Hello!
New-ish to Manjaro.
I’m having an issue after a fresh install where two monitors connected to one nvidia gpu are displaying correctly, but my third monitor connected to a different nvidia gpu is not displaying anything.
I have used Manjaro Settings Manager to auto install the proprietary video-nvidia driver. I’ve also tried to use the KDE display configuration to enable the third monitor. I can enable it, but the setting does not stay saved upon closing after hitting apply or on reboot. I’ve also used nvidia-settings to save a new xorg.conf after I deleted to first one from a suggested solution from someone else’s post, to no avail.
Also looked at other forum posts, but the answers look to help with configuring an iGPU and a second GPU.
Not sure what else to try! Please let me know what I can provide to help.
Thanks in advance!
pobrn
1 January 2021 20:45
2
Please post the output of xrandr
, xrandr --listproviders
, and inxi -Fazy
Thank you for the quick response!
Here is what I got.
xrandr
Screen 0: minimum 8 x 8, current 6399 x 1440, maximum 32767 x 32767
DP-0 disconnected (normal left inverted right x axis y axis)
DP-1 disconnected (normal left inverted right x axis y axis)
DP-2 disconnected (normal left inverted right x axis y axis)
DP-3 disconnected (normal left inverted right x axis y axis)
HDMI-0 connected primary 2560x1440+1920+0 (normal left inverted right x axis y axis) 597mm x 336mm panning 4479x1440+1920+0 tracking 6399x1440+0+0 border 0/0/0/0
2560x1440 59.95 + 143.91*
2560x1080 59.94
1920x1200 59.88
1920x1080 60.00 59.94 50.00
1680x1050 59.95
1600x1200 60.00
1280x1024 75.02 60.02
1280x800 59.81
1280x720 60.00 59.94 50.00
1152x864 75.00
1024x768 75.03 60.00
800x600 75.00 60.32
720x576 50.00
720x480 59.94
640x480 75.00 59.93 59.94
HDMI-1 connected 1920x1080+0+0 (normal left inverted right x axis y axis) 531mm x 299mm panning 3839x1080+0+0 tracking 6399x1440+0+0 border 0/0/0/0
1920x1080 60.00*+ 59.99 59.94 50.00
1680x1050 59.95
1600x1200 60.00
1440x900 59.89
1366x768 59.79
1280x960 60.00
1152x864 75.00
1024x768 75.03 70.07 60.00
800x600 75.00 72.19 60.32 56.25
720x576 50.00
720x480 59.94
640x480 75.00 72.81 59.93 59.94
HDMI-2 disconnected (normal left inverted right x axis y axis)
DP-4 disconnected (normal left inverted right x axis y axis)
DP-5 disconnected (normal left inverted right x axis y axis)
DP-1-0 disconnected
DP-1-1 disconnected
HDMI-1-0 connected
1920x1080 60.00 + 59.99 59.94 50.00
1680x1050 59.95
1600x1200 60.00
1440x900 59.89
1366x768 59.79
1280x960 60.00
1152x864 75.00
720x576 50.00
720x480 59.94
DP-1-2 disconnected
DP-1-3 disconnected
DP-1-4 disconnected
DP-1-5 disconnected
USB-C-1-0 disconnected
1920x1080 (0x1c6) 148.500MHz +HSync +VSync
h: width 1920 start 2008 end 2052 total 2200 skew 0 clock 67.50KHz
v: height 1080 start 1084 end 1089 total 1125 clock 60.00Hz
1920x1080 (0x1dc) 138.500MHz +HSync -VSync
h: width 1920 start 1968 end 2000 total 2080 skew 0 clock 66.59KHz
v: height 1080 start 1083 end 1088 total 1110 clock 59.99Hz
1920x1080 (0x1c7) 148.350MHz +HSync +VSync
h: width 1920 start 2008 end 2052 total 2200 skew 0 clock 67.43KHz
v: height 1080 start 1084 end 1089 total 1125 clock 59.94Hz
1920x1080 (0x1c8) 148.500MHz +HSync +VSync
h: width 1920 start 2448 end 2492 total 2640 skew 0 clock 56.25KHz
v: height 1080 start 1084 end 1089 total 1125 clock 50.00Hz
