Please let me know if this should be posted elsewhere.
The issue is with the T480 screen and not the two 1920x1080 monitors (HP LA2405x). These models do not have an HDMI input, only VGA, DVI and DP, and work flawlessly with the T480 and an X230 (Manjaro I3) as well as a Windows desktop. One is connected HDMI to DVI, the other USB C to DP.
The issue with the T480 screen is that it does not appear to close the app displayed. (Occasionally will black out altogether). For example, if ARANDR is running on the T480 screen, after you close the app, it appears to be still running, but it is not. The mouse pointer works fine but the app is unresponsive and there is no way (to my knowledge) to clear the display, If you launch ARANDR again, it works again. You can launch a browser over it and it works just fine, but it will not clear when closed.
This is the behavior with both external displays connected or just one. (either one). If someone can point me in the right direction it would be much appreciated.
Thank you in advance.
sudo inxi --admin --verbosity=7 --filter --no-host
Kernel: 6.1.71-1-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 13.2.1
root=UUID=91995cc5-fb74-4b37-97fd-99a9027d6e52 rw quiet
udev.log_priority=3
Desktop: i3 v: 4.23 with: i3bar tools: xautolock avail: i3lock dm: LightDM
v: 1.32.0 Distro: Manjaro Linux base: Arch Linux
Type: Laptop System: LENOVO product: 20L5001BUS v: ThinkPad T480
serial: Chassis: type: 10 serial:
Mobo: LENOVO model: 20L5001BUS v: SDK0J40697 WIN serial:
part-nu: LENOVO_MT_20L5_BU_Think_FM_ThinkPad T480
uuid: 65095acc-24b0-11b2-a85c-a6cdcf15cc48 UEFI: LENOVO
v: N24ET73W (1.48 ) date: 06/13/2023
ID-1: BAT0 charge: 22.1 Wh (100.0%) condition: 22.1/24.0 Wh (92.2%)
volts: 11.3 min: 11.5 model: SMP 01AV421 type: Li-poly serial:
status: full cycles: 34
ID-2: BAT1 charge: 10.2 Wh (52.0%) condition: 19.6/24.1 Wh (81.6%)
volts: 11.6 min: 11.4 model: Celxpert 01AV424 type: Li-poly serial:
status: not charging cycles: 57
System RAM: total: 16 GiB available: 15.39 GiB used: 1.74 GiB (11.3%)
igpu: 32 MiB
Device-1: ChannelA-DIMM0 type: DDR4 detail: synchronous unbuffered
(unregistered) size: 8 GiB speed: 2400 MT/s volts: curr: 1.2 width (bits):
data: 64 total: 64 manufacturer: 0000 part-no: N/A serial: N/A
Device-2: ChannelB-DIMM0 type: DDR4 detail: synchronous unbuffered
data: 64 total: 64 manufacturer: 0443 part-no: RMSA3260ME78HAF-2666
serial:
Info: model: Intel Core i5-8250U socket: BGA1356 (U3E1) note: check bits: 64
type: MT MCP arch: Coffee Lake gen: core 8 level: v3 note: check built: 2017
process: Intel 14nm family: 6 model-id: 0x8E (142) stepping: 0xA (10)
microcode: 0xF4
L3: 6 MiB desc: 1x6 MiB
Speed (MHz): avg: 426 high: 615 min/max: 400/3400 base/boost: 1600/1800
scaling: driver: intel_pstate governor: powersave volts: 1.0 V
ext-clock: 100 MHz cores: 1: 615 2: 400 3: 400 4: 400 5: 400 6: 400 7: 400
8: 400 bogomips: 28808
intel_pt invpcid invpcid_single lahf_lm lm mca mce md_clear mmx monitor
movbe mpx msr mtrr nonstop_tsc nopl nx pae pat pbe pcid pclmulqdq pdcm
pdpe1gb pebs pge pln pni popcnt pse pse36 pti pts rdrand rdseed rdtscp
rep_good sdbg sep sgx smap smep ss ssbd sse sse2 sse4_1 sse4_2 ssse3
stibp syscall tm tm2 tpr_shadow tsc tsc_adjust tsc_deadline_timer vme vmx
vnmi vpid x2apic xgetbv1 xsave xsavec xsaveopt xsaves xtopology xtpr
vulnerable
Type: spectre_v2 mitigation: IBRS, IBPB: conditional, STIBP: conditional,
RSB filling, PBRSB-eIBRS: Not affected
Device-1: Intel UHD Graphics 620 vendor: Lenovo driver: i915 v: kernel
arch: Gen-9.5 process: Intel 14nm built: 2016-20 ports:
active: HDMI-A-2,eDP-1 empty: DP-1,DP-2,HDMI-A-1 bus-ID: 00:02.0
chip-ID: 8086:5917 class-ID: 0300
Device-2: Chicony Integrated Camera (1280x720@30) driver: uvcvideo
type: USB rev: 2.0 speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 1-8:4
chip-ID: 04f2:b604 class-ID: 0e02 serial:
Display: x11 server: X.Org v: 21.1.10 compositor: Picom v: git-b700a
driver: X: loaded: modesetting alternate: fbdev,vesa dri: iris gpu: i915
display-ID: :0 screens: 1
Screen-1: 0 s-res: 3840x1200 s-dpi: 96 s-size: 1016x317mm (40.00x12.48")
s-diag: 1064mm (41.9")
Monitor-1: not-matched mapped: HDMI-2 pos: right res: 1920x1200 hz: 60
dpi: 94 size: 518x324mm (20.39x12.76") diag: 611mm (24.05") modes: N/A
Monitor-2: not-matched mapped: eDP-1 pos: primary,left res: 1920x1080
hz: 60 dpi: 158 size: 309x174mm (12.17x6.85") diag: 355mm (13.96")
modes: N/A
API: OpenGL Message: Unable to show GL data. glxinfo is missing.
