Multi-Monitor setup not working after updates
Hey folks,
I did a pacman -Syu and it broke my System. I’m running the 5.10 and the 455.45.01 nonfree nvidia driver.
After reboot my primary display stopped working and just my secondary works. I can’t change any settings in gnome-settings, but in nvidia-settings the primary display is disabled and I can activate it. It then shows just nvidia-settings windows and no gnome-gui. After a reboot I’m back where I started.
When I boot with just my primary display connected, I get a black screen with a mouse cursor and I can’t change to tty.
I tried to re-install the nvidia driver, but it didn’t help.
Any help?
    ~ >>> inxi --full --verbosity=7 --filter --no-host
      Kernel: 5.10.2-2-MANJARO x86_64 bits: 64 compiler: gcc v: 10.2.0
      Desktop: GNOME 3.38.2 tk: GTK 3.24.24 wm: gnome-shell dm: GDM 3.38.2.1
      Distro: Manjaro Linux
      Type: Desktop System: ASUS product: N/A v: N/A serial: <filter>
      Mobo: ASUSTeK model: PRIME Z490-A v: Rev 1.xx serial: <filter>
      UEFI: American Megatrends v: 0607 date: 05/29/2020
      RAM: total: 31.25 GiB used: 3.94 GiB (12.6%)
      RAM Report:
      Info: 10-Core model: Intel Core i9-10900 bits: 64 type: MT MCP
      arch: Comet Lake rev: 5 L2 cache: 20 MiB bogomips: 112043
      Speed: 800 MHz min/max: 800/5200 MHz Core speeds (MHz): 1: 800 2: 800
      3: 801 4: 801 5: 801 6: 800 7: 800 8: 800 9: 800 10: 800 11: 800 12: 800
      13: 800 14: 800 15: 800 16: 800 17: 800 18: 801 19: 800 20: 800
      fsgsbase fxsr ht hwp hwp_act_window hwp_epp hwp_notify ibpb ibrs
      ibrs_enhanced ida intel_pt invpcid invpcid_single lahf_lm lm mca mce
      md_clear mmx monitor movbe mpx msr mtrr nonstop_tsc nopl nx ospke pae pat
      pbe pcid pclmulqdq pdcm pdpe1gb pebs pge pku pln pni popcnt pse pse36 pts
      rdrand rdseed rdtscp rep_good sdbg sep smap smep smx ss ssbd sse sse2
      xsaves xtopology xtpr
      Device-1: NVIDIA vendor: Micro-Star MSI driver: nvidia v: 455.45.01
      bus ID: 01:00.0 chip ID: 10de:2206
      Display: x11 server: X.org 1.20.10 compositor: gnome-shell driver: nvidia
      OpenGL: renderer: GeForce RTX 3080/PCIe/SSE2 v: 4.6.0 NVIDIA 455.45.01
      direct render: Yes
      Device-1: Intel Comet Lake PCH cAVS vendor: ASUSTeK driver: snd_hda_intel
      v: kernel bus ID: 00:1f.3 chip ID: 8086:06c8
      Device-2: NVIDIA vendor: Micro-Star MSI driver: snd_hda_intel v: kernel
      bus ID: 01:00.1 chip ID: 10de:1aef
      Device-3: Logitech C505 HD Webcam type: USB driver: snd-usb-audio,uvcvideo
      bus ID: 1-3:4 chip ID: 046d:08e3 serial: <filter>
      Device-4: FiiO FiiO K5 Pro type: USB driver: snd-usb-audio
      bus ID: 1-10.2:9 chip ID: 2972:0047
      Sound Server: ALSA v: k5.10.2-2-MANJARO
      Processes: 371 Uptime: 26m wakeups: 0 Init: systemd v: 247 Compilers:
      gcc: 10.2.0 Packages: 1402 pacman: 1398 snap: 4 Shell: Zsh v: 5.8
      running in: gnome-terminal inxi: 3.2.01
And here is my xorg.conf:
# nvidia-settings: X configuration file generated by nvidia-settings
# nvidia-settings:  version 455.45.01
Section "ServerLayout"
    Identifier     "Layout0"
    Screen      0  "Screen0" 3840 0
    Screen      1  "Screen1" LeftOf "Screen0"
    InputDevice    "Keyboard0" "CoreKeyboard"
    InputDevice    "Mouse0" "CorePointer"
    Option         "Xinerama" "1"
EndSection
Section "Files"
EndSection
Section "InputDevice"
    # generated from default
    Identifier     "Mouse0"
    Driver         "mouse"
    Option         "Protocol" "auto"
    Option         "Device" "/dev/psaux"
    Option         "Emulate3Buttons" "no"
    Option         "ZAxisMapping" "4 5"
EndSection
    Identifier     "Keyboard0"
    Driver         "kbd"
EndSection
Section "Monitor"
    # HorizSync source: edid, VertRefresh source: edid
    Identifier     "Monitor0"
    VendorName     "Unknown"
    ModelName      "AOC G2460"
    HorizSync       30.0 - 160.0
    VertRefresh     30.0 - 150.0
    Option         "DPMS"
EndSection
Section "Monitor"
    Identifier     "Monitor1"
    ModelName      "Acer XB273K GP"
    HorizSync       510.0 - 510.0
    VertRefresh     48.0 - 120.0
    Option         "DPMS"
EndSection
Section "Device"
    Identifier     "Device0"
    Driver         "nvidia"
    VendorName     "NVIDIA Corporation"
    BoardName      "GeForce RTX 3080"
    BusID          "PCI:2:0:0"
    Screen          0
EndSection
Section "Device"
    Identifier     "Device1"
    Driver         "nvidia"
    BusID          "PCI:2:0:0"
    Screen          1
EndSection
Section "Screen"
    Identifier     "Screen0"
    Device         "Device0"
    Monitor        "Monitor0"
    DefaultDepth    24
    Option         "Stereo" "0"
    Option         "nvidiaXineramaInfoOrder" "DFP-5"
    Option         "metamodes" "DP-4: nvidia-auto-select +0+0"
    Option         "SLI" "Off"
    Option         "MultiGPU" "Off"
    Option         "BaseMosaic" "off"
    SubSection     "Display"
        Depth       24
    EndSubSection
EndSection
Section "Screen"
    Identifier     "Screen1"
    Device         "Device1"
    Monitor        "Monitor1"
    DefaultDepth    24
    Option         "Stereo" "0"
    Option         "metamodes" "DP-2: nvidia-auto-select +0+0 {AllowGSYNC=Off}"
    Option         "SLI" "Off"
        Depth       24
    EndSubSection
EndSection
Hi Lain - I’ve got the exact same problem on my work machine.
This is the first time a manjaro update breaks my work setup and therefore productivity.
Where do I get these logs from?
I could add mine, too. Maybe this would help.
I found this thread stating the same problem with a great solution for the moment:
(I am not allowed to post links so it’s a pre formatted block now, sorry)
https://forum.manjaro.org/t/after-update-to-kernel-5-10-cannot-enable-external-monitor/46355/3
In grub I bootet back into Kernel 5.9 and everything works fine.
You could, sure, also try one of the other probable temporarily solutions given in the linked thread until multi monitor works good in 5.10 again.
Regards,
Horst