1680x1050 (0x1c9) 146.250MHz -HSync +VSync
h: width 1680 start 1784 end 1960 total 2240 skew 0 clock 65.29KHz
v: height 1050 start 1053 end 1059 total 1089 clock 59.95Hz
1600x1200 (0x1ca) 162.000MHz +HSync +VSync
h: width 1600 start 1664 end 1856 total 2160 skew 0 clock 75.00KHz
v: height 1200 start 1201 end 1204 total 1250 clock 60.00Hz
1440x900 (0x1dd) 106.500MHz -HSync +VSync
h: width 1440 start 1520 end 1672 total 1904 skew 0 clock 55.93KHz
v: height 900 start 903 end 909 total 934 clock 59.89Hz
1366x768 (0x1de) 85.500MHz +HSync +VSync
h: width 1366 start 1436 end 1579 total 1792 skew 0 clock 47.71KHz
v: height 768 start 771 end 774 total 798 clock 59.79Hz
1280x1024 (0x1cb) 135.000MHz +HSync +VSync
h: width 1280 start 1296 end 1440 total 1688 skew 0 clock 79.98KHz
v: height 1024 start 1025 end 1028 total 1066 clock 75.02Hz
1280x1024 (0x1cc) 108.000MHz +HSync +VSync
h: width 1280 start 1328 end 1440 total 1688 skew 0 clock 63.98KHz
v: height 1024 start 1025 end 1028 total 1066 clock 60.02Hz
1280x960 (0x1df) 108.000MHz +HSync +VSync
h: width 1280 start 1376 end 1488 total 1800 skew 0 clock 60.00KHz
v: height 960 start 961 end 964 total 1000 clock 60.00Hz
1280x720 (0x1ce) 74.250MHz +HSync +VSync
h: width 1280 start 1390 end 1430 total 1650 skew 0 clock 45.00KHz
v: height 720 start 725 end 730 total 750 clock 60.00Hz
1280x720 (0x1cf) 74.180MHz +HSync +VSync
h: width 1280 start 1390 end 1430 total 1650 skew 0 clock 44.96KHz
v: height 720 start 725 end 730 total 750 clock 59.94Hz
1280x720 (0x1d0) 74.250MHz +HSync +VSync
h: width 1280 start 1720 end 1760 total 1980 skew 0 clock 37.50KHz
v: height 720 start 725 end 730 total 750 clock 50.00Hz
1152x864 (0x1d1) 108.000MHz +HSync +VSync
h: width 1152 start 1216 end 1344 total 1600 skew 0 clock 67.50KHz
v: height 864 start 865 end 868 total 900 clock 75.00Hz
1024x768 (0x1d2) 78.750MHz +HSync +VSync
h: width 1024 start 1040 end 1136 total 1312 skew 0 clock 60.02KHz
v: height 768 start 769 end 772 total 800 clock 75.03Hz
1024x768 (0x1e0) 75.000MHz -HSync -VSync
h: width 1024 start 1048 end 1184 total 1328 skew 0 clock 56.48KHz
v: height 768 start 771 end 777 total 806 clock 70.07Hz
1024x768 (0x1d3) 65.000MHz -HSync -VSync
h: width 1024 start 1048 end 1184 total 1344 skew 0 clock 48.36KHz
v: height 768 start 771 end 777 total 806 clock 60.00Hz
800x600 (0x1d4) 49.500MHz +HSync +VSync
h: width 800 start 816 end 896 total 1056 skew 0 clock 46.88KHz
v: height 600 start 601 end 604 total 625 clock 75.00Hz
800x600 (0x1e1) 50.000MHz +HSync +VSync
h: width 800 start 856 end 976 total 1040 skew 0 clock 48.08KHz
v: height 600 start 637 end 643 total 666 clock 72.19Hz
800x600 (0x1d5) 40.000MHz +HSync +VSync
h: width 800 start 840 end 968 total 1056 skew 0 clock 37.88KHz
v: height 600 start 601 end 605 total 628 clock 60.32Hz
800x600 (0x1e2) 36.000MHz +HSync +VSync
h: width 800 start 824 end 896 total 1024 skew 0 clock 35.16KHz
v: height 600 start 601 end 603 total 625 clock 56.25Hz
720x576 (0x1d6) 27.000MHz -HSync -VSync
h: width 720 start 732 end 796 total 864 skew 0 clock 31.25KHz
v: height 576 start 581 end 586 total 625 clock 50.00Hz
720x480 (0x1d7) 27.000MHz -HSync -VSync
h: width 720 start 736 end 798 total 858 skew 0 clock 31.47KHz
v: height 480 start 489 end 495 total 525 clock 59.94Hz
640x480 (0x1d8) 31.500MHz -HSync -VSync
h: width 640 start 656 end 720 total 840 skew 0 clock 37.50KHz