Device-1: Intel Sunrise Point-LP HD Audio vendor: Lenovo ThinkPad T480
driver: snd_hda_intel v: kernel alternate: snd_soc_skl, snd_soc_avs,
snd_sof_pci_intel_skl bus-ID: 00:1f.3 chip-ID: 8086:9d71 class-ID: 0403
API: ALSA v: k6.1.71-1-MANJARO status: kernel-api with: aoss
Device-1: Intel Ethernet I219-V vendor: Lenovo ThinkPad T480 driver: e1000e
v: kernel port: N/A bus-ID: 00:1f.6 chip-ID: 8086:15d8 class-ID: 0200
IF: enp0s31f6 state: down mac:
Device-2: Intel Wireless 8265 / 8275 driver: iwlwifi v: kernel pcie:
gen: 1 speed: 2.5 GT/s lanes: 1 bus-ID: 03:00.0 chip-ID: 8086:24fd
class-ID: 0280
IF: wlp3s0 state: up mac:
IP v4: type: dynamic noprefixroute scope: global
broadcast:
IP v6: type: noprefixroute scope: link
WAN IP:
Device-1: Intel Bluetooth wireless interface driver: btusb v: 0.8 type: USB
rev: 2.0 speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 1-7:3 chip-ID: 8087:0a2b
class-ID: e001
Report: rfkill ID: hci0 rfk-id: 2 state: down bt-service: not found
rfk-block: hardware: no software: no address: see --recommends
Local Storage: total: 931.51 GiB used: 43.52 GiB (4.7%)
model: SSD 970 EVO Plus 1TB size: 931.51 GiB block-size: physical: 512 B
logical: 512 B speed: 31.6 Gb/s lanes: 4 tech: SSD serial:
fw-rev: 4B2QEXM7 temp: 23.9 C scheme: GPT
ID-1: / raw-size: 931.22 GiB size: 915.53 GiB (98.32%)
used: 43.52 GiB (4.8%) fs: ext4 block-size: 4096 B dev: /dev/nvme0n1p2
maj-min: 259:2 label: N/A uuid: 91995cc5-fb74-4b37-97fd-99a9027d6e52
used: 312 KiB (0.1%) fs: vfat block-size: 512 B dev: /dev/nvme0n1p1
maj-min: 259:1 label: N/A uuid: 5465-82FD
Hub-1: 1-0:1 info: hi-speed hub with single TT ports: 12 rev: 2.0
Device-1: 1-1:2 info: MosArt Wireless Mouse 2.4G type: mouse
lanes: 1 mode: 1.1 power: 100mA chip-ID: 062a:4106 class-ID: 0301
Device-2: 1-7:3 info: Intel Bluetooth wireless interface type: bluetooth
mode: 1.1 power: 100mA chip-ID: 8087:0a2b class-ID: e001
Device-3: 1-8:4 info: Chicony Integrated Camera (1280x720@30) type: video
lanes: 1 mode: 2.0 power: 500mA chip-ID: 04f2:b604 class-ID: 0e02
serial:
Device-4: 1-9:5 info: Synaptics Metallica MIS Touch Fingerprint Reader
type: driver: N/A interfaces: 1 rev: 2.0
chip-ID: 06cb:009a class-ID: ff00 serial:
Hub-2: 2-0:1 info: super-speed hub ports: 6 rev: 3.0
Device-1: 2-3:2 info: Realtek Card Reader type: mass storage
driver: usb-storage interfaces: 1 rev: 3.0 speed: 5 Gb/s (596.0 MiB/s)
lanes: 1 mode: 3.2 gen-1x1 power: 800mA chip-ID: 0bda:0316 class-ID: 0806
serial:
Src: /sys System Temperatures: cpu: 39.0 C pch: 34.0 C mobo: N/A
Fan Speeds (rpm): N/A
Power: 12v: N/A 5v: 5 3.3v: N/A vbat: N/A
Processes: 195 Power: uptime: 7m states: freeze,mem,disk suspend: deep
avail: s2idle wakeups: 0 hibernate: platform
avail: shutdown,reboot,suspend,test_resume image: 6.15 GiB
daemons: xfce4-power-manager,upowerd Init: systemd v: 255
Packages: pm: pacman pkgs: 1045 libs: 357 tools: pamac Compilers:
gcc: 13.2.1 Shell: Sudo (sudo) v: 1.9.15p5 default: Bash v: 5.2.21
running-in: urxvtd inxi: 3.3.32
[mike@T480 ~]$ ^C
[mike@T480 ~]$ sudo inxi --admin --verbosity=7 --filter --no-host
udev.log_priority=3
System RAM: total: 16 GiB available: 15.39 GiB used: 2.12 GiB (13.8%)
igpu: 32 MiB
serial:
microcode: 0xF4
Speed (MHz): avg: 430 high: 641 min/max: 400/3400 base/boost: 1600/1800
ext-clock: 100 MHz cores: 1: 400 2: 400 3: 400 4: 400 5: 400 6: 400 7: 641
vulnerable
modes: N/A
class-ID: 0280
broadcast:
WAN IP:
class-ID: e001
fw-rev: 4B2QEXM7 temp: 25.9 C scheme: GPT
serial:
serial:
Src: /sys System Temperatures: cpu: 42.0 C pch: 37.5 C mobo: N/A
Processes: 204 Power: uptime: 12m states: freeze,mem,disk suspend: deep
