Ok. This is a thing that I keep stumbling upon every now and then.
Last time, this morning while using PAMAC to upgrade the 300+ packages it was alerting as “due for upgrade”.
The output:
Preparing…
Synchronizing package databases…
Resolving dependencies…
Checking inter-conflicts…
Checking keyring…
Checking integrity…
Loading package files…
Checking file conflicts…
Failed to commit transaction:
conflicting files:
- /etc/skel/.xinitrc exists in both manjaro-gnome-settings and manjaro-kde-settings
I’ve made my homeworks and gone through this:
…which lead me to renaming /etc/skel/.xinitrc into /etc/skel/.xinitrc.old
Yet the second spin of upgrading from PAMAC returned the very same error…hmmmm.
Time to see if there was a concurrent ownership claimed by multiple packages at the same time.
pacman -Qo /etc/skel/.xinitrc
/etc/skel/.xinitrc is owned by manjaro-gnome-settings 20200512-1
…while I am using KDE…! So I should have given PAMAC more credit (“the same file exists in 2 packages” that are meant to be used in an exclusive manner…that is…one at a time!).
Knowing that this would possibly break the other (unused) DE installed on my machine (GNOME), I had to swallow the bullet and try to see if removing the elements causing co-ownership of xinitrc would solve the issue:
sudo pacman -R manjaro-gnome-assets
sudo pacman -R manjaro-gnome-settings
Then I crossed my finger and re-used PAMAC to perform the hundreds upgrades…this time it did work.
But what’s gonna happen next time I have to eventually use GNOME? Will surely have to re-install the removed packages…
My question(s)
- Will re-installing manjaro-gnome-assets and settings be enough to re-run GNOME?
- Is there a better way to handle multiple DE co-existence (aka co-ownership of /etc/skel/.xinitrc) or should I surrender to the idea of completely uninstalling GNOME?
