphans and possibly remove:
