I have a 1050Ti Max-Q GPU on my laptop and I use the proprietary Nvidia driver(525.89.02-3 now but it wasn’t working as long as I remember (and I am on unstable branch)). Multi-monitor works in X11 but when I try Wayland, multi-monitor does not work.
To troubleshoot I tried other distros.
- I installed Ubuntu with Gnome and it worked (so the problem is not hardware issue, but it could be Plasma)
- Then I tried KDE Neon (unstable) and it also worked (so the issue is not the Plasma either)
- Then I tried the new Manjaro ISO and it didn’t work (so the issue is not a change by me because a new installation is not working, so I thought it is probably Manjaro)
- And finally I tried EndeavourOS, it also didn’t work (so the issue is not from Manjaro)
My suspicion now is there is a difference between Ubuntu’s (maybe Debian) and Arch’s Nvidia driver somehow because Ubuntu based distros work but Arch based ones don’t.
Kernel: 6.1.12-1-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 12.2.1
parameters: BOOT_IMAGE=/vmlinuz-6.1-x86_64
root=UUID=1897eec7-b7ae-46d4-a635-d2ce7cf19502 rw rootflags=subvol=@ quiet
splash vt.global_cursor_default=0
cryptdevice=UUID=1bff087b-4a51-41ad-9ff3-a2373a713203:luks-1bff087b-4a51-41ad-9ff3-a2373a713203
root=/dev/mapper/luks-1bff087b-4a51-41ad-9ff3-a2373a713203
resume=UUID=5f0e9b27-1791-4732-9e6a-bab86718c296 udev.log_priority=3
nmi_watchdog=0
Desktop: KDE Plasma v: 5.26.5 tk: Qt v: 5.15.8 wm: kwin_x11 vt: 1 dm: SDDM
Type: Laptop System: Acer product: Nitro AN515-51 v: V1.22
serial: <superuser required>
Mobo: KBL model: Freed_KLS v: V1.22 serial: <superuser required>
UEFI: Insyde v: 1.22 date: 03/15/2019
ID-1: BAT1 charge: 36.4 Wh (100.0%) condition: 36.4/48.9 Wh (74.4%)
volts: 16.2 min: 15.2 model: LG 004B384234314341 type: Li-ion
serial: <filter> status: full
RAM: total: 15.51 GiB used: 5.26 GiB (33.9%)
Info: model: Intel Core i7-7700HQ bits: 64 type: MT MCP arch: Kaby Lake
gen: core 7 level: v3 note: check built: 2018 process: Intel 14nm family: 6
model-id: 0x9E (158) stepping: 9 microcode: 0x9A
L3: 6 MiB desc: 1x6 MiB
Speed (MHz): avg: 800 min/max: 800/3800 scaling: driver: intel_pstate
governor: powersave cores: 1: 800 2: 800 3: 800 4: 800 5: 800 6: 800 7: 800
8: 800 bogomips: 44817
Flags: 3dnowprefetch abm acpi adx aes aperfmperf apic arat arch_perfmon
art avx avx2 bmi1 bmi2 bts clflush clflushopt cmov constant_tsc cpuid
hwp_epp hwp_notify ibpb ibrs ida intel_pt invpcid invpcid_single lahf_lm
lm mca mce mmx monitor movbe mpx msr mtrr nonstop_tsc nopl nx pae pat pbe
pcid pclmulqdq pdcm pdpe1gb pebs pge pln pni popcnt pse pse36 pti pts
rdrand rdseed rdtscp rep_good sdbg sep smap smep ss ssbd sse sse2 sse4_1
xsaves xtopology xtpr
vulnerable
Type: mds status: Vulnerable: Clear CPU buffers attempted, no microcode;
SMT vulnerable
Type: mmio_stale_data status: Vulnerable: Clear CPU buffers attempted, no
