After a pacman -Syu yesterday I have multiple applications failing on start, including the lightdm greeter. I was only seeing a blank screen after reboot.
Turns out multiple applications stopped working because they are still depending on core/icu 73 while the update bumped it to v74.
Could it be that packages in “extra” have not yet been recompiled?
lightdm-gtk-greeter
lightdm-gtk-greeter: error while loading shared libraries: libicuuc.so.73: cannot open shared object file: No such file or directory
pacman -F $(which lightdm-gtk-greeter)
/usr/bin/lightdm-gtk-greeter is owned by extra/lightdm-gtk-greeter 1:2.0.8-3
gvim
gvim: error while loading shared libraries: libicuuc.so.73: cannot open shared object file: No such file or directory
pacman -F $(which gvim)
/usr/bin/gvim is owned by extra/gvim 9.0.1506-1
pacman -Q | grep icu
icu 74.2-1
lib32-icu 74.2-1
I already tried to fix the situation but at least the following attempts did not yet help:
Either you are in a partial-upgrade state or those packages are from a third party.
If they are packages you built, such as from the AUR, then they should be rebuilt following system library updates.
I ran your command, “-Syu” claimed there was nothing to update. However,this seems weird and I do not quite know what to make of it. gvim seems to be owned by extra/gvim 9.0.1506-1 but I have the most recent version installed that you mentioned (even after the full reinstall of all packages that I did):
pacman -Q gvim
gvim 9.0.2167-1
gvim
We will see when they query installed packages instead of the package database.
(which of course returns the repo packages, and the outdated versions if the db was outdated)
I always misunderstood what -F does thank you for the correction!
When I use “-Qo” it seems like I do indeed have the most recent version of gvim - and it seems to not work with libuuc.so.74 unfortunately (same for the lightdm greeter which is more of a problem right now):
$ gvim
$ pacman -Qo $(which gvim)
/usr/bin/gvim is owned by gvim 9.0.2167-1
$ lightdm-gtk-greeter
$ pacman -Qo $(which lightdm-gtk-greeter)
/usr/bin/lightdm-gtk-greeter is owned by lightdm-gtk-greeter 1:2.0.8-3
Problem solved! I got the final hint from a post in the Arch forums - lddtree showed me that I had a dependency to an older version of libxml2 that was lying around in a “Cisco Secure Connect” folder which was included in my library path.
Thanks for your support - maybe this helps someone else with a similar problem…
