Ran the programs from console and while there were some errors none seemed related to each other or the issue itself, they all just terminate with:
zsh: segmentation fault (core dumped)
Here is the inxi output:
Kernel: 6.12.68-1-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 15.2.1
root=UUID=46cd7c27-c44c-4f3e-b31f-c78a397024d8 rw quiet splash
udev.log_priority=3 DEEPIN_GFXMODE=
Desktop: KDE Plasma v: 6.5.5 tk: Qt v: N/A info: frameworks v: 6.22.0
Type: Desktop Mobo: ASRock model: B450M Pro4 R2.0
serial: <superuser required> uuid: <superuser required> Firmware: UEFI
vendor: American Megatrends v: P5.70 date: 10/20/2022
System RAM: total: 32 GiB available: 31.27 GiB used: 12.58 GiB (40.2%)
Device-1: Channel-A DIMM 0 type: no module installed
(unregistered) size: 16 GiB speed: 3134 MT/s volts: note: check curr: 1
min: 1 max: 1 width (bits): data: 64 total: 64 manufacturer: Corsair
part-no: CMK32GX4M2D3600C18 serial: N/A
Device-3: Channel-B DIMM 0 type: no module installed
Info: model: AMD Ryzen 5 3600 bits: 64 type: MT MCP arch: Zen 2 gen: 2
level: v3 note: check built: 2020-22 process: TSMC n7 (7nm)
family: 0x17 (23) model-id: 0x71 (113) stepping: 0 microcode: 0x8701034
desc: 6x512 KiB L3: 32 MiB desc: 2x16 MiB
Speed (MHz): avg: 4100 min/max: 550/4793 boost: enabled scaling:
driver: amd-pstate-epp governor: performance cores: 1: 4100 2: 4100 3: 4100
4: 4100 5: 4100 6: 4100 7: 4100 8: 4100 9: 4100 10: 4100 11: 4100 12: 4100
bogomips: 98438
f16c flushbyasid fma fpu fsgsbase fxsr fxsr_opt ht hw_pstate ibpb ibs
pfthreshold pge pni popcnt pse pse36 rapl rdpid rdpru rdrand rdseed rdt_a
rdtscp rep_good sep sev sev_es sha_ni skinit smap smca smep ssbd sse sse2
sse4_1 sse4_2 sse4a ssse3 stibp succor svm svm_lock syscall tce topoext
tsc tsc_scale umip v_spec_ctrl v_vmsave_vmload vgif vmcb_clean vme
vmmcall wbnoinvd wdt x2apic xgetbv1 xsave xsavec xsaveerptr xsaveopt
xtopology
Type: retbleed mitigation: untrained return thunk; SMT enabled with STIBP
protection
always-on; RSB filling; PBRSB-eIBRS: Not affected; BHI: Not affected
Device-1: NVIDIA GA104 [GeForce RTX 3060 Ti Lite Hash Rate] vendor: ZOTAC
driver: nvidia v: 590.48.01 alternate: nouveau,nvidia_drm
non-free: 550-580.xx+ status: current (as of 2025-11; EOL~2026-12-xx)
arch: Ampere code: GAxxx process: TSMC n7 (7nm) built: 2020-2023 pcie:
gen: 3 speed: 8 GT/s lanes: 16 link-max: gen: 4 speed: 16 GT/s ports:
active: DP-2,DP-3,HDMI-A-1 empty: DP-1 bus-ID: 07:00.0 chip-ID: 10de:2489
class-ID: 0300
Device-2: Microdia USB Live camera driver: snd-usb-audio,uvcvideo
type: USB rev: 2.0 speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 3-2:2
chip-ID: 0c45:6536 class-ID: 0102 serial: <filter>
compositor: kwin_wayland driver: X: loaded: nvidia
gpu: nvidia,nvidia-nvswitch d-rect: 5520x1200 display-ID: 0
Monitor-1: DP-2 pos: right model: HP LP2465 serial: <filter> built: 2006
res: mode: 1920x1200 hz: 60 scale: 100% (1) dpi: 94 gamma: 1.2 chroma: red:
x: 0.639 y: 0.329 green: x: 0.298 y: 0.608 blue: x: 0.149 y: 0.059 white:
x: 0.314 y: 0.329 size: 519x324mm (20.43x12.76") diag: 616mm (24.2")
ratio: 16:10 modes: 1920x1200, 1600x1200, 1680x1050, 1600x1000,
1280x1024, 1280x960, 1152x720, 1024x768, 800x600, 640x480
Monitor-2: DP-3 pos: center model: Samsung LS27AG30x serial: <filter>
built: 2022 res: mode: 1920x1080 hz: 144 scale: 100% (1) dpi: 82 gamma: 1.2
chroma: red: x: 0.682 y: 0.310 green: x: 0.275 y: 0.651 blue: x: 0.149
y: 0.067 white: x: 0.314 y: 0.329 size: 597x336mm (23.5x13.23")
diag: 685mm (27") ratio: 16:9 modes: 1920x1080, 1680x1050, 1600x900,
1280x1024, 1440x900, 1280x800, 1152x864, 1280x720, 1024x768, 800x600,
720x576, 720x480, 640x480
Monitor-3: HDMI-A-1 pos: primary,left model: Samsung SMS22A450
serial: <filter> built: 2012 res: mode: 1680x1050 hz: 60 scale: 100% (1)
dpi: 91 gamma: 1.2 chroma: red: x: 0.643 y: 0.333 green: x: 0.298 y: 0.608
blue: x: 0.145 y: 0.055 white: x: 0.329 y: 0.329
size: 459x296mm (18.07x11.65") diag: 558mm (22") ratio: 16:10, 3:2
modes: 1680x1050, 1280x1024, 1440x900, 1280x960, 1280x800, 1152x864,
1280x720, 1024x768, 800x600, 720x576, 720x480, 640x480
API: EGL v: 1.5 hw: drv: nvidia platforms: device: 0 drv: nvidia device: 2
drv: swrast gbm: drv: nvidia surfaceless: drv: nvidia wayland: drv: nvidia
x11: drv: nvidia inactive: device-1
API: OpenGL v: 4.6.0 compat-v: 4.5 vendor: nvidia mesa v: 25.3.4-arch1.1
glx-v: 1.4 direct-render: yes renderer: NVIDIA GeForce RTX 3060 Ti/PCIe/SSE2
memory: 7.81 GiB display-ID: :1.0
API: Vulkan v: 1.4.335 layers: 9 device: 0 type: discrete-gpu name: NVIDIA
GeForce RTX 3060 Ti driver: nvidia v: 590.48.01 device-ID: 10de:2489
surfaces: N/A
Device-1: NVIDIA GA104 High Definition Audio vendor: ZOTAC
link-max: gen: 4 speed: 16 GT/s bus-ID: 07:00.1 chip-ID: 10de:228b
class-ID: 0403
vendor: ASRock driver: snd_hda_intel v: kernel pcie: gen: 4 speed: 16 GT/s
lanes: 16 bus-ID: 09:00.4 chip-ID: 1022:1487 class-ID: 0403
Device-3: Corsair VOID ELITE Wireless Gaming Dongle
driver: hid-generic,snd-usb-audio,usbhid type: USB rev: 1.1 speed: 12 Mb/s
lanes: 1 mode: 1.1 bus-ID: 1-5:3 chip-ID: 1b1c:0a51 class-ID: 0300
Device-4: Microdia USB Live camera driver: snd-usb-audio,uvcvideo
Device-5: Medeli KRUX EDIS 1000 driver: hid-generic,snd-usb-audio,usbhid
type: USB rev: 1.1 speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 3-3:3
chip-ID: 0a67:d064 class-ID: 0300 serial: <filter>
API: ALSA v: k6.12.68-1-MANJARO status: kernel-api with: aoss
Server-2: PipeWire v: 1.4.10 status: active with: 1: pipewire-pulse
vendor: ASRock driver: r8169 v: kernel pcie: gen: 1 speed: 2.5 GT/s lanes: 1
port: f000 bus-ID: 05:00.0 chip-ID: 10ec:8168 class-ID: 0200
IF: enp5s0 state: up speed: 1000 Mbps duplex: full mac: <filter>
IF-ID-1: virbr0 state: down mac: <filter>
Local Storage: total: 931.51 GiB used: 545.29 GiB (58.5%)
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Samsung model: SSD 980 1TB
lanes: 4 tech: SSD serial: <filter> fw-rev: 3B4QFXO7 temp: 34.9 C
scheme: GPT