v: height 480 start 481 end 484 total 500 clock 75.00Hz
640x480 (0x1e3) 31.500MHz -HSync -VSync
h: width 640 start 656 end 696 total 832 skew 0 clock 37.86KHz
v: height 480 start 481 end 484 total 520 clock 72.81Hz
640x480 (0x1d9) 25.170MHz -HSync -VSync
h: width 640 start 656 end 752 total 800 skew 0 clock 31.46KHz
v: height 480 start 490 end 492 total 525 clock 59.93Hz
640x480 (0x1da) 25.175MHz -HSync -VSync
h: width 640 start 656 end 752 total 800 skew 0 clock 31.47KHz
v: height 480 start 490 end 492 total 525 clock 59.94Hz
Providers: number : 2
Provider 0: id: 0x1b8 cap: 0x1, Source Output crtcs: 4 outputs: 9 associated providers: 1 name:NVIDIA-0
Provider 1: id: 0x37f cap: 0x2, Sink Output crtcs: 4 outputs: 8 associated providers: 1 name:NVIDIA-G0
inxi -Fazy
Kernel: 5.9.16-1-MANJARO x86_64 bits: 64 compiler: gcc v: 10.2.0
parameters: BOOT_IMAGE=/boot/vmlinuz-5.9-x86_64
root=UUID=86fea408-8ce2-47c3-93f4-64c9b1dd38bb rw quiet
cryptdevice=UUID=32eef146-b9ae-40de-8358-27e3221457d9:luks-32eef146-b9ae-40de-8358-27e3221457d9
root=/dev/mapper/luks-32eef146-b9ae-40de-8358-27e3221457d9 apparmor=1
security=apparmor
resume=/dev/mapper/luks-ae5568b9-7482-4a7e-acc0-0a16d561baa4
udev.log_priority=3
Desktop: KDE Plasma 5.20.4 tk: Qt 5.15.2 wm: kwin_x11 dm: SDDM
Distro: Manjaro Linux
Type: Desktop System: Gigabyte product: Z390 AORUS MASTER v: N/A
serial: <filter>
Mobo: Gigabyte model: Z390 AORUS MASTER-CF v: x.x serial: <filter>
UEFI: American Megatrends v: F11c date: 12/18/2019
Info: 8-Core model: Intel Core i9-9900K bits: 64 type: MT MCP
arch: Kaby Lake note: check family: 6 model-id: 9E (158) stepping: C (12)
microcode: DE L2 cache: 16 MiB
bogomips: 115232
Speed: 800 MHz min/max: 800/5000 MHz Core speeds (MHz): 1: 800 2: 800 3: 801
4: 800 5: 800 6: 800 7: 800 8: 801 9: 800 10: 800 11: 800 12: 800 13: 800
14: 800 15: 800 16: 801
Type: tsx_async_abort mitigation: Clear CPU buffers; SMT vulnerable
Device-1: NVIDIA vendor: Gigabyte driver: nvidia v: 455.45.01
alternate: nouveau,nvidia_drm bus ID: 01:00.0 chip ID: 10de:2204
Device-2: NVIDIA TU102 [GeForce RTX 2080 Ti Rev. A] vendor: Gigabyte
driver: nvidia v: 455.45.01 alternate: nouveau,nvidia_drm bus ID: 04:00.0
chip ID: 10de:1e07
Display: x11 server: X.Org 1.20.10 compositor: kwin_x11 driver: nvidia
display ID: :0 screens: 1
Screen-1: 0 s-res: 6399x1440 s-dpi: 107 s-size: 1519x342mm (59.8x13.5")
s-diag: 1557mm (61.3")
Monitor-1: HDMI-0 res: 2560x1440 dpi: 109 size: 597x336mm (23.5x13.2")
diag: 685mm (27")
Monitor-2: HDMI-1 res: 1920x1080 hz: 60 dpi: 92 size: 531x299mm (20.9x11.8")
diag: 609mm (24")
OpenGL: renderer: GeForce RTX 3090/PCIe/SSE2 v: 4.6.0 NVIDIA 455.45.01
direct render: Yes
Device-1: Intel Cannon Lake PCH cAVS vendor: Gigabyte driver: snd_hda_intel
v: kernel alternate: snd_soc_skl,snd_sof_pci bus ID: 00:1f.3
chip ID: 8086:a348
Device-2: NVIDIA vendor: Gigabyte driver: snd_hda_intel v: kernel
bus ID: 01:00.1 chip ID: 10de:1aef
Device-3: NVIDIA TU102 High Definition Audio vendor: Gigabyte
driver: snd_hda_intel v: kernel bus ID: 04:00.1 chip ID: 10de:10f7
Device-4: Logitech HD Webcam C615 type: USB driver: snd-usb-audio,uvcvideo
bus ID: 1-5.2:8 chip ID: 046d:082c serial: <filter>
Device-5: Razer USA RZ19-0229 Gaming Microphone type: USB
driver: hid-generic,snd-usb-audio,usbhid bus ID: 1-5.4:11 chip ID: 1532:0511
serial: <filter>
Sound Server: ALSA v: k5.9.16-1-MANJARO