microcode; SMT vulnerable
Type: spectre_v2 mitigation: IBRS, IBPB: conditional, RSB filling,
PBRSB-eIBRS: Not affected
Type: srbds status: Vulnerable: No microcode
Device-1: Intel HD Graphics 630 vendor: Acer Incorporated ALI driver: i915
v: kernel arch: Gen-9.5 process: Intel 14nm built: 2016-20 ports:
active: eDP-1 empty: none bus-ID: 00:02.0 chip-ID: 8086:591b class-ID: 0300
Device-2: NVIDIA GP107M [GeForce GTX 1050 Ti Mobile]
vendor: Acer Incorporated ALI driver: nvidia v: 525.89.02
alternate: nouveau,nvidia_drm non-free: 525.xx+
status: current (as of 2023-02) arch: Pascal code: GP10x process: TSMC 16nm
built: 2016-21 pcie: gen: 1 speed: 2.5 GT/s lanes: 16 link-max: gen: 3
speed: 8 GT/s bus-ID: 01:00.0 chip-ID: 10de:1c8c class-ID: 0300
Device-3: Chicony HD WebCam type: USB driver: uvcvideo bus-ID: 1-9:7
chip-ID: 04f2:b5f7 class-ID: 0e02
Display: x11 server: X.Org v: 21.1.7 with: Xwayland v: 22.1.8
compositor: kwin_x11 driver: X: loaded: modesetting,nvidia
alternate: fbdev,nouveau,nv,vesa dri: iris gpu: i915 display-ID: :0
screens: 1
Screen-1: 0 s-res: 3840x1080 s-dpi: 96 s-size: 1013x285mm (39.88x11.22")
s-diag: 1052mm (41.43")
Monitor-1: HDMI-1-0 pos: left res: 1920x1080 hz: 60 dpi: 102
size: 477x268mm (18.78x10.55") diag: 547mm (21.54") modes: N/A
Monitor-2: eDP-1 pos: primary,right res: 1920x1080 hz: 60 dpi: 142
size: 344x194mm (13.54x7.64") diag: 395mm (15.55") modes: N/A
API: OpenGL v: 4.6 Mesa 22.3.5 renderer: Mesa Intel HD Graphics 630 (KBL
GT2) direct-render: Yes
Device-1: Intel CM238 HD Audio vendor: Acer Incorporated ALI
driver: snd_hda_intel v: kernel bus-ID: 00:1f.3 chip-ID: 8086:a171
class-ID: 0403
Device-2: NVIDIA GP107GL High Definition Audio
vendor: Acer Incorporated ALI driver: snd_hda_intel v: kernel pcie: gen: 1
speed: 2.5 GT/s lanes: 16 link-max: gen: 3 speed: 8 GT/s bus-ID: 01:00.1
chip-ID: 10de:0fb9 class-ID: 0403
Sound API: ALSA v: k6.1.12-1-MANJARO running: yes
Sound Server-1: PulseAudio v: 16.1 running: no
Sound Server-2: PipeWire v: 0.3.65 running: yes
Device-1: Qualcomm Atheros QCA6174 802.11ac Wireless Network Adapter
vendor: Lite-On driver: ath10k_pci v: kernel pcie: gen: 1 speed: 2.5 GT/s
lanes: 1 bus-ID: 02:00.0 chip-ID: 168c:003e class-ID: 0280
IF: wlp2s0 state: down mac: <filter>
vendor: Acer Incorporated ALI driver: r8168 v: 8.050.03-NAPI modules: r8169
pcie: gen: 1 speed: 2.5 GT/s lanes: 1 port: 3000 bus-ID: 03:00.1
IF: enp3s0f1 state: up speed: 1000 Mbps duplex: full mac: <filter>
IF-ID-1: virbr0 state: down mac: <filter>
Device-1: Lite-On type: USB driver: btusb v: 0.8 bus-ID: 1-7:6
chip-ID: 04ca:3016 class-ID: e001
Device-1: luks-1bff087b-4a51-41ad-9ff3-a2373a713203 maj-min: 254:0
type: LUKS dm: dm-0 size: 830.17 GiB
Components:
p-1: nvme0n1p3 maj-min: 259:3 size: 830.17 GiB
Local Storage: total: 1.36 TiB used: 583.01 GiB (41.7%)
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Samsung model: SSD 980 PRO 1TB