ID-1: / raw-size: 638.01 GiB size: 626.92 GiB (98.26%)
used: 545.23 GiB (87.0%) fs: ext4 dev: /dev/nvme0n1p2 maj-min: 259:2
label: N/A uuid: 46cd7c27-c44c-4f3e-b31f-c78a397024d8
ID-2: /efi raw-size: 300 MiB size: 299.4 MiB (99.80%)
used: 62.1 MiB (20.7%) fs: vfat dev: /dev/nvme0n1p1 maj-min: 259:1
label: N/A uuid: 6238-E3A0
ID-1: swap-1 type: file size: 6 GiB used: 98.5 MiB (1.6%) priority: -2
file: /swapfile
ID-1: /dev/nvme0n1p3 maj-min: 259:3 size: 292.66 GiB fs: ntfs label: N/A
uuid: 3C047D8F047D4CC0
Device-1: 1-4:2 info: Micro Star MSI GK50 ELITE Gaming Keyboard
type: keyboard,HID driver: hid-generic,usbhid interfaces: 3 rev: 2.0
chip-ID: 0db0:0b5b class-ID: 0300
Device-2: 1-5:3 info: Corsair VOID ELITE Wireless Gaming Dongle
type: audio,HID driver: hid-generic,snd-usb-audio,usbhid interfaces: 4
rev: 1.1 speed: 12 Mb/s (1.4 MiB/s) lanes: 1 mode: 1.1 power: 100mA
Device-1: 3-2:2 info: Microdia USB Live camera type: video,audio
driver: snd-usb-audio,uvcvideo interfaces: 5 rev: 2.0
Device-2: 3-3:3 info: Medeli KRUX EDIS 1000 type: audio,HID
driver: hid-generic,snd-usb-audio,usbhid interfaces: 3 rev: 1.1
Device-3: 3-4:4 info: Endgame Gear WE Series Gaming Receiver
type: mouse,keyboard driver: hid-generic,usbhid interfaces: 2 rev: 2.0
chip-ID: 3367:1961 class-ID: 0301
System Temperatures: cpu: 47.4 C mobo: N/A
Fan Speeds (rpm): N/A
Packages: 2171 pm: pacman pkgs: 2145 libs: 457 tools: pamac,yay pm: flatpak
pkgs: 26
1: https://mirrors.manjaro.org/repo/stable/$repo/$arch
2: https://ftp.rz.tu-bs.de/pub/mirror/manjaro.org/repos/stable/$repo/$arch
3: https://cofractal-ewr.mm.fcix.net/manjaro/stable/$repo/$arch
4: https://coresite.mm.fcix.net/manjaro/stable/$repo/$arch
5: https://ohioix.mm.fcix.net/manjaro/stable/$repo/$arch
6: https://volico.mm.fcix.net/manjaro/stable/$repo/$arch
7: https://codingflyboy.mm.fcix.net/manjaro/stable/$repo/$arch
8: https://ziply.mm.fcix.net/manjaro/stable/$repo/$arch
Processes:
CPU top: 5 of 387
1: cpu: 248% command: OxygenNotIncluded pid: 45547 mem: 5629.0 MiB (17.5%)
2: cpu: 100% command: ps pid: 53024 mem: 4.42 MiB (0.0%)
3: cpu: 60.4% command: firefox pid: 4169 mem: 1030.5 MiB (3.2%)
4: cpu: 30.3% command: firefox pid: 4406 mem: 117.1 MiB (0.3%)
5: cpu: 22.7% command: Discord pid: 1703 mem: 256.3 MiB (0.8%)
Memory top: 5 of 387
1: mem: 5629.0 MiB (17.5%) command: OxygenNotIncluded pid: 45547 cpu: 248%
2: mem: 1030.5 MiB (3.2%) command: firefox pid: 4169 cpu: 60.4%
3: mem: 926.4 MiB (2.8%) command: firefox pid: 4837 cpu: 7.3%
4: mem: 817.2 MiB (2.5%) command: ./steamwebhelper pid: 5943 cpu: 0.6%
5: mem: 753.0 MiB (2.3%) command: steamwebhelper pid: 6025 cpu: 5.1%
Processes: 387 Power: uptime: 7h 10m states: freeze,mem,disk suspend: deep
suspend, test_resume image: 12.48 GiB services: org_kde_powerdevil,
power-profiles-daemon, upowerd Init: systemd v: 258 default: graphical
tool: systemctl
Compilers: clang: 21.1.6 gcc: 15.2.1 alt: 13/14 Shell: Zsh v: 5.9
default: Bash v: 5.3.9 running-in: konsole inxi: 3.3.40