Device-1: Intel Wireless-AC 9560 [Jefferson Peak] driver: iwlwifi v: kernel
bus ID: 00:14.3 chip ID: 8086:a370
IF: wlo1 state: down mac: <filter>
Device-2: Intel Ethernet I219-V vendor: Gigabyte driver: e1000e v: kernel
port: efa0 bus ID: 00:1f.6 chip ID: 8086:15bc
IF: eno2 state: up speed: 1000 Mbps duplex: full mac: <filter>
Local Storage: total: 12.13 TiB used: 10.17 GiB (0.1%)
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Samsung model: SSD 970 PRO 512GB
size: 476.94 GiB block size: physical: 512 B logical: 512 B speed: 31.6 Gb/s
lanes: 4 serial: <filter> rev: 1B2QEXP7 temp: 29.9 C
ID-2: /dev/nvme1n1 maj-min: 259:2 vendor: Samsung model: SSD 970 EVO 250GB
size: 232.89 GiB block size: physical: 512 B logical: 512 B speed: 31.6 Gb/s
lanes: 4 serial: <filter> rev: 2B2QEXE7 temp: 33.9 C
ID-3: /dev/nvme2n1 maj-min: 259:1 vendor: Samsung model: SSD 970 PRO 512GB
lanes: 4 serial: <filter> rev: 1B2QEXP7 temp: 37.9 C
ID-4: /dev/sda maj-min: 8:0 vendor: Western Digital model: WD40EFRX-68WT0N0
size: 3.64 TiB block size: physical: 4096 B logical: 512 B speed: 6.0 Gb/s
serial: <filter> rev: 0A80
ID-5: /dev/sdb maj-min: 8:16 vendor: Western Digital model: WD60EFRX-68L0BN1
size: 5.46 TiB block size: physical: 4096 B logical: 512 B speed: 6.0 Gb/s
serial: <filter> rev: 0A82
ID-6: /dev/sdc maj-min: 8:32 vendor: Western Digital model: WD20EFRX-68EUZN0
size: 1.82 TiB block size: physical: 4096 B logical: 512 B speed: 6.0 Gb/s
ID-7: /dev/sdd maj-min: 8:48 type: USB vendor: Samsung model: Type-C
size: 59.75 GiB block size: physical: 512 B logical: 512 B serial: <filter>
rev: 1100
ID-1: / raw size: 407.64 GiB size: 400.24 GiB (98.18%)
used: 10.16 GiB (2.5%) fs: ext4 dev: /dev/dm-0 maj-min: 254:0
mapped: luks-32eef146-b9ae-40de-8358-27e3221457d9
ID-2: /boot/efi raw size: 300 MiB size: 299.4 MiB (99.80%)
used: 480 KiB (0.2%) fs: vfat dev: /dev/nvme0n1p1 maj-min: 259:4
ID-1: swap-1 type: partition size: 69 GiB used: 0 KiB (0.0%) priority: -2
dev: /dev/dm-1 maj-min: 254:1
mapped: luks-ae5568b9-7482-4a7e-acc0-0a16d561baa4
System Temperatures: cpu: 46.0 C mobo: N/A gpu: nvidia temp: 43 C
Processes: 333 Uptime: 30m wakeups: 1 Memory: 62.73 GiB
used: 2.68 GiB (4.3%) Init: systemd v: 247 Compilers: gcc: N/A Packages:
pacman: 1259 lib: 398 flatpak: 0 Shell: Zsh v: 5.8 running in: yakuake
inxi: 3.2.01
pobrn
1 January 2021 20:55
4
What’s the output of xrandr --output HDMI-1-0 --auto
It looks like an error.
xrandr: Configure crtc 4 failed
X Error of failed request: BadValue (integer parameter out of range for operation)
Major opcode of failed request: 140 (RANDR)
Minor opcode of failed request: 21 (RRSetCrtcConfig)
Value in failed request: 0x0
Serial number of failed request: 88
Current serial number in output stream: 88
pobrn
1 January 2021 20:59
6
Well, this seems to be the same problem I’m having when I’m trying to use an NVIDIA GPU as an output sink. It works for me on the 5.4 kernel, so I suggest you try that if you can.
sudo mhwd-kernel -i linux54
and then in your bootloader, under “advanced options” (or similar) you can select the kernel you want to use.
Roger. I’ll give that a try.
No change. Went back into the Display Configuration and re-enabled the monitor. Still a black screen. Doesn’t wake monitor from sleep.
Linux comp 5.4.85-1-MANJARO #1 SMP PREEMPT Mon Dec 21 21:38:53 UTC 2020 x86_64 GNU/Linux