lanes: 4 type: SSD serial: <filter> rev: 3B2QGXA7 temp: 42.9 C scheme: GPT
ID-2: /dev/sda maj-min: 8:0 vendor: Toshiba model: MQ01ABD050
size: 465.76 GiB block-size: physical: 4096 B logical: 512 B speed: 3.0 Gb/s
type: HDD rpm: 5400 serial: <filter> rev: 5A scheme: GPT
ID-1: / raw-size: 830.17 GiB size: 830.17 GiB (100.00%)
used: 582.34 GiB (70.1%) fs: btrfs dev: /dev/dm-0 maj-min: 254:0
mapped: luks-1bff087b-4a51-41ad-9ff3-a2373a713203 label: N/A
uuid: 1897eec7-b7ae-46d4-a635-d2ce7cf19502
ID-2: /boot raw-size: 2 GiB size: 1.9 GiB (95.01%) used: 675.2 MiB (34.7%)
fs: ext4 dev: /dev/nvme0n1p1 maj-min: 259:1 label: N/A
uuid: 5820bada-78a0-40bf-9dec-100761341f76
ID-3: /boot/efi raw-size: 250 MiB size: 246.1 MiB (98.46%)
used: 5.7 MiB (2.3%) fs: vfat dev: /dev/nvme0n1p2 maj-min: 259:2
label: NO_LABEL uuid: 54AB-7859
ID-4: /games raw-size: 830.17 GiB size: 830.17 GiB (100.00%)
ID-5: /home raw-size: 830.17 GiB size: 830.17 GiB (100.00%)
ID-6: /var/cache raw-size: 830.17 GiB size: 830.17 GiB (100.00%)
ID-7: /var/log raw-size: 830.17 GiB size: 830.17 GiB (100.00%)
ID-8: /virtual raw-size: 830.17 GiB size: 830.17 GiB (100.00%)
ID-1: swap-1 type: partition size: 32 GiB used: 0 KiB (0.0%) priority: -2
dev: /dev/nvme0n1p4 maj-min: 259:4 label: N/A
uuid: 5f0e9b27-1791-4732-9e6a-bab86718c296
Hub-1: 1-0:1 info: Hi-speed hub with single TT ports: 16 rev: 2.0
Hub-2: 1-3:2 info: Genesys Logic Hub ports: 4 rev: 2.1 speed: 480 Mb/s
power: 100mA chip-ID: 05e3:0610 class-ID: 0900
Device-1: 1-3.4:4 info: Samsung Galaxy A5 (MTP) type: Still Imaging
driver: N/A interfaces: 2 rev: 2.1 speed: 480 Mb/s power: 64mA
chip-ID: 04e8:6860 class-ID: 0601 serial: <filter>
Device-2: 1-5:3 info: Razer USA RC30-0315 Gaming Mouse [Basilisk X
HyperSpeed] type: Mouse,Keyboard driver: razermouse,usbhid interfaces: 3
rev: 2.0 speed: 12 Mb/s power: 500mA chip-ID: 1532:0083 class-ID: 0300
Device-3: 1-6:5 info: Corsair K55 RGB PRO Gaming Keyboard
type: Keyboard,HID driver: usbfs interfaces: 3 rev: 1.1 speed: 12 Mb/s
power: 500mA chip-ID: 1b1c:1ba4 class-ID: 0300 serial: <filter>
Device-4: 1-7:6 info: Lite-On type: Bluetooth driver: btusb interfaces: 2
rev: 2.0 speed: 12 Mb/s power: 100mA chip-ID: 04ca:3016 class-ID: e001
Device-5: 1-9:7 info: Chicony HD WebCam type: Video driver: uvcvideo
interfaces: 2 rev: 2.0 speed: 480 Mb/s power: 500mA chip-ID: 04f2:b5f7
class-ID: 0e02
Hub-3: 2-0:1 info: Super-speed hub ports: 8 rev: 3.0 speed: 5 Gb/s
Hub-4: 2-3:2 info: Genesys Logic Hub ports: 4 rev: 3.1 speed: 5 Gb/s
chip-ID: 05e3:0612 class-ID: 0900
System Temperatures: cpu: 48.0 C pch: 47.0 C mobo: N/A
Processes: 297 Uptime: 1h 35m wakeups: 1 Init: systemd v: 252
default: graphical tool: systemctl Compilers: gcc: 12.2.1 clang: 15.0.7
Packages: pm: pacman pkgs: 1691 libs: 417 tools: pamac,paru pm: flatpak
pkgs: 0 Shell: fish v: 3.6.0 default: Bash v: 5.1.16 running-in: konsole
inxi: 3.3.25
